  3. LDR as light sensor
LDR as light sensor
buildldrno datalight senors
9 Posts 2 Posters 6.9k Views 2 Watching
  • Flor SandersF
    Flor SandersF
    Flor Sanders
    Hello
    Since I'm a student and the holidays have begun, I finally have time to convert my purchases online into a domotic system.
    I succesfully set up my raspi 2 with domoticz and started working on my very first sensor.
    Now in the "build section" at light, there are true light sensors used, but I only needed an estimated value on which I can base actions.
    So my idea was to use an LDR and some calculations to convert the analog input to a luxish value.
    Now... I've edited the "light" sketch from the build section to send the value I calculated, but when I look in domoticz, at "Hardware setup", it seems like this child is sending no values. (screenshot below).
    And when I go to "setup devices", this sensor doesn't even show up. (screenshot below)
    Can anyone check my code and say what I've done wrong. I'll also add a picture of my breadboard in a moment. Don't know whether that'll be clear though.
    Screenshots:
    Setup Hardware
    Setup devices
    Breadboard:
    Setup
    My code:
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    int lastLightLevel;
    boolean metric = true;
    MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      gw.begin();
      gw.sendSketchInfo("Room Flor 1", "1.0");
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      int lightLevel = (2500/((analogRead(LIGHT_SENSOR_ANALOG_PIN)*0.0048828125)-500))/10;
      Serial.println(lightLevel);
          gw.send(msgLux.set(lightLevel));
          lastLightLevel = lightLevel;
    • GertSandersG
      GertSandersG
      GertSanders
      0_1468322988720_MyLightSensor.ino
      Here is my version of a LDR based light sensor code.
      • Flor SandersF
        Flor SandersF
        Flor Sanders
        @GertSanders Thank you!
        So, you are basically sending a light intensity value between 0 and 100 to domoticz.
        I'm going to leave the battery part out because my sensor is installed near a power outlet, and I can just use power from an adapter.
        I'm testing it now, and reporting back with my results!
        • Flor SandersF
          Flor SandersF
          Flor Sanders
          @GertSanders
          Okay
          So after editing your code to work on the slightly older mysensors library I still have installed, all seems to work!
          Thanks a lot for your help!
          Screenshots:
          New code:
           * Version 1.0 - Henrik EKblad
           * This sketch provides an example how to implement a humidity/temperature
           * sensor using DHT11/DHT-22
          #define LIGHTLEVEL 1
          #define ledpin 13
          #define LIGHT_SENSOR_ANALOG_PIN A0
          #define MESSAGEWAIT 500
          #define SENDRETRIES 5
          int LightLevel = 0;
          int PreviousLightLevel = 0;
          boolean BatOK = false;
          boolean LightOK = false;
          DHT dht;
          float lastTemp;
          float lastHum;
          MyMessage LightMsg(LIGHTLEVEL, V_LIGHT_LEVEL);
            gw.begin();
            gw.present(LIGHTLEVEL, S_LIGHT_LEVEL);
            pinMode(ledpin, OUTPUT);
            pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT_PULLUP);
            LightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
            LightOK = false;
              if (!metric) {
                lastHum = humidity;
            if (!LightOK)
              if (LightLevel != PreviousLightLevel)
                LightOK = gw.send(LightMsg.set(LightLevel));
                if (LightOK)
                  PreviousLightLevel = LightLevel;
                LightOK = true;
          void blipled()
            gw.sleep(100);              // wait for a second
            digitalWrite(ledpin, HIGH);   // turn the LED on (HIGH is the voltage level)
            gw.sleep(50);              // wait for a second
            digitalWrite(ledpin, LOW);    // turn the LED off by making the voltage HIGH
          • Flor SandersF Flor Sanders
            @GertSanders
            Okay
            Screenshots:
            New code:
            #define ledpin 13
            int LightLevel = 0;
            DHT dht;
            float lastTemp;
            float lastHum;
              gw.begin();
              LightOK = false;
                if (!metric) {
                  lastHum = humidity;
              if (!LightOK)
                  if (LightOK)
                  LightOK = true;
            void blipled()
            GertSandersG
            GertSandersG
            GertSanders
            @Flor-Sanders
            You should read the analog value of pin A0 in the loop as well.
            And why not use the version 2.0.0 library, it makes the sketches more readable and compact.
            Flor SandersF 1 Reply Last reply
            • Flor SandersF
              Flor SandersF
              Flor Sanders
              @GertSanders
              Oh right! Guessed I missed that while copying and pasting everything.
              I just remarked there was a v2.0 while writing the sketch... Might rewrite it while I'm busy :-)
              • GertSandersG GertSanders
                @Flor-Sanders
                Flor SandersF
                Flor SandersF
                Flor Sanders
                wrote on last edited by Flor Sanders
                @GertSanders
                So I just succesfully updated the code to library 2.0.0
                Yet, now nothing shows up in domoticz. Do I also need to update something to the raspberry pi 2 (which is acting as the gateway).
                Since the serial gateway is stating to be succesfully sending information.
                New code:
                 * Example sketch showing how to measue light level using a LM393 photo-resistor
                 * http://www.mysensors.org/build/light
                //Including nescessary libraries
                //Defining child ID's and sensor pins
                #define LIGHTLEVEL 0
                #define HUMIDITY 1
                #define TEMPERATURE 2
                DHT dht;
                //Defining values to store sensor information
                int LightLevel = 0;
                float lastTemp;
                float lastHum;
                int lastLightLevel;
                //Defining sleep and wait times
                unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)(30 seconds)
                MyMessage msgHum(HUMIDITY, V_HUM);
                MyMessage msgTemp(TEMPERATURE, V_TEMP);
                void presentation()  {
                  sendSketchInfo("Room Flor 1", "2.0");
                  wait(MESSAGEWAIT);
                  wait(MESSAGEWAIT);
                  present(HUMIDITY, S_HUM);
                  wait(MESSAGEWAIT);
                  present(TEMPERATURE, S_TEMP);
                      lastHum = humidity;
                  int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                      send(LightMsg.set(lightLevel));
                  sleep(SLEEP_TIME);
                  @GertSanders
                  New code:
                  #define HUMIDITY 1
                  DHT dht;
                  int LightLevel = 0;
                  float lastTemp;
                  float lastHum;
                  int lastLightLevel;
                    wait(MESSAGEWAIT);
                    wait(MESSAGEWAIT);
                    wait(MESSAGEWAIT);
                        lastHum = humidity;
                    sleep(SLEEP_TIME);
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @Flor-Sanders
                  No idea, there seems to be an issue with 2.0.0 and Raspi Gateway. I'm using the dev version of 2.0.0 without updating my raspi GW. Will check in the coming days on my SMS node (moet ik klaar maken voor de meetup in Breda).
                  • Flor SandersF
                    Flor SandersF
                    Flor Sanders
                    @GertSanders
                    Then I'll temporaraly switch over to a serial gateway.
                    Thanks again for the info!
