  3. MG812(Co2) Sensor ppm calculation
6 Posts 2 Posters 5.2k Views 3 Watching
  • Mahendra SondagarM Offline
    Mahendra Sondagar
    wrote on last edited by Mahendra Sondagar
    Hello Folks,
    This one is my first post here :)
    from few day I'm playing with MG812 Co2 sensor let me tell you that the sensor is quite similar with famous MG811 Co2 sensor but instead of high voltage(6V) it uses** 5V**.
    both sensor produced EMF in mV at the output w.r.t Co2 concatenation when Co2 concentration rises output falls.
    here is the datasheet for MG812 sensor
    0_1473162025895_MG812 CO2 Manual V1.1.pdf
    I've taken MG811 as a reference for ppm calculation
    here is the link for the firmware from DFrobot
    link text
    I've use this code with my sensor when i play it my arduino shows, **Under heating/beyond range(400~10,000)
    that's why I've decides to display it's o\p EMF,
    my problem is when i make simple code to to read it's sample voltage then sensor's o\p voltage is not same as suggested in datasheet(250-330mV)
    here is my pin config got the Sensor
    pin connection
    1(Heater1) ---------> +5V
    3(Heater2) ----------> GND
    2(TE1) ----------> GNG
    3(TE2) ----------> Arduino(A0)
    here is my o\p on Arduino terminal
    MG812 Co2 sensor Interfacing...
    Samplse: 23
    Volts: 0.11
    mV: 112.3046875000
    Samplse: 15
    Volts: 0.07
    mV: 73.2421875000
    Samplse: 21
    Volts: 0.10
    mV: 102.5390625000
    Samplse: 16
    Volts: 0.08
    mV: 78.1250000000
    Samplse: 18
    Volts: 0.09
    mV: 87.8906250000
    Samplse: 19
    Volts: 0.09
    mV: 92.7734375000
    Samplse: 15
    Volts: 0.07
    mV: 73.2421875000
    Samplse: 22
    Volts: 0.11
    mV: 107.4218750000
    Samplse: 16
    Volts: 0.08
    mV: 78.1250000000
    Samplse: 19
    Volts: 0.09
    mV: 92.7734375000
    Samplse: 19
    Volts: 0.09
    mV: 92.7734375000
    Samplse: 17
    Volts: 0.08
    mV: 83.0078125000
    Samplse: 20
    Volts: 0.10
    mV: 97.6562500000
    Samplse: 15
    Volts: 0.07
    mV: 73.2421875000
    Guys can any one help me here
    I'll appreciate all precious comments and suggestions :)
    Y 1 Reply Last reply
    • Mahendra SondagarM Mahendra Sondagar
      Hello Folks,
      link text
      pin connection
      Samplse: 23
      Volts: 0.11
      mV: 112.3046875000
      Samplse: 15
      Volts: 0.07
      mV: 73.2421875000
      Samplse: 21
      Volts: 0.10
      mV: 102.5390625000
      Samplse: 16
      Volts: 0.08
      mV: 78.1250000000
      Samplse: 18
      Volts: 0.09
      mV: 87.8906250000
      Samplse: 19
      Volts: 0.09
      mV: 92.7734375000
      Samplse: 15
      Volts: 0.07
      mV: 73.2421875000
      Samplse: 22
      Volts: 0.11
      mV: 107.4218750000
      Samplse: 16
      Volts: 0.08
      mV: 78.1250000000
      Samplse: 19
      Volts: 0.09
      mV: 92.7734375000
      Samplse: 19
      Volts: 0.09
      mV: 92.7734375000
      Samplse: 17
      Volts: 0.08
      mV: 83.0078125000
      Samplse: 20
      Volts: 0.10
      mV: 97.6562500000
      Samplse: 15
      Volts: 0.07
      mV: 73.2421875000
      Y Offline
      Y Offline
      @Mahendra-Sondagar welcome to the forum!
      Did you check with a multimeter if the voltages are the same as the arduino reports?
        Mahendra Sondagar
        yes, Yveaux
        I've check through multimeter before
          yes, Yveaux
          Y Offline
          Y Offline
          @Mahendra-Sondagar then most likely it is an issue with your code to read out the ads. Please share your code it with us.
          Mahendra SondagarM 2 Replies Last reply
          • Y Yveaux
            Mahendra Sondagar
            @Yveaux
            The code is straight foreword it simply reads ADC's channel and convert in to voltage
            Insert Code Here
            #include <Arduino.h>
            void Setup(){
            Serial.begin(9600);
            Serial.println("MG812 Co2 ppm calculation...");
            delay(1000);
            void loop(){
            uint16_t  samplse= analogRead(0);
            Serial.print("Samplse: ");
            Serial.println(samplse);
            float volts=((5.0*samplse)/1024);
            Serial.print("Volts: ");
            Serial.println(volts);
            float mv=(volts*1000);
            Serial.print("mV: ");
            Serial.println(mv);
            delay(2000);
            • Y Yveaux
              Mahendra Sondagar
              @Yveaux
              Have you read datasheet here...
              At the o\p side they mention unity gain amplifier with OpAmp
              but the thing is that unity gain amplifier always produced same output volts!
              12.1k
