  3. Vera
  4. Vera Plus and MySensors Local Serial Gateway
12 Posts 2 Posters 4.4k Views 2 Watching
    I haven't tried the Vera plugin with locally attached sensors. Took another look at the code but I can't see any reason why it shouldn't work.
    Might be good to introduce some more log-entries in the plugin lua code to see where it fails.
    Here:
    https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L328
    and here:
    https://github.com/mysensors/Vera/blob/development/L_Arduino.lua#L397
    briskspiritB 1 Reply Last reply
    • briskspiritB
      briskspiritB
      briskspirit
      Mmm, will try.. but I am new to LUA)) So will try to understand it.
      I am clicking start include and then reset my gateway, right?
      As you see the problem is in gateway inclusion and discarded commands
        Here:
        and here:
        briskspiritB
        briskspiritB
        briskspirit
        @hek
        And which branch I should use? development or UI7 ?
          Think they are the same at the moment.
            briskspiritB
            briskspiritB
            briskspirit
            @hek
            Still can't see in code why it get discarded.. Saw that there is discard for 1.0 versions in payload - changed to 2.0 in my sketch - no luck.
            Here is my sketch, look plz maybe somewhere is an error, but took here on forum from some member who has it working on Vera:
            //Comento la siguiente linea para que no necesite radio
            //#define MY_RADIO_NRF24
            // Enable serial gateway
            #define MY_GATEWAY_SERIAL
            //#define MY_BAUD_RATE 9600
            // Enable inclusion mode
            //Para el sensor de temperatura
            #ifdef TEMP
             #include <OneWire.h>
             #define ONE_WIRE_BUS 2
             MyMessage msg(0,V_TEMP);
            //Structura de reles
            typedef struct  {
             int  pin;
             char desc[20];
             bool ON;
             bool OFF;
            } sRELE;
            sRELE Rele [] = { {13 , "LED", HIGH, LOW},
                             {31 , "RELE ASPERSOR PORCHE", LOW, HIGH},
                             {33 , "RELE TURBINAS", LOW, HIGH},
                             {35 , "RELE GOTEROS BAJOS", LOW, HIGH}
            #ifdef TEMP
             sensors.begin();
             //Para los reles
              // Serial.println("start call Setup");
             for (int sensor=0 ; sensor<NUMBER_OF_RELAYS;sensor++) {
               // Poner el rele en output mode
               pinMode(Rele[sensor].pin, OUTPUT);
               // Poner el rele en el ultimo estado conocido (usando eeprom storage)
               digitalWrite(Rele[sensor].pin, loadState(sensor)?Rele[sensor].ON:Rele[sensor].OFF);
              // Serial.println("End call Setup");
             // Presentar los sensores y actuadores locales
             //Serial.println("start call presentation");
             // Mandar la info del sketch
             sendSketchInfo("myGateway", "2.0");
             //Presentar los reles
             for (int rele=0; rele<NUMBER_OF_RELAYS;rele++) {
               // Registrar todos los reles al gw
               present(rele, S_LIGHT,Rele[rele].desc);
             //Serial.println("End call presentation");
            #ifdef TEMP
             //Presento el sensor de temperatura
             present(9,S_TEMP,"SENSOR_TEMP");
            bool STATUS;
            #ifdef TEMP
            // Serial.print("Solicitando temperaturas...");
             sensors.requestTemperatures(); // Send the command to get temperatures
             float temperatura = sensors.getTempCByIndex(0);
             send(msg.setSensor(9).set(temperatura,1));
            // Serial.println("DONE");
             sleep(2000);
             // Solo esperamos mensajes V_LIGTH de momento, pero lo chequeamos por si acaso.
             if (message.type==V_LIGHT) {
                // Cambiar estado del rele
                digitalWrite(Rele[message.sensor].pin, message.getBool()?Rele[message.sensor].ON:Rele[message.sensor].OFF);
                // Almacenar estado en la eeprom
                // Escribir informacion de debug
               // Serial.print("Cambio entrante para sensor:");
               // Serial.print(message.sensor);
               // Serial.print(", Nuevo status: ");
                //Serial.println(message.getBool());
            • briskspiritB
              briskspiritB
              briskspirit
              As I understand the code, when I reset gateway and it was in inclusion mode - I get here:
              elseif (messageType==msgType.PRESENTATION) then
              log("Presentation: ".. s)
              presentation(incomingData, device, childId, altId)
              But I don't see any code in presentation function that belongs to creation of new device in Vera...
              I see creation at processInternalMessage, but it would not run as I get Presentation: 0;255;0;0;17;2.0.1-beta , but for inclusion it should be Presentation: 0;255;3;0;17;2.0.1-beta ? (message_type 3, not 0 as 0 do nothing with dev inclusion)
                Can't find any obvious error in the sketch.
                The creation process starts after inclusion mode ends.. see my link above.
                  briskspiritB
                  briskspiritB
                  briskspirit
                  Nope, I am sorry, but you are wrong... In case of local sensor it would not start(and I tested that with debug log in each function).
                  Made some test function called processInclusion and now I got new devices listed) But because I am not a coder and don't know LUA - need to polish it a bit.
                  The problem is that I need to push reset button on arduino, after that gateway send presentation BUT without internal type of message! So there is two ways:
                  1 - make function for just inclusion process and put in right after presentation fujnction(pice of code from processInternal** function)
                  2 - Make gateway to send some internal command right after presentation(not tested)
                  First way tested, but I need to reset gateway same quantity of times as I have external sensors. So each new sensor is added after each reset.
                  • briskspiritB
                    briskspiritB
                    briskspirit
                    wrote on last edited by briskspirit
                    (Edited post)
                    Thought all night about my problem and it's solution... Just was one thought that dev's of mysensors plugin can't make mistake in old tested plugin) Reviewed plugin code once again and understood it's logic. So first we get called Presentation function which stores new devices in array and than we should get command from gateway about finished inclusion process and plugin start to add devices to Vera. So the problem is: when we don't use radio and only local sensors we don't get message about inclusion finish! )
                    Solution is to send this message manually from gateway right after presentation processes. Should look like 0;255;3;0;5;0
                    So I have added this lines to my Arduino sketch in presentation function:
                    Serial.print("0;255;3;0;5;0");
                      Serial.print("\n");
                    This solution will work without coding to existing Vera plugin :)
                    (Sorry, didn't found any other way to send this message like with MyMessage container)
                    • briskspiritB briskspirit
                      (Edited post)
                        Serial.print("\n");
                      briskspiritB
                      briskspiritB
                      briskspirit
                      @hek , maybe you could help to do that more right? And I think that this should be added to GitHub as a bug for 2.0.1-dev lib version (don't have an account on git)
