  3. My New IrrigationController
23 Posts 6 Posters 12.8k Views 10 Watching
  • marekdM marekd
    @m26872
    You can squeeze, but I wanted to have more options and not to be limited by memory - anyway at this stage of developing. Because normally you have only one sprinkler controller you can use better uC - I did this way. Playing with more advance programming for memory optimization - is not for me (at this stage of my knowledge) - but thanks for this hint , I might use it in future.
    I was reading your post about 2AA battery node... this is my let's say next step to make.
    epierreE
    epierreE
    epierre
    @marekd said:
    @m26872
    on the OsPi hardware, both Arduino/PI (depending on installation) are powered from 24V AC for the sprinkler valves
    z-wave - Vera -> Domoticz
    marekdM 1 Reply Last reply
    • epierreE epierre
      @marekd said:
      @m26872
      marekdM
      marekdM
      marekd
      @epierre
      could you explain? I did't understand our thoughts.
      • epierreE
        epierreE
        epierre
        @mareked you could power everything only from the 24V AC as they do !
        marekdM 2 Replies Last reply
        • epierreE epierre
          marekdM
          marekdM
          marekd
          @epierre I never thought about it - but you are right! Got some LM7805 and Graetz bride (or 1N4004's)... must think about. I could save some space and additional power supply.
          Thank YOU!
          • epierreE epierre
            marekdM
            marekdM
            marekd
            but going form ~22V DC to 5V makes a lot lot lot of heat! any idea how to avoid this issue?
            • epierreE
              epierreE
              epierre
              check ospi they have published their BOM
              • epierreE epierre
                marekdM
                marekdM
                marekd
                @epierre
                power supply unit with LM2596 is rather complicated to build and needs parts which I don't have. I could, of course, buy step down module for around 1-2$. Maybe I'll come back to this solution after this watering season - now is is to late for this. Thanks anyway!
                • marekdM
                  marekdM
                  marekd
                  Finally I launched my Irrigation System, there are some small bugs in the code, but can live with it - for now. Have plans how to rebuild this in winter time to be more robust and to look better.
                  Runs under Domoticz and manually with keypad.
                  For now it looks like this:
                  • epierreE epierre
                    marekdM
                    marekdM
                    marekd
                    @epierre
                    Started to play with LM2596, I've got sth. like this:
                    http://www.ebay.com/itm/1pcs-1-23V-30V-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-/400985220074?hash=item5d5c94e3ea:g:o10AAOxy0x1TVSpD
                    Added diode bridge between transformer and this converter. But my concern is that I've some big voltage peaks the the output of it. It happens when I'm opening/closing valves (AC solenoids) connected to this transformer.
                    Set this converter to 12V DC but my readings are sometimes around 20V DC and I am affraid that I could destroy by Arduino.
                    Do you (anyone) have any suggestion ?
                    • gbgent_ncG
                      gbgent_ncG
                      gbgent_nc
                      @marekd
                      Just wondering, could you not set your zones up as an array. This would reduce the size a little and should also free up memory for variables.
                      • gbgent_ncG gbgent_nc
                        @marekd
                        marekdM
                        marekdM
                        marekd
                        @gbgent_nc
                        Yes I could and did already because have to use ProMini [my MEGA2560 was killed ;) ].
                        Anyway plan is now to use 2xProMini., one for LCD, Keyboard, relays and second for temperature x2, water meter, rain sensor and relay for pump.
                        • fetsF
                          fetsF
                          fets
                          @marekd could you give us a link to your walves.
                          • fetsF fets
                            marekdM
                            marekdM
                            marekd
                            @fets
                            Manufacturer is RAIN S.p.a Italy, www.rain.it.
                            Model I use is RN150.
                            Got them from Leroy Merlin, price was around 11 EUR.
                            fetsF 1 Reply Last reply
                            • marekdM marekd
                              @fets
                              fetsF
                              fetsF
                              fets
                              @marekd thanks
                              • marekdM marekd
                                Last summer during vacation, was quite hot at my place. My green grass in the garden became ... brown and yellow - there was nobody to irrigate and was no rain, of course!
                                So I made a decision to buy irrigation controller and all that stuff. I wanted to have 7-8 zones, BT or wireless control, temperature and rain based control, RTC, Keypad, etc. The problem was that nobody had it or was to expencive.
                                So long story short I came up with idea to build one with all those features i need. Without having experience with uC I start to learn (google and youtube) a bit and build some "prototypes". Than IrrigatonController ver 1.0 was ready (December 2015):0_1462825721811_1.jpg
                                Than I found @petewill IrrigationControler at youtube - but it was to hard for me from software (all this MySensors) and hardware side - I thought!
                                So I built new one - well it is almost done.
                                It is tested and working, few things are still missing like running without HA controller and rain sensor. Anyway I post some pictures and script what I've done. At my place it is working under Domoticz and manual (keypad). Tomorrow final wiring!
                                0_1462826941290_IMG_20160509_203348.jpg .
                                Any comments are more than welcome, know that script need some more work - but it is just a beginning.
                                 * based on Version 1.0 - Henrik Ekblad
                                 * Version 2.0 - Marek Dajnowicz
                                 * Example sketch showing how to control physical relays.
                                 * http://www.mysensors.org/build/relay
                                #define MY_RF24_CE_PIN A8 // żółty 51
                                #define MY_RF24_CS_PIN A9 // pomarańczowy 53
                                #define MY_NODE_ID 66
                                #define MY_REPEATER_FEATURE
                                #include <Time.h>
                                #include <LiquidCrystal.h>
                                #include <OneWire.h>
                                #include <DS3232RTC.h>  // A  DS3231/DS3232 library
                                #include <Keypad_I2C.h> // Klawiatura na I2c
                                #include <Keypad.h> // klawiatura
                                #define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                #define NUMBER_OF_RELAYS 8 // Total number of attached relays
                                #define ONE_WIRE_BUS 22 // Pin where dallase sensor is connected MEGA256
                                #define TEMPERATURE_PRECISION 12
                                #define CHILD_ID_SPRINKLER1 1
                                #define CHILD_ID_SPRINKLER2 2
                                #define CHILD_ID_SPRINKLER3 3
                                #define CHILD_ID_SPRINKLER4 4
                                #define CHILD_ID_SPRINKLER5 5
                                #define CHILD_ID_SPRINKLER6 6
                                #define CHILD_ID_SPRINKLER7 7
                                #define CHILD_ID_PUMP 10
                                #define CHILD_ID_TEMP 11
                                #define CHILD_ID_TEMP2 12
                                boolean timeReceived = false;
                                LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                DeviceAddress addrT1 = { 0x28, 0xFF, 0x9F, 0x80, 0x93, 0x15, 0x04, 0xF7 }; //DS18 Dallas temp.
                                float T1;
                                int numSensors = 0;
                                MyMessage msgValve1(CHILD_ID_SPRINKLER1, V_LIGHT);
                                MyMessage msgValve2(CHILD_ID_SPRINKLER2, V_LIGHT);
                                MyMessage msgValve3(CHILD_ID_SPRINKLER3, V_LIGHT);
                                MyMessage msgValve4(CHILD_ID_SPRINKLER4, V_LIGHT);
                                MyMessage msgValve5(CHILD_ID_SPRINKLER5, V_LIGHT);
                                MyMessage msgValve6(CHILD_ID_SPRINKLER6, V_LIGHT);
                                MyMessage msgValve7(CHILD_ID_SPRINKLER7, V_LIGHT);
                                MyMessage msgPump(CHILD_ID_PUMP, V_LIGHT);
                                MyMessage msgT1(CHILD_ID_TEMP, V_TEMP);
                                MyMessage msgT2(CHILD_ID_TEMP2, V_TEMP);
                                /**** Kepad settings */
                                const byte ROWS = 4;
                                const byte COLS = 4;
                                char keys[ROWS][COLS] = {
                                  {'1', '2', '3', 'A'},
                                  {'4', '5', '6', 'B'},
                                  {'7', '8', '9', 'C'},
                                  {'*', '0', '#', 'D'}
                                byte rowPins[ROWS] = {47, 45, 43, 41};
                                byte colPins[COLS] = {39, 37, 35, 33};
                                int i2caddress = 0x20;
                                Keypad_I2C kpd = Keypad_I2C( makeKeymap(keys), rowPins, colPins, ROWS, COLS, i2caddress );
                                bool state;
                                // system messages
                                const char *string_table[] =
                                  "     WELCOME! =)", 			// 0
                                  "DOMOTICZ TIME", 				// 1
                                  "WATERING",  					// 2
                                  "    SYSTEM CHECK  ",			// 3
                                  "  STARTING UP THE",			// 4
                                  "  WATERING SYSTEM", 			// 5
                                  "    Popmp is ON ", 		    // 6
                                  "      MySensors",		   	// 7
                                  "   Watering System",	      	// 8
                                  "   Please wait !!"	        // 9
                                const char *string_table2[] = {
                                  "Strefa 1", "Strefa 2", "Strefa 3", "Strefa 4", "Strefa 5", "Strefa 6", "Strefa 7", "Pompa zasilająca" // ZONE 1...2...
                                const unsigned long tUpdate = 60000; // update interval for temp sensors
                                unsigned long t0;
                                  for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++)
                                    pinMode(pin, OUTPUT); // Then set relay pins in output mode
                                    digitalWrite(pin, RELAY_OFF); // set all relays OFF
                                    saveState(sensor, state); // save data at startup.
                                  requestTime();
                                  kpd.begin();  //keypad
                                  sensors.begin(); //dallas temp
                                  sensors.setResolution(addrT1, TEMPERATURE_PRECISION);
                                  lcd.begin(20, 4); //(20 characters and 4 line display)
                                  lcd.clear();
                                  lcd.backlight();
                                  lcd.createChar(0, clock);
                                  lcd.createChar(1, raindrop);
                                  lcd.home();
                                  lcd.print(string_table[4]);
                                  lcd.setCursor(0, 1);
                                  lcd.print(string_table[5]);
                                  lcd.setCursor(0, 3);
                                  lcd.print(string_table[7]);
                                  delay(3000);
                                  for (int i = 0; i < 20; i++) {
                                    delay(100);
                                    lcd.scrollDisplayLeft();
                                  lcd.clear();
                                  lcd.home();
                                  lcd.print(string_table[0]);
                                  lcd.print(string_table[3]);
                                  (lcd.setCursor(0, 3));
                                  for (int M = 1; M >= 0; M--) // countdown
                                    lcd.setCursor(10, 3);
                                    lcd.print(M);
                                    delay(1000);
                                  lcd.clear();
                                  lcd.home ();
                                  requestTime();
                                  ServerUpdate();
                                  sendSketchInfo("Watering", "2.0");
                                  for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                                    present(sensor, S_LIGHT, string_table2[sensor - 1]); // use CHILD ID names from table
                                  present(CHILD_ID_TEMP, S_TEMP,"Dallas");
                                  present(CHILD_ID_TEMP2, S_TEMP,"RTC Temp");
                                  domoticztime(); // to PRINT the time from conroller
                                  keypad(); // READING KEYPAD
                                  if ((millis() - t0) > tUpdate) ServerUpdate();
                                void ServerUpdate()
                                  T1 = sensors.getTempC(addrT1);
                                  send(msgT1.set(T1 , 1));
                                  int t= RTC.temperature()/4;
                                  send(msgT2.set(t,2));
                                  lcd.setCursor(11, 2);
                                  lcd.print("T:");
                                  lcd.print(T1);
                                  lcd.print(char(223));
                                  lcd.print("C");
                                  lcd.setCursor(11, 3);
                                  lcd.print("T:");
                                  lcd.print(t);
                                  lcd.print("C");
                                  t0 = millis();
                                void domoticztime()
                                  lcd.home();
                                  lcd.setCursor(0, 2);
                                 // lcd.print(string_table[1]);
                                  //lcd.setCursor(2, 2);
                                  lcd.write(byte(0));
                                  lcd.setCursor(1, 2);
                                  lcd.print(hour());
                                  lcd.print(":");
                                  int min = minute();
                                  if (min < 10) lcd.print("0");
                                  lcd.print(minute());
                                  lcd.print(":");
                                  lcd.print(second());
                                  lcd.print(day());
                                  lcd.print("/");
                                  lcd.print(month());
                                  lcd.print("/");
                                  lcd.print(year());
                                void keypad()
                                  char key = kpd.getKey(); delay(50);
                                  if (key == '*') ALL_OFF();
                                  if (key == '#') WRONG();
                                  if (key == '1') ZONE_1();
                                  if (key == '2') ZONE_2();
                                  if (key == '3') ZONE_3();
                                  if (key == '4') ZONE_4();
                                  if (key == '5') ZONE_5();
                                  if (key == '6') ZONE_6();
                                  if (key == '7') ZONE_7();
                                  if (key == '8') WRONG();
                                  if (key == '9') WRONG();
                                  if (key == '0') WRONG();
                                  if (key == 'D') DEBUG();
                                void DEBUG()
                                {for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++)
                                    state = loadState(sensor);
                                    Serial.print("sensor: ");
                                    Serial.print(sensor);
                                    Serial.print("  /  stan:  ");
                                    Serial.println(state);
                                void ALL_OFF()// TURNING ALL ZONES OFF @ ONE KEY PRESSED
                                  lcd.clear();
                                  lcd.print(" TURN ALL ZONES OFF");
                                  Serial.println(" turn ALL OFF");
                                  send(msgValve1.set(0) );delay(100);
                                  send(msgValve2.set(0) );delay(100);
                                  send(msgValve3.set(0) );delay(100);
                                  send(msgValve4.set(0) );delay(100);
                                  send(msgValve5.set(0) );delay(100);
                                  send(msgValve6.set(0) );delay(100);
                                  send(msgValve7.set(0) );
                                  send(msgValve1.set(0), true); delay(100);
                                  send(msgValve2.set(0), true);delay(100);
                                  send(msgValve3.set(0), true);delay(100);
                                  send(msgValve4.set(0), true);delay(100);
                                  send(msgValve5.set(0), true);delay(100);
                                  send(msgValve6.set(0), true);delay(100);
                                  send(msgValve7.set(0), true);
                                  DEBUG();
                                  delay(1500);
                                  lcd.clear();
                                void ZONE_1()
                                { // zone 1, pin 2
                                  byte pin=RELAY_1;
                                  state = loadState(CHILD_ID_SPRINKLER1);
                                  digitalWrite(pin, state ? RELAY_ON : RELAY_OFF);
                                  saveState(CHILD_ID_SPRINKLER1, state);
                                  if (state == 1)
                                    lcd.print(" ");
                                  send(msgValve1.set(state ? false : true), true);
                                void ZONE_2()
                                  byte pin=RELAY_1+1;
                                  state = loadState(CHILD_ID_SPRINKLER2);
                                  saveState(CHILD_ID_SPRINKLER2, state);
                                 if (state == 1)
                                    lcd.setCursor(1, 1);
                                    lcd.print(" ");
                                  send(msgValve2.set(state ? false : true), true);
                                void ZONE_3()
                                byte pin=RELAY_1+2;
                                  state = loadState(CHILD_ID_SPRINKLER3);
                                  saveState(CHILD_ID_SPRINKLER3, state);
                                  if (state == 1)
                                    lcd.setCursor(2, 1);
                                    lcd.print(" ");
                                  send(msgValve3.set(state ? false : true), true);
                                void ZONE_4()
                                byte pin=RELAY_1+3;
                                  state = loadState(CHILD_ID_SPRINKLER4);
                                  saveState(CHILD_ID_SPRINKLER4, state);
                                  if (state == 1)
                                    lcd.setCursor(3, 1);
                                    lcd.print(" ");
                                  send(msgValve4.set(state ? false : true), true);
                                void ZONE_5()
                                byte pin=RELAY_1+4;
                                  state = loadState(CHILD_ID_SPRINKLER5);
                                  saveState(CHILD_ID_SPRINKLER5, state);
                                  if (state == 1)
                                    lcd.setCursor(4, 1);
                                    lcd.print(" ");
                                  send(msgValve5.set(state ? false : true), true);
                                void ZONE_6()
                                byte pin=RELAY_1+5;
                                  state = loadState(CHILD_ID_SPRINKLER6);
                                  saveState(CHILD_ID_SPRINKLER6, state);
                                  if (state == 1)
                                    lcd.setCursor(5, 1);
                                    lcd.print(" ");
                                  send(msgValve6.set(state ? false : true), true);
                                void ZONE_7()
                                byte pin=RELAY_1+6;
                                  state = loadState(CHILD_ID_SPRINKLER7);
                                  saveState(CHILD_ID_SPRINKLER7, state);
                                  if (state == 1)
                                    lcd.setCursor(6, 1);
                                    lcd.print(" ");
                                  send(msgValve7.set(state ? false : true), true);
                                void WRONG() {}
                                  byte zone;
                                  if (message.isAck()) {
                                    // Change relay state
                                    digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
                                    zone = message.sensor; // less typing :)
                                    // Store state in eeprom
                                    // representing active zones at LCD
                                    if (message.getBool() == RELAY_ON) // checking new state of relay
                                      Serial.print("Watering ZONE: "); Serial.println(zone);
                                      lcd.setCursor(0, 0);
                                      lcd.print("Watering ZONE: ");
                                      lcd.setCursor(zone - 1, 1);
                                      lcd.print(zone);
                                    if (message.getBool() == RELAY_OFF) // checking new state of relay
                                      lcd.print(" ");
                                    Serial.print("Incoming change for ZONE:");
                                Regards
                                karl261K
                                karl261K
                                karl261
                                @marekd Great controller! For the keypad: I see from the code that you use the I2C code. How did you connect your keypad? Did you use a I2C extension chip? And, which keypad_i2c library do you use? I found multiple on the net.
                                • karl261K karl261
                                  marekdM
                                  marekdM
                                  marekd
                                  @karl261
                                  in case I2C yes, and no.
                                  with 1st generation [with 1 ProMini] I used I2C port expander PCF8574.
                                  with 2nd generation [with MEGA2560] just pins, 8 pins, declared like this:
                                  /**** Kepad settings /
                                  ', '0', '#', 'D'}
                                  with 3rd generation - plan to have 2nd ProMini with PCF expander.
                                  attached library I use.
                                  0_1474294070076_Keypad_I2C.zip
                                  and some pictures of generation 3, which is under construct :)
                                  Power supply:
                                  and control box with 2 ProMinis:
                                  karl261K 1 Reply Last reply
                                  • marekdM marekd
                                    @karl261
                                    ', '0', '#', 'D'}
                                    Power supply:
                                    karl261K
                                    karl261K
                                    karl261
                                    @marekd Thanks for the detailed reply. What the monster capacitor for in gen 3?
                                    I plan to build my keypad with one pro mini and the PCF8574. Like your gen 1 & 3. How did / are you planning to wire the PCF8574? It seems rather straight forward according to this:
                                    https://www.hackster.io/venkatesh_rao/i2c-keypad-73a012
                                    Is this the wiring you are using? Or is it different?
                                    Since I am building a battery keypad, I was also planning to use the interrupt line of the PCF8574.
                                    • karl261K karl261
                                      marekdM
                                      marekdM
                                      marekd
                                      @karl261
                                      Capacitor is not so big ;) generally helps.
                                      I my wiring there is no pull-up resistors at I2C lines. Rest is the same.
