  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.3k Views 18 Watching
  • pepsonP
    pepsonP
    pepson
    wrote on last edited by pepson
    #42
    What is ACK ?
    And can you show me all code with your if transport is ok to send update status to gateway...but if transport is wrong example try send every 1 minut and stop when send is good.
    I am begginner sorry
    Did you know any info that this function will be implement in next version as you write in latest your post ?
    • Boots33B Boots33
      @rayan said:
      @Boots33
      ack is important , so we can not found any solution for this ? for exapmle add a code to this sketch , that when radio is disconnect so without ack work and when radio is ok this way stop and with ack work again.
      this idea is for when a radio have problem or fail or other reason... so this light or other divece dont stop working and work handy when radio go to correct or change radio....
      if you can change your code and add this option , so your sketch is best code for light control
      There have been a few threads about the issue of nodes not running the loop part of the sketch if a connection to the gateway cannot be established. Have a look Here and Here for a bit more info. It is a feature I am sure many would like to see in the next version of MySensors. For the moment MySensors does not support 100% what you want to do.
      If you want to combine the two versions of the sketches you will need to have a method to check whether a connection to the gateway is present. You could try something like this in the loop.
      if (isTransportOK()){
          // put code to execute when connection is available here
        else {
          // put code to execute when no connection is available here
      You will be adding a fair bit of complexity to the sketch. Can you tell me why the ACK is so important for you.
      rayanR
      rayanR
      rayan
      wrote on last edited by rayan
      #43
      @Boots33
      ack is a feedback . is this true ? so when i am out of home and i want turn on light , so ack show me that light is on or no ! also when there is a problem in connection and ack dont receive, so node search and found a new way for connection.
      now i dont have a arduino and radio for test :) but do you think this code will be ok ?without else.
       if (!isTransportOK())
      if (...)            //if change switch to up or down
      ...                 //change state of relay
      if(isTransportOK())
      send(msg.set(state ? true : false), true);  // (last state)
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue && value == 0) {
        oldValue = value;
      (i can not work with Bounce2 library :) ) please help to fill lines
      in loop we add a "if (!isTransportOK())" and write when change switch (on/off) state of relay change and this is repeat until connection will be ok ! so send a ack and for continue follow your code...
      is this right ? can you do this change ?
      • pepsonP
        pepsonP
        pepson
        Hi
        I can test it but i must have finall code because i dont know what code i must put in (...). I am begginer user and i dont know how write programming.
        rayanR 1 Reply Last reply
        • pepsonP pepson
          Hi
          rayanR
          rayanR
          rayan
          @pepson
          @Boots33 can solve this maybe because i dont work with Bounce2 lib.
          • pepsonP
            pepsonP
            pepson
            Ok but can you give me ready code which i must put in code to my relays and then i test it.
            • pepsonP pepson
              rayanR
              rayanR
              rayan
              @pepson
              i dont have a ready sketch! wait to boots answer
              • pepsonP
                pepsonP
                pepson
                Ok i am waiting...
                • Boots33B
                  Boots33B
                  Boots33
                  wrote on last edited by Boots33
                  #49
                  Guys I feel this thread has wandered a long way from the original topic and has taken up a lot of time. i really don't think there is a lot to be gained by turning the fairly simple relay sketch into what you now desire.
                  Even with the changes it still will not work if it boots up and can't find the gateway.
                  I am posting a final sketch which you may like to try, again it is untested so you may still need to work on it. I hope you understand I have a few of my own uncompleted projects that I want to get back to with the limited free time I have. Good luck with your MySensors journey.
                  #define MY_REPEATER_FEATURE
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  #define SSR_A_ID 1   // Id of the sensor child
                  #define SSR_B_ID 2   // Id of the sensor child
                  const int buttonPinA = 18;
                  const int buttonPinB = 19;
                  const int relayPinA = 5;
                  const int relayPinB = 6;
                  int oldValueA = 0;
                  int oldValueB = 0;
                  bool stateA = false;
                  bool stateB = false;
                  int trigger = 0;
                  Bounce debouncerA = Bounce();
                  Bounce debouncerB = Bounce();
                  MyMessage msgA(SSR_A_ID, V_STATUS);
                  MyMessage msgB(SSR_B_ID, V_STATUS);
                    pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                    pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
                    pinMode(relayPinA, OUTPUT);
                    pinMode(relayPinB, OUTPUT);
                    // After setting up the buttons, setup debouncer
                    debouncerA.attach(buttonPinA);
                    debouncerA.interval(5);
                    debouncerB.attach(buttonPinB);
                    debouncerB.interval(5);
                    digitalWrite(relayPinA, RELAY_OFF);
                    digitalWrite(relayPinB, RELAY_OFF);
                      /*--------------------- Added these lines for toggle switch-------------------------*/
                    oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
                    oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
                   // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                   // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                  void presentation()  {
                    sendSketchInfo("Mains Controller", "1.0");
                    present(SSR_A_ID, S_LIGHT);
                    present(SSR_B_ID, S_LIGHT);
                  if (trigger == 0){
                    trigger = 1;
                      connectionPresent();
                    else {
                     connectionLost();
                      switch (message.sensor) {
                        case 1:
                          stateA = message.getBool();
                          digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                        case 2:
                          stateB = message.getBool();
                          digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                      Serial.print("from node:");
                      Serial.println(message.sender);
                  void connectionPresent() {
                       debouncerA.update();
                    int valueA = debouncerA.read();
                    if (valueA != oldValueA) {
                      send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                    oldValueA = valueA;
                    debouncerB.update();
                    int valueB = debouncerB.read();
                    if (valueB != oldValueB) {
                      send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                    oldValueB = valueB;
                    void connectionLost() {
                     // send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                      send(msgA.set(stateA ? false : true), false); // Send new state with no request for ack
                      stateA = stateA ? false : true;               // invert the state
                       digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);  // toggle the relay
                    oldValueA = valueA;
                      //send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                      send(msgB.set(stateB ? false : true), false); // Send new state with no request for ack
                      stateB = stateB ? false : true;                // invert the state
                       digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);  // toggle the relay
                    oldValueB = valueB;
                  rayanR 2 Replies Last reply
                  • pepsonP
                    pepsonP
                    pepson
                    Still not working correct. After lost connection with gateway and then change status , after connection restore , but status is still not update in Domoticz. Still show before lost connection.
                    • Boots33B Boots33
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValueA = 0;
                      int oldValueB = 0;
                      int trigger = 0;
                      if (trigger == 0){
                        trigger = 1;
                        else {
                         connectionLost();
                            case 1:
                            case 2:
                        oldValueA = valueA;
                        oldValueB = valueB;
                        oldValueA = valueA;
                        oldValueB = valueB;
                      rayanR
                      rayanR
                      rayan
                      #51
                      • Boots33B Boots33
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValueA = 0;
                        int oldValueB = 0;
                        int trigger = 0;
                        if (trigger == 0){
                          trigger = 1;
                          else {
                           connectionLost();
                              case 1:
                              case 2:
                          oldValueA = valueA;
                          oldValueB = valueB;
                          oldValueA = valueA;
                          oldValueB = valueB;
                        rayanR
                        rayanR
                        rayan
                        @Boots33
                        hi my friend.
                        i use your sketch and thank you.but there is a problem.
                        sketchs in site , when relay is fail , when i send command , so show to me "Error sending switch command, check device/hardware !" but your sketch dont show this error. so i dont understand relay is fail or no , when we are out home. can you fix this ?
                        • korttomaK korttoma
                          Here is an example that I'm using with 4 relays and 4 monostable buttons:
                          #define SN "RelayButtonArray"
                          #define SV "1.0"
                          #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                          #define RELAY_OFF 1
                          #define noRelays 4                     //2-4
                          const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                          const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                          class Relay             // relay class, store all relevant data (equivalent to struct)
                            public:
                              int buttonPin;                   // physical pin number of button
                              int relayPin;             // physical pin number of relay
                              boolean relayState;               // relay status (also stored in EEPROM)
                          Relay Relays[noRelays];
                          Bounce debouncer[noRelays];
                          MyMessage msg[noRelays];
                            void before() {
                              pinMode(pin, OUTPUT);
                            wait(100);
                            for (int i = 0; i < noRelays; i++) {
                              Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                              msg[i].type = V_LIGHT;
                              wait(100);
                              Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                              digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                              send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                              wait(50);
                              debouncer[i].interval(30);
                              wait(50);
                            sendSketchInfo(SN, SV);
                            wait(100);
                              present(i, S_LIGHT);                               // present sensor to gateway
                            wait(100);
                            for (byte i = 0; i < noRelays; i++) {
                              if (debouncer[i].update()) {
                                if ( value == LOW) {
                                  // save sensor state in EEPROM (location == sensor number)
                                  saveState( i, Relays[i].relayState );
                            //wait(20);
                              if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                            wait(20);
                          breimannB
                          breimannB
                          breimann
                          @korttoma love this sketch. Used it for a dual LED strip light controller for our loft where our kids sleep - daughter on one side and boys on the other, both with LED strips (RGB) i installed. This way we can turn them on or off remotely without having to climb up there!!
                          Worked great. Thankyou for sharing.
                            moskovskiy82
                            Anybody has a sketch where multiple buttons are put up on single wire and voltage drop is used to distinguish between them?
                            • nieatyN
                              nieatyN
                              nieaty
                              • pepsonP
                                pepsonP
                                pepson
                                Hi
                                Has anybody solution how resolved problem update status when connection with gateway is not available and then come back connection with gateway?
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Hi
                                  Boots33B 1 Reply Last reply
                                  • pepsonP pepson
                                    Hi
                                    Boots33B
                                    Boots33B
                                    Boots33
                                    @pepson have a look at this Synchronising Light switch
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      I try sketch from your link but i test and the same issu.
                                      I enable relay, then disable GATEWAY MySensors on DOmoticz and then change status relay to DISABLE by button. Then enable Gateway on Domoticz and still in domoticz show that relay is ENABLED. Not update status that i manual DISABLE relay by button.
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        This is my sketch with my radio and this not working... no sync status after lost connection with gateway and after come back gateway...
                                           Relay with button sketch
                                        #define MY_RADIO_RFM69
                                        #define MY_RFM69_FREQUENCY RF69_868MHZ
                                        #define MY_IS_RFM69HW                         // Enable and select radio type attached
                                        // Node id defaults to AUTO (tries to fetch id from controller)
                                        #define MY_NODE_ID 10
                                        #define RELAY_ON 0
                                        #define RELAY_OFF 1
                                        Bounce debouncer = Bounce();
                                        int oldValue = 0;
                                        bool uplinkAvailable = true;
                                        bool state = false;
                                        bool requestState;
                                        bool firstStart = true;
                                        unsigned long returnWait = 1500;               // how long to wait for return from controller in milliseconds
                                        void setup(){
                                          debouncer.interval(5);
                                          present(CHILD_ID, S_BINARY);
                                        void loop(){
                                            if (request( CHILD_ID, V_STATUS)) {       // request the current state of the switch on the controller and check that an ack was received
                                              wait (returnWait);                      //wait needed to allow request to return from controller
                                              Serial.println(requestState);
                                              if (requestState != state) {           // check that controller is corectly showing the current relay state
                                                send(msg.set(state), false);         // notify controller of current state
                                            else {
                                              uplinkAvailable = false;               // no uplink established
                                              uplinkCheckTime = millis();
                                            firstStart = false;                     // set firstStart flag false to prevent code from running again
                                          debouncer.update();
                                            if (!send(msg.set(state), true)) {                        //Attempt to notify controller of changed state
                                              uplinkAvailable = false;                                // no uplink available
                                         oldValue = value;
                                        void uplinkCheck() {
                                          if (request( CHILD_ID, V_STATUS)) {         // request the current state of the switch on the controller and check that the request was succsessful
                                        • pepsonP pepson
                                          Boots33B
                                          Boots33B
                                          Boots33
                                          @pepson said in Multi Button Relay Sketch:
                                          As far as I know there is no direct way to test for a connection all the way to the controller in MySensors 2.1.
                                          My sketch for the synchronising switch uses the presence of the gateway as the test, this has been adequate for my needs. My controller and gateway are both powered from the same place so they both go down if power is lost.
                                          I have found Domoticz very stable and have not had any issues with it at all so am wondering why Dometicz seems to be giving you problems. is it powered from a different supply to your gateway?
                                          I do have another sketch that uses requestTime as a way of checking for the controller that may be of use to you. it needs a little cleaning up first, so will have a look at it when i get a chance and post it for you to try.
                                          pepsonP 1 Reply Last reply
