  3. What is wrong with this sketch?
20 Posts 4 Posters 5.0k Views 4 Watching
  • nielsokkerN
    nielsokkerN
    nielsokker
    I am trying to debug it. I will let you know in a second.
    • nielsokkerN
      nielsokkerN
      nielsokker
      #define MY_DEBUG    // Enables debug messages in the serial log
      #define MY_RADIO_RFM69
      #define MY_REPEATER_FEATURE  // Enables repeater functionality for a radio node
      #define PRESSURE_ID 1
      #define MOTION_ID 2   // Id of the sensor child
      #define FSR_Pin = A0; //analog pin 0
      int value = 0; // change this to a signed  or unsigned thingy
      int oldvalue = 0; // change this to a signed  or unsigned thingy
      #define OPEN 0
      #define CLOSE 1
      boolean lastTripped = 0;
      MyMessage msgPressure(PRESSURE_ID, V_TRIPPED);
      MyMessage msgMotion(MOTION_ID, V_TRIPPED);
        pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as inputa
        sendSketchInfo("Pressure/Motion Sensor", "1.0");
        present(PRESSURE_ID, S_DOOR);
        present(MOTION_ID, S_MOTION);
        int FSRReading = analogRead(FSR_Pin);
        if (FSRReading > 150)
          value = CLOSE;
          value = OPEN;
        // Read digital motion value
        boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR);
        if (lastTripped != tripped) // if only the tripped has changed
          //Serial.println(tripped);
          send(msgMotion.set(tripped ? "1" : "0")); // Send tripped value to gw
          lastTripped = tripped;
        if (value != oldvalue)
          send(msgPressure.set(value ? "1" : "0"));
          oldvalue = value;
        wait(SLEEP_TIME);
      I changed the loop part. I had a lot of double code which did not do anything. I changed some ints to defines because they did not change ever. I changed sleep to wait since it is a repeater (they cannot sleep). Also. After every round you want to sleep, so why not just write it once instead of in every if statement.
      I hope this helps you.
      nielsokkerN 1 Reply Last reply
      • nielsokkerN nielsokker
        #define OPEN 0
        #define CLOSE 1
            value = CLOSE;
            value = OPEN;
            oldvalue = value;
          wait(SLEEP_TIME);
        nielsokkerN
        nielsokkerN
        nielsokker
        @nielsokker
        I see it does not compile. You have to change the define.
        #define FSR_Pin = A0; //analog pin 0 needs to be
        needs to be
        #define FSR_Pin  A0 //analog pin 0 needs to be
        corbinC 1 Reply Last reply
          @nielsokker
          needs to be
          corbinC
          corbinC
          corbin
          @nielsokker
          That wait at the end of the loop won't wake up on interrupt, for the motion sensor.
          @Cliff-Karlsson
          Is this node intended to be a repeater as well?
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            @corbin said:
            Yes it will be permanently powered so I figured I could use it for a repeater as well.
            As it won't run on batteries I don't need sleep (?) I just want it to update on pressure (when it goes from 1 to 0 or from 0 to 1) and when detecting movement and not spamming my controller as the original sketch that I made did.
              corbinC
              corbinC
              corbin
              @Cliff-Karlsson
              This is the sketch I'm using for a repeater and motion node. If you are using a HC-SR501 PIR with high and low triggers it should work ok without spamming your gateway.
              Note that there are no sleeps or waits, it will just keep running the loop. I don't know if that is ideal - definitely no good for batteries.
               * Version 1.0 - Henrik Ekblad
               * Example sketch showing how to create a node thay repeates messages
               * from nodes far from gateway back to gateway.
               * It is important that nodes that has enabled repeater mode calls
               * process() frequently. Repeaters should never sleep.
              boolean previousTripped = LOW;
              // Initialize motion message
                //Send the sensor node sketch version information to the gateway
                sendSketchInfo("Motion and Repeater Node", "1.0");
                present(CHILD_ID, S_MOTION);
                // Sensor must be HIGH and not yet sent the status of the sensor
                if ((tripped == HIGH) && (tripped != previousTripped) ) {
                  send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
                  previousTripped = tripped;
                // Is sensor low and not sent? Then send LOW to gateway
                if ((tripped == LOW) && (tripped != previousTripped)) {
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                This is my last attempt and I think it works pretty well, but the gateway still get spammed. When I trigger the motion-sensor the domotizc log looks like this:
                2016-07-19 11:38:53.250 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:54.354 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:54.411 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:55.515 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:55.574 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:56.678 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:56.736 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:57.842 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:57.899 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:59.003 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:38:59.061 (RFM) Lighting 2 (Säng Motion)
                2016-07-19 11:39:00.166 (RFM) Lighting 2 (Säng Motion)
                int FSR_Pin = A0; //analog pin 0
                int value = 0;
                int oldvalue = 0;
                int OPEN = 0;
                int CLOSE = 1;
                if(FSRReading > 150)
                    value=CLOSE;
                    value=OPEN;
                  else if ((tripped == LOW) && (tripped != previousTripped)) {
                   else if(value!= oldvalue)
                        send(msgPressure.set(value?"1":"0"));
                       oldvalue = value;
                   else{
                        sleep(1000);
                AWIA 1 Reply Last reply
                  int value = 0;
                  int oldvalue = 0;
                  int OPEN = 0;
                  int CLOSE = 1;
                      value=CLOSE;
                      value=OPEN;
                         oldvalue = value;
                     else{
                          sleep(1000);
                  AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  @Cliff-Karlsson A few things:
                  1. You are mixing all kinds of variable types which makes it rather confusing. a boolean can only have a "true" or "false" value (not HIGH/LOW or OPEN/CLOSE ).
                  2. The pressure sensor "value" is fact a boolean. I would be easier to read if you make it a boolean and name it "pressureHigh" or so.
                  3. The operator <test>?<if true>: <if false> takes a boolean as first argument.
                  4. There are two independent sensors (motion and "pressure") in your node. so you should treat them as such. so something like this instead of stacking "else if"
                  if (<sensor 1>)    // sensor 1 actions
                  else (<sensor 1>)
                  if (<sensor 2>)    // sensor 2 actions
                  else (<sensor 2>)
                  sleep(  <interrupt>, <time>) ;
                  the spamming of the gateway is probably caused by somethin else ;-)
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Ok, I am going to try to make some use of that info. But can I still use "sleep( <interrupt>, <time>) ;" when I also need to monitor the A0 (Pressure)? Will the Pressure still trigger when the sensor sleeps and there are no motion?
                    corbinC AWIA 2 Replies Last reply
                      corbinC
                      corbinC
                      corbin
                      @Cliff-Karlsson
                      You cannot use sleep of any kind, because it will power down the radio, and you need that running 100% of the time for the repeater function.
                        AWIA
                        AWIA
                        AWI
                        @Cliff-Karlsson It depends what kind of pressure sensor you have, i will probably be enough if you poll it each second or so. And as @corbin mentioned don't use repeater function when you sleep.
                        Cliff KarlssonC 1 Reply Last reply
                        • AWIA AWI
                          Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Ok, I know this is probably very basic. But exactly how would I modify the original sketch to have it behave like this?
                            nielsokkerN
                            nielsokkerN
                            nielsokker
                            @Cliff-Karlsson
                            I dont really understand what you mean. You want it to send its value every second? In that case my attempt still works. You want to use interrupts?
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              I just want a sketch that updates the status of the pressure sensor when it goes from HIGH to LOW or from LOW to HIGH. And when Movement is detected, but does only report back to the controller when a actual change has happened.
                              In my last sketch all seemed to work except it "spammed" the controller with the motion-sensor:
                                nielsokkerN
                                nielsokkerN
                                nielsokker
                                @Cliff-Karlsson
                                I see why. But once again, i think i made your sketch work.
                                As i see it. This is the current desired logic.
                                once per second, you want to check the following things:
                                • is there motion?
                                • has there been a change in pressure (HIGH to LOW or LOW to HIGH)?
                                But actually you want to check both ALWAYS. The thing you are obviously looking for, are interrupts. I do not know how these work if you do not want to sleep. Maybe there is a wait(interrupt_pin_1_functor, interrupt_pin_2_functor, waittime=forever) function (I know the sleep() version exists).
                                Maybe you already know what interrupts are but, in short: When a given interrupt pin notices a difference in value (HIGH to LOW, for example) it gives a signal. The current code is being stopped and the function that is bound to the pin is executed. This function could be sending the new value to the gateway.
                                Can someone confirm this?
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  I tried again with your sketch @nielsokker , I think I only added some sleep. But the motion-sensor just turns on/off super-quick every time the motion triggers. What am I doing wrong ?
                                  AWIA nielsokkerN 2 Replies Last reply
                                    AWIA
                                    AWIA
                                    AWI
                                    @Cliff-Karlsson how is your motion sensor powered? It needs a solid power supply
                                      nielsokkerN
                                      nielsokkerN
                                      nielsokker
                                      wrote on last edited by nielsokker
                                      Yea, my example just checks both sensors every second. So it sends both values every second. I know now that is not what you want. At least the code looks better in my opinion (ofc its my code :) ).
                                      I have to agree with @AWI that it seems like your sensor does not work properly.
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        ahh!!!, you where right. I powered the node using a mobile charger but had not connected the PIR to the same GND as the charger. Now it works.
