  3. Nodemcu + RFM69. Level converter needed?
18 Posts 5 Posters 7.0k Views 4 Watching
  • G gmccarthy
    After many months of struggling with the poor range of NRF24L01+ (And having tried all the tricks) I'm not trying my luck with the RFM69 radio. (RFM69CW - 868Mhz)
    When connecting the rfm69 to the nodemcu (For the ESP8266 gateway), is a 5v to 3.3v logic level converted required?
    For the projects listed it says you need one when connecting it to the Arduino but wasn't sure about the Nodemcu.
    Also can someone confirm the wiring - its not 100% clear.
    Is this correct?
    Nodemcu ---> RFM69
    D2 ---> N/C
    D8 ---> NSS
    D5 ---> SCK
    D7 ---> MOSI
    D6 ---> MISO
    N/C ---> D100
    And of course GND and VCC (3.3v)
    @gmccarthy I don't know about the connections, but the nodemcu is 3.3V so there is no need for a level converter.
    • G
      G
      gmccarthy
      Thanks - I can only think my connections are wrong then. Can't get any comms going on the rfm69.
      • korttomaK
        korttomaK
        korttoma
        You allso need to connect the DI00 for the RFM69.
        • Tomas
        G 1 Reply Last reply
        • korttomaK korttoma
          G
          G
          gmccarthy
          @korttoma That probably explains why I can't get it working. Do you know what pin it needs to connect to on the nodemcu?
          On this link the DI00 is gray (https://www.mysensors.org/build/connect_radio) but here it doesnt show where to connect it (https://www.mysensors.org/build/esp8266_gateway)
          • E
            E
            emc2
            Did you try @chrille wiring:
            https://forum.mysensors.org/topic/3061/solved-esp8266-gateway-with-rfm69-wdt-issues/4
            exemple here:
            https://github.com/janchrillesen/arduino-stuff/blob/master/GatewayESP8266-RFM69.ino
            • korttomaK
              korttomaK
              korttoma
              I do not know about the nodemcu but I connected IRQ (DI00 of RFM69) to GPIO4 on my ESP-07 and added the following line to the sketch:
              #define MY_RF69_IRQ_PIN 4
              • Tomas
              • E emc2
                exemple here:
                G
                G
                gmccarthy
                @emc2 Thanks for the link.
                I've connected up the missing pin and believe the wiring is all correct. Double checked the wiring on the arduino mini as well to the rfm69 (Via logic converter)
                Still can't get it to communicate using DallasTemperatureSensor-RFM69.ino
                Starting sensor (RRNNA-, 2.0.0)
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=5)
                TSM:FPAR
                TSP:MSG:SEND 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                • E
                  E
                  emc2
                  And you set up the pins radio type in your gateway sketch too right?
                  #define MY_RADIO_RFM69
                  #define MY_RF69_SPI_CS 15
                  • E emc2
                    G
                    G
                    gmccarthy
                    @emc2 Yes
                    • E
                      E
                      emc2
                      I guess you would need to give the logs for the gateway too, to see if you have a radio fail somewhere.
                      • E emc2
                        G
                        G
                        gmccarthy
                        wrote on last edited by gmccarthy
                        @emc2 This is all I see on the gateway:
                        0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:RADIO:OK
                        0;255;3;0;9;TSM:GW MODE
                        0;255;3;0;9;TSM:READY
                        scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 6
                        cnt
                        f r0, scandone
                        connected with homenet, channel 1
                        dhcp client start...
                        ..............ip:192.168.1.100,mask:255.255.255.0,gw:192.168.1.1
                        .IP: 192.168.1.100
                        pm open,type:2 0
                        0;255;3;0;9;TSP:SANCHK:OK
                        • E
                          E
                          emc2
                          It seems good on the gateway to me, no radio error at least.
                          Past that no idea.
                          • E emc2
                            Past that no idea.
                            G
                            G
                            gmccarthy
                            @emc2 Thanks. Will keep digging but I"m almost out of idea as well. :(
                            • E
                              E
                              emc2
                              @gmccarthy maybe an interesting read:
                              https://forum.mysensors.org/topic/4889/esp8266-rfm69-gateway/5
                              • korttomaK
                                korttomaK
                                korttoma
                                On the arduino mini I think you should connect the DI00 (IRQ) to pin 2 like you see on this page
                                For some CPU types the IRQ pin is hard coded and can not be re-assigned.
                                • Tomas
                                • TON RIJNAARDT
                                  TON RIJNAARDT
                                  TON RIJNAARD
                                  @gmccarthy i have insert this line in the gateway then was it working for me
                                  #define MY_RFM69_PA_LEVEL RF69_PA_LOW
                                  • E emc2
                                    G
                                    G
                                    gmccarthy
                                    @emc2 Interesting read.
                                    @korttoma I've connected up IRQ line. Still no luck,
                                    @TON-RIJNAARD Have tried that now as well. No luck.
                                    Tried going back to basics and now have 2 x Arduino pros with RFM69 - both loaded with pingpong script.
                                    Don't know where I'm going wrong but I can't even start the script - entering 1 or T does nothing. (I"ve used the script before with the NRF radio and it works)
                                    Have also tried the latest dev version.
                                    Just keep getting this on both arduinos:
                                    0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.0.1-beta
                                    4 TSM:INIT
                                    1 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.0.1-beta
                                    5 TSM:INIT
                                    7 TSM:INIT:TSP OK
                                    8 TSM:FPAR
                                    138 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    2145 !TSM:FPAR:NO REPLY
                                    2147 TSM:FPAR
                                    2277 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    4284 !TSM:FPAR:NO REPLY
                                    4286 TSM:FPAR
                                    4416 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    6423 !TSM:FPAR:NO REPLY
                                    6425 TSM:FPAR
                                    6555 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    8562 !TSM:FPAR:FAIL
                                    8563 TSM:FAIL:CNT=1
                                    8565 TSM:FAIL:PDT
                                    12.5k
