  2. Bug Reports
  3. [solved] RFM69 based nodes unable to report Lib Version
51 Posts 8 Posters 24.9k Views 5 Watching
  • T
    TimO
    I've tinkered a little w5100-RFM69-gateway lateley wich works with the softspi implementation I've tried to push the other day. I'll give your implementation a try at the weekend.
      @TimO
      ah okay! welcome betatester :)
        wrote on last edited by hek
        @korttoma
        The node seems to send parent info here:
        TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
        And myscontroller logs this:
        17.10.2016 9:12:04 RX 101;255;3;0;6;0
        • scalzS scalz
          @korttoma
          I have not looked at your msg version problem yet.
          Well if you want to try something it's possible...so here it is:
          • List of changes, some notes, and current status : https://docs.google.com/spreadsheets/d/191NpTBogLPijYxS2V_oHZnVlcW4B65J1kXAqYrr4qeE/edit#gid=884074439
          • https://github.com/scalz/Mysensors
          Don't try the listenmode for the moment plz :)
          I'm not sure yet, but i think i will remove conditional define on ATC as it does not use lot of mem. etc..
          Do you use softspi, w5100. I have all hardware but no time to test this part. This should work now.
          Sidenote:
          I'm ok to help one or two betatester only for the moment. Lucky!
          Be a little bit more patient, PR should go soon now as you can see from the current status ;)
          Enjoy :smiley:
          chrilleC
          chrilleC
          chrille
          It's great to see work being put into the RFM69 driver. I have tried to install your code and updated my gateway and a sensor node
          On the sensor node I added
          sendSignalStrength(1);
          sendRadioTxLevel(1);
          and in the debug window I see
          6899 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=29,pt=1,l=1,sg=0,ft=0,st=OK:51
          7035 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=30,pt=1,l=1,sg=0,ft=0,st=NACK:0
          Message type 30 always fails (st=NACK) - is this expected?
          Gateway is ESP8266 and node is Anarduino (328p+RFM69CW)
          J 1 Reply Last reply
          • chrilleC chrille
            J
            J
            jpaulin
            wrote on last edited by jpaulin
            @korttoma
            I get exactly the same bug. I found a way to solve it, but not sure if it's the root cause.
            I use RFM69W and the latest release from the Development Branch.
            From your message dump:
            TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            !TSF:MSG:SEND,101-101-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
            The Internal Presentation Message with Lib Version as payload always fails. (!TSF: c=0, t=17, st=NACK:2.0.1-beta)
            The message is sent immediately after the previously sent internal message (TSF: c=3, t=15, st=OK:0100) (t=15 => I_REQUEST_SIGNING).
            The Gateway responds the Signing Preference Message to the node exactly at the same time the node tries to send the Lib Version Presentation Message to the Gateway. Seems that won't work. There's no buffering?
            I added a 1s delay for test purpose in MySensorsCore.cpp to give time to finish the response from the gateway before sending the Lib Version Presentation Message.
            New message dump from my test-node after changes:
            TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
            TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            Now a new message appears in the node, the response message from the Gateway to the Signing Preference Message, and the presentation of the Lib Version works as expected.
            In MySensorsCore.cpp at line 216 I added a wait(1000); to mitigate the issue.
            	// Send signing preferences for this node to the GW
            	signerPresentation(_msgTmp, GATEWAY_ADDRESS);
            wait(1000);
            		// Send presentation for this radio node
            	#if defined(MY_REPEATER_FEATURE)
            		(void)present(NODE_SENSOR_ID, S_ARDUINO_REPEATER_NODE);
            		(void)present(NODE_SENSOR_ID, S_ARDUINO_NODE);
            I guess the final patch would look different and would need to be looked into by @Anticimex or @hek. :smiley:
            AnticimexA 1 Reply Last reply
            • J jpaulin
              @korttoma
              wait(1000);
              AnticimexA
              AnticimexA
              Anticimex
              @jpaulin the signing backend is already waiting for the GW to send a message. So if it is not waiting long enough I believe the existing delay should be increased instead: https://github.com/mysensors/MySensors/blob/development/core/MySigning.cpp#L158
              tekkaT 1 Reply Last reply
              • AnticimexA Anticimex
                tekkaT
                tekkaT
                tekka
                @Anticimex This is a conditional wait(), i.e. only when signing is enabled: https://github.com/mysensors/MySensors/blob/development/core/MySigning.cpp#L154-L160
                Since the GW always replies to signing preferences, but the node only waits if signing is enabled - this message will eventually collide with the following lib version message, as seen above.
                I suggest removing the surrounding #ifdef.
                • tekkaT tekka
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @tekka true. Moving the existing delay outside the preprocessor condition should help.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    @jpaulin could you please file a pull request with the delay moved outside the preprocessor condition (as you have the rig to verify the change works)?
                      J
                      J
                      jpaulin
                      @Anticimex
                      I don't know how to file a pull request, so I put the test results here.
                      Modified as follows to remove the preprocessor condition at: https://github.com/mysensors/MySensors/blob/development/core/MySigning.cpp#L154-L160
                      // #if defined(MY_SIGNING_FEATURE)
                          // If we do support signing, wait for the gateway to tell us how it prefer us to transmit our messages
                          if (destination == GATEWAY_ADDRESS) {
                      	    SIGN_DEBUG(PSTR("Waiting for GW to send signing preferences...\n"));
                      	    wait(2000, C_INTERNAL, I_SIGNING_PRESENTATION);
                      // #endif
                      solves the issue.
                      At the same time the internal message received from the gateway seems to be erroneously transferred to the receive() function in a sketch. Adding to the sketch
                          Serial.println("something came in");
                      gets the message dump:
                      2310 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2332 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      something came in
                      2409 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
                      2496 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      To solve this I made the following change to _processInternalMessages(void) in MySensorsCore.cpp.
                      Line https://github.com/mysensors/MySensors/blob/development/core/MySensorsCore.cpp#L407 is replaced with:
                      	else if (type == I_SIGNING_PRESENTATION) {
                      	else return false;
                      The message dump now looks like this:
                      2250 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2269 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2331 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
                      2441 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      At the API description page https://www.mysensors.org/download/serial_api_20 seems to be another error.
                      For the internal message t=15 the name description
                      I_REQUEST_SIGNING 	15 	Used between sensors when initialting signing.
                      should be changed to
                      I_SIGNING_PRESENTATION 	15 	Provides signing related preferences.
                      This I think is relevant both for the master and the development branch.
                      • J jpaulin
                        @Anticimex
                        // #endif
                        solves the issue.
                        something came in
                        	else return false;
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @jpaulin thanks for the updates. I will have a look at making a pr when I get opportunity. @hek does the documentation issue sound familiar? ;)
                        • J jpaulin
                          @Anticimex
                          // #endif
                          solves the issue.
                          something came in
                          	else return false;
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @jpaulin I have made a pull request. My solution differs slightly from your as the I_SIGNING_PRESENTATION should never reach the _processInternalMessages function. I do however not have the ability to test so I would appreciate if you could test the PR for me?
                          Thanks for finding and pointing out the flaws! :D
                            J
                            J
                            jpaulin
                            @Anticimex
                            I updated my node and GW with your pull request and made some basic tests and it seems to work ok with my sketch. I added MY_DEBUG_VERBOSE_SIGNING and got the following messages.
                            From the node:
                            2205 TSM:READY
                            2220 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            2226 Waiting for GW to send signing preferences...
                            2280 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            2285 Received signing presentation, but signing is not supported (message ignored)
                            2349 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
                            2450 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                            From the GW:
                            0;255;3;0;9;TSF:MSG:PINGED,ID=3,HP=1
                            0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            0;255;3;0;9;Informing node 3 that we do not require signatures because we do not support it
                            0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
                            0;255;3;0;9;Sending message on topic: my_RFM69_gw1-out/3/255/0/0/17
                            0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                            Do you need some more testing?
                            • J jpaulin
                              @Anticimex
                              From the node:
                              2205 TSM:READY
                              From the GW:
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @jpaulin thanks for testing. The change should have little effect for people using signing. The issue is for people who does not use it as the node did not wait for a gw response in that case.
                              • korttomaK
                                korttomaK
                                korttoma
                                tried the latest development branch on my test system and the results are good so far. Now I just need to update my "real" system also. Thanks to everyone that participated in solving this!!
                                • Tomas
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  Updated now also 2 nodes in my "real" system and both now successfully reported Lib version. I did not update the GW. Maybe it is safe to say that the Lib reporting problem is solved now.
                                  Now I will try to look in to the sofSerial RFM69 solution that @scalz is working on, do you have any eta on when you will try to include our solution in the official MySensors development branch?
                                  Any recommendations for the wiring of an W5100/RFM69 Gateway?
                                  • Tomas
                                    #21
                                    i have removed my stuff for the moment..
                                    for integration in mysensors, it's coreteam work in progress, thx to @Tekka ;)
                                    Once, someone smart told me that 1+1=3, quite true :) and with Tekka i think we can say = 4 ahah
                                    So for an eta.., i prefer not saying anything lol, just i'm back on this for the week, i was playing with other stuff..
                                    • korttomaK korttoma
                                      J
                                      J
                                      jpaulin
                                      @korttoma I have an up and running RFM69 GW with W5100 (actually a W5500, but it's the same). I'm not using softSerial in my setup. With this it is possible to integrate with eg. Moteino or Anarduino, which comes with the radio chip preinstalled on the Arduino compatible boards. But a standard arduino with a separate chip would work as well (lower price). The GW-RFM69 has been stable and flawless, as far as I can see, for quite some time. The SPI for the RFM69 and W5500 uses the following pins in my setup.
                                      RFM69W:
                                      • SCK = 13
                                      • MISO = 12
                                      • MOSI = 11
                                      • CS = 10
                                      • IRQ = 2
                                      W5500:
                                      • SCK = 13
                                      • MISO = 12
                                      • MOSI = 11
                                      • CS = 7
                                      I'll try to share wire diagrams and software setup later. I had to do some tweakings in the ethernet.h file to make it work.
                                      korttomaK 1 Reply Last reply
                                      • J jpaulin
                                        RFM69W:
                                        • SCK = 13
                                        • MISO = 12
                                        • MOSI = 11
                                        • CS = 10
                                        • IRQ = 2
                                        W5500:
                                        • SCK = 13
                                        • MISO = 12
                                        • MOSI = 11
                                        • CS = 7
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @jpaulin I am very interested in your solution. Could it work with a normal Arduino Pro mini 3,3V version? Just so that I know if I need to order some parts or can work with what I have.
                                        • Tomas
                                        J 2 Replies Last reply
                                          J
                                          J
                                          jpaulin
                                          @korttoma
                                          Yes, it should work with an Arduino Pro Mini 3.3V. Personally I'm using for the moment an Anarduino. But it's almost the same.
                                          12.5k
