  3. MultiRelayExpanderWithToggleSwitch unstable
3 Posts 2 Posters 1.5k Views 2 Watching
  • Mateusz PiętaM Offline
    Mateusz Pięta
    wrote on last edited by Mateusz Pięta
    Im working on GW with directly attached sensors for Relay array using PCF8574 ( i need about 24 relays & buttons ) using MySensors development branch
    I know that code works but sometimes gateway does not respond to domoticz at startup ( or even serial monitor ) and sometimes it breaks after few minutes of working..
    faulty arduino ? dont have any spare one to test :(
    Or maybe there is a code problem ?
    check it out:
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_SERIAL
    //#define MY_REPEATER_FEATURE
    #include <PCF8574.h>
    #define RELAY_ON 0
    #define RELAY_OFF 1
    #define noExpanders 2
    class Relay
    public:
      int buttonPin;
      int relayPin;
      boolean relayState;
      boolean buttonState = 1;
    PCF8574 relays_exp[noExpanders];
    PCF8574 buttons_exp[noExpanders];
    Relay Relays[noExpanders][8];
    MyMessage msg;
    void setup(){
    relays_exp[0].begin(0x38);
    relays_exp[1].begin(0x39);
    buttons_exp[0].begin(0x3B);
    buttons_exp[1].begin(0x3F);
    for ( int i = 0 ; i < noExpanders ; i++ )
      for ( int j = 0 ; j < 8 ; j++ )
        Relays[i][j].buttonPin = j;
        Relays[i][j].relayPin = j;
        Relays[i][j].relayState = loadState(8*i+j);
        buttons_exp[i].pinMode(j, INPUT_PULLUP);
        wait(50);
        relays_exp[i].pinMode(j, OUTPUT);
        relays_exp[i].digitalWrite(Relays[i][j].relayPin, Relays[i][j].relayState? RELAY_ON:RELAY_OFF);
        msg.setSensor(8*i+j);
        msg.setType(V_LIGHT);
        send(msg.set(Relays[i][j].relayState? true : false));
        wait(50);
    void presentation()  {
    sendSketchInfo("MultiRelayExpanderWithToggleSwitch", "0.9b");
    wait(100);
        present(8*i+j, S_LIGHT);
            if (buttons_exp[i].digitalRead(j) != Relays[i][j].buttonState)
                Relays[i][j].relayState = !Relays[i][j].relayState;
                Relays[i][j].buttonState = !Relays[i][j].buttonState;
                relays_exp[i].digitalWrite(Relays[i][j].relayPin, Relays[i][j].relayState?RELAY_ON:RELAY_OFF);
                saveState(8*i+j, Relays[i][j].relayState );
        wait(50);
    void receive(const MyMessage &message){
       if (message.type == V_LIGHT)
         if (message.sensor < noExpanders * 8)
           if (message.sensor < 8)
             Relays[0][message.sensor].relayState = message.getBool();
             relays_exp[0].digitalWrite(Relays[0][message.sensor].relayPin, Relays[0][message.sensor].relayState? RELAY_ON:RELAY_OFF);
             saveState( message.sensor, Relays[0][message.sensor].relayState );
           if (message.sensor >= 8)
             Relays[1][message.sensor -8].relayState = message.getBool();
             relays_exp[1].digitalWrite(Relays[0][message.sensor -8].relayPin, Relays[1][message.sensor -8].relayState? RELAY_ON:RELAY_OFF);
             saveState( message.sensor, Relays[1][message.sensor -8].relayState );
      wait(20);
      Mateusz Pięta
      Everything works now :)
      below is corrected code:
      //"MultiRelayExpanderWithToggleSwitch" for MySensors 2.0
      //Author : Mateusz Pieta
      //email: m.pieta@outlook.com
      //Sketch to use PCF8574 expanders for Relay Arrays with Button Actuators
      #define RELAY_ON 1
      #define RELAY_OFF 0
      class Relay
      public:
        int buttonPin;
        int relayPin;
        boolean relayState;
      MyMessage msg;
      void setup(){
          wait(100);
          wait(50);
      wait(100);
          wait(50);
               relays_exp[1].digitalWrite(Relays[1][message.sensor -8].relayPin, Relays[1][message.sensor -8].relayState? RELAY_ON:RELAY_OFF);
        wait(20);
      • A Offline
        A Offline
        Ausonius
        Hello
        I wanted to understand are you using 2 PCF8574? one for input and another for output?
        also in the code which entries are to add the relays and assign a specific button?
        the code if inserted on wemos d1 works?
        sorry for the many questions because I have to put 8 relays controlled with 8 buttons and interface with domoticz
        thank you
