  3. processing incoming MQTT messages to actuate gateway local relay / variable.
mqttlocal sensorsincomming messagesgatewayesp8266mqttclient
3 Posts 1 Posters 2.1k Views 1 Watching
  • Meshx86M Offline
    Meshx86M Offline
    Meshx86
    I've seen the relay sketch which has a receive function but that is for Radio Nodes, i was wondering about processing arrived MQTT messages to the MQTTClient gateway so it changes a variable / acts on a relay.
    is there any way to do that ? is it using the receive function as well ?
    note: i've already defines a message that has the V_type and CHILD_ID matching, i've got the message on the gateway console, i was wondering to get it into a variable.
    Meshx86M 1 Reply Last reply
    • Meshx86M Meshx86
      Meshx86M Offline
      Meshx86M Offline
      Meshx86
      @Meshx86 i figured out the problem which i believe it is a bug, you can't have in your incoming MQTT prefix "/" or "-" in the path, otherwise the message won't be parsed properly
      • Meshx86M Offline
        Meshx86M Offline
        Meshx86
        by hek:
        This PR was merged a few days ago:
        https://github.com/mysensors/MySensors/pull/633
