  3. Send fake data to FHEM without transmitter
13 Posts 2 Posters 5.5k Views 2 Watching
    A Former User
    Hello.
    I want use the serial gateway...but i don´t want to use the NRF24 at this moment.
    I only want to know the data format send via USB.
    So the data format is:
    node-id;child-sensor-id;message-type;ack;sub-type;payload\n
    but i want send this by myself with an arduino sketch.
    I think i can send this data via serialprint ?
      You don't need to activate any radio for the gateway.
        A Former User
        Ok, thanks.
        In the gateway i can disable radio.
        But i get an error in the log of FHEM
        MYSENSORS: ignoring set-msg from unknown radioId 0, childId 0 for V_LEVEL
        Can i set the radio ID by myself ?
          Like I said earlier, do you have the latest MySensors version from the development branch installed?
            A Former User
            wrote on last edited by [[global:former-user]]
            I delete the library and copy the developer library to the the arduino folder.
            In serial monitor see this
            0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.0.1-beta
            0;255;0;0;17;2.0.1-beta
            0;255;3;0;11;Dust Sensor
            0;255;3;0;12;1.1
            0;1;0;0;24;
            0;255;3;0;9;MCO:BGN:STP
            0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
            Raw Signal Value (0-1023): 388 - Voltage: 1.89 - Dust Density: 222.07
            0;1;1;0;37;223
            Raw Signal Value (0-1023): 241 - Voltage: 1.18 - Dust Density: 100.05
            0;1;1;0;37;101
            FHEM show me
            2016.09.14 19:14:06 3: Setting MYS_GW serial parameters to 115200,8,N,1
            2016.09.14 19:14:06 5: MYSENSORS send: Rx: fr=000 ci=000 c=003(C_INTERNAL    ) st=002(I_VERSION       ) ack=0 ''
            2016.09.14 19:14:06 5: SW: 303b303b333b303b323b0a
            2016.09.14 19:14:06 1: /dev/ttyUSB0 reappeared (MYS_GW)
            2016.09.14 19:14:07 5: MYSENSORS/RAW: /0;255;3;0;9;MCO:BGN:INIT GW,CP=R
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;255;3;0;9;MCO:BGN:INIT GW,CP=R/-NGA--,VER=2.0.1-beta
            0;255;3;0;
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=009(I_LOG_MESSAGE   ) ack=0 'MCO:BGN:INIT GW,CP=R-NGA--,VER=2.0.1-beta'
            2016.09.14 19:14:07 5: MYSENSORS gateway MYS_GW: MCO:BGN:INIT GW,CP=R-NGA--,VER=2.0.1-beta
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;255;3;0;/14;Gateway startup complete.
            0;2
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=014(I_GATEWAY_READY ) ack=0 'Gateway startup complete.'
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;2/55;0;0;17;2.0.1-beta
            0;255;3;0;1
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=000(C_PRESENTATION) st=017(S_ARDUINO_NODE  ) ack=0 '2.0.1-beta'
            2016.09.14 19:14:07 3: MYSENSORS: ignoring presentation-msg from unknown radioId 0, childId 255, sensorType 17
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;255;3;0;1/1;Dust Sensor
            0;255;3;0;12;1.1
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=011(I_SKETCH_NAME   ) ack=0 'Dust Sensor'
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=012(I_SKETCH_VERSION) ack=0 '1.1'
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0/;0;0;0;24;
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=000 c=000(C_PRESENTATION) st=024(S_DUST          ) ack=0 ''
            2016.09.14 19:14:07 3: MYSENSORS: ignoring presentation-msg from unknown radioId 0, childId 0, sensorType 24
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;255;3;0;9;MCO:REG:N/OT NEEDED
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=009(I_LOG_MESSAGE   ) ack=0 'MCO:REG:NOT NEEDED'
            2016.09.14 19:14:07 5: MYSENSORS gateway MYS_GW: MCO:REG:NOT NEEDED
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;255;3;0;9;MCO:BGN:ST/P
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=009(I_LOG_MESSAGE   ) ack=0 'MCO:BGN:STP'
            2016.09.14 19:14:07 5: MYSENSORS gateway MYS_GW: MCO:BGN:STP
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;255;3;0;9;MCO:BGN:INIT OK,ID/=0,PAR=0,DIS=0,REG=1
            Raw Signal
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=255 c=003(C_INTERNAL    ) st=009(I_LOG_MESSAGE   ) ack=0 'MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1'
            2016.09.14 19:14:07 5: MYSENSORS gateway MYS_GW: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
            2016.09.14 19:14:07 5: MYSENSORS/RAW: Raw Signal /Value (0-1023): 1023 - Voltage:
            2016.09.14 19:14:07 5: MYSENSORS/RAW: Raw Signal Value (0-1023): 1023 - Voltage: /5.00 - Dust Density: 749.17
            0;0
            2016.09.14 19:14:07 5: MYSENSORS Read: Raw Signal Value (0-1023): 1023 - Voltage: 5.00 - Dust Density: 749.17is no parsable mysensors message
            2016.09.14 19:14:07 5: MYSENSORS/RAW: 0;0/;1;0;37;750
            2016.09.14 19:14:07 5: MYSENSORS Read: Rx: fr=000 ci=000 c=001(C_SET         ) st=037(V_LEVEL         ) ack=0 '750'
            2016.09.14 19:14:07 3: MYSENSORS: ignoring set-msg from unknown radioId 0, childId 0 for V_LEVEL
            EDIT: I only put something in the code to let write some data.
            There was no example with temperature or somthing simple, so i use the dust example.
              Hmm. Wonder why about this message "ignoring presentation-msg from unknown radioId".
              I know too little about FHEM to answer you unfortunately.
                A Former User
                The serial output is ok ?
                Can i define a ID by myself ?
                  No, a gateway always get id=0
                    A Former User
                    Ok, the gateway, but i want to simulate an sensor...or is there no way to do this ?
                      Not without hacking this line: https://github.com/mysensors/MySensors/blob/development/core/MySensorsCore.h#L70
                        A Former User
                        Ok, thanks for your help.
                        I will stop here now.
