  3. MyNodes.NET
  4. MyNodes.NET moving to node.js.
Scheduled Pinned Locked Moved MyNodes.NET
36 Posts 11 Posters 18.1k Views 12 Watching
  • dpressleD
    dpressleD
    dpressle
    looks like its going to be a great controller, node is one of the strongest players these days, good luck to you i hope i can help in development.
    Few notes:
    1. You are using some deprecated node libraries, you get an warning when running node install.
      npm WARN deprecated jade@1.11.0: Jade has been renamed to pug, please install the latest version of pug instead of jade
      npm WARN deprecated transformers@2.1.0: Deprecated, use jstransformer
    2. I would try to use angular as front end
    3. when trying to run "node ./bin/www" i get exception:
      mys_gateway.connectToSerialPort(config.gateway.mysensors.serial.port, config.gateway.mysensors.serial.baudRate);
    TypeError: mys_gateway.connectToSerialPort is not a function
    derwishD 1 Reply Last reply
    • dpressleD dpressle
      Few notes:
      derwishD
      derwishD
      derwish
      wrote on last edited by derwish
      @dpressle
      Hi. connectToSerialPort should work. The connection with the gateway is already working, and all is displayed correctly on the /mysensors page.
      I'm not familiar with Angular yet. To me it seems pretty cumbersome. Handlebars now works not bad in the role of templating engine. What are the advantages of switching to angular?
      dpressleD 1 Reply Last reply
      • derwishD derwish
        @dpressle
        dpressleD
        dpressleD
        dpressle
        @derwish
        You are right, Handlebars and Angular together would be pretty useless.
        Handlebars and Angular are completely different things.
        Handlebars is a template engine. You write a fancy templatey-string, give it a JSON object, and it renders out HTML from the data. There's no data-binding, no updating, it's just a once-off render.
        AngularJS is an HTML compiler and databinder. Angular will look through the HTML for angular-templating tags, interpret/compile them, and update the HTML with changes to data on a given controller scope. Angular doesn't just render an HTML string once, it compiles the HTML, binds it to a scope, and updates when data on that scope changes.
        • ismail çataroğluI
          ismail çataroğluI
          ismail çataroğlu
          Great work. The most stable controller of i tried. I think it will be good sending e-mail and/or sms When an alarm condition/event occurs. thank you .
          • ismail çataroğluI ismail çataroğlu
            derwishD
            derwishD
            derwish
            @ismail-çataroğlu Thank you. I will add an email node. Perhaps an sms, if I can find a good service.
            • dpressleD
              dpressleD
              dpressle
              I have no idea how you are getting this to work, when i try to run with the latest code i get this error:
              node bin\www
              C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\mysensors\gateway-io.js:13
              gateway.on('newNode', function (node) {
              TypeError: gateway.on is not a function
              at Object.module.exports.listen (C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\mysensors\gateway-io.js:13:10)
              at C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\web-server\configure.js:17:46
              at Object.<anonymous> (C:\Users\dpressle\Documents\github_repos\mynodes.js\modules\web-server\configure.js:86:3)
              at Module._compile (module.js:410:26)
              at Object.Module._extensions..js (module.js:417:10)
              at Module.load (module.js:344:32)
              at Function.Module._load (module.js:301:12)
              at Module.require (module.js:354:17)
              at require (internal/module.js:12:17)
              at Object.<anonymous> (C:\Users\dpressle\Documents\github_repos\mynodes.js\bin\www:9:2)
              my node version is:
              node --version
              v4.3.0
              npm --version
              2.14.12
                node bin\www
                my node version is:
                node --version
                v4.3.0
                npm --version
                2.14.12
                derwishD
                derwishD
                derwish
                @dpressle I use:
                node -v
                v6.2.0
                npm -v
                3.8.9
                • derwishD derwish
                  @dpressle I use:
                  node -v
                  v6.2.0
                  npm -v
                  3.8.9
                  dpressleD
                  dpressleD
                  dpressle
                  @derwish strange seems like latest node is 4.4.7 for windows and linux how do you get V 6.xxx
                  node official download page
                    derwishD
                    derwishD
                    derwish
                    @dpressle
                    https://nodejs.org/en/download/current/
                    Current version: v6.2.2 (includes npm 3.9.5)
                    • derwishD derwish
                      @dpressle
                      dpressleD
                      dpressleD
                      dpressle
                      @derwish got it thanks, i will try.
                      • dpressleD
                        dpressleD
                        dpressle
                        Getting close (or not)
                        node -v
                        v6.2.2
                        npm -v
                        3.10.3
                        node bin\www
                        C:\Users\dpressle\Documents\github_repos\mynodes.js\node_modules\serialport\node_modules\bindings\bindings.js:83
                        throw e
                        Error: Module version mismatch. Expected 48, got 46.
                        • dpressleD
                          dpressleD
                          dpressle
                          ok its working now, after deleting the node_modules dir and runing "npm install" again
                          • derwishD derwish
                            @ericvdb Thanks for the feedback. It would be very cool if it was possible to see the values on the inputs/outputs. I have thought about it, but I don't specialist in front-end development and I haven't tried to implement it yet. However, in the new version I'm going to do step-by-step code execution in the nodes (instead of events). Thus you can manually control the speed with which the changed value is pushed along the chain of nodes (up to each step).
                            I don't refuse support .net version of the controller. The new version will be developed in a separate repository. I decided to write a new version in node.js for two reasons:
                            Microsoft has released a new (still beta) version ASP.NET and they changed so many things in it compared to the last. I wanted to port the code to a new version, but it turned out that it's not easy. If I do the porting now, I will have to do it again when Microsoft will release the final version ASP.NET. So I decided to wait until the API is finally completed.
                            I expect there are developers who join the development MyNodes.NET. But the interest of developers is not so strong as I expected. Perhaps ASP.NET not so popular among developers who may be interested in creating a smart home, and such things. I thought MyNodes may become more popular if it will be written in node.js. Let's see what will come out of this.
                            Hello, I have some interest in the project in ASP.NET as it looks very promising, just didn't have time to check the code yet, but I hope I will be able to do it in the coming weeks.
                            I'm not sure it's necessary to hurry to move to the next version of ASP.NET, you can keep using the current version and let MS finish, then let it some time to smooth out the rough edges after the final version is released :)
                            • Nca78N Nca78
                              derwishD
                              derwishD
                              derwish
                              @Nca78 Thank you for your interest. Write about your experience, and ask questions if something is not clear in the code.
                              • neechN
                                neechN
                                neech
                                derwish,
                                Your controller looks awesome.
                                I'd like to start implementing this on my raspberry pi (either pi 1 model B or pi 3). I ran into dependency issues when installing mono on my pi 1 model B. The link to the .net install instructions is different then in your video so I followed the instructions on your video with out success.
                                Do I just need to wait for the node.js version to come out? Would that version still require .NET? I would assume not because node.js is based on javascript. Do you have any node.js development versions that I could try?
                                Looking forward to getting this installed.
                                neech
                                • neechN neech
                                  derwish,
                                  neech
                                  derwishD
                                  derwishD
                                  derwish
                                  #23
                                  @neech Hi. Version for node.js will not require ASP.NET. It will be independent software. But it is still in a very early stage of development, and there are no predictions when it will be finished. But now, I think you need to find instructions on how to install ASP.NET 5 version RC1, and then everything will work fine.
                                  • neechN
                                    neechN
                                    neech
                                    @derwish ,
                                    This is the only instructions I have found for installing .net on linux:
                                    https://www.microsoft.com/net/core#debian
                                    Do you think this will work?
                                    neech
                                    • fahrettineF
                                      fahrettineF
                                      fahrettine
                                      Good news!!!
                                      When do you plan to lounch the new (Node.JS) version?
                                      • fahrettineF fahrettine
                                        Good news!!!
                                        derwishD
                                        derwishD
                                        derwish
                                        #26
                                        @fahrettine I halted the development, because now working on a commercial project. But I plan to continue to develop after two months. I think that in this case, the working version will be released by the end of the year.
                                        • neechN neech
                                          @derwish ,
                                          neech
                                          derwishD
                                          derwishD
                                          derwish
                                          @neech This instructions for the latest version of the framework. It's not compatible. Look for how to install the RC1 version.
