  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.3k Views 18 Watching
  • korttomaK
    korttomaK
    korttoma
    I'm the sketch I'm using you can freely define what pins you want to use:
    const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
    const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
    • Tomas
    • rayanR rayan
      @Boots33 this your code is good, but there is a small issue .button work just when the connection is ok (radio with gateway) ! and when radio is disconnect or controller is off, so button dont work handy . do you have any idea for this ? that when controller is off the button work handy
      Boots33B
      Boots33B
      Boots33
      wrote on last edited by Boots33
      #37
      As far as I know that is the way Mysensors works at the moment, if the node boots up and cannot find the gateway then it wont run the loop part of the sketch.
      If the gateway drops out after the node has booted then the loop part of the sketch will still run while the node tries to re-establish the connection. Because the sketch relies on an ACK back from the gateway to toggle the relay it still wont work if the gateway is down.
      You could modify the sketch so it does not rely on the ACK. This would at least allow it to work if the gateway goes down after the node has booted.
      Another way to ensure the switch will operate would be to add some circuit to override the node, like discussed Here
      Have made a quick change to the sketch so it does not need the ACK. I have not tried it but give it a go and see if it works
      #define MY_REPEATER_FEATURE
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define SSR_A_ID 1   // Id of the sensor child
      #define SSR_B_ID 2   // Id of the sensor child
      const int buttonPinA = 18;
      const int buttonPinB = 19;
      const int relayPinA = 5;
      const int relayPinB = 6;
      int oldValueA = 0;
      int oldValueB = 0;
      bool stateA = false;
      bool stateB = false;
      int trigger = 0;
      Bounce debouncerA = Bounce();
      Bounce debouncerB = Bounce();
      MyMessage msgA(SSR_A_ID, V_STATUS);
      MyMessage msgB(SSR_B_ID, V_STATUS);
        pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
        pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
        pinMode(relayPinA, OUTPUT);
        pinMode(relayPinB, OUTPUT);
        // After setting up the buttons, setup debouncer
        debouncerA.attach(buttonPinA);
        debouncerA.interval(5);
        debouncerB.attach(buttonPinB);
        debouncerB.interval(5);
        digitalWrite(relayPinA, RELAY_OFF);
        digitalWrite(relayPinB, RELAY_OFF);
          /*--------------------- Added these lines for toggle switch-------------------------*/
        oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
        oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
       // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
       // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
      void presentation()  {
        sendSketchInfo("Mains Controller", "1.0");
        present(SSR_A_ID, S_LIGHT);
        present(SSR_B_ID, S_LIGHT);
      if (trigger == 0){
        trigger = 1;
        debouncerA.update();
        // Get the update value
        int valueA = debouncerA.read();
        if (valueA != oldValueA) {
         // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
          send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
          stateA = stateA ? false : true;               // invert the state
           digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);  // toggle the relay
        oldValueA = valueA;
        debouncerB.update();
        int valueB = debouncerB.read();
        if (valueB != oldValueB) {
          //send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
          send(msgB.set(stateB ? false : true), false); // Send new state with no request for ack
          stateB = stateB ? false : true;                // invert the state
           digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);  // toggle the relay
        oldValueB = valueB;
          switch (message.sensor) {
            case 1:
              stateA = message.getBool();
              digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
            case 2:
              stateB = message.getBool();
              digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
          Serial.print("from node:");
          Serial.println(message.sender);
      rayanR 1 Reply Last reply
      • pepsonP
        pepsonP
        pepson
        ok then i test it.
        But can you also add option to set mode button ? Bistable and monostable ?
        • Boots33B Boots33
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValueA = 0;
          int oldValueB = 0;
          int trigger = 0;
          if (trigger == 0){
            trigger = 1;
            oldValueA = valueA;
            oldValueB = valueB;
                case 1:
                case 2:
          rayanR
          rayanR
          rayan
          wrote on last edited by rayan
          #39
          @Boots33
          ack is important , so we can not found any solution for this ? for exapmle add a code to this sketch , that when radio is disconnect so without ack work and when radio is ok this way stop and with ack work again.
          this idea is for when a radio have problem or fail or other reason... so this light or other divece dont stop working and work handy when radio go to correct or change radio....
          if you can change your code and add this option , so your sketch is best code for light control
          Boots33B 1 Reply Last reply
          • pepsonP
            pepsonP
            pepson
            wrote on last edited by pepson
            #40
            @korttoma your sketch not working for me. I change numer relay to 2 and change pin buttons and relay and not control relay.
            @Boots33
            Ok i correct your sketch and use:
            Switch Bistable:
               DESCRIPTION
               Sketch for 2x relay with buttons bistable. After back power all relays set OFF and send correct status OFF to controller.
            // Define Relays
            #define RELAY_OFF 0  // GPIO value to write to turn off attached relay
            // Define Sensor ID's
            // Define buttons and relays
            const int buttonPinA = 3;
            const int buttonPinB = 4;
            // Define Variables
            int oldValueA = 0;
            int oldValueB = 0;
            int trigger = 0;
              sendSketchInfo("2xRelay with bistable", "1.1");
            if (trigger == 0){
              trigger = 1;
              oldValueA = valueA;
              oldValueB = valueB;
                  case 1:
                  case 2:
            Switch monostable:
               DESCRIPTION
               Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
            // Define Relays
            // Define Variables
            int oldValueA = 0;
            int oldValueB = 0;
            int trigger = 0;
              sendSketchInfo("2xRelay with monostable", "1.0");
            if (trigger == 0){
              trigger = 1;
              if (valueA != oldValueA && valueA == 0) {
              oldValueA = valueA;
              if (valueB != oldValueB && valueB == 0) {
              oldValueB = valueB;
                  case 1:
                  case 2:
            On this sketches it works ok. After power down and then power back all relays go to OFF and correct send info to Gateway and Domoticz that relays is OFF. But when Gateway is available.
            But problem is when GATEWAY is not awailable when power for node come back.
            If before lost power relay is ON and then power lost , and gateway is lost, and then power back to Node it goes to OFF all relay. It is ok.But when Gateway come back and now is available still show in Domoticz that relay is ON(on begin was ON). But Node should update status info after Gateway come back and is now available. But no update and show in Domoticz latest status.
            It is very need and then this sketches will be the best for lights :)
            When power lost and then come back, Node with sketches faster start then start Raspberry with Domoticz and connect Gateway Serial MySensors. An in this situation status is not update in Gateway/Domoticz.
            Please help us. please
            • rayanR rayan
              @Boots33
              Boots33B
              Boots33B
              Boots33
              @rayan said:
              @Boots33
              There have been a few threads about the issue of nodes not running the loop part of the sketch if a connection to the gateway cannot be established. Have a look Here and Here for a bit more info. It is a feature I am sure many would like to see in the next version of MySensors. For the moment MySensors does not support 100% what you want to do.
              If you want to combine the two versions of the sketches you will need to have a method to check whether a connection to the gateway is present. You could try something like this in the loop.
              if (isTransportOK()){
                  // put code to execute when connection is available here
                else {
                  // put code to execute when no connection is available here
              You will be adding a fair bit of complexity to the sketch. Can you tell me why the ACK is so important for you.
              • pepsonP
                pepsonP
                pepson
                #42
                What is ACK ?
                And can you show me all code with your if transport is ok to send update status to gateway...but if transport is wrong example try send every 1 minut and stop when send is good.
                I am begginner sorry
                Did you know any info that this function will be implement in next version as you write in latest your post ?
                • Boots33B Boots33
                  @rayan said:
                  @Boots33
                    else {
                  rayanR
                  rayanR
                  rayan
                  #43
                  @Boots33
                  ack is a feedback . is this true ? so when i am out of home and i want turn on light , so ack show me that light is on or no ! also when there is a problem in connection and ack dont receive, so node search and found a new way for connection.
                  now i dont have a arduino and radio for test :) but do you think this code will be ok ?without else.
                   if (!isTransportOK())
                  if (...)            //if change switch to up or down
                  ...                 //change state of relay
                  if(isTransportOK())
                  send(msg.set(state ? true : false), true);  // (last state)
                    debouncer.update();
                    int value = debouncer.read();
                    if (value != oldValue && value == 0) {
                    oldValue = value;
                  (i can not work with Bounce2 library :) ) please help to fill lines
                  in loop we add a "if (!isTransportOK())" and write when change switch (on/off) state of relay change and this is repeat until connection will be ok ! so send a ack and for continue follow your code...
                  is this right ? can you do this change ?
                  • pepsonP
                    pepsonP
                    pepson
                    Hi
                    I can test it but i must have finall code because i dont know what code i must put in (...). I am begginer user and i dont know how write programming.
                    • pepsonP pepson
                      Hi
                      rayanR
                      rayanR
                      rayan
                      @pepson
                      @Boots33 can solve this maybe because i dont work with Bounce2 lib.
                      • pepsonP
                        pepsonP
                        pepson
                        Ok but can you give me ready code which i must put in code to my relays and then i test it.
                        • pepsonP pepson
                          rayanR
                          rayanR
                          rayan
                          @pepson
                          i dont have a ready sketch! wait to boots answer
                          • pepsonP
                            pepsonP
                            pepson
                            Ok i am waiting...
                            • Boots33B
                              Boots33B
                              Boots33
                              #49
                              Guys I feel this thread has wandered a long way from the original topic and has taken up a lot of time. i really don't think there is a lot to be gained by turning the fairly simple relay sketch into what you now desire.
                              Even with the changes it still will not work if it boots up and can't find the gateway.
                              I am posting a final sketch which you may like to try, again it is untested so you may still need to work on it. I hope you understand I have a few of my own uncompleted projects that I want to get back to with the limited free time I have. Good luck with your MySensors journey.
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              int oldValueA = 0;
                              int oldValueB = 0;
                              int trigger = 0;
                              if (trigger == 0){
                                trigger = 1;
                                  connectionPresent();
                                else {
                                 connectionLost();
                                    case 1:
                                    case 2:
                              void connectionPresent() {
                                oldValueA = valueA;
                                oldValueB = valueB;
                                void connectionLost() {
                                oldValueA = valueA;
                                oldValueB = valueB;
                              rayanR 2 Replies Last reply
                              • pepsonP
                                pepsonP
                                pepson
                                Still not working correct. After lost connection with gateway and then change status , after connection restore , but status is still not update in Domoticz. Still show before lost connection.
                                • Boots33B Boots33
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int oldValueA = 0;
                                  int oldValueB = 0;
                                  int trigger = 0;
                                  if (trigger == 0){
                                    trigger = 1;
                                    else {
                                     connectionLost();
                                        case 1:
                                        case 2:
                                    oldValueA = valueA;
                                    oldValueB = valueB;
                                    oldValueA = valueA;
                                    oldValueB = valueB;
                                  rayanR
                                  rayanR
                                  rayan
                                  #51
                                  • Boots33B Boots33
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                    int trigger = 0;
                                    if (trigger == 0){
                                      trigger = 1;
                                      else {
                                       connectionLost();
                                          case 1:
                                          case 2:
                                      oldValueA = valueA;
                                      oldValueB = valueB;
                                      oldValueA = valueA;
                                      oldValueB = valueB;
                                    rayanR
                                    rayanR
                                    rayan
                                    @Boots33
                                    hi my friend.
                                    i use your sketch and thank you.but there is a problem.
                                    sketchs in site , when relay is fail , when i send command , so show to me "Error sending switch command, check device/hardware !" but your sketch dont show this error. so i dont understand relay is fail or no , when we are out home. can you fix this ?
                                    • korttomaK korttoma
                                      Here is an example that I'm using with 4 relays and 4 monostable buttons:
                                      #define SN "RelayButtonArray"
                                      #define SV "1.0"
                                      #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                                      #define RELAY_OFF 1
                                      #define noRelays 4                     //2-4
                                      class Relay             // relay class, store all relevant data (equivalent to struct)
                                        public:
                                          int buttonPin;                   // physical pin number of button
                                          int relayPin;             // physical pin number of relay
                                          boolean relayState;               // relay status (also stored in EEPROM)
                                      Relay Relays[noRelays];
                                      Bounce debouncer[noRelays];
                                      MyMessage msg[noRelays];
                                        void before() {
                                          pinMode(pin, OUTPUT);
                                        wait(100);
                                        for (int i = 0; i < noRelays; i++) {
                                          Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                          msg[i].type = V_LIGHT;
                                          wait(100);
                                          Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                          digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                          send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                          wait(50);
                                          debouncer[i].interval(30);
                                          wait(50);
                                        sendSketchInfo(SN, SV);
                                        wait(100);
                                          present(i, S_LIGHT);                               // present sensor to gateway
                                        wait(100);
                                        for (byte i = 0; i < noRelays; i++) {
                                          if (debouncer[i].update()) {
                                            if ( value == LOW) {
                                              // save sensor state in EEPROM (location == sensor number)
                                              saveState( i, Relays[i].relayState );
                                        //wait(20);
                                          if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                            digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                            saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                                        wait(20);
                                      breimannB
                                      breimannB
                                      breimann
                                      @korttoma love this sketch. Used it for a dual LED strip light controller for our loft where our kids sleep - daughter on one side and boys on the other, both with LED strips (RGB) i installed. This way we can turn them on or off remotely without having to climb up there!!
                                      Worked great. Thankyou for sharing.
                                        moskovskiy82
                                        Anybody has a sketch where multiple buttons are put up on single wire and voltage drop is used to distinguish between them?
                                        • nieatyN
                                          nieatyN
                                          nieaty
