  3. How to include the battery measurement?
12 Posts 3 Posters 5.5k Views 2 Watching
  • tlpeterT
    tlpeterT
    tlpeter
    I am trying to build a sensor with a DHT22 and for now on a solar panel and a battery.
    I want to see the battery level within Domoticz.
    I cannot seem to merge both the battery sketch and the DHT sketch together.
    Most of the times i get an error about a { being in a place where it should not belong.
    I think i lost it :smiley: and i am going mad soon.
    Also how to send the battery level to Domoticz? i tried the battery sketch alone and nothing happens.
    • tlpeterT tlpeter
      sundberg84S
      sundberg84S
      @tlpeter
      Its easier for us if you post the code so we can have a look if you want help :)
      Well, before 2.0 it was gw.sendBatteryLevel(batteryPcnt); and now it is sendBatteryLevel(batteryPcnt);
      The battery% needs to be attached to a sensor - so it will be displayed in the deviced tab if you look at the device/sensor.
      • tlpeterT
        tlpeterT
        tlpeter
        sendBatteryLevel doesn't do anything.
        I have modified it a bit and now i have some readings.
        I will do a bit more playing to see where i will end.
        • tlpeterT tlpeter
          sundberg84S
          sundberg84S
          @tlpeter - it does, but it needs to be together with a sensor. You will find it in "devices".
          • sundberg84S
            sundberg84S
            • tlpeterT
              tlpeterT
              tlpeter
              wrote on last edited by tlpeter
              I have voltage now (utility) and a percentage under devices.
              I have read somewhere that the percentage is depending on the last sensors poll so i will now try to add the DHT part in to the sketch.
              • tlpeterT
                tlpeterT
                tlpeter
                I have the voltage part working and i think also the battery percentage with it.
                I build the sketch like this. Can you have a little look?
                #define CHILD_ID_BATT 0
                #define CHILD_ID_HUM 1
                #define CHILD_ID_TEMP 2
                #define DHT_DATA_PIN 3 // Set this to the pin you connected the DHT's data pin to
                #define SENSOR_TEMP_OFFSET 0
                static const uint64_t UPDATE_INTERVAL = 30000;
                //unsigned long SLEEP_TIME = 9000;  // sleep time between reads (seconds * 1000 milliseconds)
                int oldBatteryPcnt = 0;
                float lastTemp;
                float lastHum;
                uint8_t nNoUpdatesTemp;
                uint8_t nNoUpdatesHum;
                boolean metric = true;
                MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
                DHT dht;
                   analogReference(INTERNAL1V1);
                   analogReference(INTERNAL);
                   sendSketchInfo("Battery Meter", "1.0");
                   present(CHILD_ID_BATT, S_MULTIMETER);
                   wait(20);
                   present(CHILD_ID_HUM, S_HUM);
                   wait(20);
                   wait(20);
                   // get the battery Voltage
                   #ifdef MY_DEBUG
                   Serial.println(sensorValue);
                   #ifdef MY_DEBUG
                   Serial.print(batteryV);
                   Serial.println(" V");
                   Serial.print(batteryPcnt);
                   Serial.println(" %");
                     // Power up radio after sleep
                     send(msgBatt.set(batteryV, 1));
                    //sendBatteryLevel(batteryPcnt);
                     oldBatteryPcnt = batteryPcnt;
                  dht.readSensor(true);
                  if (isnan(temperature)) {
                    lastTemp = temperature;
                    if (!metric) {
                    // Reset no updates counter
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                    Serial.print("T: ");
                    nNoUpdatesTemp++;
                  if (isnan(humidity)) {
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                    Serial.print("H: ");
                    Serial.println(humidity);
                    nNoUpdatesHum++;
                   //sleep(SLEEP_TIME);
                   sleep(UPDATE_INTERVAL);
                • tlpeterT tlpeter
                  float lastTemp;
                  float lastHum;
                  DHT dht;
                     wait(20);
                     wait(20);
                     wait(20);
                     #ifdef MY_DEBUG
                     #ifdef MY_DEBUG
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesHum++;
                  sundberg84S
                  sundberg84S
                  @tlpeter - Im not a coding guy, but it looks good to me.
                  Myself i build my sketches, test and look at serial output and Domoticz output. When im happy with the result - i go for it.
                  This is going to create two devices i think, one humidity/temp and one voltage. The batterypct and voltage will be seperated from humidity/temp i think even if they belong together. If you want the procentage in devices for the right device you just skip the voltage part.
                  • tlpeterT
                    tlpeterT
                    tlpeter
                    I have voltage now and a percentage at the devices.
                    Hum and temp do work fine.
                    I only sucked all the juice out of the battery so it is charging now by the little solar panel.
                    I found out that 2,4V was really the lowest voltage that worked :smile:
                    • tlpeterT tlpeter
                      sundberg84S
                      sundberg84S
                      @tlpeter If you want to suck more juice out of the batteries use a DC-DC step up booster: https://www.mysensors.org/store/#regulators then you can go down to 0.9V :)
                      • tlpeterT
                        tlpeterT
                        tlpeter
                        I will buy one later :smile:
                        This is just to play with as i wanted to know how the battery measurement works.
                        • clio75C
                          clio75C
                          clio75
                          Hi, This part should not have been updated
                          this part is icluded in the lib
                          So leave it like the exsample
                          For sending over your voltage you need one additional
                          Good luck
