  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.1k Views 36 Watching
    Slorf
    @Koresh
    I got all the parts, but I think the NRF24L01 is the normal version and not the + version, there is no + to be found on the chip.
    Would the older NRF24L01 ( without plus ) work on the board ?, or do I have to use the R1 resistor ?
    ( Resistor 1M ( which package size ) - unnecessary element (R1 can be mounted for backward compatibility with nRF24L01, nevermind)
    Alex
    KoreshK 1 Reply Last reply
    • S Slorf
      @Koresh
      Alex
      KoreshK
      KoreshK
      Koresh
      @Slorf It depends on crystal. If oscillator starts and works correctly some days you can omit it.
        Slorf
        @Koresh
        Ermm... how do I know it works correctly ?, and if it doesn't work correctly which 1M resistor do I have to use ?
        Thanks for your help !!!
        Alex
        • S Slorf
          @Koresh
          Alex
          KoreshK
          KoreshK
          Koresh
          @Slorf NRF oscillator can work or not (or could stop after some time). If problems appear use any 1m resistor (0402 or 0603 if you can solder it). Do not worry. It is the last stage (after nrf soldering and atmega programming).
          Can you provide link to your nrf chip(where you buy it)? I want to check it.
            Slorf
            @Koresh
            Sorry for the late reply, our second son was born just 2 weeks ago.... no sleep anymore :-)
            It looks like this one, except mines it labelled: 0935VI, the one on the link 0935VJ
            http://www.aliexpress.com/store/product/NRF24L01-QFN20-24L01-SMD-chip-new-original-SDQYS/1823911_32468479303.html
            sundberg84S Y 2 Replies Last reply
            • S Slorf
              @Koresh
              sundberg84S
              sundberg84S
              @Slorf said:
              @Koresh
              Congrats!!! :baby: :sleeping: :smiley:
              • S Slorf
                @Koresh
                Y
                Y
                yury
                @Slorf said:
                reply
                Congrats and enjoy ))
                • Sander TeunissenS
                  Sander TeunissenS
                  Sander Teunissen
                  @koresh Just created a light sensor from one of the boards I bought from you. It works great !
                  I had to do some tweaking with the serial monitor speed from my arduino IDE (I had to double the speed which was set in the code or something)
                  I also had to press the reset button just before uploading of the sketch started.
                  Apart from that: Great !
                  Thanks !
                  • Sander TeunissenS Sander Teunissen
                    Thanks !
                    KoreshK
                    KoreshK
                    Koresh
                    wrote on last edited by Koresh
                    #83
                    @Sander-Teunissen
                    Thanks to your responce.
                    I'm sorry to hear you faced some hardware problem. Of course the board must restart itself. It may be couse of low quality of mounting first boards or it was damaged during delivery :(
                    May be you used incorrect usb-ttl converters boards without correct dtr line? I faced them year ago.. it was bad surprise )
                    Sander TeunissenS 1 Reply Last reply
                    • KoreshK Koresh
                      @Sander-Teunissen
                      Sander TeunissenS
                      Sander TeunissenS
                      Sander Teunissen
                      @Koresh No problems. I am happy working with them.
                      • Sander TeunissenS
                        Sander TeunissenS
                        Sander Teunissen
                        @Koresh I guess I already know the answer, but this board works with 3.3 volts ? If I want to connect something like this:
                        https://www.mysensors.org/build/motion ,which works only on 5V I'd need to add a step up converter ?
                        Sander.
                          Sander.
                          KoreshK
                          KoreshK
                          Koresh
                          #86
                          Sander.
                          Board contains two 3.3v LDO. You can change one of them to 5v (do not forget check schematic).
                          • hensingH
                            hensingH
                            hensing
                            @Sander-Teunissen you can modify the motion sensor to work on 3.3V (see http://www.instructables.com/id/Convert-a-5v-PIR-Motion-Sensor-to-33v-for-ESP8266/)
                            • hensingH
                              hensingH
                              hensing
                              @Koresh can you give us an ETA of the sensor? I'm looking forward to buy some :)
                              • TigroenotT
                                TigroenotT
                                Tigroenot
                                I aasembled your node, but the radio chip version is not the + one. After burning the MYS bootloader is prints the debug in serial:
                                60110 TSM:FAIL:RE-INIT
                                60112 TSM:INIT
                                60119 !TSM:INIT:TSP FAIL
                                60123 TSM:FAIL:CNT=7
                                60125 TSM:FAIL:PDT
                                Any suggestions?
                                • TigroenotT Tigroenot
                                  60112 TSM:INIT
                                  60125 TSM:FAIL:PDT
                                  Any suggestions?
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  60112 TSM:INIT
                                  60125 TSM:FAIL:PDT
                                  Any suggestions?
                                  For not the + version you should mount 1M resistor (R21). And check all soldering points of course.
                                  • TigroenotT
                                    TigroenotT
                                    Tigroenot
                                    I checked everything twice of course. I don't have 0402 1M resistor, the smallest I have is 0805 :)
                                      KoreshK
                                      KoreshK
                                      Koresh
                                      You can easily solder THD resistor in parallel with Q2 ;)
                                      • TigroenotT
                                        TigroenotT
                                        Tigroenot
                                        @Koresh Did that. No luck.
                                        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        12 !TSM:INIT:TSP FAIL
                                        14 TSM:FAIL:CNT=1
                                        16 TSM:FAIL:PDT
                                        • TigroenotT
                                          TigroenotT
                                          Tigroenot
                                          Allright, I have replaced the nrf chips to those with + and... that was it, everything is working very well now :)
                                          Here they are, freshly handmade :)
