  3. Yet Another RGB driver (activeRGB)
69 Posts 4 Posters 22.6k Views 6 Watching
  • A activemind
    @activemind said:
    @Samuel235 Thanks. Wouldnt have been possible to come this far without your help and feedback.
    Going to try routing soon, I am thinking 10mil for normal trace and 80mil for 12v/5v/3v3/GND.
    Does that sound right?
    -AM
    80mil looks too fat :-)
    How about 60mil?
    -AM
    activemind
    Is it okay to route most of the power signal on the back and keep GND and everything else on the front?
    General routing recommendations? (doing it for the first time :-)
    -AM
    S 1 Reply Last reply
    • A activemind
      -AM
      Samuel235
      @activemind, those traces are huge and i wouldn't go that big as it may cause imperfections in signal lines. You should be fine here with 10-12mil traces. If i remember correctly anyway.
      I normally do ground planes/pours on top layer and bottom layer so all of the copper on the surfaces are ground unless its routed to a signal or vcc. However, keep it simple and just route it as you wish. There shouldn't be any issues here as its all relatively low voltage. If it makes it easier for yourself then yes, put all ground on the bottom.
      MySensors 2.1.1
      • A
        activemind
        Ok, I will go back to 12 mil for power and gnd and 10 mil for other signals.
        -AM
        • A
          activemind
          Board is almost routed...
          Just a couple of connections for MySX connector left.
          Next step would be to silkscreen....no idea how to do that :-P
          -AM
          • A
            activemind
            Found an issue! The footprint I had for LE33 was wrong! pins 1&3 were reversed!
            Fixing and rerouting now..
              Samuel235
              Finding errors, creating the routes and the silkscreen are my favorite parts of module creation!
              Learn to appreciate and enjoy these remaining steps as this is what you will be doing mostly when creating your own PCBs ;)
              You're out of my depth now because everything remaining for you is software usage, and i do not have any experience with KiCAD unfortunately.
              MySensors 2.1.1
              • A
                activemind
                Thanks for all the feedback and holding my hand while trying to do this first PCB @Samuel235
                It was fun routing the board with 20mil power(12v,5v,3.3v) & GND and 10 mil for rest of the signals.
                But its done now.
                Question: How big of a deal it is if I have 3 mounting holes rather than on all 4 corners? Or is it better if I make them smaller? Whats the std size everyone uses for mounting holes?
                • A
                  activemind
                  Here is what the PCB looks like after routing. Still some cleanup and checking to do but almost there...
                  You can see that 4th mounting hole (right top) is outside the PCB. I had to move it temporarily so that I could route it. Now I need to make it smaller or drop it alltogether!
                  -AM
                  • A
                    activemind
                    And here is what it will finally look like:
                    Comments?
                    -AM
                      Samuel235
                      Just make sure your trace spacing conforms to that of the board house you are using. Board houses have minimum size and spacing rules, comply to those and you'll be good to go.
                      If there is no need to anchor it down, no terminals etc then you can get rid of it. However you have screw terminals there and then therefor i would advise to have a mount around that point. I normally attempt a M3 screw hole, which is around 3.5mm needed for the screw to pass through.
                      What is the size of your mounting holes now?
                      MySensors 2.1.1
                      A 1 Reply Last reply
                      • S Samuel235
                        activemind
                        Hmmmm! The module I am using is called 1pin in KiCad and on measurement its around 4.5mm dia.
                        Am I making the holes too big? Let me see if there is some std module for 3.5mm holes.
                        -AM
                        • A activemind
                          -AM
                          activemind
                          -AM
                          I take it back! I searched some more and found mounting hole 3.5mm footprint and it matches exactly what I have!
                          Looks like I will have to move some stuff around to make some more space for the mounting holes :-(
                          -AM
                          • A
                            activemind
                            Are M2 screw mounting holes okay or the standard is M3?
                            -AM
                              Samuel235
                              I would say the normal is M3 but honestly, use whatever you want to use. At the end of the day it is only a mounting screw. Not like its holding a lot of pressure. Go for an M2 hole if you want :) - Just keep any copper away from them for when you come to screw it down, you don't want to strip the silkscreen off and make a electrical connection to copper underneath :)
                              MySensors 2.1.1
                              • A
                                activemind
                                Moved around some routes and I was able to fit in M3 screw holes. I think this puppy is done now.
                                Whats the next step? What is all this copper filling?
                                -AM
                                  Samuel235
                                  Oh nice! What copper filling do you refer to?
                                  MySensors 2.1.1
                                  • A
                                    activemind
                                    The next step. I am looking at this tutorial and it talks about fill area and what not. I have no idea whats the next step.
                                    Do I just generate the gerber files and I am done or there is some filling step reamining?
                                    Still trying to wrap my head around this!
                                    -AM
                                      Samuel235
                                      Your talking about GND planes. So, yeah you can do this, it isn't 100% necessary, but i do. Are you having issues following the guide to do it or are you asking me if you should do it?
                                      MySensors 2.1.1
                                      • A
                                        activemind
                                        I am asking if I should do it, keeping in mind that this is my first PCB and I want to keep it simple.
                                        Based on what you said above, seems I can skip this step and just generate the gerber files and send them off to dirtyPCB. Is that right?
                                        -AM
                                          #48
                                          @activemind
                                          i don't know how planes work in Kicad. but for multiple reasons, if I were you, I would add gnd plane. Try it, then you will know ;) Or don't try if you're not confident that should work too.
                                          I won't do a lesson, there are lot of resources on internet, but mostly for :
                                          • impedance
                                          • ground loop
                                          • preventing noise and emi reduction
                                          • etc.
                                          plus when you start your board by drawing it where you need it, this ease your airwire then, at least in Eagle ;)
