  2. Announcements
  • E ericvdb
    @marceloaqno
    i was able to get a bit further by replacing all "unsigned long" declarations with "uint"
    Remains unsolved:
    root@raspberrypi:/downloads/MySensors# make
    cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
    g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
    examples_linux/mysGateway.cpp: In function âvoid onPulse()â:
    examples_linux/mysGateway.cpp:96:28: error: âmicrosâ was not declared in this scope
         uint newBlink = micros();
    examples_linux/mysGateway.cpp: In function âvoid loop()â:
    examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(uint&)â is ambiguous
         sleep(SEND_FREQUENCY);
    examples_linux/mysGateway.cpp:180:25: note: candidates are:
    In file included from examples_linux/mysGateway.cpp:22:0:
    /usr/include/unistd.h:444:21: note: unsigned int sleep(unsigned int)
     extern unsigned int sleep (unsigned int __seconds);
    In file included from ./MySensors.h:320:0,
                     from examples_linux/mysGateway.cpp:60:
    ./core/MySensorsCore.cpp:543:8: note: int8_t sleep(uint32_t, bool)
     int8_t sleep(const uint32_t sleepingMS, const bool smartSleep) {
    Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
    make: *** [examples_linux/mysGateway.o] Error 1
    marceloaqno
    Code Contributor
    wrote on last edited by marceloaqno
    #54
    @ericvdb micros() hasn't been ported, use:
    millis() /1000;
    for sleep(), replace:
    with
    sleep(SEND_FREQUENCY, false);
    Also, if you want to print something don't use Serial.print() or Serial.println(), use printf() or debug().
    Serial.print("l/min:");
    Serial.println(flow);
    should be:
    debug("l/min: %f\n", flow);
    as @hek said, the main focus now is to be used as a gateway, with time adding sensors will become less problematic.
    • E
      E
      ericvdb
      @marceloaqno
      I have it almost working. Regarding the interrupt, I have to pull-up to 3.3V the io pin through a resistor of 10k?
      Right now the interrupt isn't firing
      • M marceloaqno
        @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
        @ericvdb yes, you can attach a function to handle an interruption like this:
        uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
        uint8_t physPin = 16;	// Choose a pin that fits your needs
        void irqHandler(void)
        	// Process the interrupt
        	attachInterrupt(physPin, irqHandler, mode);
        Support for I2C was added in the latest version.
        shfgS
        shfgS
        shfg
        @marceloaqno thanks, turned on mosquitto logging and am getting this error on mosquitto:
        1476724216: Invalid protocol "MQTT" in CONNECT from 127.0.0.1.
        1476724216: Socket read error on client (null), disconnecting.
        Tried an alternative mosquitto broker on another server too - same error.
        • E
          E
          ericvdb
          @marceloaqno
          I have it working :smiley: only need to play with the debounce value
          • M marceloaqno
            shfgS
            shfgS
            shfg
            @marceloaqno I finally have the MQTT gateway working after upgrading mosquitto to the latest build... I had installed mosquitto with apt-get under Wheezy which apparently pulled an older version. In retrospect probably should have just upgraded to Jessie from the outset! Working perfectly now (still under wheezy though FWIW)... thanks!
            • b0rmannB
              b0rmannB
              b0rmann
                marceloaqno
                Code Contributor
                @Christian-Simonsen start the gateway with debug enabled:
                mysGateway -d
                • Christian SimonsenC Christian Simonsen
                  Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
                  However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
                  If there is I need to monitor this via OSX Terminal.
                  jerseyguy1996J
                  jerseyguy1996J
                  jerseyguy1996
                  @Christian-Simonsen If you don't have debug enabled you could also just use:
                  tail -f /dev/ttyUSB20
                  My port is named ttyUSB20. You should substitute whatever you have named your port.
                  Christian SimonsenC 1 Reply Last reply
                  • jerseyguy1996J jerseyguy1996
                    Christian SimonsenC
                    Christian SimonsenC
                    Christian Simonsen
                    @jerseyguy1996
                    Thanks I'll test it. But it seems like I've jumped over a step or two. Or something isn't working. Nothing happened when I wrote "Make" in Terminal, so I jumped over this step. I guess that might be the problem.
                    Do I have to configure (./configure -help) or can I use the default values when I connect the NRF24L01 to the GPIO pins?
                    • b0rmannB b0rmann
                      [[topic:post-is-deleted]]
                      marceloaqno
                      Code Contributor
                      @b0rmann what happened? Did you fixed the problem you described in your last message?
                      b0rmannB 1 Reply Last reply
                      • M marceloaqno
                        b0rmannB
                        b0rmannB
                        b0rmann
                        @marceloaqno
                        it's my problem. accidentally disconnected power from nrf24 on running gw
                        • E
                          E
                          ericvdb
                          @marceloaqno I have it completely working now. :satisfied: A Raspberry Pi PulseCounter for water/gas/electricity consumption measurements with ethernet/mqtt. I can post my code here if you want.
                          Minor detail:
                          millis() / 1000;
                          should be
                          millis() * 1000;
                          to get micros() ;)
                          • E ericvdb
                            Minor detail:
                            millis() / 1000;
                            should be
                            millis() * 1000;
                            to get micros() ;)
                            marceloaqno
                            Code Contributor
                            @ericvdb Congrats! oops, sorry about my mistake.
                              Christian SimonsenC
                              Christian Simonsen
                                Christian SimonsenC
                                Christian Simonsen
                                Seems I'm closing in to working solution. I didn't understand how to use the ./configure element before now. However I ended up with these configurations
                                pi@raspberrypi:~ $ ./MySensors/configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24 --my-rf24-irq-pin=15
                                [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
                                [OK] init system detected: systemd
                                make: *** No rule to make target 'clean'.  Stop.
                                [OK] Finished.
                                pi@raspberrypi:~ $ sudo ./MySensors/examples_linux/mysGateway -d
                                mysGateway: Starting gateway...
                                mysGateway: Protocol version - 2.0.1-beta
                                mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
                                mysGateway: TSF:LRT:OK
                                mysGateway: TSM:INIT
                                mysGateway: TSM:INIT:TSP OK
                                mysGateway: TSM:INIT:GW MODE
                                mysGateway: TSM:READY
                                mysGateway: MCO:REG:NOT NEEDED
                                mysGateway: MCO:BGN:STP
                                mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                mysGateway: TSM:READY:NWD REQ
                                mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                mysGateway: TSF:SRT:OK
                                Based on this it seem to all be ok on the Raspberry Pi side.. So I uploaded the "MockMySensors" sketch to my Arduino Uno with NRF24 connected. Below is the code and failure message I get from the Arduino. Do I need to set a gateway address or something?
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=254)
                                TSM:FPAR
                                TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                !TSM:FPAR:FAIL
                                !TSM:FAILURE
                                TSM:PDT```
                                • NiklasON
                                  NiklasON
                                  NiklasO
                                  Thanks for adding signing.
                                  I want to use my rPi to generate random soft serials for my sensors.
                                  Could all three "gen" commands output the line to put in SecurityPersonalizer.ino like it does when using the "set" commands?
                                    [OK] Finished.
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT```
                                    marceloaqno
                                    Code Contributor
                                    #70
                                    @Christian-Simonsen you need to be within the MySensors folders to execute commands configure and make.
                                    I recommend you to test that everything is working before using the option --my-rf24-irq-pin=15
                                    Like this:
                                    cd MySensors
                                    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24
                                    make
                                    • NiklasON NiklasO
                                      marceloaqno
                                      Code Contributor
                                      @NiklasO Done (#622). Thanks for the sugestion.
                                      • M marceloaqno
                                        Like this:
                                        cd MySensors
                                        make
                                        Christian SimonsenC
                                        Christian SimonsenC
                                        Christian Simonsen
                                        @marceloaqno said:
                                        cd MySensors
                                        Thanks for letting me know, didn't know that not running it from the specific folder would have an impact.
                                        I reconfigured it as you recommended. and restarted the gateway, with the result below.
                                        pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d
                                        mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                        mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
                                        mysGateway: !TSF:MSG:LEN,0!=7
                                        mysGateway: !TSF:MSG:LEN,14!=7
                                        What is the best way to test if the gateway work? What sketch should I use on the arduino? and how do I see in Terminal that the mysGateway receive the transfer successfully?
                                        jerseyguy1996J M 2 Replies Last reply
                                        • b0rmannB
                                          b0rmannB
                                          b0rmann
                                          very interesting data...
                                          journalctl -u mysgateway --since 13:15 | grep MSG:READ
                                          Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
                                          Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                                          Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
                                          Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
                                          Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                                          Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                                          Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                                          Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                                          Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
                                          Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
                                          Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
                                          Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                                          Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
                                          Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=12,c=1,t=0,pt=7,l=5,sg=0:34
                                          Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=14,c=1,t=0,pt=7,l=5,sg=0:24
                                          node 2
                                          sensor 167 - dht18b20 indoor
                                          sensor 251 - dht18b20 indoor
                                          node 3
                                          sensor 0 - dht18b20 outdoor
                                          sensor 3 - light (0..100)
                                          sensor 4 - light (0..100)
                                          questions:
                                          why node 2 and node 3 send messages directly and via node 10?
                                          24.6 - is actual value from 2/251, but gateway receive this value from 3/0 How is it possible?
