  3. Decent Accuracy Temp&Humidity Sensors?
10 Posts 6 Posters 8.3k Views 4 Watching
  • N Offline
    N Offline
    NotYetRated
    Been about 6-8 months since I have been active here, busy with other house work and such.
    Looking to update/make new sensors, was looking at the Senseboard and its integrated Si7021, I like the accuracy range it provides. Are people using these on their boards? I don't have much use right now for battery powered, are there any other options for low cost, good precision temperature and humidity? I don't like the cost of the DS22's at like 6+ bucks a pop. Are the Si a better choice? Just looking for cost effective, high accuracy. :)
    D 1 Reply Last reply
    • N NotYetRated
      Dwalt
      @NotYetRated On eBay, the si7021 and dht22 are about the same cost ~ $3.25 - $3.50 USD. The si7021 are better for low or battery power @ 1.9 - 3.6V while the dht22 range is 3.3 - 5.5V. The si7021 is also much smaller package @ 3x3mm.
      • A Offline
        A Offline
        ahhk
        Also take a look at HTU21D....
        • E Offline
          E Offline
          emc2
          I was wondering in an other post if anyone had some experience (accuracy, easy to use etc) with BME280 (tep/hum and baro) http://www.ebay.com/itm/401000227934
          Mine is still on the way but hopefully will see in a few weeks.
          • R Offline
            R Offline
            robosensor
            I'm using BME280 (from aliexpress), very good and accurate sensor. But sensor price is not comfortable for me.
            Easy to use (I'm using adafruit bme280 libraries with MySensors).
            • E Offline
              E Offline
              emc2
              Good to know it's accurate.
              I agree the price is still a little steep and I would not put this one everywhere. But for a weather station project it's nice to have everything in one sensor.
              • A Offline
                A Offline
                ahhk
                @robosensor: What about power consumption, max/min voltage and measuring time?
                Greetings
                Andreas
                • R Offline
                  R Offline
                  robosensor
                  @ahhk https://www.bosch-sensortec.com/de/homepage/products_3/environmental_sensors_1/bme280/bme280_1
                  Average current consumption (1Hz data refresh rate)
                  1.8 μA @ 1 Hz (H, T)
                  2.8 μA @ 1 Hz (P, T)
                  3.6 μA @ 1 Hz (H, P, T)
                  H - humidity, P - pressure, T - temperature
                  0.1 μA in sleep mode
                  Supply voltage 1.71 - 3.6 V
                  • A Offline
                    A Offline
                    ahhk
                    very NICE :sunglasses:
                    • R robosensor
                      T Offline
                      T Offline
                      Toyman
                      I also failed into this trap :-) in fact, bme280 consumption in NORMAL mode is 450-600ua
                      12.2k
