  3. My New IrrigationController
23 Posts 6 Posters 12.8k Views 10 Watching
  • epierreE epierre
    check ospi they have published their BOM
    marekdM
    marekdM
    marekd
    @epierre
    power supply unit with LM2596 is rather complicated to build and needs parts which I don't have. I could, of course, buy step down module for around 1-2$. Maybe I'll come back to this solution after this watering season - now is is to late for this. Thanks anyway!
    • marekdM
      marekdM
      marekd
      Finally I launched my Irrigation System, there are some small bugs in the code, but can live with it - for now. Have plans how to rebuild this in winter time to be more robust and to look better.
      Runs under Domoticz and manually with keypad.
      For now it looks like this:
      • epierreE epierre
        marekdM
        marekdM
        marekd
        @epierre
        Started to play with LM2596, I've got sth. like this:
        http://www.ebay.com/itm/1pcs-1-23V-30V-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-/400985220074?hash=item5d5c94e3ea:g:o10AAOxy0x1TVSpD
        Added diode bridge between transformer and this converter. But my concern is that I've some big voltage peaks the the output of it. It happens when I'm opening/closing valves (AC solenoids) connected to this transformer.
        Set this converter to 12V DC but my readings are sometimes around 20V DC and I am affraid that I could destroy by Arduino.
        Do you (anyone) have any suggestion ?
        • gbgent_ncG
          gbgent_ncG
          gbgent_nc
          @marekd
          Just wondering, could you not set your zones up as an array. This would reduce the size a little and should also free up memory for variables.
          marekdM 1 Reply Last reply
          • gbgent_ncG gbgent_nc
            @marekd
            marekdM
            marekdM
            marekd
            @gbgent_nc
            Yes I could and did already because have to use ProMini [my MEGA2560 was killed ;) ].
            Anyway plan is now to use 2xProMini., one for LCD, Keyboard, relays and second for temperature x2, water meter, rain sensor and relay for pump.
            • fetsF
              fetsF
              fets
              @marekd could you give us a link to your walves.
              • fetsF fets
                marekdM
                marekdM
                marekd
                @fets
                Manufacturer is RAIN S.p.a Italy, www.rain.it.
                Model I use is RN150.
                Got them from Leroy Merlin, price was around 11 EUR.
                fetsF 1 Reply Last reply
                • marekdM marekd
                  @fets
                  fetsF
                  fetsF
                  fets
                  @marekd thanks
                  • marekdM marekd
                    Last summer during vacation, was quite hot at my place. My green grass in the garden became ... brown and yellow - there was nobody to irrigate and was no rain, of course!
                    So I made a decision to buy irrigation controller and all that stuff. I wanted to have 7-8 zones, BT or wireless control, temperature and rain based control, RTC, Keypad, etc. The problem was that nobody had it or was to expencive.
                    So long story short I came up with idea to build one with all those features i need. Without having experience with uC I start to learn (google and youtube) a bit and build some "prototypes". Than IrrigatonController ver 1.0 was ready (December 2015):0_1462825721811_1.jpg
                    Than I found @petewill IrrigationControler at youtube - but it was to hard for me from software (all this MySensors) and hardware side - I thought!
                    So I built new one - well it is almost done.
                    It is tested and working, few things are still missing like running without HA controller and rain sensor. Anyway I post some pictures and script what I've done. At my place it is working under Domoticz and manual (keypad). Tomorrow final wiring!
                    0_1462826941290_IMG_20160509_203348.jpg .
                    Any comments are more than welcome, know that script need some more work - but it is just a beginning.
                     * based on Version 1.0 - Henrik Ekblad
                     * Version 2.0 - Marek Dajnowicz
                     * Example sketch showing how to control physical relays.
                     * http://www.mysensors.org/build/relay
                    #define MY_RF24_CE_PIN A8 // żółty 51
                    #define MY_RF24_CS_PIN A9 // pomarańczowy 53
                    #define MY_NODE_ID 66
                    #define MY_REPEATER_FEATURE
                    #include <Time.h>
                    #include <LiquidCrystal.h>
                    #include <OneWire.h>
                    #include <DS3232RTC.h>  // A  DS3231/DS3232 library
                    #include <Keypad_I2C.h> // Klawiatura na I2c
                    #include <Keypad.h> // klawiatura
                    #define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    #define NUMBER_OF_RELAYS 8 // Total number of attached relays
                    #define ONE_WIRE_BUS 22 // Pin where dallase sensor is connected MEGA256
                    #define TEMPERATURE_PRECISION 12
                    #define CHILD_ID_SPRINKLER1 1
                    #define CHILD_ID_SPRINKLER2 2
                    #define CHILD_ID_SPRINKLER3 3
                    #define CHILD_ID_SPRINKLER4 4
                    #define CHILD_ID_SPRINKLER5 5
                    #define CHILD_ID_SPRINKLER6 6
                    #define CHILD_ID_SPRINKLER7 7
                    #define CHILD_ID_PUMP 10
                    #define CHILD_ID_TEMP 11
                    #define CHILD_ID_TEMP2 12
                    boolean timeReceived = false;
                    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                    DeviceAddress addrT1 = { 0x28, 0xFF, 0x9F, 0x80, 0x93, 0x15, 0x04, 0xF7 }; //DS18 Dallas temp.
                    float T1;
                    int numSensors = 0;
                    MyMessage msgValve1(CHILD_ID_SPRINKLER1, V_LIGHT);
                    MyMessage msgValve2(CHILD_ID_SPRINKLER2, V_LIGHT);
                    MyMessage msgValve3(CHILD_ID_SPRINKLER3, V_LIGHT);
                    MyMessage msgValve4(CHILD_ID_SPRINKLER4, V_LIGHT);
                    MyMessage msgValve5(CHILD_ID_SPRINKLER5, V_LIGHT);
                    MyMessage msgValve6(CHILD_ID_SPRINKLER6, V_LIGHT);
                    MyMessage msgValve7(CHILD_ID_SPRINKLER7, V_LIGHT);
                    MyMessage msgPump(CHILD_ID_PUMP, V_LIGHT);
                    MyMessage msgT1(CHILD_ID_TEMP, V_TEMP);
                    MyMessage msgT2(CHILD_ID_TEMP2, V_TEMP);
                    /**** Kepad settings */
                    const byte ROWS = 4;
                    const byte COLS = 4;
                    char keys[ROWS][COLS] = {
                      {'1', '2', '3', 'A'},
                      {'4', '5', '6', 'B'},
                      {'7', '8', '9', 'C'},
                      {'*', '0', '#', 'D'}
                    byte rowPins[ROWS] = {47, 45, 43, 41};
                    byte colPins[COLS] = {39, 37, 35, 33};
                    int i2caddress = 0x20;
                    Keypad_I2C kpd = Keypad_I2C( makeKeymap(keys), rowPins, colPins, ROWS, COLS, i2caddress );
                    bool state;
                    // system messages
                    const char *string_table[] =
                      "     WELCOME! =)", 			// 0
                      "DOMOTICZ TIME", 				// 1
                      "WATERING",  					// 2
                      "    SYSTEM CHECK  ",			// 3
                      "  STARTING UP THE",			// 4
                      "  WATERING SYSTEM", 			// 5
                      "    Popmp is ON ", 		    // 6
                      "      MySensors",		   	// 7
                      "   Watering System",	      	// 8
                      "   Please wait !!"	        // 9
                    const char *string_table2[] = {
                      "Strefa 1", "Strefa 2", "Strefa 3", "Strefa 4", "Strefa 5", "Strefa 6", "Strefa 7", "Pompa zasilająca" // ZONE 1...2...
                    const unsigned long tUpdate = 60000; // update interval for temp sensors
                    unsigned long t0;
                      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++)
                        pinMode(pin, OUTPUT); // Then set relay pins in output mode
                        digitalWrite(pin, RELAY_OFF); // set all relays OFF
                        saveState(sensor, state); // save data at startup.
                      requestTime();
                      kpd.begin();  //keypad
                      sensors.begin(); //dallas temp
                      sensors.setResolution(addrT1, TEMPERATURE_PRECISION);
                      lcd.begin(20, 4); //(20 characters and 4 line display)
                      lcd.clear();
                      lcd.backlight();
                      lcd.createChar(0, clock);
                      lcd.createChar(1, raindrop);
                      lcd.home();
                      lcd.print(string_table[4]);
                      lcd.setCursor(0, 1);
                      lcd.print(string_table[5]);
                      lcd.setCursor(0, 3);
                      lcd.print(string_table[7]);
                      delay(3000);
                      for (int i = 0; i < 20; i++) {
                        delay(100);
                        lcd.scrollDisplayLeft();
                      lcd.clear();
                      lcd.home();
                      lcd.print(string_table[0]);
                      lcd.print(string_table[3]);
                      (lcd.setCursor(0, 3));
                      for (int M = 1; M >= 0; M--) // countdown
                        lcd.setCursor(10, 3);
                        lcd.print(M);
                        delay(1000);
                      lcd.clear();
                      lcd.home ();
                      requestTime();
                      ServerUpdate();
                      sendSketchInfo("Watering", "2.0");
                      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                        present(sensor, S_LIGHT, string_table2[sensor - 1]); // use CHILD ID names from table
                      present(CHILD_ID_TEMP, S_TEMP,"Dallas");
                      present(CHILD_ID_TEMP2, S_TEMP,"RTC Temp");
                      domoticztime(); // to PRINT the time from conroller
                      keypad(); // READING KEYPAD
                      if ((millis() - t0) > tUpdate) ServerUpdate();
                    void ServerUpdate()
                      T1 = sensors.getTempC(addrT1);
                      send(msgT1.set(T1 , 1));
                      int t= RTC.temperature()/4;
                      send(msgT2.set(t,2));
                      lcd.setCursor(11, 2);
                      lcd.print("T:");
                      lcd.print(T1);
                      lcd.print(char(223));
                      lcd.print("C");
                      lcd.setCursor(11, 3);
                      lcd.print("T:");
                      lcd.print(t);
                      lcd.print("C");
                      t0 = millis();
                    void domoticztime()
                      lcd.home();
                      lcd.setCursor(0, 2);
                     // lcd.print(string_table[1]);
                      //lcd.setCursor(2, 2);
                      lcd.write(byte(0));
                      lcd.setCursor(1, 2);
                      lcd.print(hour());
                      lcd.print(":");
                      int min = minute();
                      if (min < 10) lcd.print("0");
                      lcd.print(minute());
                      lcd.print(":");
                      lcd.print(second());
                      lcd.print(day());
                      lcd.print("/");
                      lcd.print(month());
                      lcd.print("/");
                      lcd.print(year());
                    void keypad()
                      char key = kpd.getKey(); delay(50);
                      if (key == '*') ALL_OFF();
                      if (key == '#') WRONG();
                      if (key == '1') ZONE_1();
                      if (key == '2') ZONE_2();
                      if (key == '3') ZONE_3();
                      if (key == '4') ZONE_4();
                      if (key == '5') ZONE_5();
                      if (key == '6') ZONE_6();
                      if (key == '7') ZONE_7();
                      if (key == '8') WRONG();
                      if (key == '9') WRONG();
                      if (key == '0') WRONG();
                      if (key == 'D') DEBUG();
                    void DEBUG()
                    {for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++)
                        state = loadState(sensor);
                        Serial.print("sensor: ");
                        Serial.print(sensor);
                        Serial.print("  /  stan:  ");
                        Serial.println(state);
                    void ALL_OFF()// TURNING ALL ZONES OFF @ ONE KEY PRESSED
                      lcd.clear();
                      lcd.print(" TURN ALL ZONES OFF");
                      Serial.println(" turn ALL OFF");
                      send(msgValve1.set(0) );delay(100);
                      send(msgValve2.set(0) );delay(100);
                      send(msgValve3.set(0) );delay(100);
                      send(msgValve4.set(0) );delay(100);
                      send(msgValve5.set(0) );delay(100);
                      send(msgValve6.set(0) );delay(100);
                      send(msgValve7.set(0) );
                      send(msgValve1.set(0), true); delay(100);
                      send(msgValve2.set(0), true);delay(100);
                      send(msgValve3.set(0), true);delay(100);
                      send(msgValve4.set(0), true);delay(100);
                      send(msgValve5.set(0), true);delay(100);
                      send(msgValve6.set(0), true);delay(100);
                      send(msgValve7.set(0), true);
                      DEBUG();
                      delay(1500);
                      lcd.clear();
                    void ZONE_1()
                    { // zone 1, pin 2
                      byte pin=RELAY_1;
                      state = loadState(CHILD_ID_SPRINKLER1);
                      digitalWrite(pin, state ? RELAY_ON : RELAY_OFF);
                      saveState(CHILD_ID_SPRINKLER1, state);
                      if (state == 1)
                        lcd.print(" ");
                      send(msgValve1.set(state ? false : true), true);
                    void ZONE_2()
                      byte pin=RELAY_1+1;
                      state = loadState(CHILD_ID_SPRINKLER2);
                      saveState(CHILD_ID_SPRINKLER2, state);
                     if (state == 1)
                        lcd.setCursor(1, 1);
                        lcd.print(" ");
                      send(msgValve2.set(state ? false : true), true);
                    void ZONE_3()
                    byte pin=RELAY_1+2;
                      state = loadState(CHILD_ID_SPRINKLER3);
                      saveState(CHILD_ID_SPRINKLER3, state);
                      if (state == 1)
                        lcd.setCursor(2, 1);
                        lcd.print(" ");
                      send(msgValve3.set(state ? false : true), true);
                    void ZONE_4()
                    byte pin=RELAY_1+3;
                      state = loadState(CHILD_ID_SPRINKLER4);
                      saveState(CHILD_ID_SPRINKLER4, state);
                      if (state == 1)
                        lcd.setCursor(3, 1);
                        lcd.print(" ");
                      send(msgValve4.set(state ? false : true), true);
                    void ZONE_5()
                    byte pin=RELAY_1+4;
                      state = loadState(CHILD_ID_SPRINKLER5);
                      saveState(CHILD_ID_SPRINKLER5, state);
                      if (state == 1)
                        lcd.setCursor(4, 1);
                        lcd.print(" ");
                      send(msgValve5.set(state ? false : true), true);
                    void ZONE_6()
                    byte pin=RELAY_1+5;
                      state = loadState(CHILD_ID_SPRINKLER6);
                      saveState(CHILD_ID_SPRINKLER6, state);
                      if (state == 1)
                        lcd.setCursor(5, 1);
                        lcd.print(" ");
                      send(msgValve6.set(state ? false : true), true);
                    void ZONE_7()
                    byte pin=RELAY_1+6;
                      state = loadState(CHILD_ID_SPRINKLER7);
                      saveState(CHILD_ID_SPRINKLER7, state);
                      if (state == 1)
                        lcd.setCursor(6, 1);
                        lcd.print(" ");
                      send(msgValve7.set(state ? false : true), true);
                    void WRONG() {}
                      byte zone;
                      if (message.isAck()) {
                        // Change relay state
                        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
                        zone = message.sensor; // less typing :)
                        // Store state in eeprom
                        // representing active zones at LCD
                        if (message.getBool() == RELAY_ON) // checking new state of relay
                          Serial.print("Watering ZONE: "); Serial.println(zone);
                          lcd.setCursor(0, 0);
                          lcd.print("Watering ZONE: ");
                          lcd.setCursor(zone - 1, 1);
                          lcd.print(zone);
                        if (message.getBool() == RELAY_OFF) // checking new state of relay
                          lcd.print(" ");
                        Serial.print("Incoming change for ZONE:");
                    Regards
                    karl261K
                    karl261K
                    karl261
                    @marekd Great controller! For the keypad: I see from the code that you use the I2C code. How did you connect your keypad? Did you use a I2C extension chip? And, which keypad_i2c library do you use? I found multiple on the net.
                    • karl261K karl261
                      marekdM
                      marekdM
                      marekd
                      @karl261
                      in case I2C yes, and no.
                      with 1st generation [with 1 ProMini] I used I2C port expander PCF8574.
                      with 2nd generation [with MEGA2560] just pins, 8 pins, declared like this:
                      /**** Kepad settings /
                      ', '0', '#', 'D'}
                      with 3rd generation - plan to have 2nd ProMini with PCF expander.
                      attached library I use.
                      0_1474294070076_Keypad_I2C.zip
                      and some pictures of generation 3, which is under construct :)
                      Power supply:
                      and control box with 2 ProMinis:
                      karl261K 1 Reply Last reply
                      • marekdM marekd
                        @karl261
                        ', '0', '#', 'D'}
                        Power supply:
                        karl261K
                        karl261K
                        karl261
                        @marekd Thanks for the detailed reply. What the monster capacitor for in gen 3?
                        I plan to build my keypad with one pro mini and the PCF8574. Like your gen 1 & 3. How did / are you planning to wire the PCF8574? It seems rather straight forward according to this:
                        https://www.hackster.io/venkatesh_rao/i2c-keypad-73a012
                        Is this the wiring you are using? Or is it different?
                        Since I am building a battery keypad, I was also planning to use the interrupt line of the PCF8574.
                        • karl261K karl261
                          marekdM
                          marekdM
                          marekd
                          @karl261
                          Capacitor is not so big ;) generally helps.
                          I my wiring there is no pull-up resistors at I2C lines. Rest is the same.
