  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.1k Views 36 Watching
    oh maybe I didn't understand well, I thought that semtech ic (rfm69) would be onboard?? because if we wire our antenna, I don't see well why not use rfm69 module instead. In case of pcb antenna trace, ic onboard makes more sense imho. but maybe I'm wrong..I thought to give a try to this sometimes ago but had this reflexion,..and good design of pcb antenna trace for 433-915mhz is a lot bigger than 2.4ghz nrf. and smaller trace, lower range..+ need to be tuned for each design (in theory, I'm not expert)
    that's cool because koresh is skilled at this :) lot of thing to learn! so I can't wait to see or try one board!
      Slorf
      @Koresh
      I got all the parts, but I think the NRF24L01 is the normal version and not the + version, there is no + to be found on the chip.
      Would the older NRF24L01 ( without plus ) work on the board ?, or do I have to use the R1 resistor ?
      ( Resistor 1M ( which package size ) - unnecessary element (R1 can be mounted for backward compatibility with nRF24L01, nevermind)
      Alex
      KoreshK 1 Reply Last reply
      • S Slorf
        @Koresh
        Alex
        KoreshK
        KoreshK
        Koresh
        @Slorf It depends on crystal. If oscillator starts and works correctly some days you can omit it.
          Slorf
          @Koresh
          Ermm... how do I know it works correctly ?, and if it doesn't work correctly which 1M resistor do I have to use ?
          Thanks for your help !!!
          Alex
          • S Slorf
            @Koresh
            Alex
            KoreshK
            KoreshK
            Koresh
            @Slorf NRF oscillator can work or not (or could stop after some time). If problems appear use any 1m resistor (0402 or 0603 if you can solder it). Do not worry. It is the last stage (after nrf soldering and atmega programming).
            Can you provide link to your nrf chip(where you buy it)? I want to check it.
              Slorf
              @Koresh
              Sorry for the late reply, our second son was born just 2 weeks ago.... no sleep anymore :-)
              It looks like this one, except mines it labelled: 0935VI, the one on the link 0935VJ
              http://www.aliexpress.com/store/product/NRF24L01-QFN20-24L01-SMD-chip-new-original-SDQYS/1823911_32468479303.html
              sundberg84S Y 2 Replies Last reply
              • S Slorf
                @Koresh
                sundberg84S
                sundberg84S
                @Slorf said:
                @Koresh
                Congrats!!! :baby: :sleeping: :smiley:
                • S Slorf
                  @Koresh
                  Y
                  Y
                  yury
                  @Slorf said:
                  reply
                  Congrats and enjoy ))
                  • Sander TeunissenS
                    Sander TeunissenS
                    Sander Teunissen
                    @koresh Just created a light sensor from one of the boards I bought from you. It works great !
                    I had to do some tweaking with the serial monitor speed from my arduino IDE (I had to double the speed which was set in the code or something)
                    I also had to press the reset button just before uploading of the sketch started.
                    Apart from that: Great !
                    Thanks !
                    • Sander TeunissenS Sander Teunissen
                      Thanks !
                      KoreshK
                      KoreshK
                      Koresh
                      wrote on last edited by Koresh
                      #83
                      @Sander-Teunissen
                      Thanks to your responce.
                      I'm sorry to hear you faced some hardware problem. Of course the board must restart itself. It may be couse of low quality of mounting first boards or it was damaged during delivery :(
                      May be you used incorrect usb-ttl converters boards without correct dtr line? I faced them year ago.. it was bad surprise )
                      Sander TeunissenS 1 Reply Last reply
                      • KoreshK Koresh
                        @Sander-Teunissen
                        Sander TeunissenS
                        Sander TeunissenS
                        Sander Teunissen
                        @Koresh No problems. I am happy working with them.
                        • Sander TeunissenS
                          Sander TeunissenS
                          Sander Teunissen
                          @Koresh I guess I already know the answer, but this board works with 3.3 volts ? If I want to connect something like this:
                          https://www.mysensors.org/build/motion ,which works only on 5V I'd need to add a step up converter ?
                          Sander.
                            Sander.
                            KoreshK
                            KoreshK
                            Koresh
                            #86
                            Sander.
                            Board contains two 3.3v LDO. You can change one of them to 5v (do not forget check schematic).
                            • hensingH
                              hensingH
                              hensing
                              @Sander-Teunissen you can modify the motion sensor to work on 3.3V (see http://www.instructables.com/id/Convert-a-5v-PIR-Motion-Sensor-to-33v-for-ESP8266/)
                              • hensingH
                                hensingH
                                hensing
                                @Koresh can you give us an ETA of the sensor? I'm looking forward to buy some :)
                                • TigroenotT
                                  TigroenotT
                                  Tigroenot
                                  I aasembled your node, but the radio chip version is not the + one. After burning the MYS bootloader is prints the debug in serial:
                                  60110 TSM:FAIL:RE-INIT
                                  60112 TSM:INIT
                                  60119 !TSM:INIT:TSP FAIL
                                  60123 TSM:FAIL:CNT=7
                                  60125 TSM:FAIL:PDT
                                  Any suggestions?
                                  • TigroenotT Tigroenot
                                    60112 TSM:INIT
                                    60125 TSM:FAIL:PDT
                                    Any suggestions?
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    60112 TSM:INIT
                                    60125 TSM:FAIL:PDT
                                    Any suggestions?
                                    For not the + version you should mount 1M resistor (R21). And check all soldering points of course.
                                    • TigroenotT
                                      TigroenotT
                                      Tigroenot
                                      I checked everything twice of course. I don't have 0402 1M resistor, the smallest I have is 0805 :)
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        You can easily solder THD resistor in parallel with Q2 ;)
                                        • TigroenotT
                                          TigroenotT
                                          Tigroenot
                                          @Koresh Did that. No luck.
                                          0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 !TSM:INIT:TSP FAIL
                                          14 TSM:FAIL:CNT=1
                                          16 TSM:FAIL:PDT
