  3. My Ethernet Gateway with custom case.
6 Posts 4 Posters 4.6k Views 1 Watching
  • J
    J
    jribera
    Hi All,
    Thought i would share my Ethernet Gateway in a custom case.
    The board is a itead iboard http://imall.iteadstudio.com/im120410001.html since i mounted this one in a case no modifications were needed to the board to connect the radio module.
    The case is actually a modified HP MSM320 wireless access point http://www.zdtronic.com/images/MSM325.jpg which i cut down and sprayed black. As luck would have it the Ethernet + Power line up perfectly with the existing holes. There were even 3 existing holes which i simply had to drill out to for the larger LEDs.
    So far i have tried the serial gateway based on a Nano & a Ethernet Gateway with a ENC28J60 and this is by far the most reliable solution.
    RJ_MakeR 1 Reply Last reply
    • HomerH
      HomerH
      Homer
      Nice work!
      • J jribera
        Hi All,
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @jribera
        Nice indeed.
        RJ_Make
        • J
          J
          jribera
          Thanks for the feedback !
          Forgot to mention if your from Australia and looking for relatively cheap local itead supplier i can recommend http://www.monkeyboard.org/shop/
          Prices are more expensive but they can deliver in 1-2 days.
          • H
            H
            hugob
            Nice project. I am am interested in two things:
            • I want to use the same board. Can you tell what modifications you did to the gateway software to get this working. I guess you are using the analog inputs on the board configured as digital outputs to drive the leds.
            • The case is nice, but it is on sale for $270 (with a HP wireless access point inside).. How did you get the case?
            • J
              J
              jribera
              All the info is here http://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/3
              There are enough digital pins to drive the 3 leds.
              As for the case i just happened to have a box of them from an old wireless upgrade project. at work. Maybe check ebay for some non working/old ones ?
