  3. bootloader
bootloader
bootloaderfirmwareotg
23 Posts 8 Posters 18.7k Views 10 Watching
    Mickey
    Thanks a lot...
    I already create a MYSController and GW + 2 NODES but your explanation made things much clearer especially the OTA part.
    Do you plan to publish MYSController source?
    and again I really appreciate the detailed step by step guide.
    • tekkaT tekka
      For completeness, here are the MYSBootloader instructions for OTA updates via MYSController:
      1. Load gw sketch and connect arduino either via serial or ethernet port. No special bootloader needed for that part (i.e. standard optiboot bootloader will do the job).
      2. Add these lines to the boards.txt file in your Arduino IDE installation folder (located somewhere like C:/Program Files/Arduino/hardware/arduino/avr)
        proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader
        proMYSBL16.upload.tool=avrdude
        proMYSBL16.upload.protocol=arduino
        proMYSBL16.upload.maximum_size=30720
        proMYSBL16.upload.maximum_data_size=2048
        proMYSBL16.upload.speed=115200
        proMYSBL16.bootloader.tool=avrdude
        proMYSBL16.bootloader.low_fuses=0xF7
        proMYSBL16.bootloader.high_fuses=0xDA
        proMYSBL16.bootloader.extended_fuses=0x06
        proMYSBL16.bootloader.unlock_bits=0x3F
        proMYSBL16.bootloader.lock_bits=0xFF
        proMYSBL16.bootloader.file=MySensors/MYSBootloader.hex
        proMYSBL16.build.mcu=atmega328p
        proMYSBL16.build.f_cpu=16000000L
        proMYSBL16.build.board=AVR_UNO
        proMYSBL16.build.core=arduino
        proMYSBL16.build.variant=standard
        ######## settings for 8Mhz internal clock
        proMYSBL8.upload.tool=avrdude
        proMYSBL8.upload.speed=57600
        proMYSBL8.bootloader.lock_bits=0xFF
        proMYSBL8.build.board=AVR_UNO
        proMYSBL8.build.core=arduino
      3. Copy MYSBootloader.hex (from MYSController/Bootloader folder) to the Arduino IDE installation folder C:/Program Files/Arduino/hardware/arduino/avr/bootloaders/MySensors/
      4. Restart Arduino IDE, choose under Tools | Board | ATmega328 external 16Mhz with MYSBootloader or Tools | Board | ATmega328 internal 8Mhz with MYSBootloader depending on your settings
      5. Connect USBasp to sensor node and select Tools | Burn Bootloader
      6. If everything worked well until here, you now have the MYSBootloader with the fuse settings from above burnt to your sensor node (16Mhz extXTAL or 8Mhz intRC, BOOTSZ 1024W, BOD 1V8).
      7. Please use the AVR fuse calculator to retrieve the individual fuse settings. If you need to change frequency, BOD or other settings, change the fuse settings based on the fuse calculator.
        Important: The MYSBootloader.hex file was compiled for 16Mhz oscillators but it should also work at 8Mhz. If you intend to go below 8Mhz, I highly recommend to compile the bootloader with adjusted frequency settings.
      8. Start MYSController, hit config and adjust settings (COM-Port & baud or IP address:port)
      9. Hit connect: Connection to gateway should be established (gateway answers with gateway ready message), the node should appear and request an ID & FW.
      10. Right-mouse click on that node, select assign FW, choose for example **TimeReporter ** (demo firmware included in the MYSController/Firmware folder). Then click reboot and wait until FW is uploaded and node boots.
      11. TimeReporter firmware reports every few seconds some values such as time, millis, and voltage.
      12. Custom firmware: compile your sketch and retrieve the generated .hex file (activate verbose mode in the Arduino IDE to get compiler messages and output path).
      13. Copy .hex file to MYSController/Firmware folder and edit firmware_config.csv file according to the existing lines.
      14. Hit Refresh Repo in MYSController and the newly copied firmware should appear in the Assign FW dropdown list, ready to be uploaded.
      Have fun :)
      Dheeraj
      @tekka
      thanks for providing the steps to upload the MSYbootloader..
      any idea why i'm getting following error in linking phase
      "avr-gcc" -Os -nostartfiles -Wl,-s -Wl,-static -Wl,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-section-start=.text=0x7800 -mmcu=atmega328p -o MYSBootloader.elf MYSBootloader.o -lm
      MYSBootloader.o: In function main': MYSBootloader.c:(.init9+0x288): undefined reference to __boot_page_erase_short'
      MYSBootloader.c:(.init9+0x2b8): undefined reference to __boot_page_fill_short' MYSBootloader.c:(.init9+0x2d6): undefined reference to __boot_page_write_short'
      MYSBootloader.c:(.init9+0x2e0): undefined reference to `__boot_rww_enable_short'
      collect2: error: ld returned 1 exit status
      make: *** [MYSBootloader.elf] Error 1
      not sure which library to include to resolve the issue.
      tekkaT 1 Reply Last reply
      • D Dheeraj
        @tekka
        tekkaT
        tekkaT
        tekka
        @Dheeraj These are the code and cycle-optimized versions of the standard boot.h library which can be found here.
        Alternatively, substitute these calls:
        __boot_page_erase_short() ==> boot_page_erase()
        __boot_page_fill_short() ==> boot_page_fill()
        __boot_rww_enable_short() ==> boot_rww_enable()
        • tekkaT tekka
          Have fun :)
          MarkV
          wrote on last edited by MarkV
          @tekka
          Goodmorning i've got a question:
          Isn't it possible to write a Boards.txt for al boards? or does someone have this allready.
          I tried to load the bootloader in a Arduino Uno (CH340 interface) but this didn't function.
          It would be nice to load it in:
          Arduino Mega 2560
          Arduino Uno (official)
          Arduino Uno (CH340) chinees clone
          Arduino mini
          Arduino nano
          Arduino micro
          etc.
          • M MarkV
            @tekka
            Arduino Mega 2560
            Arduino mini
            Arduino nano
            Arduino micro
            etc.
            tekkaT
            tekkaT
            tekka
            @MarkV I'm not sure I understand your question - bootloaders are programmed via the ISP interface (e.g. USBasp or ArduinoISP as programmer), not via serial/usb interface.
            • tekkaT tekka
              MarkV
              @tekka
              Thanks for the replay.
              I ment i trying to load the boatloader into a arduino pro mini (clone) through a Arduino (as ISP) Mega 2560.
              When i try to upload the boatloader i'm getting this error:
              avrdude: Yikes!  Invalid device signature.
                       this check.
              Fout bij het branden van de bootloader.
              What's wrong and what should i change?
              • dynamiteD
                dynamiteD
                dynamite
                wrote on last edited by dynamite
                @MarkV I had this message two days ago as well. I was programming with usbasp. I have solved it by powering my pro mini with a separate power supply. So please check the cables.
                • dynamiteD dynamite
                  MarkV
                  @dynamite
                  Oh thanks, will do that. .
                  But why does it giveel this message.. i wouldn't link this message to a failty powernapp supply..
                  dynamiteD 1 Reply Last reply
                  • M MarkV
                    @dynamite
                    dynamiteD
                    dynamiteD
                    dynamite
                    @MarkV Dont't know, it helped in my case. Whether it was actually the power supply is the question. But if it helps in your case as well, than most probably yes. I think it has something to do with the communication and it reads a faulty or no signature.
                      MarkV
                      @dynamite
                      tryed it and got a other error report:
                      avrdude: Expected signature for ATmega328P is 1E 95 0F
                               Double check chip, or use -F to override this check.
                      Verkeerde microcontroller gevonden. Hebt u het correcte board geselecteerd in het menu Hulpmiddelen > Board?
                      What now?
                      • M MarkV
                        @dynamite
                        What now?
                        dynamiteD
                        dynamiteD
                        dynamite
                        @MarkV This is exactly the message I have received as well... Maybe check the other connection. Replace some cables? I the end I have been able to eliminate this message without changing anything in the software. In my case it was hardware related. (I was programming a pro mini and had it with two seperate mini's)
                          MarkV
                          I've got it duss far.. Stupid me, i've forgot to change the reset pin from 10 to 53.
                          After that it says ready with uploading the bootloader..
                          Now i'm going to test it to see if it worked...
                          • Mayank RaichuraM
                            Mayank RaichuraM
                            Mayank Raichura
                            I'm trying to burn 16Mhz version but I get the following error at the end:
                            avrdude: verification error, first mismatch at byte 0x0000
                                     0x3f != 0xff
                            Programmer: Usbasp
                            RedferneR 1 Reply Last reply
                            • Mayank RaichuraM Mayank Raichura
                                       0x3f != 0xff
                              Programmer: Usbasp
                              RedferneR
                              RedferneR
                              Redferne
                              @Mayank-Raichura I had the same problem with usbasp. The fix was to remove the -D flag (disable auto erase) when running avrdude.
                              Mayank RaichuraM 1 Reply Last reply
                              • RedferneR Redferne
                                Mayank RaichuraM
                                Mayank RaichuraM
                                Mayank Raichura
                                @Redferne Thanks. I'll check it out.
