  3. What is wrong with this sketch?
20 Posts 4 Posters 5.0k Views 4 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    This is my last attempt and I think it works pretty well, but the gateway still get spammed. When I trigger the motion-sensor the domotizc log looks like this:
    2016-07-19 11:38:53.250 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:54.354 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:54.411 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:55.515 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:55.574 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:56.678 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:56.736 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:57.842 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:57.899 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:59.003 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:38:59.061 (RFM) Lighting 2 (Säng Motion)
    2016-07-19 11:39:00.166 (RFM) Lighting 2 (Säng Motion)
    #define MY_DEBUG    // Enables debug messages in the serial log
    #define MY_RADIO_RFM69
    #define MY_REPEATER_FEATURE  // Enables repeater functionality for a radio node
    #define PRESSURE_ID 1
    #define MOTION_ID 2   // Id of the sensor child
    int FSR_Pin = A0; //analog pin 0
    int value = 0;
    int oldvalue = 0;
    int OPEN = 0;
    int CLOSE = 1;
    boolean previousTripped = LOW;
    MyMessage msgPressure(PRESSURE_ID, V_TRIPPED);
    MyMessage msgMotion(MOTION_ID, V_TRIPPED);
     sendSketchInfo("Pressure/Motion Sensor", "1.0");
      present(PRESSURE_ID, S_DOOR);
      present(MOTION_ID, S_MOTION);
    int FSRReading = analogRead(FSR_Pin);
    if(FSRReading > 150)
        value=CLOSE;
        value=OPEN;
    // Read digital motion value
       // Sensor must be HIGH and not yet sent the status of the sensor
        if ((tripped == HIGH) && (tripped != previousTripped) ) {
        send(msgMotion.set(tripped ? "1" : "0")); // Send tripped value to gw
        previousTripped = tripped;
      // Is sensor low and not sent? Then send LOW to gateway
      else if ((tripped == LOW) && (tripped != previousTripped)) {
       else if(value!= oldvalue)
            send(msgPressure.set(value?"1":"0"));
           oldvalue = value;
       else{
            sleep(1000);
    AWIA 1 Reply Last reply
      int value = 0;
      int oldvalue = 0;
      int OPEN = 0;
      int CLOSE = 1;
          value=CLOSE;
          value=OPEN;
             oldvalue = value;
         else{
              sleep(1000);
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @Cliff-Karlsson A few things:
      1. You are mixing all kinds of variable types which makes it rather confusing. a boolean can only have a "true" or "false" value (not HIGH/LOW or OPEN/CLOSE ).
      2. The pressure sensor "value" is fact a boolean. I would be easier to read if you make it a boolean and name it "pressureHigh" or so.
      3. The operator <test>?<if true>: <if false> takes a boolean as first argument.
      4. There are two independent sensors (motion and "pressure") in your node. so you should treat them as such. so something like this instead of stacking "else if"
      if (<sensor 1>)    // sensor 1 actions
      else (<sensor 1>)
      if (<sensor 2>)    // sensor 2 actions
      else (<sensor 2>)
      sleep(  <interrupt>, <time>) ;
      the spamming of the gateway is probably caused by somethin else ;-)
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Ok, I am going to try to make some use of that info. But can I still use "sleep( <interrupt>, <time>) ;" when I also need to monitor the A0 (Pressure)? Will the Pressure still trigger when the sensor sleeps and there are no motion?
        corbinC AWIA 2 Replies Last reply
          corbinC
          corbinC
          corbin
          @Cliff-Karlsson
          You cannot use sleep of any kind, because it will power down the radio, and you need that running 100% of the time for the repeater function.
            AWIA
            AWIA
            AWI
            @Cliff-Karlsson It depends what kind of pressure sensor you have, i will probably be enough if you poll it each second or so. And as @corbin mentioned don't use repeater function when you sleep.
            Cliff KarlssonC 1 Reply Last reply
            • AWIA AWI
              Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Ok, I know this is probably very basic. But exactly how would I modify the original sketch to have it behave like this?
              nielsokkerN 1 Reply Last reply
                nielsokkerN
                nielsokkerN
                nielsokker
                @Cliff-Karlsson
                I dont really understand what you mean. You want it to send its value every second? In that case my attempt still works. You want to use interrupts?
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  I just want a sketch that updates the status of the pressure sensor when it goes from HIGH to LOW or from LOW to HIGH. And when Movement is detected, but does only report back to the controller when a actual change has happened.
                  In my last sketch all seemed to work except it "spammed" the controller with the motion-sensor:
                    nielsokkerN
                    nielsokkerN
                    nielsokker
                    @Cliff-Karlsson
                    I see why. But once again, i think i made your sketch work.
                    As i see it. This is the current desired logic.
                    once per second, you want to check the following things:
                    • is there motion?
                    • has there been a change in pressure (HIGH to LOW or LOW to HIGH)?
                    But actually you want to check both ALWAYS. The thing you are obviously looking for, are interrupts. I do not know how these work if you do not want to sleep. Maybe there is a wait(interrupt_pin_1_functor, interrupt_pin_2_functor, waittime=forever) function (I know the sleep() version exists).
                    Maybe you already know what interrupts are but, in short: When a given interrupt pin notices a difference in value (HIGH to LOW, for example) it gives a signal. The current code is being stopped and the function that is bound to the pin is executed. This function could be sending the new value to the gateway.
                    Can someone confirm this?
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      I tried again with your sketch @nielsokker , I think I only added some sleep. But the motion-sensor just turns on/off super-quick every time the motion triggers. What am I doing wrong ?
                      AWIA nielsokkerN 2 Replies Last reply
                        AWIA
                        AWIA
                        AWI
                        @Cliff-Karlsson how is your motion sensor powered? It needs a solid power supply
                          nielsokkerN
                          nielsokkerN
                          nielsokker
                          wrote on last edited by nielsokker
                          Yea, my example just checks both sensors every second. So it sends both values every second. I know now that is not what you want. At least the code looks better in my opinion (ofc its my code :) ).
                          I have to agree with @AWI that it seems like your sensor does not work properly.
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            ahh!!!, you where right. I powered the node using a mobile charger but had not connected the PIR to the same GND as the charger. Now it works.
