  3. bootloader
bootloader
bootloaderfirmwareotg
23 Posts 8 Posters 18.6k Views 10 Watching
  • M MarkV
    @tekka
    Goodmorning i've got a question:
    Isn't it possible to write a Boards.txt for al boards? or does someone have this allready.
    I tried to load the bootloader in a Arduino Uno (CH340 interface) but this didn't function.
    It would be nice to load it in:
    Arduino Mega 2560
    Arduino Uno (official)
    Arduino Uno (CH340) chinees clone
    Arduino mini
    Arduino nano
    Arduino micro
    etc.
    tekkaT
    tekkaT
    tekka
    @MarkV I'm not sure I understand your question - bootloaders are programmed via the ISP interface (e.g. USBasp or ArduinoISP as programmer), not via serial/usb interface.
    • tekkaT tekka
      MarkV
      @tekka
      Thanks for the replay.
      I ment i trying to load the boatloader into a arduino pro mini (clone) through a Arduino (as ISP) Mega 2560.
      When i try to upload the boatloader i'm getting this error:
      avrdude: Yikes!  Invalid device signature.
               this check.
      Fout bij het branden van de bootloader.
      What's wrong and what should i change?
      • dynamiteD
        dynamiteD
        dynamite
        wrote on last edited by dynamite
        @MarkV I had this message two days ago as well. I was programming with usbasp. I have solved it by powering my pro mini with a separate power supply. So please check the cables.
        • dynamiteD dynamite
          MarkV
          wrote on last edited by MarkV
          @dynamite
          Oh thanks, will do that. .
          But why does it giveel this message.. i wouldn't link this message to a failty powernapp supply..
          dynamiteD 1 Reply Last reply
          • M MarkV
            @dynamite
            dynamiteD
            dynamiteD
            dynamite
            @MarkV Dont't know, it helped in my case. Whether it was actually the power supply is the question. But if it helps in your case as well, than most probably yes. I think it has something to do with the communication and it reads a faulty or no signature.
              MarkV
              @dynamite
              tryed it and got a other error report:
              avrdude: Expected signature for ATmega328P is 1E 95 0F
                       Double check chip, or use -F to override this check.
              Verkeerde microcontroller gevonden. Hebt u het correcte board geselecteerd in het menu Hulpmiddelen > Board?
              What now?
              • M MarkV
                @dynamite
                What now?
                dynamiteD
                dynamiteD
                dynamite
                @MarkV This is exactly the message I have received as well... Maybe check the other connection. Replace some cables? I the end I have been able to eliminate this message without changing anything in the software. In my case it was hardware related. (I was programming a pro mini and had it with two seperate mini's)
                  MarkV
                  I've got it duss far.. Stupid me, i've forgot to change the reset pin from 10 to 53.
                  After that it says ready with uploading the bootloader..
                  Now i'm going to test it to see if it worked...
                  • Mayank RaichuraM
                    Mayank RaichuraM
                    Mayank Raichura
                    I'm trying to burn 16Mhz version but I get the following error at the end:
                    avrdude: verification error, first mismatch at byte 0x0000
                             0x3f != 0xff
                    Programmer: Usbasp
                    RedferneR 1 Reply Last reply
                    • Mayank RaichuraM Mayank Raichura
                               0x3f != 0xff
                      Programmer: Usbasp
                      RedferneR
                      RedferneR
                      Redferne
                      @Mayank-Raichura I had the same problem with usbasp. The fix was to remove the -D flag (disable auto erase) when running avrdude.
                      Mayank RaichuraM 1 Reply Last reply
                      • RedferneR Redferne
                        Mayank RaichuraM
                        Mayank RaichuraM
                        Mayank Raichura
                        @Redferne Thanks. I'll check it out.
