  2. Announcements
  • b0rmannB b0rmann
    [[topic:post-is-deleted]]
    marceloaqno
    Code Contributor
    @b0rmann what happened? Did you fixed the problem you described in your last message?
    b0rmannB 1 Reply Last reply
    • M marceloaqno
      b0rmannB
      b0rmannB
      b0rmann
      @marceloaqno
      it's my problem. accidentally disconnected power from nrf24 on running gw
      • E
        E
        ericvdb
        @marceloaqno I have it completely working now. :satisfied: A Raspberry Pi PulseCounter for water/gas/electricity consumption measurements with ethernet/mqtt. I can post my code here if you want.
        Minor detail:
        millis() / 1000;
        should be
        millis() * 1000;
        to get micros() ;)
        • E ericvdb
          Minor detail:
          millis() / 1000;
          should be
          millis() * 1000;
          to get micros() ;)
          marceloaqno
          Code Contributor
          @ericvdb Congrats! oops, sorry about my mistake.
          • Christian SimonsenC
            Christian SimonsenC
            Christian Simonsen
              Christian SimonsenC
              Christian Simonsen
              Seems I'm closing in to working solution. I didn't understand how to use the ./configure element before now. However I ended up with these configurations
              pi@raspberrypi:~ $ ./MySensors/configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24 --my-rf24-irq-pin=15
              [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
              [OK] init system detected: systemd
              make: *** No rule to make target 'clean'.  Stop.
              [OK] Finished.
              pi@raspberrypi:~ $ sudo ./MySensors/examples_linux/mysGateway -d
              mysGateway: Starting gateway...
              mysGateway: Protocol version - 2.0.1-beta
              mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
              mysGateway: TSF:LRT:OK
              mysGateway: TSM:INIT
              mysGateway: TSM:INIT:TSP OK
              mysGateway: TSM:INIT:GW MODE
              mysGateway: TSM:READY
              mysGateway: MCO:REG:NOT NEEDED
              mysGateway: MCO:BGN:STP
              mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              mysGateway: TSM:READY:NWD REQ
              mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              mysGateway: TSF:SRT:OK
              Based on this it seem to all be ok on the Raspberry Pi side.. So I uploaded the "MockMySensors" sketch to my Arduino Uno with NRF24 connected. Below is the code and failure message I get from the Arduino. Do I need to set a gateway address or something?
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=254)
              TSM:FPAR
              TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT```
              • NiklasON
                NiklasON
                NiklasO
                Thanks for adding signing.
                I want to use my rPi to generate random soft serials for my sensors.
                Could all three "gen" commands output the line to put in SecurityPersonalizer.ino like it does when using the "set" commands?
                • Christian SimonsenC Christian Simonsen
                  [OK] Finished.
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT```
                  marceloaqno
                  Code Contributor
                  wrote on last edited by marceloaqno
                  #70
                  @Christian-Simonsen you need to be within the MySensors folders to execute commands configure and make.
                  I recommend you to test that everything is working before using the option --my-rf24-irq-pin=15
                  Like this:
                  cd MySensors
                  ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-radio=nrf24
                  make
                  Christian SimonsenC 1 Reply Last reply
                  • NiklasON NiklasO
                    marceloaqno
                    Code Contributor
                    @NiklasO Done (#622). Thanks for the sugestion.
                    • M marceloaqno
                      Like this:
                      cd MySensors
                      make
                      Christian SimonsenC
                      Christian SimonsenC
                      Christian Simonsen
                      @marceloaqno said:
                      cd MySensors
                      Thanks for letting me know, didn't know that not running it from the specific folder would have an impact.
                      I reconfigured it as you recommended. and restarted the gateway, with the result below.
                      pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d
                      mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                      mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
                      mysGateway: !TSF:MSG:LEN,0!=7
                      mysGateway: !TSF:MSG:LEN,14!=7
                      What is the best way to test if the gateway work? What sketch should I use on the arduino? and how do I see in Terminal that the mysGateway receive the transfer successfully?
                      jerseyguy1996J M 2 Replies Last reply
                      • b0rmannB
                        b0rmannB
                        b0rmann
                        very interesting data...
                        journalctl -u mysgateway --since 13:15 | grep MSG:READ
                        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
                        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
                        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
                        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                        Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                        Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
                        Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
                        Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
                        Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
                        Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
                        Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
                        Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=12,c=1,t=0,pt=7,l=5,sg=0:34
                        Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=14,c=1,t=0,pt=7,l=5,sg=0:24
                        node 2
                        sensor 167 - dht18b20 indoor
                        sensor 251 - dht18b20 indoor
                        node 3
                        sensor 0 - dht18b20 outdoor
                        sensor 3 - light (0..100)
                        sensor 4 - light (0..100)
                        questions:
                        why node 2 and node 3 send messages directly and via node 10?
                        24.6 - is actual value from 2/251, but gateway receive this value from 3/0 How is it possible?
                          Christian SimonsenC
                          Christian Simonsen
                          wrote on last edited by Christian Simonsen
                          #74
                          Is there anyone here that can give me some one-to-one support this evening to setup the Raspberry Pi + NRF24L01 as a gateway with MyController, and a Arduino Uno + NRF24L01 as Sensor node. I'm stuck after trying various things over the past week, so looks like I need some additional skills/knowledge to get the first setup working.
                          Maybe we can use Skype or some other medium. I will gladly pay a bit for this support if anyone is interested. I have some free time from 18:00 CET - 23:30 CET today...
                          • nicoN
                            nicoN
                            nico
                            hi, the gateway works but how display sensors in domoticz?
                            Thank you very much
                            alexsh1A 1 Reply Last reply
                            • nicoN nico
                              Thank you very much
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @nico you need a sensor to send data to GW and assuming you have GW added to Domoticz, Domoticz will add up corresponding values to "Devices"
                              • nicoN
                                nicoN
                                nico
                                I have a gateway and 1 sensor ,obviously.
                                I have added serial GW but anyone sensor appear, i'm sure that the sensor works, and the gateway also (see with the command mysGateway -d).
                                Can you have any idea ? Thank you
                                • nicoN nico
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @nico I would suggest you open up a different post in the Troubleshooting section regarding this matter
                                  1 post GW and sensor logs
                                  2. How do you know that the GW was added to Domoticz? Logs please?
                                    @marceloaqno said:
                                    cd MySensors
                                    jerseyguy1996J
                                    jerseyguy1996J
                                    jerseyguy1996
                                    @Christian-Simonsen
                                    You can pretty much test out using any of the arduino examples here:
                                    https://github.com/mysensors/MySensors/tree/development/examples
                                    Each one will present itself to the gateway when it starts up and you will see the presentation in the debug log. Make sure to run:
                                    https://github.com/mysensors/MySensors/tree/development/examples/ClearEepromConfig
                                    on the arduino first to make sure it starts with a fresh eeprom. After you select an Arduino sketch to test it with (seriously it doesn't matter which one you try) make sure to look at the sketch and add:
                                    #define MY_NODE_ID 4
                                    For MY_NODE_ID you can select any number. Just make sure that each new sensor node that you create has a different node number so like start out at MY_NODE_ID 1 and when you make another sensor node you can #define MY_NODE_ID 2 and so on.
                                    Next load it up to the Arduino, open the serial monitor, and see what happens. If you watch the serial monitor on the arduino you will see it present itself to the gateway and then you can confirm it in the debug log on the raspberry pi.
                                    I think it is pretty normal to have the problems you are having. I uninstalled and reinstalled the gateway 3 times on the Raspberry Pi before I finally got it all figured out. Once you get it running it is a glorious thing.
                                      @marceloaqno said:
                                      cd MySensors
                                      marceloaqno
                                      Code Contributor
                                      #80
                                      @Christian-Simonsen
                                      looks like a power issue with the nrf24 module.
                                      • b0rmannB b0rmann
                                        node 2
                                        node 3
                                        questions:
                                        marceloaqno
                                        Code Contributor
                                        @b0rmann Can you provide a full debug log of all involved nodes?
                                        • Patrik SöderströmP
                                          Patrik SöderströmP
                                          Patrik Söderström
                                          Can I attach one or more DallasTemp sensors on the Raspberry Pi gateway?
