  3. Nodemcu + RFM69. Level converter needed?
18 Posts 5 Posters 6.7k Views 4 Watching
  • G Offline
    G Offline
    gmccarthy
    wrote on last edited by gmccarthy
    After many months of struggling with the poor range of NRF24L01+ (And having tried all the tricks) I'm not trying my luck with the RFM69 radio. (RFM69CW - 868Mhz)
    When connecting the rfm69 to the nodemcu (For the ESP8266 gateway), is a 5v to 3.3v logic level converted required?
    For the projects listed it says you need one when connecting it to the Arduino but wasn't sure about the Nodemcu.
    Also can someone confirm the wiring - its not 100% clear.
    Is this correct?
    Nodemcu ---> RFM69
    D2 ---> N/C
    D8 ---> NSS
    D5 ---> SCK
    D7 ---> MOSI
    D6 ---> MISO
    N/C ---> D100
    And of course GND and VCC (3.3v)
    • G gmccarthy
      Is this correct?
      Nodemcu ---> RFM69
      D2 ---> N/C
      D8 ---> NSS
      D5 ---> SCK
      D7 ---> MOSI
      D6 ---> MISO
      N/C ---> D100
      @gmccarthy I don't know about the connections, but the nodemcu is 3.3V so there is no need for a level converter.
      • G Offline
        G Offline
        gmccarthy
        Thanks - I can only think my connections are wrong then. Can't get any comms going on the rfm69.
        • K Offline
          K Offline
          korttoma
          You allso need to connect the DI00 for the RFM69.
          • Tomas
          G 1 Reply Last reply
          • K korttoma
            G Offline
            G Offline
            gmccarthy
            @korttoma That probably explains why I can't get it working. Do you know what pin it needs to connect to on the nodemcu?
            On this link the DI00 is gray (https://www.mysensors.org/build/connect_radio) but here it doesnt show where to connect it (https://www.mysensors.org/build/esp8266_gateway)
            • E Offline
              E Offline
              emc2
              Did you try @chrille wiring:
              https://forum.mysensors.org/topic/3061/solved-esp8266-gateway-with-rfm69-wdt-issues/4
              exemple here:
              https://github.com/janchrillesen/arduino-stuff/blob/master/GatewayESP8266-RFM69.ino
              • K Offline
                K Offline
                korttoma
                I do not know about the nodemcu but I connected IRQ (DI00 of RFM69) to GPIO4 on my ESP-07 and added the following line to the sketch:
                #define MY_RF69_IRQ_PIN 4
                • Tomas
                • E emc2
                  exemple here:
                  G Offline
                  G Offline
                  gmccarthy
                  @emc2 Thanks for the link.
                  I've connected up the missing pin and believe the wiring is all correct. Double checked the wiring on the arduino mini as well to the rfm69 (Via logic converter)
                  Still can't get it to communicate using DallasTemperatureSensor-RFM69.ino
                  Starting sensor (RRNNA-, 2.0.0)
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=5)
                  TSM:FPAR
                  TSP:MSG:SEND 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  • E Offline
                    E Offline
                    emc2
                    And you set up the pins radio type in your gateway sketch too right?
                    #define MY_RADIO_RFM69
                    #define MY_RF69_SPI_CS 15
                    • E emc2
                      G Offline
                      G Offline
                      gmccarthy
                      @emc2 Yes
                      • E Offline
                        E Offline
                        emc2
                        I guess you would need to give the logs for the gateway too, to see if you have a radio fail somewhere.
                        • E emc2
                          G Offline
                          G Offline
                          gmccarthy
                          @emc2 This is all I see on the gateway:
                          0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSM:RADIO:OK
                          0;255;3;0;9;TSM:GW MODE
                          0;255;3;0;9;TSM:READY
                          scandone
                          state: 0 -> 2 (b0)
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 6
                          cnt
                          f r0, scandone
                          connected with homenet, channel 1
                          dhcp client start...
                          ..............ip:192.168.1.100,mask:255.255.255.0,gw:192.168.1.1
                          .IP: 192.168.1.100
                          pm open,type:2 0
                          0;255;3;0;9;TSP:SANCHK:OK
                          • E Offline
                            E Offline
                            emc2
                            It seems good on the gateway to me, no radio error at least.
                            Past that no idea.
                            • E emc2
                              Past that no idea.
                              G Offline
                              G Offline
                              gmccarthy
                              @emc2 Thanks. Will keep digging but I"m almost out of idea as well. :(
                              • E Offline
                                E Offline
                                emc2
                                @gmccarthy maybe an interesting read:
                                https://forum.mysensors.org/topic/4889/esp8266-rfm69-gateway/5
                                • K Offline
                                  K Offline
                                  korttoma
                                  On the arduino mini I think you should connect the DI00 (IRQ) to pin 2 like you see on this page
                                  For some CPU types the IRQ pin is hard coded and can not be re-assigned.
                                  • Tomas
                                  • TON RIJNAARDT Offline
                                    TON RIJNAARD
                                    @gmccarthy i have insert this line in the gateway then was it working for me
                                    #define MY_RFM69_PA_LEVEL RF69_PA_LOW
                                    • E emc2
                                      G Offline
                                      G Offline
                                      gmccarthy
                                      @emc2 Interesting read.
                                      @korttoma I've connected up IRQ line. Still no luck,
                                      @TON-RIJNAARD Have tried that now as well. No luck.
                                      Tried going back to basics and now have 2 x Arduino pros with RFM69 - both loaded with pingpong script.
                                      Don't know where I'm going wrong but I can't even start the script - entering 1 or T does nothing. (I"ve used the script before with the NRF radio and it works)
                                      Have also tried the latest dev version.
                                      Just keep getting this on both arduinos:
                                      0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.0.1-beta
                                      4 TSM:INIT
                                      1 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.0.1-beta
                                      5 TSM:INIT
                                      7 TSM:INIT:TSP OK
                                      8 TSM:FPAR
                                      138 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2145 !TSM:FPAR:NO REPLY
                                      2147 TSM:FPAR
                                      2277 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4284 !TSM:FPAR:NO REPLY
                                      4286 TSM:FPAR
                                      4416 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6423 !TSM:FPAR:NO REPLY
                                      6425 TSM:FPAR
                                      6555 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      8562 !TSM:FPAR:FAIL
                                      8563 TSM:FAIL:CNT=1
                                      8565 TSM:FAIL:PDT
                                      12.2k
