  3. MyNodes.NET
  4. MyNodes.NET moving to node.js.
Scheduled Pinned Locked Moved MyNodes.NET
36 Posts 11 Posters 18.1k Views 12 Watching
  • dpressleD dpressle
    I have no idea how you are getting this to work, when i try to run with the latest code i get this error:
    node bin\www
    C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\mysensors\gateway-io.js:13
    gateway.on('newNode', function (node) {
    TypeError: gateway.on is not a function
    at Object.module.exports.listen (C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\mysensors\gateway-io.js:13:10)
    at C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\web-server\configure.js:17:46
    at Object.<anonymous> (C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\web-server\configure.js:86:3)
    at Module._compile (module.js:410:26)
    at Object.Module._extensions..js (module.js:417:10)
    at Module.load (module.js:344:32)
    at Function.Module._load (module.js:301:12)
    at Module.require (module.js:354:17)
    at require (internal/module.js:12:17)
    at Object.<anonymous> (C:\Users\dpressle\Documents\github_repos\mynodes.js\bin\www:9:2)
    my node version is:
    node --version
    v4.3.0
    npm --version
    2.14.12
    derwishD
    derwishD
    derwish
    @dpressle I use:
    node -v
    v6.2.0
    npm -v
    3.8.9
    dpressleD 1 Reply Last reply
    • derwishD derwish
      @dpressle I use:
      node -v
      v6.2.0
      npm -v
      3.8.9
      dpressleD
      dpressleD
      dpressle
      @derwish strange seems like latest node is 4.4.7 for windows and linux how do you get V 6.xxx
      node official download page
      derwishD 1 Reply Last reply
        derwishD
        derwishD
        derwish
        @dpressle
        https://nodejs.org/en/download/current/
        Current version: v6.2.2 (includes npm 3.9.5)
        • derwishD derwish
          @dpressle
          dpressleD
          dpressleD
          dpressle
          @derwish got it thanks, i will try.
          • dpressleD
            dpressleD
            dpressle
            Getting close (or not)
            node -v
            v6.2.2
            npm -v
            3.10.3
            node bin\www
            C:\Users\dpressle\Documents\github_repos\mynodes.js\node_modules\serialport\node_modules\bindings\bindings.js:83
            throw e
            Error: Module version mismatch. Expected 48, got 46.
            • dpressleD
              dpressleD
              dpressle
              ok its working now, after deleting the node_modules dir and runing "npm install" again
              • derwishD derwish
                @ericvdb Thanks for the feedback. It would be very cool if it was possible to see the values on the inputs/outputs. I have thought about it, but I don't specialist in front-end development and I haven't tried to implement it yet. However, in the new version I'm going to do step-by-step code execution in the nodes (instead of events). Thus you can manually control the speed with which the changed value is pushed along the chain of nodes (up to each step).
                I don't refuse support .net version of the controller. The new version will be developed in a separate repository. I decided to write a new version in node.js for two reasons:
                Microsoft has released a new (still beta) version ASP.NET and they changed so many things in it compared to the last. I wanted to port the code to a new version, but it turned out that it's not easy. If I do the porting now, I will have to do it again when Microsoft will release the final version ASP.NET. So I decided to wait until the API is finally completed.
                I expect there are developers who join the development MyNodes.NET. But the interest of developers is not so strong as I expected. Perhaps ASP.NET not so popular among developers who may be interested in creating a smart home, and such things. I thought MyNodes may become more popular if it will be written in node.js. Let's see what will come out of this.
                Hello, I have some interest in the project in ASP.NET as it looks very promising, just didn't have time to check the code yet, but I hope I will be able to do it in the coming weeks.
                I'm not sure it's necessary to hurry to move to the next version of ASP.NET, you can keep using the current version and let MS finish, then let it some time to smooth out the rough edges after the final version is released :)
                • Nca78N Nca78
                  derwishD
                  derwishD
                  derwish
                  @Nca78 Thank you for your interest. Write about your experience, and ask questions if something is not clear in the code.
                  • neechN
                    neechN
                    neech
                    derwish,
                    Your controller looks awesome.
                    I'd like to start implementing this on my raspberry pi (either pi 1 model B or pi 3). I ran into dependency issues when installing mono on my pi 1 model B. The link to the .net install instructions is different then in your video so I followed the instructions on your video with out success.
                    Do I just need to wait for the node.js version to come out? Would that version still require .NET? I would assume not because node.js is based on javascript. Do you have any node.js development versions that I could try?
                    Looking forward to getting this installed.
                    neech
                    • neechN neech
                      derwish,
                      neech
                      derwishD
                      derwishD
                      derwish
                      wrote on last edited by derwish
                      #23
                      @neech Hi. Version for node.js will not require ASP.NET. It will be independent software. But it is still in a very early stage of development, and there are no predictions when it will be finished. But now, I think you need to find instructions on how to install ASP.NET 5 version RC1, and then everything will work fine.
                      • neechN
                        neechN
                        neech
                        @derwish ,
                        This is the only instructions I have found for installing .net on linux:
                        https://www.microsoft.com/net/core#debian
                        Do you think this will work?
                        neech
                        • fahrettineF
                          fahrettineF
                          fahrettine
                          Good news!!!
                          When do you plan to lounch the new (Node.JS) version?
                          • fahrettineF fahrettine
                            Good news!!!
                            derwishD
                            derwishD
                            derwish
                            #26
                            @fahrettine I halted the development, because now working on a commercial project. But I plan to continue to develop after two months. I think that in this case, the working version will be released by the end of the year.
                            • neechN neech
                              @derwish ,
                              neech
                              derwishD
                              derwishD
                              derwish
                              @neech This instructions for the latest version of the framework. It's not compatible. Look for how to install the RC1 version.
                              • neechN
                                neechN
                                neech
                                @derwish , like this? https://blog.tonysneed.com/2015/05/25/develop-and-deploy-asp-net-5-apps-on-linux/
                                • eboE
                                  eboE
                                  ebo
                                  Hi @derwish
                                  What is the current status about the project to node.js?
                                  still moving?
                                  • eboE ebo
                                    Hi @derwish
                                    still moving?
                                    derwishD
                                    derwishD
                                    derwish
                                    @ebo hi
                                    I had to postpone this project because of work, but I plan to start in January and finish within a month or two.
                                    • antlombA
                                      antlombA
                                      antlomb
                                      Hi @derwish, can I ask you what's the status of the project ? Thanks in advance for your time.
                                      • antlombA antlomb
                                        derwishD
                                        derwishD
                                        derwish
                                        Hi @antlomb! The development is in full swing and is nearing completion. I did a great job, much more than I planned for this version. The final step is the redesign of the user interface, and some more minor improvements. I made everything much more convenient and intuitive. You can see the CHANGELOG.
                                        • Alex_Black1989A
                                          Alex_Black1989A
                                          Alex_Black1989
                                          Banned
