  3. Nano on Battery(Programming problem)
7 Posts 2 Posters 2.5k Views 1 Watching
  • clio75C
    clio75C
    clio75
    Due to a wrong order I have a lot of nano that I need to use.
    SO I trying to get the nano to work on battery. These have the ch340 chip and this chip is using approx 20 mA in standby.
    So I removed the CH340 and the voltage regulator.
    I tried to program the nano with the USB->serial(ftdi232) that I used for mini but with no success.
    If anyone have idea how to program a nano without the usb interface I like to hear you :)
    Thanx
    • sundberg84S
      sundberg84S
      @clio75. You can use a uno or nano as ISP: https://www.arduino.cc/en/Tutorial/ArduinoISP
      or a ISCP progrmm er.
      • clio75C
        clio75C
        clio75
        Yes That's correct :D
        I can try this now :dancer:
        Thanx
        • clio75C
          clio75C
          clio75
          @sundberg84,
          Is it possible to use an arduino to program a sketch into an other arduino ?
          I can program a bootloader, but don't see a way to upload a sketch
          Thanx
          • clio75C clio75
            @sundberg84,
            Thanx
            sundberg84S
            sundberg84S
            @clio75 - yes, in the arduino IDE use "Arduino as ISP as programmer and use upload using programmer and that should work.
            The first arduino should have the ArduinoISP sketch flashed found in the example menu.
            • clio75C
              clio75C
              clio75
              OK, I will Try again :)
              Thanx
              • clio75C
                clio75C
                clio75
                I was not able to upload a sketch with "arduino as ISP" so I whent back to my orginal idea to use a FTDI232(like I use for microPro).
                I looked into the schematic on the nano and the micro. I found that on the micro the DTR pin there is a capacitor between reset and DTR input.. But the reset pin on the Nano did not. So I modified one FTDI232 with a capacitor 0,1uF (See picture).
                0_1475261114646_upload-7dd5f974-3c47-4f1c-9813-0116635d687d
                When I also crossed the TX/RX pins it finally works :+1:
