  3. 12V distribution box - mysensorized!
22 Posts 4 Posters 6.7k Views 4 Watching
  • A Offline
    A Offline
    activemind
    Kicked off a thread here about a 12V distribution box. Basically takes input from a 12V power supply and provides 4-5 12V output with a VA display.
    Just got done sending off my first PCB to Itead. Its a RGB LED driver using 12V supply. Once again, a shout out to @Samuel235 for his constant feedback and support during that project! :+1:
    I think it would be cool if we can make this 12V distribution box smarter(MySensor aware). I am thinking of doing a PCB for this so that we can report the current draw on each of the ports and maybe control (on/off) each of the ports remotely too.
    Project in investigation phase currently but I need to keep busy till my other PCB shows up from Itead :-)
    -AM
    • A Offline
      A Offline
      activemind
      Looking some more into it I am thinking of using ACS713 current sensor for this board.
      But it has just 1 channel and I am going to need multiple of these if I want to do like 4-5 outputs.
      Does anyone know of such chip that is similar but does multiple channels?
      -AM
      • A Offline
        A Offline
        activemind
        wrote on last edited by activemind
        Or maybe ACS712.
        But both of these need Vcc=5V. I was hoping to use a 12V powered IC so that I can reduce some circuitry.
        Nevermind, I would need 5/3.3V for the arduino/NRF anyways so this should not be an issue.
        I still need to findout if there is a multichannel version.
        -AM
        • A Offline
          A Offline
          activemind
          Thinking out loud here but would it be better if I put connectors for current measurement on the PCB for connecting something like this or should I put the ACS chip on the PCB?
          The advantage of using a module is that populating it can be made optional, so you can jumper it if you dont want it on one of the channels. So it would be possible to have like 4 channel out of 5 that report and 1 that does not.
          Plus the cost of the module and bare chip is the same, so I dont think there is any difference from that point of view.
          -AM
          • A Offline
            A Offline
            activemind
            Or maybe do 1 for the entire board and forget about per channel. Maybe thats the right approach!
            -AM
            • A Offline
              A Offline
              activemind
              I need some help from one of the hw guys.
              I have arduino pin driving the gate of a FET like so many other examples.
              I have another signal called Fault which is active low.
              Now I want to and the two signals such that when fault becomes active (becomes 0), the FET is forced off.
              Whats the circuit for that?
              -AM
              A 1 Reply Last reply
              • A activemind
                -AM
                A Offline
                A Offline
                activemind
                I have arduino PWM pin driving the gate of a FET like so many other examples.
                -AM
                • A Offline
                  A Offline
                  activemind
                  Nevermind, found the answer. Just put another FET in there with fault signal driving the gate.
                  -AM
                  • A Offline
                    A Offline
                    activemind
                    So I managed to finish the schematic and and posting it for people to look over.
                    Features:
                    1. 1 input and 6 output - 12V
                    2. Easy hook ups for Voltmeter/Ammeter display.
                    3. Voltage and current draw fed back to arduino as input.
                    4. Hardware based overcurrent protection with latch feature.
                    5. Fault status can be reported back to Controller.
                    6. Switch to turn supply off.
                    7. LED indicators for power on and fault.
                    8. All easy solder through components.
                    Comments?
                    -AM
                    • A Offline
                      A Offline
                      activemind
                      Initial placement is done and this is what it looks like....very crowded board. Had to place the comparator underneath the pro mini, is that going to be an issue?0_1466743436714_12vDist.jpg
                      • A Offline
                        A Offline
                        activemind
                        Also, thinking ahead about routing this board. Is it okay to do a GND pour on one side and 12V on the other?
                        -AM
                        • A Offline
                          A Offline
                          activemind
                          redid some of the placement and changed the resistors to horizontal mount from vertical.
                          looking better...I guess :-)
                          -AM
                          • A Offline
                            A Offline
                            activemind
                            Debating about changing the size to 5x9 size so that it can fit inside a 5x10 box like this
                            -AM
                            • D Offline
                              A little off topic, but what PCB software are you using to do your illustrations and layout? It looks like nice software. Is it for windows only or is there a linux version?
                              • mfalkviddM Offline
                                @activemind those boxes are 56x95mm on the inside (I have lots of them). They have mounting points in the corners, about 1.5mm from the inner wall. The outer diameter of the mounting points is 5.5mm and the inner diameter is approximately 2mm.
                                • D dbemowsk
                                  A Offline
                                  A Offline
                                  activemind
                                  I am a KiCad beginner. I started like a couple of days ago and this is my second PCB. Waiting for the first one to come back from fab house :-)
                                  -AM
                                    A Offline
                                    A Offline
                                    activemind
                                    Thanks for the measurements @mfalkvidd . I am still debating about increasing the PCB size though because I looked at one of my existing boxes with the DC connector I am planning to use, and I realized that I need little more space because the connector extend out.
                                    Still playing with the placement on the PCB but looks like I have everything in place for now. Lets see what happens when I try to route it!
                                    The only thing I am concerned about is will placing the comparator IC underneath the pro mini cause any issues?
                                    -AM
                                    • A activemind
                                      -AM
                                      As long as the Pro Mini is placed high enouch to not touch the IC it won't cause any issues. The jmodule uses the same idea: https://www.openhardware.io/view/20/jModule
                                      • A Offline
                                        A Offline
                                        activemind
                                        Thanks @mfalkvidd for the link. I feel more confident that this might work.
                                        Didnt get a chance to work on this for past couple of days. Maybe soon...
                                        -AM
                                        • A Offline
                                          A Offline
                                          activemind
                                          Ok, so the board is routed. This was fun....very crowded board...at least by my noob standards :-)
                                          Done all DRC and connectivity checks...looks good.
                                          -AM
                                          12.2k
