  3. Relay with button
Relay with button
7 Posts 2 Posters 1.9k Views 2 Watching
  • LanmanL Offline
    LanmanL Offline
    Lanman
    Does anyone have an updates sketch for the relay with button that works on the current library?
    • K Offline
      K Offline
      korttoma
      Have you checked from GitHub?
      Updated examples allong with some external librarys are available from here -> https://github.com/mysensors/MySensorsArduinoExamples
      Relay with button sketch is here -> https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/RelayWithButtonActuator
      • Tomas
      • LanmanL Offline
        LanmanL Offline
        Lanman
        Hi, thanks for the reply, by the looks of it this is the same sketch on the my sensors site, unfortunately it doesn't seem to work on the new library, unless that is just me doing something retarded.
        K 1 Reply Last reply
        • LanmanL Lanman
          K Offline
          K Offline
          korttoma
          Can you elaborate on this? What is it that is not working? Can you get the serial debug output from your node?
          // Enable debug prints
          • Tomas
          • LanmanL Offline
            LanmanL Offline
            Lanman
            It won't even upload to the arduino,
            It works if you use the old library but on v 2.0 this is the result.
            C:\Users\Shane\AppData\Local\Temp\ccwaR9Zf.ltrans2.ltrans.o: In function `loop':
            ccwaR9Zf.ltrans2.o:(.text+0x8): undefined reference to `Bounce::update()'
            ccwaR9Zf.ltrans2.o:(.text+0x10): undefined reference to `Bounce::read()'
            C:\Users\Shane\AppData\Local\Temp\ccwaR9Zf.ltrans2.ltrans.o: In function `setup':
            ccwaR9Zf.ltrans2.o:(.text+0x9e): undefined reference to `Bounce::attach(int)'
            ccwaR9Zf.ltrans2.o:(.text+0xaa): undefined reference to `Bounce::interval(unsigned int)'
            C:\Users\Shane\AppData\Local\Temp\ccwaR9Zf.ltrans3.ltrans.o: In function `global constructors keyed to 65535_0_relay_button1.ino.cpp.o.2246':
            ccwaR9Zf.ltrans3.o:(.text.startup+0x64): undefined reference to `Bounce::Bounce()'
            Multiple libraries were found for "MySensors.h"
            Used: D:\Data\Documents\Arduino\libraries\MySensors
            Not used: C:\Program Files (x86)\Arduino\libraries\MySensors-master
            exit status 1
            • K Offline
              K Offline
              korttoma
              Looks like you just have some issues with your libraries.
              Seems like you have 2 instances of the MySensors library installed in 2 different locations. Maybe you should delete or move the one you are not using to another location.
              Also the Bounce2 library is not included in the MySensors 2.0 library so you need to install it separately if it is missing.
              You can collect the Bounce2 library from this collection -> https://github.com/mysensors/MySensorsArduinoExamples
              • Tomas
              • LanmanL Offline
                LanmanL Offline
                Lanman
                Just as I suspected, it was me doing something retarded, thanks for your help.
                12.2k
