  3. How to get RFM69H 868Mhz working?
25 Posts 4 Posters 8.4k Views 4 Watching
  • vgaV
    vgaV
    vga
    Thanks alexsh1 for your posts!
    @alexsh1 said:
    do you have antennas and what type please?
    I don´t have any antenna connected to the transceiver. Is this a problem?
    @alexsh1 said:
    Double and triple check your wiring.
    ...i can´t remember, how often i´ve checked it.
    @alexsh1 said:
    Which version of MySensors are you using?
    currently i´m using 2.0beta
    @alexsh1 said:
    Can you pleas post your MyConfig.h?
    In your sketch you have to do the following:
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    I´ve added the second line to my sketches in gateway and sensor-node, but also no success.
    here is my MyConfig.h
     * @file MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    *  Serial and debug options
    // I_DEBUG requests are:
    // V: CPU voltage
    // F: CPU frequency
    // M: free memory
    //#define MY_SPECIAL_DEBUG
    //#define MY_DISABLED_SERIAL
    //#define MY_CORE_ONLY
    #ifdef MY_DISABLED_SERIAL
    #undef MY_DEBUG
     * @def MY_BAUD_RATE
    #ifndef MY_BAUD_RATE
    #define MY_BAUD_RATE 115200
    //#define MY_RADIO_NRF24
    //#define MY_RS485
     * @def MY_NODE_ID
    #ifndef MY_NODE_ID
    #define MY_NODE_ID AUTO
     * @def MY_PARENT_NODE_ID
    #ifndef MY_PARENT_NODE_ID
     * @def MY_OTA_FLASH_SS
    #ifndef MY_OTA_FLASH_SS
    #define MY_OTA_FLASH_SS 8
     * @def MY_OTA_FLASH_JDECID
     * @brief Flash jdecid.
    #ifndef MY_OTA_FLASH_JDECID
    *  Gateway config
     * @def MY_GATEWAY_MAX_CLIENTS
    *  Information LEDs blinking
    // disabled in the gateway.
    //#define MY_LEDS_BLINKING_FEATURE
    // off when blinking
    //#define MY_DEFAULT_ERR_LED x
    //#define MY_DEFAULT_TX_LED x
    //#define MY_DEFAULT_RX_LED x
    		#define MY_INCLUSION_MODE_BUTTON_PIN 3
    *  Message Signing Settings
     * @def MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204
     * @def MY_SIGNING_SOFT
    //#define MY_SIGNING_SOFT
    *  RS485 Driver Defaults
     * @def MY_RS485_BAUD_RATE
     * @brief The RS485 BAUD rate.
    #ifndef MY_RS485_BAUD_RATE
    *  NRF24L01P Driver Defaults
     * @def MY_DEBUG_VERBOSE_RF24
     * @def MY_RF24_SPI_MAX_SPEED
     * @def MY_RF24_CE_PIN
    #ifndef MY_RF24_CE_PIN
    		#define MY_RF24_CE_PIN 4
    		#define MY_RF24_CE_PIN 27
    		#define MY_RF24_CE_PIN 9
     * @def MY_RF24_CS_PIN
    #ifndef MY_RF24_CS_PIN
    		#define MY_RF24_CS_PIN 15
    		#define MY_RF24_CS_PIN 3
    		#define MY_RF24_CS_PIN 10
     * @def MY_RF24_PA_LEVEL
    #ifndef MY_RF24_PA_LEVEL
     * @def MY_RF24_CHANNEL
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL	76
     * @def MY_RF24_DATARATE
    #ifndef MY_RF24_DATARATE
     * @def MY_RF24_BASE_RADIO_ID
    #ifndef MY_RF24_BASE_RADIO_ID
     * @def MY_RF24_ADDR_WIDTH
     * @brief RF24 address width.
    #ifndef MY_RF24_ADDR_WIDTH
    #define MY_RF24_ADDR_WIDTH 5
     * @def MY_RF24_SANITY_CHECK
    #define MY_RF24_SANITY_CHECK
    //#define MY_SOFTSPI
     * @def MY_SOFT_SPI_SCK_PIN
     * @brief Soft SPI SCK pin.
    #ifndef MY_SOFT_SPI_SCK_PIN
     * @def MY_SOFT_SPI_MISO_PIN
     * @brief Soft SPI MISO pin.
    #ifndef MY_SOFT_SPI_MISO_PIN
     * @def MY_SOFT_SPI_MOSI_PIN
     * @brief Soft SPI MOSI pin.
    #ifndef MY_SOFT_SPI_MOSI_PIN
    *  RFM69 Driver Defaults
     * @def MY_RFM69_FREQUENCY
    #ifndef MY_RFM69_FREQUENCY
     * @def MY_IS_RFM69HW
    //#define MY_IS_RFM69HW
     * @def MY_RFM69HW
    #ifdef MY_IS_RFM69HW
    	#define MY_RFM69HW true
    	#define MY_RFM69HW false
     * @def MY_RFM69_NETWORKID
    #ifndef MY_RFM69_NETWORKID
     * @def MY_RF69_IRQ_PIN
     * @brief RF69 IRQ pin.
    #ifndef MY_RF69_IRQ_PIN
     * @def MY_RF69_SPI_CS
    #ifndef MY_RF69_SPI_CS
     * @def MY_RF69_IRQ_NUM
     * @brief RF69 IRQ pin number.
    #ifndef MY_RF69_IRQ_NUM
    //#define MY_GATEWAY_W5100
    //#define MY_GATEWAY_ENC28J60
    //#define MY_GATEWAY_ESP8266
     * @def MY_PORT
    #ifndef MY_PORT
    #define MY_PORT 5003
    //#define MY_USE_UDP
     * @def MY_IP_RENEWAL_INTERVAL
     * @def MY_MAC_ADDRESS.
    #ifndef MY_MAC_ADDRESS
     * @ingroup internals
     * under some form of attack.
     * - LDB (Locked During Boot)
     * @def MY_NODE_LOCK_FEATURE
     * @def MY_NODE_UNLOCK_PIN
    #ifndef MY_NODE_UNLOCK_PIN
    #define MY_NODE_UNLOCK_PIN 14
    /** @}*/ // Node lock group
    #if DOXYGEN
    @alexsh1 said:
    Pleas make sure your transceivers are W version and not HW.
    Is this the best version of transceiver for Arduino Pro Mini 3,3V and Nano?
    So the H version can not be powered with 3,3V VCC from Arduino Pro Mini/Nano?
    fetsF 1 Reply Last reply
    • vgaV vga
       * @file MyConfig.h
      #ifndef MyConfig_h
      #define MyConfig_h
      #include <stdint.h>
      // V: CPU voltage
      // F: CPU frequency
      // M: free memory
      #undef MY_DEBUG
       * @def MY_BAUD_RATE
      //#define MY_RS485
       * @def MY_NODE_ID
      #ifndef MY_NODE_ID
      *  Gateway config
       * @def MY_RFM69HW
       * @def MY_PORT
      #ifndef MY_PORT
      #if DOXYGEN
      fetsF
      fetsF
      fets
      yes it is
      • vgaV
        vgaV
        vga
        @fets said:
        yes it is
        sorry, thought it is possible for function test if there are no antennas attached to it, if gateway and sensor are side by side.
        So, for making it real, is this the correct length for my transceiver:
        868 1/4 wave = 82.2mm ? (length including the soldered part of the wire?)
        • vgaV vga
          @fets said:
          yes it is
          fetsF
          fetsF
          fets
          @vga no it's 86.4mm (= (3 10^8 / (868 10^6)) / 4)
          In my case soldered part included
          • vgaV
            vgaV
            vga
            Thank you, just added the antennas. ...but also no connection.
            alexsh1A 1 Reply Last reply
            • vgaV vga
              alexsh1A
              alexsh1A
              alexsh1
              @vga both antennas on both transceivers?
              • vgaV
                vgaV
                vga
                yes, from Gateway and Sensore-Node now has wire antennas.
                • vgaV
                  vgaV
                  vga
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    #24
                    No - RF24 is for nrf24l01+ not for RFM69
                    I have run out of ideas - please check out my thread (posted above). Maybe this would help. And I would always suggest to check again all the steps - you have probably a silly mistake and it is a matter of check to spot it
                    • vgaV
                      vgaV
                      vga
                      thanks alexsh1.
                      One more thing:
                      Gateway is a Arduino Pro Mini 3,3V and powered with a connected FTDI 3,3V Breakout to USB from Raspberry Pi 2.
                      Sensor node is also a Arduino Pro Mini 3,3V but powered with a FTDI 5V Breakout (the only second one i have at moment) which is connected to my MacBooks´USB.
                      Is this a acceptable way?
                      So at the end i have to buy a "W" Module, and try it again?
