  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.3k Views 18 Watching
  • pepsonP
    pepsonP
    pepson
    wrote on last edited by pepson
    #40
    @korttoma your sketch not working for me. I change numer relay to 2 and change pin buttons and relay and not control relay.
    @Boots33
    Ok i correct your sketch and use:
    Switch Bistable:
       DESCRIPTION
       Sketch for 2x relay with buttons bistable. After back power all relays set OFF and send correct status OFF to controller.
    #define MY_REPEATER_FEATURE
    // Define Relays
    #define RELAY_OFF 0  // GPIO value to write to turn off attached relay
    // Define Sensor ID's
    #define SSR_A_ID 1   // Id of the sensor child
    #define SSR_B_ID 2   // Id of the sensor child
    // Define buttons and relays
    const int buttonPinA = 3;
    const int buttonPinB = 4;
    const int relayPinA = 5;
    const int relayPinB = 6;
    // Define Variables
    int oldValueA = 0;
    int oldValueB = 0;
    bool stateA = false;
    bool stateB = false;
    int trigger = 0;
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage msgB(SSR_B_ID, V_STATUS);
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
      // After setting up the buttons, setup debouncer
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5);
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);
      digitalWrite(relayPinA, RELAY_OFF);
      digitalWrite(relayPinB, RELAY_OFF);
      pinMode(relayPinA, OUTPUT);
      pinMode(relayPinB, OUTPUT);
        /*--------------------- Added these lines for toggle switch-------------------------*/
      oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
      oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
     // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
     // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
    void presentation()  {
      sendSketchInfo("2xRelay with bistable", "1.1");
      present(SSR_A_ID, S_LIGHT);
      present(SSR_B_ID, S_LIGHT);
    if (trigger == 0){
      trigger = 1;
      debouncerA.update();
      // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA) {
       // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
        send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
        stateA = stateA ? false : true;               // invert the state
         digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);  // toggle the relay
      oldValueA = valueA;
      debouncerB.update();
      int valueB = debouncerB.read();
      if (valueB != oldValueB) {
        //send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
        send(msgB.set(stateB ? false : true), false); // Send new state with no request for ack
        stateB = stateB ? false : true;                // invert the state
         digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);  // toggle the relay
      oldValueB = valueB;
        switch (message.sensor) {
          case 1:
            stateA = message.getBool();
            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
          case 2:
            stateB = message.getBool();
            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
        Serial.print("from node:");
        Serial.println(message.sender);
    Switch monostable:
       DESCRIPTION
       Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
    // Define Relays
    // Define Variables
    int oldValueA = 0;
    int oldValueB = 0;
    int trigger = 0;
      sendSketchInfo("2xRelay with monostable", "1.0");
    if (trigger == 0){
      trigger = 1;
      if (valueA != oldValueA && valueA == 0) {
      oldValueA = valueA;
      if (valueB != oldValueB && valueB == 0) {
      oldValueB = valueB;
          case 1:
          case 2:
    On this sketches it works ok. After power down and then power back all relays go to OFF and correct send info to Gateway and Domoticz that relays is OFF. But when Gateway is available.
    But problem is when GATEWAY is not awailable when power for node come back.
    If before lost power relay is ON and then power lost , and gateway is lost, and then power back to Node it goes to OFF all relay. It is ok.But when Gateway come back and now is available still show in Domoticz that relay is ON(on begin was ON). But Node should update status info after Gateway come back and is now available. But no update and show in Domoticz latest status.
    It is very need and then this sketches will be the best for lights :)
    When power lost and then come back, Node with sketches faster start then start Raspberry with Domoticz and connect Gateway Serial MySensors. An in this situation status is not update in Gateway/Domoticz.
    Please help us. please
    • rayanR rayan
      @Boots33
      ack is important , so we can not found any solution for this ? for exapmle add a code to this sketch , that when radio is disconnect so without ack work and when radio is ok this way stop and with ack work again.
      this idea is for when a radio have problem or fail or other reason... so this light or other divece dont stop working and work handy when radio go to correct or change radio....
      if you can change your code and add this option , so your sketch is best code for light control
      Boots33B
      Boots33B
      Boots33
      @rayan said:
      @Boots33
      There have been a few threads about the issue of nodes not running the loop part of the sketch if a connection to the gateway cannot be established. Have a look Here and Here for a bit more info. It is a feature I am sure many would like to see in the next version of MySensors. For the moment MySensors does not support 100% what you want to do.
      If you want to combine the two versions of the sketches you will need to have a method to check whether a connection to the gateway is present. You could try something like this in the loop.
      if (isTransportOK()){
          // put code to execute when connection is available here
        else {
          // put code to execute when no connection is available here
      You will be adding a fair bit of complexity to the sketch. Can you tell me why the ACK is so important for you.
      rayanR 1 Reply Last reply
      • pepsonP
        pepsonP
        pepson
        #42
        What is ACK ?
        And can you show me all code with your if transport is ok to send update status to gateway...but if transport is wrong example try send every 1 minut and stop when send is good.
        I am begginner sorry
        Did you know any info that this function will be implement in next version as you write in latest your post ?
        • Boots33B Boots33
          @rayan said:
          @Boots33
            else {
          rayanR
          rayanR
          rayan
          wrote on last edited by rayan
          #43
          @Boots33
          ack is a feedback . is this true ? so when i am out of home and i want turn on light , so ack show me that light is on or no ! also when there is a problem in connection and ack dont receive, so node search and found a new way for connection.
          now i dont have a arduino and radio for test :) but do you think this code will be ok ?without else.
           if (!isTransportOK())
          if (...)            //if change switch to up or down
          ...                 //change state of relay
          if(isTransportOK())
          send(msg.set(state ? true : false), true);  // (last state)
            debouncer.update();
            int value = debouncer.read();
            if (value != oldValue && value == 0) {
            oldValue = value;
          (i can not work with Bounce2 library :) ) please help to fill lines
          in loop we add a "if (!isTransportOK())" and write when change switch (on/off) state of relay change and this is repeat until connection will be ok ! so send a ack and for continue follow your code...
          is this right ? can you do this change ?
          • pepsonP
            pepsonP
            pepson
            Hi
            I can test it but i must have finall code because i dont know what code i must put in (...). I am begginer user and i dont know how write programming.
            • pepsonP pepson
              Hi
              rayanR
              rayanR
              rayan
              @pepson
              @Boots33 can solve this maybe because i dont work with Bounce2 lib.
              • pepsonP
                pepsonP
                pepson
                Ok but can you give me ready code which i must put in code to my relays and then i test it.
                • pepsonP pepson
                  rayanR
                  rayanR
                  rayan
                  @pepson
                  i dont have a ready sketch! wait to boots answer
                  • pepsonP
                    pepsonP
                    pepson
                    Ok i am waiting...
                    • Boots33B
                      Boots33B
                      Boots33
                      wrote on last edited by Boots33
                      #49
                      Guys I feel this thread has wandered a long way from the original topic and has taken up a lot of time. i really don't think there is a lot to be gained by turning the fairly simple relay sketch into what you now desire.
                      Even with the changes it still will not work if it boots up and can't find the gateway.
                      I am posting a final sketch which you may like to try, again it is untested so you may still need to work on it. I hope you understand I have a few of my own uncompleted projects that I want to get back to with the limited free time I have. Good luck with your MySensors journey.
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      const int buttonPinA = 18;
                      const int buttonPinB = 19;
                      int oldValueA = 0;
                      int oldValueB = 0;
                      int trigger = 0;
                        sendSketchInfo("Mains Controller", "1.0");
                      if (trigger == 0){
                        trigger = 1;
                          connectionPresent();
                        else {
                         connectionLost();
                            case 1:
                            case 2:
                      void connectionPresent() {
                        oldValueA = valueA;
                        oldValueB = valueB;
                        void connectionLost() {
                        oldValueA = valueA;
                        oldValueB = valueB;
                      rayanR 2 Replies Last reply
                      • pepsonP
                        pepsonP
                        pepson
                        Still not working correct. After lost connection with gateway and then change status , after connection restore , but status is still not update in Domoticz. Still show before lost connection.
                        • Boots33B Boots33
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          int oldValueA = 0;
                          int oldValueB = 0;
                          int trigger = 0;
                          if (trigger == 0){
                            trigger = 1;
                            else {
                             connectionLost();
                                case 1:
                                case 2:
                            oldValueA = valueA;
                            oldValueB = valueB;
                            oldValueA = valueA;
                            oldValueB = valueB;
                          rayanR
                          rayanR
                          rayan
                          #51
                          • Boots33B Boots33
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            int oldValueA = 0;
                            int oldValueB = 0;
                            int trigger = 0;
                            if (trigger == 0){
                              trigger = 1;
                              else {
                               connectionLost();
                                  case 1:
                                  case 2:
                              oldValueA = valueA;
                              oldValueB = valueB;
                              oldValueA = valueA;
                              oldValueB = valueB;
                            rayanR
                            rayanR
                            rayan
                            @Boots33
                            hi my friend.
                            i use your sketch and thank you.but there is a problem.
                            sketchs in site , when relay is fail , when i send command , so show to me "Error sending switch command, check device/hardware !" but your sketch dont show this error. so i dont understand relay is fail or no , when we are out home. can you fix this ?
                            • korttomaK korttoma
                              Here is an example that I'm using with 4 relays and 4 monostable buttons:
                              #define SN "RelayButtonArray"
                              #define SV "1.0"
                              #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                              #define RELAY_OFF 1
                              #define noRelays 4                     //2-4
                              const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                              const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                              class Relay             // relay class, store all relevant data (equivalent to struct)
                                public:
                                  int buttonPin;                   // physical pin number of button
                                  int relayPin;             // physical pin number of relay
                                  boolean relayState;               // relay status (also stored in EEPROM)
                              Relay Relays[noRelays];
                              Bounce debouncer[noRelays];
                              MyMessage msg[noRelays];
                                void before() {
                                  pinMode(pin, OUTPUT);
                                wait(100);
                                for (int i = 0; i < noRelays; i++) {
                                  Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                  msg[i].type = V_LIGHT;
                                  wait(100);
                                  Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                  digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                  send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                  wait(50);
                                  debouncer[i].interval(30);
                                  wait(50);
                                sendSketchInfo(SN, SV);
                                wait(100);
                                  present(i, S_LIGHT);                               // present sensor to gateway
                                wait(100);
                                for (byte i = 0; i < noRelays; i++) {
                                  if (debouncer[i].update()) {
                                    if ( value == LOW) {
                                      // save sensor state in EEPROM (location == sensor number)
                                      saveState( i, Relays[i].relayState );
                                //wait(20);
                                  if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                    digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                    saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                                wait(20);
                              breimannB
                              breimannB
                              breimann
                              @korttoma love this sketch. Used it for a dual LED strip light controller for our loft where our kids sleep - daughter on one side and boys on the other, both with LED strips (RGB) i installed. This way we can turn them on or off remotely without having to climb up there!!
                              Worked great. Thankyou for sharing.
                                moskovskiy82
                                Anybody has a sketch where multiple buttons are put up on single wire and voltage drop is used to distinguish between them?
                                • nieatyN
                                  nieatyN
                                  nieaty
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Hi
                                    Has anybody solution how resolved problem update status when connection with gateway is not available and then come back connection with gateway?
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      Hi
                                      Boots33B 1 Reply Last reply
                                      • pepsonP pepson
                                        Hi
                                        Boots33B
                                        Boots33B
                                        Boots33
                                        @pepson have a look at this Synchronising Light switch
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          I try sketch from your link but i test and the same issu.
                                          I enable relay, then disable GATEWAY MySensors on DOmoticz and then change status relay to DISABLE by button. Then enable Gateway on Domoticz and still in domoticz show that relay is ENABLED. Not update status that i manual DISABLE relay by button.
