  3. send message to sensor on GW
5 Posts 2 Posters 2.1k Views 3 Watching
  • dpressleD
    dpressleD
    dpressle
    How can i send a message to a gateway node?
    I tried the following:
    on the GW i added a node id parameter #define MY_NODE_ID 1 and a receive function
    on another node i use setDestination for the message i want to send to the GW with the node id of the GW (1)
    i expect to get into the receive function on the GW which does not happen
    in the GW serial monitor i see the message getting in:
    0;255;3;0;9;TSP:MSG:READ 2-2-1 s=2,c=1,t=54,pt=2,l=2,sg=0:1
    Can any one let em know if what i am trying to do is even possible?
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      The gateway always has node id 0.
      dpressleD 1 Reply Last reply
        dpressleD
        dpressleD
        dpressle
        @martinhjelmare you are right... still it doesn't seem to get into the receive function in the GW:
        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=54,pt=2,l=2,sg=0:1
        1;1;1;0;54;1
        • martinhjelmareM
          martinhjelmareM
          martinhjelmare
          There is a bug in 2.0.0 where receive isn't called on incoming message if destination is gateway. It's fixed in the dev branch.
          https://github.com/mysensors/MySensors/pull/522
            dpressleD
            dpressleD
            dpressle
            @martinhjelmare Thanks, i will try dev branch
