  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 451.8k Views 35 Watching
  • Thanh-VietT Thanh-Viet
    Hi Guys,
    Nice work. I'm based in Hong Kong, and what matters to us is PM2.5, NO2 and Ozone (and indoor CO2/VOC).
    Have you guys checked the laser based particle sensors like the Plantower G1-G3-G5, Innovafitness SDS011/021 ?
    http://aqicn.org/sensor
    alexsh1A
    alexsh1A
    alexsh1
    @Thanh-Viet Hello. Yes, I have Plantower G3 on order from Aliexpress and won't be able to test it before September. I think adopting it for MySensors is going to be easy
    • paqorP
      paqorP
      paqor
      Hello, there are statements if the values increase the MQ135 when a room ventilated, without people and is furnished? I I have several rooms here an increase over time. Perhaps this is also by the increase in temperature, sunlight or gases from the furniture. I have not found any literature on this. Is this behavior with other users as well?
      • paqorP
        paqorP
        paqor
        Has the type of installation (horizontal or vertical) have an impact on the values of MQ135? I have found no photos of built-in sensors already exist in the data sheet a statement.
        alexsh1A 1 Reply Last reply
        • paqorP paqor
          alexsh1A
          alexsh1A
          alexsh1
          @paqor yes, in fact my MQ-135 was so unreliable that I had to move on to a different sensor
          • paqorP
            paqorP
            paqor
            wrote on last edited by paqor
            #248
            Those interested in a 4 sensors Sketch FHEM (CO2, Temp, Hum, Motion) has ...
            ? 1 Reply Last reply
            • paqorP paqor
              A Former User
              @paqor
              I'm interested, but i'm using mysensors 2.0. Can you update your sketch?
              paqorP 1 Reply Last reply
              • ? A Former User
                @paqor
                paqorP
                paqorP
                paqor
                @gieljnssns said:
                @paqor
                Yes, sure but I need time. I'm not a good programmer and need a lot of testing. My Englich is not particularly good. As some patience please, because I have to house, garden, woman and taking care of animals. :two_men_holding_hands:
                • paqorP paqor
                  @gieljnssns said:
                  @paqor
                  paqorP
                  paqorP
                  paqor
                  #251
                  @gieljnssns said in Air Quality Sensor:
                  @paqor
                  @paqor
                  https://gleisnetze.de/2016/08/07/sensoren4sketch/
                  • v0.8 korrigierte Lib von RSTOICA
                  • EEPROM set R0Cor
                  • amended mq135.h required!
                  • Temp, Hum --> CO2Cor
                  • Api 2.0
                  • Motion is not yet tested
                  • Auto base value set r0corr if Co2cor <390
                  • R0Cor set by TextField runs (incoming message)
                  • Redesign
                  • paqorP paqor
                    @paqor
                    @paqor
                    • EEPROM set R0Cor
                    • Api 2.0
                    • Redesign
                    paqorP
                    paqorP
                    paqor
                    #252
                    @paqor
                    Probably one should not speak of a sensor CO2 value as well as responding to many other particles at the MQ135. The most accurate CO2 measurement we certainly be possible only with a MH-Z14. I now have to buy me a part and will then calibrate the MQ135 so. With the MQ135 can z. B. only say something about the air quality in relation to the outside air. It is rather a relative value.
                    Here the comparison of MH-14T (yellow) and MQ135 (red). One sees the calibration and as yet are both curves to each other.
                    [https://smarthome.gleisnetze.de/38-mhz-14-erste-erfahrungen-mit-dem-co2-sensor-fuer-mysensors-arduino-fhem]
                    Wahrscheinlich sollte man beim MQ135 nicht von einem CO2 Wert sprechen da der Sensor auch auf viele andere Partikel reagiert. Die genaueste CO2 Messung wir sicher nur mit einem MH-Z14 möglich sein. Ich habe mir jetzt so ein Teil bestellt und werde dann den MQ135 damit kalibrieren. Mit dem MQ135 lässt sich z. B. nur etwas zur Luftgüte im Verhältnis zur Außenluft sagen. Es ist also eher ein relativer Wert.
                    • tuimansoT tuimanso
                      Your previous message
                      I have a question about the MQ-8 sensor module . The potentiometer that is soldered onto the board, is it to control the sensitivity of the LED light or for the sensor itself? According to the datasheet for the sensor, the RL (load resistance) for the sensor should be at minimum 10k Ohm, yet I only see an SMD 102 resistor on the board, which is a 1K Ohm resistor. I have used a multimeter to connect the 5V pin and the AOUT pin, and I get precisely a measurement of about 1K Ohm... Does that mean that I should connect a load resistor to this?
                      This value seems very important since it is referenced in the code, the RL is part of the calculations, yet it is already pre-written 10K ohms...
                      Please Clarify
                      ysinhY
                      ysinhY
                      ysinh
                      @tuimanso
                      There seems a general misunderstanding about how those gas sensors really work: the "heater" must be switched on (5v) and "off"(1.4v) for the air sample going in and out of the sensor, when heating the air sample expands and goes out of the sensor, then in the cool down period the remaining air contracts and sucks in a new sample.
                      Those boards with mq... sensors only provide fixed 5v heating, so this can never work reliable
                      the 1.4v is needed to keep the sensor on a minimum temperature,example 40'c for the catalyst to react, the 5v will heat it up to example 80'c, to clean the catalyst and air flows out of the sensor
                      http://i49.tinypic.com/2rzdqgn.png something like this will work
                      Soon I will report my results together with a modified sketch for mysensors 2.0
                      • epierreE epierre
                        @alexsh1 said:
                        @epierre I started looking at the formula you have used in ppmv calculation. Why do you need ppmv? All values in EPA or Europe are in μg/m3.
                        because domoticz only knows ppm... and many AIQ like use only that except for particles.
                        1. temp = °C + 273.15
                          int temp=273.15 + 22;
                          22C - is a typical temp inside though the intention is to use a sensor
                        not for me ;-)
                        1. The amended ppmv equation is going to be:
                          ppmv=(((concentrationPM250.0283168)/100) * ((0.08205temp)/28.97))/1000;
                        I have not changed 0.0283168 /100 - not sure that this is. And the whole thing is divided by 1000? why?
                        was a volume conversion
                        The molecular weight is 28.97 for dry air
                        2.08 mg/m3 is equivalent to 1.74ppm for a gas with molecular weight=28.97 Pressure=1013.25, Temperature=22C
                        Success!
                        success for the mysensors value ?
                        MySensors: Unknown/Invalid sensor type (43)
                        Domoticz doesn't recognize this command... I use 1.5.x but I have my own gateway to domoticz
                        bezeeflyB
                        bezeeflyB
                        bezeefly
                        @epierre I am working on a dust sensor project using Samyoung DSM501A. I am confused with the identical calculation formula used in the Samyoung DSM501A and Shinyei PPD42NS dust sketch.
                        concentration = 1.1pow(ratio,3)-3.8pow(ratio,2)+520*ratio+0.62;
                        My understanding is that the formula is based on the specific product's data sheet curve. Is the formula for DSM501A, PPD42NS, or both?
                        • epierreE
                          epierreE
                          epierre
                          #255
                          This is formula for Shinyei, you're right, I'searched back but don't know if a formula was made out : https://groups.google.com/forum/#!topic/airqualityegg/A1F9padoW10
                          strangely here it is used too : http://learn.linksprite.com/arduino/shields/use-dust-sensor-dsm501-with-arduino/
                          a formula by Chris Nafis here: https://github.com/OSBSS/Samyoung_Dust_Sensor/blob/master/Samyoung_Dust_Sensor.ino
                          z-wave - Vera -> Domoticz
                          bezeeflyB 1 Reply Last reply
                          • epierreE epierre
                            bezeeflyB
                            bezeeflyB
                            bezeefly
                            @epierre I obtained the following equation by polynomial fit the low ratio vs particle (pcs/283ml) graph in the DSM501 datasheet.
                            concentration = (0.1 * pow(ratio, 2)) + (619 * ratio) + 50;
                            Please help to check whether the equation is correct.
                            epierreE 1 Reply Last reply
                            • bezeeflyB bezeefly
                              epierreE
                              epierreE
                              epierre
                              #257
                              looks correct for the red curve
                              using http://www.xuru.org/rt/PR.asp with:
                              4 2500
                              8 5000
                              12 7500
                              16 10000
                              20 12500
                              22 15000
                              gives =7,613212955POWER(B3;2) + 467,3617082B3 + 631,9862425
                              a bit better ;-)
                              and on the previous one datasheet http://www.mouser.com/ds/2/744/Seeed_101020012-838657.pdf:
                              2 1000
                              3.9 2000
                              5.8 3000
                              7.2 4000
                              9 5000
                              10 6000
                              11.3 7000
                              12.6 8000
                              y = 19.09464953 x2 + 383.1041412 x + 174.9189116
                              • jumpingJ
                                jumpingJ
                                jumping
                                I bought the classic MQ sensors (MQ2, MQ4 and MQ135) and I'm building a multisensor node with arduino nano v3:
                                @epierre can I use sketch https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino, is it suitable?
                                thanks
                                Raspberrry PI3 - Domoticz
                                ESP8266 GW - MySensors 2.1.1
                                • jumpingJ jumping
                                  thanks
                                  epierreE
                                  epierreE
                                  epierre
                                  @jumping you will need to scale down the script obviously, in term of power it will be too short to have more than one.
                                  jumpingJ 1 Reply Last reply
                                  • epierreE epierre
                                    jumpingJ
                                    jumpingJ
                                    jumping
                                    thanks for your answer! please, can you explain how the following code in your sketch is related to datasheet?
                                    • float CO_secCurve[2] = {726.7809737, -4.040111669}; //MQ135
                                    I understand the sketch in the "Gas Detection - Example", but not the previous.
                                    sorry for my poor english :-)
                                    • epierreE
                                      epierreE
                                      epierre
                                      @jumping see just above on power regressin curves, this is the result from a power regression based on the data sheet provided by one maker. Sometime I leave the data points in the sketch, sometime not (based on history ;-)
                                      • epierreE epierre
                                        Air Quality Index is a combination of several sensors values:
                                        • sulfur dioxide (SO2) MQ136 / (avoid:2SH12 no datasheet)
                                        • nitrogen dioxide (NO2) MiCS-2710 MiCS-2714 MICS-6814
                                        • carbon monoxide (CO) MQ-7 MiCS-5525 TGS2442 MICS-6814
                                        • ozone (O3) MQ131 MICS-2610 MICS-2614
                                        • Particles concentration: PM2.5 and PM10 (SamYoung DSM501, Shinyei_PPD42NS, avoid: Sharp_GP2Y1010AU)
                                        Additional gases can be interesting to track:
                                        • CO2 MH-Z14
                                        Current work being done:
                                        • manage default Ro once
                                        • take into account humidity
                                        • manage to get proper values from TGS2600
                                        • possibility to have a push if a value goes up too quick (for deadly gases even without calibration)
                                        What is done:
                                        • remove powerdown to keep heaters on
                                        • add a five minute pre-heat on each startup
                                        • removed the powerdown
                                        • 2SH12 datasheet doesn't exist
                                        WARNING: all sensors differs even within the same reference, a calibration has to be done each time. Do not rely upon a sketch result with deadly gases.
                                        Working sketch in 1.4/1.5:
                                        • https://github.com/empierre/arduino/blob/master/MQv01dgi_1_4.ino (for a Mega, MQ2, MQ6, MQ131, MQ136, MQ138, TGS2600, TGS2602, HCHO, Barometer BMP085, DHT11)
                                        • https://github.com/empierre/arduino/blob/master/AirQuality-CO-NO2-NH3.ino for MICS-6814
                                        • https://github.com/empierre/arduino/blob/master/CO2-MH-Z14.ino
                                        • https://github.com/empierre/arduino/blob/master/DustSensor_SamYoung_DSM501.ino
                                        • https://github.com/empierre/arduino/blob/master/DustSensor_Shinyei_PPD42NS.ino
                                        ambuj
                                        @epierre Hi I am working on the MQ2 sensor, I want to know CO level. Did you do it before with this sensor?
                                        http://www.amazon.in/Butane-Hydrogen-Sensor-Detector-Arduino/dp/B01N0XSQ9J?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=9d5b3107-037a-4d7b-a8b9-722d0a4bcfea.
                                        I am using this module and just start work with this sensor.
                                        • Lukács AttilaL
                                          Lukács AttilaL
                                          Lukács Attila
                                          @epierre is it possible that the lastest github for Samyoung 501a is not correct? Flashed it and the results are way too high (157000 mg/m3)?
