  3. [contest] My 12 input high precision pulse counter (kWh/ W)
[contest]
43 Posts 9 Posters 54.8k Views 10 Watching
    MarkV
    wrote on last edited by MarkV
    #32
    Thanks for the commet and i defently need some help.
    Sorry i didn't see your "new" post about the pulse counter.
    I'm uploading the sketches now.
    I only got one question, what should i uncomment in the sketches when i'm not using the display and counter?
    And when i got this working, is it possible to add to other sensors, a CNY70 (reflector sensor) to readout a water and gas meter? (but this is the next step ;-) )
    I also installed the beta version from domoticz.
    AWIA 1 Reply Last reply
    • M MarkV
      AWIA
      AWIA
      AWI
      @MarkV Next to my reaction in the other post. I cannot be hard to add more (different) sensors to the sketch. As long as you do not attach LCD / rotary, you will only miss the information and interaction.
      • P
        P
        poldim
        Merlin Gerin, Eaton, and Beger...quite the mix.
        I like the domoticz display....whats your overall opinion on it?
        • J
          J
          jeti
          wrote on last edited by jeti
          #35
          did anybody already upgraded the 12 Input pulse counter to 2.0? just asking :bowtie:
          • J jeti
            AWIA
            AWIA
            AWI
            @jeti If you are just asking. :smirk: I have updated it to 2.0 beta
            J 1 Reply Last reply
            • AWIA AWI
              J
              J
              jeti
              @AWI: :+1:
              would you mind sharing the sketches? :innocent:
              • J jeti
                @AWI: :+1:
                AWIA
                AWIA
                AWI
                @jeti Take a loot at git. The master sketch needs a little change (mysensors.h i.s.o. mysensor.h) The slave is not changed. I am a lttle disabled at the moment, so can't help you any furthe right now.
                J NickBuilderN 2 Replies Last reply
                • AWIA AWI
                  J
                  J
                  jeti
                  @AWI thanks alot, i will have a look :+1:
                  hopefully nothing serios... either way all the best :thumbsup:
                  • AWIA AWI
                    NickBuilderN
                    NickBuilderN
                    NickBuilder
                    wrote on last edited by NickBuilder
                    #40
                    Hi @AWI!
                    The GIT link is broken. Can I find your sketch for this counter elsewhere?
                    I would like to implement this counter as a "local sensor" on an ethernet gateway without radio. I guess this would require some tweaking but right now I'm confident. x)
                    • NickBuilderN NickBuilder
                      Hi @AWI!
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #41
                      @NickBuilder soory but the transition to 2.0 gave me a little GIT headache and I broke some links.. I restored the pulse counter sketches. Be carefull with combining the sketch with ethernet functionality... Both eat a lot of RAM/ROM and are time critical.
                      The sketch also stores a large amount of data in EEPROM. Be aware that the space there is more limited than the 256 bytes mentioned with saveState().
                      Please share your progress
                      • AWIA AWI
                        J
                        J
                        jeti
                        @AWI as did got get my modifcations 100% running I was pumped to see your latest update, but for reasons i do not understand i get an error while compiling:
                        error: 'hour' was not declared in this scope
                        same is the case for setTime, minute etc...
                        i already tried some stuff with the time.h but it seems nothing has an impact, not even deleting the whole library (which should end in a "libraby not found" error, but only shows the errors described above)
                        any idea what to look for?
                        thanks
                        • J jeti
                          thanks
                          J
                          J
                          jeti
                          ok found the answer :stuck_out_tongue:
                          the latest Time.h is only pointing to TimeLib.h so if I am calling TimeLib.h (instead of Time.h) directly it compiles
