  3. rfm69 network issue
rfm69 network issue
30 Posts 5 Posters 13.0k Views 4 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    These test sketches work just fine including ACK
    Node sketch (rfm69cw)
    /* RFM69 library and code by Felix Rusu - felix@lowpowerlab.com
    // Get libraries at: https://github.com/LowPowerLab/
    // Make sure you adjust the settings in the configuration section below !!!
    // Copyright Felix Rusu, LowPowerLab.com
    // Library and code by Felix Rusu - felix@lowpowerlab.com
    // License
    // This program is free software; you can redistribute it
    // and/or modify it under the terms of the GNU General
    // Public License as published by the Free Software
    // Foundation; either version 3 of the License, or
    // (at your option) any later version.
    // This program is distributed in the hope that it will
    // be useful, but WITHOUT ANY WARRANTY; without even the
    // implied warranty of MERCHANTABILITY or FITNESS FOR A
    // PARTICULAR PURPOSE. See the GNU General Public
    // License for more details.
    // You should have received a copy of the GNU General
    // Public License along with this program.
    // If not, see <http://www.gnu.org/licenses></http:>.
    // Licence can be viewed at
    // http://www.gnu.org/licenses/gpl-3.0.txt
    // Please maintain this license information along with authorship
    // and copyright notices in any redistribution of this code
    #include <RFM69.h>    //get it here: https://www.github.com/lowpowerlab/rfm69
    // *********** IMPORTANT SETTINGS - YOU MUST CHANGE/ONFIGURE TO FIT YOUR HARDWARE *************
    #define NETWORKID     100  // The same on all nodes that talk to each other
    #define NODEID        2    // The unique identifier of this node
    #define RECEIVER      1    // The recipient of packets
    //Match frequency to the hardware version of the radio on your Feather
    #define FREQUENCY     RF69_433MHZ
    //#define FREQUENCY     RF69_868MHZ
    #define ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
    #define IS_RFM69HCW   false // set to 'true' if you are using an RFM69HCW module
    #define SERIAL_BAUD   115200
    #define RFM69_CS      10
    #define RFM69_IRQ     2
    #define RFM69_IRQN    0  // Pin 2 is IRQ 0!
    #define RFM69_RST     9
    #define LED           8  // onboard blinky
    int16_t packetnum = 0;  // packet counter, we increment per xmission
    RFM69 radio;
    //RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HCW, RFM69_IRQN);
      while (!Serial); // wait until serial console is open, remove if not tethered to computer
      Serial.begin(SERIAL_BAUD);
      Serial.println("Arduino RFM69HCW Transmitter");
      // Hard Reset the RFM module
      pinMode(RFM69_RST, OUTPUT);
      digitalWrite(RFM69_RST, HIGH);
      delay(100);
      digitalWrite(RFM69_RST, LOW);
      delay(100);
      // Initialize radio
      radio.initialize(FREQUENCY,NODEID,NETWORKID);
      if (IS_RFM69HCW) {
        radio.setHighPower();    // Only for RFM69HCW & HW!
      radio.setPowerLevel(31); // power output ranges from 0 (5dBm) to 31 (20dBm)
      radio.encrypt(ENCRYPTKEY);
      pinMode(LED, OUTPUT);
      Serial.print("\nTransmitting at ");
      Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
      Serial.println(" MHz");
      delay(1000);  // Wait 1 second between transmits, could also 'sleep' here!
      char radiopacket[20] = "Hello World #";
      itoa(packetnum++, radiopacket+13, 10);
      Serial.print("Sending "); Serial.println(radiopacket);
      if (radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) { //target node Id, message as string or byte array, message length
        Serial.println("OK");
        Blink(LED, 50, 3); //blink LED 3 times, 50ms between blinks
      radio.receiveDone(); //put radio in RX mode
      Serial.flush(); //make sure all serial data is clocked out before sleeping the MCU
    void Blink(byte PIN, byte DELAY_MS, byte loops)
      for (byte i=0; i<loops; i++)
        digitalWrite(PIN,HIGH);
        delay(DELAY_MS);
        digitalWrite(PIN,LOW);
        delay(DELAY_MS);
    Gateway sketch (Moteino Mega, rfm69hcw):
    // License
    #define NETWORKID     100  //the same on all nodes that talk to each other
    #define NODEID        1
    #define IS_RFM69HCW    true // set to 'true' if you are using an RFM69HCW module
    #define RFM69_CS      10
    #define RFM69_IRQ     2
    #define RFM69_RST     9
    #define LED           15  // onboard blinky
    RFM69 radio;
      Serial.println("Feather RFM69HCW Receiver");
      delay(100);
      delay(100);
      // Initialize radio
      if (IS_RFM69HCW) {
      Serial.print("\nListening at ");
      //check if something was received (could be an interrupt from the radio)
      if (radio.receiveDone())
        //print message received to serial
        Serial.print('[');Serial.print(radio.SENDERID);Serial.print("] ");
        Serial.print((char*)radio.DATA);
        Serial.print("   [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
        //check if received message contains Hello World
        if (strstr((char *)radio.DATA, "Hello World"))
          //check if sender wanted an ACK
          if (radio.ACKRequested())
            radio.sendACK();
            Serial.println(" - ACK sent");
          Blink(LED, 40, 3); //blink LED 3 times, 40ms between blinks
        delay(DELAY_MS);
        delay(DELAY_MS);
      @alexsh1 ok. i thought you were talking about something else. So to answer, it works the same for 328p, 1284p if irq and pin is right. for st fail, perhaps the adapter..it's a lot better when soldered directly on node pcb.
      • alexsh1A
        alexsh1A
        alexsh1
        @scalz Sorted. One radio on the GW is with amplification so I had to add the following to the code:
        #define MY_IS_RFM69HW
        #define MY_RF69_IRQ_PIN 2 // not sure if this line makes any difference
        All works perfectly now.
        • alexsh1A
          alexsh1A
          alexsh1
          Anyone knows how I can change the rfm69 speed within the sketch?
          Something like MY_RF69_DATARATE or something?
          Additionally, I'd like to use encryption, but no idea where to start. This is very easy with rf69 library, but not sure how to apply in MySensors.
          • alexsh1A
            alexsh1A
            alexsh1
            This is the final product - I am @GertSanders would appreciate it
              @alexsh1 cool :) for encryption this is done at radio init. You can enable/disable it by using MY_RFM69_ENABLE_ENCRYPTION
              And for the datarate, there is no var for this. it's done by using register in radio init. I could look at adding this as I have locally updated mys with the latest rfm69 features.
              alexsh1A 2 Replies Last reply
              • scalzS scalz
                alexsh1A
                alexsh1A
                alexsh1
                @scalz Thanks! Encryption - but how do I define the key?
                or something.
                Looking forward to your updates on rfm69!
                  @alexsh1 For the encrypt key...I'm not sure how this works in mysensors. I will look into this later today ;)
                  Actually, it works like this : during radio init, encryption is enabled or not depending of the above define. For the key (which is stored in eeprom) it uses EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS which is related to signing defines..you can have more info on this in MyEepromAddresses.h . you will see how it is constructed.
                  alexsh1A 1 Reply Last reply
                  • scalzS scalz
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @scalz So they key is taken from EEPROM and I cannot define it in the sketch? I think this is similar how soft signing works on non-ATSHA204A nodes - they HMAC/AES key is stored in EEPROM
                    • scalzS scalz
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #22
                      This is not working in MySensors sketch:
                      radio.writeReg(0x03,0x0D);
                      radio.writeReg(0x04,0x05);
                      Where do I set the bitrate?
                        #23
                        @alexsh1 i don't know if it's possible on the fly, just for knowledge i will look later if it's possible as rfm69 already works well for me. And for longer range and as i have some devices with RFM95, i've started to port radiohead rfm95 for mysensors but not finished yet
                        So, about your question, it's done at init. in rfm69 driver, initialize(), line 52-53. you can try with some presets defined in rfm69registers.h if you want.
                        • scalzS scalz
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz thanks - as I said I am new to RFM69 and have to start from scratch (looking into the driver library) so apologies for asking noobs questions.
                          I did go through the driver and I see what you mean. Unfortunately those things like bidrate are not configurable from MySensors.h
                          I'm very much interested in RFM95 though the cost of a transmitter is prohibitively expensive (£7.5 for one on aliexpress vs £0.7 for nrf24l01+). I think I'll use it for some sensors outside of the house. Where do you stand with porting?
                          • J
                            J
                            jpaulin
                              #26
                              @alexsh1 : just to say i have added the possibility to set datarate ;) you're right, that could be interesting to test.
                              that will be a simple define like
                              MY_RFM69_BITRATE_CUSTOM 4800
                              where 4800 in kbits. if not defined it takes default params.
                              And here few interesting comments about the datarate : https://openenergymonitor.org/emon/node/6178
                              • chrilleC chrille
                                What kind of gateway are you using? I have seen similar issues with RFM69 on ESP8266 gateways (although my RFM69 modules are 868 MHz). The issue was present with a wire as an antenne, as well as with a rubber antenna connected to a SMA connector directly to the RFM. I was able to solve the issue in several ways:
                                1. Touching the antenna on the ESP8266 side with my fingers! (obviously a very temporary solution)
                                2. Connecting a ground plane to the rubber antenna (I used the lid from a can of beans)
                                3. Connecting a dipole antenna with a 1-2 meter cable
                                The easiest way to debug this is to load the Gateway and Node sketches from https://github.com/LowPowerLab/RFM69/tree/master/Examples on your sensor board and gateway, since these sketches provides instant feedback and tests in both directions.
                                Hopefully the RFM69 driver will get better debug output at some point.
                                frenchoF
                                frenchoF
                                frencho
                                @chrille I'm facing similar behavior with my setup, I get the st:fail but if I touch the antenna on the gateway side, it's working fine.
                                My setup is arduino 2.0, on the same node as @alexsh1 (the @GertSanders one) with the NRF2RFM69 adapter from @tbowmo. Antenna is wire lenght of 82.2 mm for the 868Mhz rfm69HW.
                                on the gateway side I did :
                                //#define MY_RADIO_NRF24
                                #define MY_RADIO_RFM69
                                I added a small capacitor on the VCC-GND of the radio, and I soldered the jumper 2 to connect IRQ
                                the inclusion mode is also fully commented (I don't have inclusion button on board)
                                and the config file also #define MY_IS_RFM69HW is uncommented as well as #define MY_RADIO_RFM69
                                Any idea where my st:fail could come from ?
                                Your second life begins when you understand you only have one !
                                chrilleC 1 Reply Last reply
                                • frenchoF frencho
                                  chrilleC
                                  chrilleC
                                  chrille
                                  No, I have only seen the issue with the combination of ESP866 and RFM69. I suggest you get the RFM69 library from lowpowerlabs and load the "Node" and "Gateway" sketches from https://github.com/LowPowerLab/RFM69/tree/master/Examples/
                                  The sketches will send packets in both directions and it's very easy to see packet loss and also the RSSI (signal strenght) of the traffic on both sides. This is what I used to diagnose my issue. You can install the RFM69 library directly in your libraries folder without conflicting with mysensors.
                                  frenchoF 1 Reply Last reply
                                  • chrilleC chrille
                                    frenchoF
                                    frenchoF
                                    frencho
                                    @chrille working, the antenna was the problem. I ordered some small antenna on ebay, and it s fine now ^^
                                    • frenchoF frencho
                                      chrilleC
                                      chrilleC
                                      chrille
                                      Glad to hear it's working now. After creating a "real" PCB for my RFM69 gateway the issue went away - and it works reliable both with an external antenna and a small rubber antenna.
                                      12.5k
