  3. How to connect USBASP to a bare atmega328p
6 Posts 5 Posters 4.2k Views 2 Watching
  • S Offline
    stoffej
    I have spend a long time trying to sort this out.
    But I getting more and more confused.
    I want to burn the bootloader to create this sensor.
    https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node
    I have
    • usbasp
    • a few ardunino uno
    • bare atmega328p
    • not enough knowledge in burning bootloaders =(
    But how do I connect the usbasp to a bare atmega328p without external crystal to burn the bootloader??
    Can I connect the usbasp to the arduino unos ICSP port?
    Like this
    And use this good guide mysensors burn bootloader
    • S Offline
      stoffej
      The ICSP connector that is nearest to the mega328 chip is the one I planning to use.
      • S Offline
        @stoffej - check this out: https://www.arduino.cc/en/Tutorial/ArduinoISP as well.
        Im not using the usbasp but a normal usb cable to my uno, then i use the uno as programmer.
        usbasp is a programmer itself and you cant use both.
        If you want to use the usbasp you need to connect the right pins from it to a breadboard where you have the atmega.
        Im sure there are more ways to do it.
        • F Offline
          F Offline
          FotoFieber
          You can run your code without a bootloader: Arduino IDE -> Sketch -> Upload Using a Programmer
          For programming optiboot and setting the fuses, I used https://github.com/WestfW/OptiLoader
          • E Offline
            E Offline
            ericvdb
            Just take out the Atmega328p from your Arduino Uno, put in a new Atmega328p, connect your USBASP and burn the bootloader.
            • S Offline
              and perhaps some parts of this howto can help you too. not the same bootloader but I use usbasp. Yes you need to use your icsp conenctor or the spi port + rst pins if you want.
              https://forum.mysensors.org/topic/3503/sensebender-dualoptiboot-ota-howto-in-mysensors/18
