  3. [SOLVED] Combine sketches for Relay + status (RGB)LED
4 Posts 2 Posters 1.6k Views 2 Watching
  • NaitsirhcN Offline
    NaitsirhcN Offline
    Naitsirhc
    First of all I would like to thank you for the good work you all are doing.
    Since I have been attended to this site, I am thinking of making a relay board with a status signal.
    What do I mean:
    I have a magnet which is working on 12V. I have this magnet installed to my door, so it is possible for me to close the door by magnet.
    From the site I have downloaded the sketch for operate a relay board, so it is possible for me to operate the magnet (with a relay) from Domoticz. It is already up and running.
    Unfortunately the magnet doesn’t have a status led, so it isn’t possible to see if this magnet is working or not.
    When I’m searching on the internet, I see several sketches to operate a led via some pins on the Arduino.
    My question is:
    Is it possible to integrate some code in the relay sketch to operate the LED.
    For your info, I have a RGB LED which only have to work with the colors green and red.
    I have done some fiddling with the code, but it doesn’t work I think:
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • REVISION HISTORY
    • Version 1.0 - Henrik Ekblad
    • DESCRIPTION
    • Example sketch showing how to control physical relays.
    • This example will remember relay state after power failure.
    • http://www.mysensors.org/build/relay
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    #define redPin = 5
    #define greenPin = 6
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 radio;
    // Message signing driver (none default)
    //MySigningNone signer;
    // Select AtMega328 hardware profile
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    gw.sendSketchInfo("RelayLED", "1.0");
    // Fetch relay status
    gw.present(sensor, S_LIGHT);
    pinMode(pin, OUTPUT);
    pinMode(redPin, OUTPUT);
    pinMode(greenPin, OUTPUT);
    digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
    setColor(255, 0, 0); // red
    setColor(0, 255, 0); // green
    if (message.type==V_LIGHT) {
    // Change relay state
    // Store state in eeprom
    void setColor(int red, int green, int blue){
    #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    analogWrite(redPin, red);
    analogWrite(greenPin, green);
    I do know I have to combine the analogWrite command with the state of the relay, but I don know if this is possible….
    Can you help me please?
    Kind regards and thanks in advance….
    italicised textitalicised textitalicised text
    Boots33B 1 Reply Last reply
    • NaitsirhcN Naitsirhc
      What do I mean:
      My question is:
      • REVISION HISTORY
      • DESCRIPTION
      #define redPin = 5
      MyHwATMega328 hw;
      #ifdef COMMON_ANODE
      red = 255 - red;
      Boots33B Offline
      Boots33B Offline
      Boots33
      wrote on last edited by Boots33
      @Naitsirhc
      If you just want to turn the leds fully on to red or green try the code below. You may need to swap the colours around depending which one you want on when the relay is active.
      I have not tested the code but i think it will work
      #define redPin  5
      #define greenPin  6
      MyHwATMega328 hw;
        gw.sendSketchInfo("Relay", "1.0");
      	 if (message.getBool()== true){
            digitalWrite(greenPin, LOW);
            digitalWrite(redPin, HIGH);
           else{
            digitalWrite(redPin, LOW);
            digitalWrite(greenPin, HIGH);
        NaitsirhcN Offline
        Naitsirhc
        You're brilliant.
        It works like you said.... Red if the door is closed and green when it is opened
        therefore I have adapted the code a littlebit:
        is now:
        if (message.getBool()== false)
        Thank you very much
        • Boots33B Offline
          Boots33B Offline
          Boots33
          Great! Glad it worked for you
