  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 451.8k Views 35 Watching
  • Tore André RosanderT
    Tore André Rosander
    wrote on last edited by Tore André Rosander
    #230
    @epierre Hi! The dev branch (v 2) and the raspberry pi gateway (nrf24 directly connected to RPi GPIO). This is what i get in the serial console when i test with gas from a lighter:
    Starting sensor (RNNNA-, 2.0.0-beta)
    Radio init successful.
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    parent=0, d=1
    req id
    req id
    read: 0-0-255 s=255,c=3,t=4,pt=0,l=2,sg=0:5
    send: 5-5-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
    send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
    send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    id=5
    Init complete, id=5, parent=0, distance=1
    LPG:0ppm    CO:0ppm    SMOKE:0ppm
    LPG:8ppm    CO:47ppm    SMOKE:18ppm
    send: 5-5-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:95
    send: 5-5-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,st=ok:0```
    • epierreE
      epierreE
      epierre
      @Tore-André-Rosander said:
      t=37
      I don't know, would it be possible to have someone knowing the difference of the gateway with domoticz for 2.0 ? here it seems correct to me, some value are well seend from the sensor, so it is between the gateway and domoticz for me.
      z-wave - Vera -> Domoticz
      • tuimansoT
        tuimansoT
        tuimanso
        @epierre I am attempting to apply this code to work with the MQ-8. I am trying to get rid of all of the radio and gw stuff that is in the code. Do you have anything that just calibrates the sensor and reads out the value without of all these other libraries?
        • tuimansoT
          tuimansoT
          tuimanso
          @epierre Also, what is the purpose of #define MQ135_MAXRSRO 2.428 //for CO2
          #define MQ135_MINRSRO? I don't see them being referenced after they're defined?
          epierreE 1 Reply Last reply
          • tuimansoT tuimanso
            epierreE
            epierreE
            epierre
            Datasheet defines min and max values they should guarantee, this is an application of it.
            if(validinterval<MQ135_MAXRSRO && validinterval>MQ135_MINRSRO) {
            • tuimansoT
              tuimansoT
              tuimanso
              Your previous message
              I have a question about the MQ-8 sensor module . The potentiometer that is soldered onto the board, is it to control the sensitivity of the LED light or for the sensor itself? According to the datasheet for the sensor, the RL (load resistance) for the sensor should be at minimum 10k Ohm, yet I only see an SMD 102 resistor on the board, which is a 1K Ohm resistor. I have used a multimeter to connect the 5V pin and the AOUT pin, and I get precisely a measurement of about 1K Ohm... Does that mean that I should connect a load resistor to this?
              This value seems very important since it is referenced in the code, the RL is part of the calculations, yet it is already pre-written 10K ohms...
              Please Clarify
              ysinhY 1 Reply Last reply
              • AtmosChemeA
                AtmosChemeA
                AtmosCheme
                Hello everyone,
                I have a few of these sensors, but lately I have been concentrating on a MQ131 ozone sensor module from SainSmart. I am building an array utilizing MQ gas sensors and an Arduino that can be attached to a drone to measure vertical concnentration profiles of ground level ozone.
                I am using an ozone generator and a 2B Technologies Ozone Monitor for the calibration of the sensor.
                I have done the 24 hour burn in period on my sensors.
                I have warmed them up to get steady values on my serial monitor.
                The problem that I am having is that I am creating nearly 20,000 ppb O3 and the analog output is only around 25 to 30 units. It works out to around 922 ppb per unit.
                Example before ozone is added the sensor reading is steady at 41. After raising the concentration of O3 to 18,727.5 ppb the reading drops to around 17-18.
                Recently I have added a 22,000 ohm resistor in series with the analog output so that my readings start out at 971. But I am still only dropping around 20 units to 951 when ozone levels rise to nearly 20,000 ppb.
                My question is how do I use a larger range of the units. There are 1023 possible values and I would like to see my reading drop from 971 to maybe the 200 area so that I am using more of the range. I would like each unit to be worth about 0.5 ppb. Ambient outdoor concentrations very rarely go higher than maybe 150 ppb so with the setup I have that would not even register on the serial output.
                Thank you in advance for any help.
                • AtmosChemeA AtmosCheme
                  Hello everyone,
                  epierreE
                  epierreE
                  epierre
                  @AtmosCheme the datasheet gives the MQ131from 1 to 1000 ppb, so you reach the limit obviously
                  http://eph.ccs.miami.edu/precise/GasSensorSpecs/Ozone.pdf
                  AtmosChemeA 1 Reply Last reply
                  • epierreE epierre
                    AtmosChemeA
                    AtmosChemeA
                    AtmosCheme
                    @epierre
                    Thank you for the reply epierre.
                    I was going off of the SainSmart website that says the range for their module is 10 ppb to 200 ppm. That would cover 10 ppb to 200,000 ppb.
                    http://www.sainsmart.com/sensors/eco/sainsmart-mq131-gas-sensor-ozone-module-for-arduino-uno-mega2560-r3-raspberry-pi.html
                    The values keep dropping down as more and more ozone is added, I'm not thinking it is a problem with range as much as a problem with resolution. I have gone as high as around 50,000 ppb and continue to get response from the sensor.
                    Ive thought of using mapping functions in my code as well as resolution functions. But I just wasn't sure if there was a component I could add to the circuit to improve resolution.
                    In my latest sketch I have used a calibration code that analog reads the sensor for 6 minutes, and then remaps the min and max values observed during that time. I though this would get a broader range of values. The problem is that the longer the sensor is on it becomes stable so the min and max values become the same and there is nothing to map. So the longer it runs the smaller the range of values in the serial monitor.
                      @epierre
                      epierreE
                      epierreE
                      epierre
                      check their datasheet (or ask for it !)
                      yes it should be possible but you don't know from the datasheet the value. On a power regression you make an estimation with error, but that may change outside of know datapoints.
                      some as the Particle Photon has a better ADC that goes up to 4096
                      • jnewton957J
                        jnewton957J
                        jnewton957
                        I just try to connect 7 sensors to an nano.
                        MQ-2, MQ-3, MQ-4,MQ-6, MQ-7,MQ-9, MQ-135
                        With sketch form robosensor https://forum.mysensors.org/topic/1595/mq2-sensor-w-airquality-sketch/2
                        I get data like MQ-7:1020 ,MQ135: 294, MQ-2:191
                        So it looks really good.
                        As i would like to have also the correct names an value names of the sensor and a correct calibration I think I should use a sketch like AirQuality-Multiple_Gas_Sensor1_4.ino
                        But I only see 3 of my 7 sensors in this sketch.
                        What would be a good sketch for my 7 sensors ??
                        Jorg
                        • walk_portoW
                          walk_portoW
                          walk_porto
                          Hello everybody,
                          I am working with an Arduino Uno and a MQ135 module arduino : http://www.sainsmart.com/sainsmart-mq135-sensor-air-quality-sensor-hazardous-gas-detection-module-arduino.html
                          I can get back data from this sensor, I got 100 ppm when I launched serial terminal after compiling and uploading this code below.
                          int sensorValue;
                            Serial.begin(9600);      // sets the serial port to 9600
                            sensorValue = analogRead(0);       // read analog input pin 0
                            Serial.println(sensorValue, DEC);  // prints the value read
                            delay(100);                        // wait 100ms for next reading
                          But, I would like to get back data from gases like NH3, NOx, alcohol, benzene, smoke and CO2 . I read a lot of topics and the datasheets of the sensor but I don't see how to do.
                          If someone could help me, it will be great.
                          • walk_portoW walk_porto
                            Hello everybody,
                            int sensorValue;
                            AtmosChemeA
                            AtmosChemeA
                            AtmosCheme
                            @walk_porto
                            I think that the only way you are going to be able to distinguish between different gases is to have a known concentration of that gas and adjust load resistance. This sensor will detect all of these gase because of cross sensitivity to the gases mentioned in the filament. You can not use just one MQ135 sensor and get readings for all of the gases.
                            • Thanh-VietT
                              Thanh-VietT
                              Thanh-Viet
                              Hi Guys,
                              Nice work. I'm based in Hong Kong, and what matters to us is PM2.5, NO2 and Ozone (and indoor CO2/VOC).
                              Have you guys checked the laser based particle sensors like the Plantower G1-G3-G5, Innovafitness SDS011/021 ?
                              http://aqicn.org/sensor
                              alexsh1A 1 Reply Last reply
                              • Thanh-VietT Thanh-Viet
                                Hi Guys,
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @Thanh-Viet Hello. Yes, I have Plantower G3 on order from Aliexpress and won't be able to test it before September. I think adopting it for MySensors is going to be easy
                                • paqorP
                                  paqorP
                                  paqor
                                  Hello, there are statements if the values increase the MQ135 when a room ventilated, without people and is furnished? I I have several rooms here an increase over time. Perhaps this is also by the increase in temperature, sunlight or gases from the furniture. I have not found any literature on this. Is this behavior with other users as well?
                                  • paqorP
                                    paqorP
                                    paqor
                                    Has the type of installation (horizontal or vertical) have an impact on the values of MQ135? I have found no photos of built-in sensors already exist in the data sheet a statement.
                                    • paqorP paqor
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @paqor yes, in fact my MQ-135 was so unreliable that I had to move on to a different sensor
                                      • paqorP
                                        paqorP
                                        paqor
                                        wrote on last edited by paqor
                                        #248
                                        Those interested in a 4 sensors Sketch FHEM (CO2, Temp, Hum, Motion) has ...
                                        ? 1 Reply Last reply
                                        • paqorP paqor
                                          A Former User
                                          @paqor
                                          I'm interested, but i'm using mysensors 2.0. Can you update your sketch?
                                          paqorP 1 Reply Last reply
