  3. Problem powering sensor from external battery (100000mah)
100000mahds18b20sr-501battery powerednrf24l01+pa+lna
12 Posts 7 Posters 9.2k Views 4 Watching
  • nutcrackerN
    nutcrackerN
    nutcracker
    wrote on last edited by nutcracker
    I had wondered that myself prior to purchasing but having seen similar battery capacities on the AliExpress website, presumed it was correct... Looking now, I think it could still be although the picture says different (description and model number state 100000mah).
    This is the model that I purchased: http://www.aliexpress.com/item/100-original-power-bank-ultra-thin-samsung-Mobile-phone-power-100000-mAh-external-battery-portable-charger/32273198121.html
    They also do a 120000mah version as well...similar physical size: http://www.aliexpress.com/item/Portable-Battery-Charger-120000mAH-Thin-External-Battery-Power-Bank-for-philips-samsung-S4-iphone-6-5s/32271404267.html
    I'll leave my unit charging overnight and see what happens tomorrow...suspect that there may not be enough juice to run the sensor...
    Nutz
    • bjornhallbergB
      bjornhallbergB
      bjornhallberg
      Sorry to be that guy, but I agree, 100.000mAh/100Ah can't be right. A car battery is like 60Ah right? So, fake ... bought a few crappy batteries from China myself so I'm not judging.
      If you want a legit 10.000mAh battery, look for the Xiaomi one that has just started selling. $15 or so. About what you could expect in that form factor and for the price. But I guess that all those mAh could be ruined by self-discharge, no idea really what chemistry they use.
      If I were you I'd move to a 3.3V system entirely, use a Pro Mini, and try with AA batteries and a regulator. Even the one linked from the store. Do you need the PA+LNA? Did you try with the regular module?
      I've run the SR-501 for many months now on two AA batteries and no regulator. A lot more activity than a mailbox too. No sign or any issues because of dropping voltage yet (but I expect it will happen).
      • nutcrackerN
        nutcrackerN
        nutcracker
        Yeah, I guess it sounded too good to be true! :)
        I've contacted them anyway for clarification and I should be able to raise a dispute and get my money back (it wasn't that expensive and no doubt can still be used...).
        Its still early days for me so getting familiar with electronics again and playing with Arduino's is fun...and certainly for the moment, 5V works for me...but I hear what your saying. Looking forward to the new boards that will be available hopefully soon via MySensors to allow further experimentation in that direction with AA batteries...
        Yes the distance between the controller and sensor is pretty large and the standard NRF24L01+ units couldn't handle it.
        Nutz
        • SalmoidesS
          SalmoidesS
          Salmoides
          i did notice in the AliExpress page for your battery, the illustration has 10,000 mah. The title must be a typo.
          Sal
          • nutcrackerN
            nutcrackerN
            nutcracker
            Yeah...I'm coming to the same conclusion that the typo exists in the description and the model number...
            Either way, I've charged the battery up and connected it to the sensor yet it powers down after 15-20 seconds... Anyone have any ideas why? I can connect the battery to other electrical equipment (e.g. my controller) and that works fine....
            Nutz
            • tbowmoT
              tbowmoT
              tbowmo
              @nutcracker
              what is the voltage on the output terminals for the following scenarios:
              1. unloaded (nothing connected)
              2. Regular equipment that works as intended
              3. Sensor that shuts down.
              • nutcrackerN
                nutcrackerN
                nutcracker
                @tbowmo
                So I've investigated my sensor setup a little further...unfortunately in the process I accidentally shorted the power connectors on the Nano so now it doesn't work so well...leave that for another time! :)
                I have a replacement that was on my original prototype connected to breadboard so was a little more careful in measuring voltage - on the Nano and on the step down board. I'm reading 4.8volts which I believe is to be expected.
                I also changed to an alternative battery source but this demonstrated the same problem.
                However, what I did discover after replacing some of the components to assist in eliminating what was causing the voltage to drop off is that** if I just have a very simple connection between the Nano and the battery (so literally only connected by the USB cable), I see the same thing - that the Nano powers itself off after 15-20 seconds**...
                So does that imply that I've a duff Nano board...? :boom:
                Anyone else have this board that can confirm a similar behaviour...?
                To be clear, this is a Nano DCCduino with 5v, 3.3v connections powered by USB (http://www.ebay.co.uk/itm/301449586123). I also have a Nano v3 (http://www.ebay.com/itm/130977189883) and that too powers down when connected to a battery via USB! No one else seen this...??
                Nutz
                • G
                  G
                  Gambituk
                  @nutcracker I think the best way to test the function of this battery pack would be to test it using it's designed purpose. So i suggest connecting a heavier load, (for example a smartphone) and see if it also turns off after the same time. or if as you (and I) suppose it stays on because of the extra current draw.
                  I also have a battery backup system for my phone and it turns off if the current draw drops below a certain level so as to stop my phone from trickle charging after it reaches 100%. (it has a button to start the charging function, it doesn't charge when i just connect the phone.)
                  Hope this helps.
                  • nutcrackerN
                    nutcrackerN
                    nutcracker
                    Hi @Gambituk,
                    The original battery pack (10000mAh unit sold as 100000mAh :)) as well as another that I've borrowed (9000mAh) work as designed, e.g. able to charge my iPhone with no problems... However, when you plug just the Arduino board via USB into the battery pack, they don't...which is real shame as this would have been ideal for my project.
                    Waiting to see what happens with the MySensor board (@axillent) that are being discussed and close to finalising as may be a AA battery, NRF24L01+PA+LNA SMA antenna and ability to have a couple of sensors is all I really need...
                    Nutz
                    • wahidW
                      wahidW
                      wahid
                      hello,
                      i know it is late, but others could see it too.
                      i had the same problem running small (LOW POWER) modules on power banks, because the battery or power bank has a built in power meter, while it is charging and consuming power, there will be power on the USB port, but the arduino's consumption is very tiny regarding charging a phone. you need to disable this feature somehow.
