  3. [contest] My 12 input high precision pulse counter (kWh/ W)
[contest]
43 Posts 9 Posters 55.3k Views 10 Watching
  • M MarkV
    Thanks for the commet and i defently need some help.
    Sorry i didn't see your "new" post about the pulse counter.
    I'm uploading the sketches now.
    I only got one question, what should i uncomment in the sketches when i'm not using the display and counter?
    And when i got this working, is it possible to add to other sensors, a CNY70 (reflector sensor) to readout a water and gas meter? (but this is the next step ;-) )
    I also installed the beta version from domoticz.
    AWIA
    AWIA
    AWI
    @MarkV Next to my reaction in the other post. I cannot be hard to add more (different) sensors to the sketch. As long as you do not attach LCD / rotary, you will only miss the information and interaction.
    • P
      P
      poldim
      Merlin Gerin, Eaton, and Beger...quite the mix.
      I like the domoticz display....whats your overall opinion on it?
      • J
        J
        jeti
        wrote on last edited by jeti
        #35
        did anybody already upgraded the 12 Input pulse counter to 2.0? just asking :bowtie:
        AWIA 1 Reply Last reply
        • J jeti
          AWIA
          AWIA
          AWI
          @jeti If you are just asking. :smirk: I have updated it to 2.0 beta
          J 1 Reply Last reply
          • AWIA AWI
            J
            J
            jeti
            @AWI: :+1:
            would you mind sharing the sketches? :innocent:
            • J jeti
              @AWI: :+1:
              AWIA
              AWIA
              AWI
              @jeti Take a loot at git. The master sketch needs a little change (mysensors.h i.s.o. mysensor.h) The slave is not changed. I am a lttle disabled at the moment, so can't help you any furthe right now.
              J NickBuilderN 2 Replies Last reply
              • AWIA AWI
                J
                J
                jeti
                @AWI thanks alot, i will have a look :+1:
                hopefully nothing serios... either way all the best :thumbsup:
                • AWIA AWI
                  NickBuilderN
                  NickBuilderN
                  NickBuilder
                  wrote on last edited by NickBuilder
                  #40
                  Hi @AWI!
                  The GIT link is broken. Can I find your sketch for this counter elsewhere?
                  I would like to implement this counter as a "local sensor" on an ethernet gateway without radio. I guess this would require some tweaking but right now I'm confident. x)
                  • NickBuilderN NickBuilder
                    Hi @AWI!
                    AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    #41
                    @NickBuilder soory but the transition to 2.0 gave me a little GIT headache and I broke some links.. I restored the pulse counter sketches. Be carefull with combining the sketch with ethernet functionality... Both eat a lot of RAM/ROM and are time critical.
                    The sketch also stores a large amount of data in EEPROM. Be aware that the space there is more limited than the 256 bytes mentioned with saveState().
                    Please share your progress
                    • AWIA AWI
                      J
                      J
                      jeti
                      @AWI as did got get my modifcations 100% running I was pumped to see your latest update, but for reasons i do not understand i get an error while compiling:
                      error: 'hour' was not declared in this scope
                      same is the case for setTime, minute etc...
                      i already tried some stuff with the time.h but it seems nothing has an impact, not even deleting the whole library (which should end in a "libraby not found" error, but only shows the errors described above)
                      any idea what to look for?
                      thanks
                      • J jeti
                        thanks
                        J
                        J
                        jeti
                        ok found the answer :stuck_out_tongue:
                        the latest Time.h is only pointing to TimeLib.h so if I am calling TimeLib.h (instead of Time.h) directly it compiles
