  2. Announcements
  • M marceloaqno
    @b0rmann what happened? Did you fixed the problem you described in your last message?
    b0rmannB
    b0rmannB
    b0rmann
    @marceloaqno
    it's my problem. accidentally disconnected power from nrf24 on running gw
    • E
      E
      ericvdb
      @marceloaqno I have it completely working now. :satisfied: A Raspberry Pi PulseCounter for water/gas/electricity consumption measurements with ethernet/mqtt. I can post my code here if you want.
      Minor detail:
      millis() / 1000;
      should be
      millis() * 1000;
      to get micros() ;)
      • E ericvdb
        Minor detail:
        millis() / 1000;
        should be
        millis() * 1000;
        to get micros() ;)
        marceloaqno
        Code Contributor
        @ericvdb Congrats! oops, sorry about my mistake.
        • Christian SimonsenC
          Christian SimonsenC
          Christian Simonsen
            Christian SimonsenC
            Christian Simonsen
            Seems I'm closing in to working solution. I didn't understand how to use the ./configure element before now. However I ended up with these configurations
            pi@raspberrypi:~ $ ./MySensors/configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24 --my-rf24-irq-pin=15
            [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
            [OK] init system detected: systemd
            make: *** No rule to make target 'clean'.  Stop.
            [OK] Finished.
            pi@raspberrypi:~ $ sudo ./MySensors/examples_linux/mysGateway -d
            mysGateway: Starting gateway...
            mysGateway: Protocol version - 2.0.1-beta
            mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
            mysGateway: TSF:LRT:OK
            mysGateway: TSM:INIT
            mysGateway: TSM:INIT:TSP OK
            mysGateway: TSM:INIT:GW MODE
            mysGateway: TSM:READY
            mysGateway: MCO:REG:NOT NEEDED
            mysGateway: MCO:BGN:STP
            mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
            mysGateway: TSM:READY:NWD REQ
            mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            mysGateway: TSF:SRT:OK
            Based on this it seem to all be ok on the Raspberry Pi side.. So I uploaded the "MockMySensors" sketch to my Arduino Uno with NRF24 connected. Below is the code and failure message I get from the Arduino. Do I need to set a gateway address or something?
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=254)
            TSM:FPAR
            TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT```
            • NiklasON
              NiklasON
              NiklasO
              Thanks for adding signing.
              I want to use my rPi to generate random soft serials for my sensors.
              Could all three "gen" commands output the line to put in SecurityPersonalizer.ino like it does when using the "set" commands?
              • Christian SimonsenC Christian Simonsen
                [OK] Finished.
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT```
                marceloaqno
                Code Contributor
                wrote on last edited by marceloaqno
                #70
                @Christian-Simonsen you need to be within the MySensors folders to execute commands configure and make.
                I recommend you to test that everything is working before using the option --my-rf24-irq-pin=15
                Like this:
                cd MySensors
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24
                make
                Christian SimonsenC 1 Reply Last reply
                • NiklasON NiklasO
                  marceloaqno
                  Code Contributor
                  @NiklasO Done (#622). Thanks for the sugestion.
                  • M marceloaqno
                    Like this:
                    cd MySensors
                    make
                    Christian SimonsenC
                    Christian SimonsenC
                    Christian Simonsen
                    @marceloaqno said:
                    cd MySensors
                    Thanks for letting me know, didn't know that not running it from the specific folder would have an impact.
                    I reconfigured it as you recommended. and restarted the gateway, with the result below.
                    pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d
                    mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                    mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
                    mysGateway: !TSF:MSG:LEN,0!=7
                    mysGateway: !TSF:MSG:LEN,14!=7
                    What is the best way to test if the gateway work? What sketch should I use on the arduino? and how do I see in Terminal that the mysGateway receive the transfer successfully?
                    jerseyguy1996J M 2 Replies Last reply
                    • b0rmannB
                      b0rmannB
                      b0rmann
                      very interesting data...
                      journalctl -u mysgateway --since 13:15 | grep MSG:READ
                      Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
                      Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                      Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
                      Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
                      Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                      Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                      Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                      Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                      Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
                      Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
                      Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
                      Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                      Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
                      Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=12,c=1,t=0,pt=7,l=5,sg=0:34
                      Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=14,c=1,t=0,pt=7,l=5,sg=0:24
                      node 2
                      sensor 167 - dht18b20 indoor
                      sensor 251 - dht18b20 indoor
                      node 3
                      sensor 0 - dht18b20 outdoor
                      sensor 3 - light (0..100)
                      sensor 4 - light (0..100)
                      questions:
                      why node 2 and node 3 send messages directly and via node 10?
                      24.6 - is actual value from 2/251, but gateway receive this value from 3/0 How is it possible?
                        Christian SimonsenC
                        Christian Simonsen
                        wrote on last edited by Christian Simonsen
                        #74
                        Is there anyone here that can give me some one-to-one support this evening to setup the Raspberry Pi + NRF24L01 as a gateway with MyController, and a Arduino Uno + NRF24L01 as Sensor node. I'm stuck after trying various things over the past week, so looks like I need some additional skills/knowledge to get the first setup working.
                        Maybe we can use Skype or some other medium. I will gladly pay a bit for this support if anyone is interested. I have some free time from 18:00 CET - 23:30 CET today...
                        • nicoN
                          nicoN
                          nico
                          hi, the gateway works but how display sensors in domoticz?
                          Thank you very much
                          alexsh1A 1 Reply Last reply
                          • nicoN nico
                            Thank you very much
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @nico you need a sensor to send data to GW and assuming you have GW added to Domoticz, Domoticz will add up corresponding values to "Devices"
                            • nicoN
                              nicoN
                              nico
                              I have a gateway and 1 sensor ,obviously.
                              I have added serial GW but anyone sensor appear, i'm sure that the sensor works, and the gateway also (see with the command mysGateway -d).
                              Can you have any idea ? Thank you
                              • nicoN nico
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @nico I would suggest you open up a different post in the Troubleshooting section regarding this matter
                                1 post GW and sensor logs
                                2. How do you know that the GW was added to Domoticz? Logs please?
                                  @marceloaqno said:
                                  cd MySensors
                                  jerseyguy1996J
                                  jerseyguy1996J
                                  jerseyguy1996
                                  @Christian-Simonsen
                                  You can pretty much test out using any of the arduino examples here:
                                  https://github.com/mysensors/MySensors/tree/development/examples
                                  Each one will present itself to the gateway when it starts up and you will see the presentation in the debug log. Make sure to run:
                                  https://github.com/mysensors/MySensors/tree/development/examples/ClearEepromConfig
                                  on the arduino first to make sure it starts with a fresh eeprom. After you select an Arduino sketch to test it with (seriously it doesn't matter which one you try) make sure to look at the sketch and add:
                                  #define MY_NODE_ID 4
                                  For MY_NODE_ID you can select any number. Just make sure that each new sensor node that you create has a different node number so like start out at MY_NODE_ID 1 and when you make another sensor node you can #define MY_NODE_ID 2 and so on.
                                  Next load it up to the Arduino, open the serial monitor, and see what happens. If you watch the serial monitor on the arduino you will see it present itself to the gateway and then you can confirm it in the debug log on the raspberry pi.
                                  I think it is pretty normal to have the problems you are having. I uninstalled and reinstalled the gateway 3 times on the Raspberry Pi before I finally got it all figured out. Once you get it running it is a glorious thing.
                                    @marceloaqno said:
                                    cd MySensors
                                    marceloaqno
                                    Code Contributor
                                    #80
                                    @Christian-Simonsen
                                    looks like a power issue with the nrf24 module.
                                    • b0rmannB b0rmann
                                      node 2
                                      node 3
                                      questions:
                                      marceloaqno
                                      Code Contributor
                                      @b0rmann Can you provide a full debug log of all involved nodes?
                                      • Patrik SöderströmP
                                        Patrik SöderströmP
                                        Patrik Söderström
                                        Can I attach one or more DallasTemp sensors on the Raspberry Pi gateway?
                                        • M marceloaqno
                                          @Christian-Simonsen
                                          Christian SimonsenC
                                          Christian SimonsenC
                                          Christian Simonsen
                                          @marceloaqno said:
                                          @Christian-Simonsen
                                          Ok,
                                          I've tested with the Voltmeter and the NRF24L01 module do get a steady 3.26 V. Both the gateway module and the Arduino sensor node...
                                          Im now building a few extra sensor nodes, so I can test without the Raspberry pi. Hopefully I can atleast get them talking based on Arduinos first. Before testing the Raspberry Pi.
                                          alexsh1A dopeeyeD 2 Replies Last reply
