  3. MySensors Hardwired
MySensors Hardwired
5 Posts 2 Posters 1.4k Views 1 Watching
  • CrankyCoderC Offline
    CrankyCoder
    I am wondering if anyone has every done anything with making a hardwired sensor. No RF. I know I know. The RF is just to make it easier and wireless. But the framework of mysensors I think could be used for nodes where it's better to be hardlined.
    I assume something like that would need to talk to the gateway, and it would still translate. I know the nodes could go directly to the end point, but I like the idea of all the framework stuff that is built in being immediately available.
    This would also open up the possibility of POE nodes.
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • T Offline
      T Offline
      tbowmo
      @Jason-Brunk
      There is a RS485 transport layer available for a wired network, so yes it is possible to do it (I don't know how many uses it though..)
      https://github.com/mysensors/MySensors/blob/development/MyConfig.h#L82
        CrankyCoder
        hmmmm. I was thinking hard lining ethernet. But this is pretty interesting as well. Definitely an option. Gonna have to do some research o this.
        www.CrankyCoder.net
        MySensors: 2.3
        • T Offline
          T Offline
          tbowmo
          That's just a bunch of ethernet Gateways then? :)
          I think that RS485 would be more suitable for sensor networks though..
            CrankyCoder
            ah, good point on the gateways. Ill have to test it out with the mqtt-client-gateway
            For RS485. Do you happen to have any examples as how it's setup from a hardware perspective if you have say 3 nodes? Do you connect node -> gateway x3 or do you go node -> node -> node-> gateway?
            www.CrankyCoder.net
            MySensors: 2.3
            12.1k
