  3. ITEAD RBoard (4 relay)
4 Posts 2 Posters 3.6k Views 1 Watching
  • T Offline
    T Offline
    timg
    Hi Everyone!
    I saw a couple of posts on the site in relation to boards from ITEAD STUDIO. I purchased the single relay unit and the 4 relay unit.
    I was able to easily get the single relay unit working through Vera (like @gregl) :) Although I still get some sync issues with Vera, like I have with relay units built on Uno'S. Not so much luck with the 4 relay unit, I'm getting the check wire error in the serial monitor (have tried other radios). I wonder if my problem is with the mapping of the radio?
    http://imall.iteadstudio.com/im120618001.html
    ftp://imall.iteadstudio.com/IM120618001_RBoard/DS_IM120618001_RBoard.pdf
    Here is the pinout of the 4 relay unit:
    Pin of Arduino Description
    D0 = RxD
    D1 = TxD
    D2 = XBee Reset
    D3 = nRF24L01+_IRQ
    D4 = R0
    D5 = R1
    D6 = R2
    D7 = R3
    D8 = nRF24L01+_CE
    D9 = nRF24L01+_CS
    D10 = SD_CS
    D11 = SPI_MOSI
    D12 = SPI_MISO
    D13 = SPI_SCK
    A0 = AD0
    A1 = AD1
    A2 = AD2
    A3 = AD3
    A4 = AD4/IIC_SCL
    A5 = AD5/IIC_SDA
    Any suggestions? If it is related to radio pin mapping what would I need to edit?
    Tim
    • T timg
      Hi Everyone!
      D0 = RxD
      D1 = TxD
      D2 = XBee Reset
      D3 = nRF24L01+_IRQ
      D4 = R0
      D5 = R1
      D6 = R2
      D7 = R3
      D8 = nRF24L01+_CE
      D9 = nRF24L01+_CS
      D10 = SD_CS
      D11 = SPI_MOSI
      D12 = SPI_MISO
      D13 = SPI_SCK
      A0 = AD0
      A1 = AD1
      A2 = AD2
      A3 = AD3
      A4 = AD4/IIC_SCL
      A5 = AD5/IIC_SDA
      Tim
      T Offline
      T Offline
      timg
      I cross referenced the (working) single relay board with the radio mapping on the Uno's and they are the same.
      So my problem is mapping of the radio on the 4 relay unit. Could someone advise what I need to edit in the sketch or config file to map the pins that are required by the 4 relay unit (as detailed above)?
      Thanks in advance,
      Tim
      • T Offline
        T Offline
        timg
        Just reading this post from @gregl. Iboard - Cheap Single board Ethernet Arduino with Radio. This may be helpful !
        • greglG Offline
          greglG Offline
          gregl
          Hi Timg - There is a copy of my heater sketch using the 4relay Rboard. Here:
          http://forum.mysensors.org/topic/282/heater-device/3
          It contains a note about the CE/CS pins ( plugin 1.3)
          //Sensor gw;
          Sensor gw(8,9); //Rboard PCB uses different pins for CE/CS - also interupt, but this isnt used at this time.
          This is a fantastic board which has been working for the past few months with zero issues! I still havent properly boxed it up. I'll await the warmer months to do this.
