  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 677.3k Views 99 Watching
  • T TimO
    @ben999 The error in your second post does not seem to be related the to binding and I've no clue what it means. So I'm glad the error is gone. ;-)
    Have you enabled DEBUG for the binding? Please show me the output after you started the discovery process. The connection to the serial gateway is successful, so no need to change the permissions with usermod at the moment.
    With debug enabled you should see the messages incoming from the gateway. If you don't see the messages arriving please check the connection between serial gateway and the node.
    ben999B
    ben999B
    ben999
    @TimO Thanks a lot for your message
    Talking right to the boss !! :wink:
    Actually, except that https://forum.mysensors.org/uploads/files/1479359162183-scan.jpeg nothing else happens...
    Log from sensor (arduino micro++nrf24+dth22) :
    No change, even when i launch a "scan for things"
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
    TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
    TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
    Request registration...
    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
    Node registration=1
    Init complete, id=1, parent=0, distance=1, registration=1
    TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.5
    T: 18.50
    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:68.1
    H: 68.10
    And that's the openhab log... again, no change when i start a "scan for things"... :
    pi@raspberrypi:/usr/share/openhab2 $ sudo ./start_debug.sh
    Launching the openHAB runtime...
    Listening for transport dt_socket at address: 5005
                              __  _____    ____
      ____  ____  ___  ____  / / / /   |  / __ )
     / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  |
    / /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ /
    \____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/
        /_/                        2.0.0-SNAPSHOT
                                   Build #574
    Hit '<tab>' for a list of available commands
    and '[cmd] --help' for help on a specific command.
    Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
    openhab> log:set DEBUG org.openhab.binding.mysensors
    openhab> log:tail
    19:47:20.265 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
    19:47:20.517 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.MySensorsHandlerFactory, component.id=0, service.id=109, service.bundleid=10, service.scope=bundle} - org.openhab.binding.mysensors
    19:47:20.619 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
    19:47:40.172 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
    19:47:48.877 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
    19:47:49.580 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
    19:47:49.939 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:bridge-ser:gateway' has been added.
    19:47:50.853 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=234, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
    19:47:50.869 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=mysensors:bridge-ser, thing.id=mysensors:bridge-ser:gateway, service.id=235, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
    19:47:50.908 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
    19:47:50.915 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors Bridge
    19:47:51.047 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:humidity:4008f727' has been added.
    19:47:51.072 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:4008f727' changed from UNINITIALIZED to INITIALIZING
    19:47:51.073 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=mysensors:humidity, thing.id=mysensors:humidity:4008f727, service.id=237, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
    19:47:51.084 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:temperature:762194fe' has been added.
    19:47:51.210 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=mysensors:temperature, thing.id=mysensors:temperature:762194fe, service.id=238, service.bundleid=10, service.scope=singleton} - org.openhab.binding.mysensors
    19:47:51.212 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:762194fe' changed from UNINITIALIZED to INITIALIZING
    19:47:51.329 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:4008f727' changed from INITIALIZING to ONLINE
    19:47:51.330 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:762194fe' changed from INITIALIZING to ONLINE
    19:47:51.332 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
    19:47:51.341 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'MotionTest-mysensors:motion:1584d6773a3:armed' has been added.
    19:47:51.345 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'MotionTest-mysensors:motion:1584d6773a3:tripped' has been added.
    19:47:51.357 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to ONLINE
    19:47:51.413 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_humidity_4008f727_battery' has been added.
    19:47:51.417 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_humidity_4008f727_battery-mysensors:humidity:4008f727:battery' has been added.
    19:47:51.421 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_humidity_4008f727_hum' has been added.
    19:47:51.425 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_humidity_4008f727_hum-mysensors:humidity:4008f727:hum' has been added.
    19:47:51.431 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_temperature_762194fe_battery' has been added.
    19:47:51.434 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_temperature_762194fe_battery-mysensors:temperature:762194fe:battery' has been added.
    19:47:51.440 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_temperature_762194fe_temp' has been added.
    19:47:51.454 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'mysensors_temperature_762194fe_temp-mysensors:temperature:762194fe:temp' has been added.
    19:47:56.749 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
    19:47:57.810 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
    19:47:58.557 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
    19:47:59.161 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
    19:47:59.682 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
    19:47:59.807 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
    19:48:04.034 [INFO ] [o.myopenhab.internal.MyOpenHABClient] - Connected to my.openHAB service (UUID = 7c0faa03-e826-473a-b1f7-8b685b487bb8, base URL = http://localhost:8080)
    Is there any other log that is worth having a look at ?
    This is really strange, because when i hook up a PIR sensor to the same arduino and nrf24, and i launch pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that arduino and raspberry interract together...
    Thanks a lot for your time
    • ben999B ben999
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=1)
      TSM:UPL
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      Node registration=1
      T: 18.50
      H: 68.10
                                __  _____    ____
          /_/                        2.0.0-SNAPSHOT
                                     Build #574
      openhab> log:tail
      TimO
      @ben999 The OH2 log looks good, but could you please enable debug output in OH2 for the binding as described in the Wiki?
      In the log from the node I see that the presentation message is the one that failed to deliver. Does this happen all the time? The binding is looking for that message. This could be a power issue.
      ben999B 1 Reply Last reply
      • T TimO
        ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        #296
        @TimO thank you for your answer
        Both RPi and sensors have been power with different power supplies but no change
        Then, to get the debug output at the karaf prompt I typed : openhab> log:set DEBUG
        This is what i got when asking for a "search for things" process:
        openhab> log:tail
        22:59:40.423 [DEBUG] [e.osgi.LoggingCommandSessionListener] - Command: 'log:clear' returned 'null'
        22:59:42.378 [DEBUG] [rg.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
        22:59:43.026 [DEBUG] [e.osgi.LoggingCommandSessionListener] - Executing command: 'log:set DEBUG'
        22:59:43.028 [DEBUG] [org.apache.felix.configadmin        ] - getProperties()
        22:59:43.032 [DEBUG] [org.apache.felix.configadmin        ] - getProperties()
        22:59:44.731 [DEBUG] [e.osgi.LoggingCommandSessionListener] - Executing command: 'log:tail'
        22:59:46.716 [DEBUG] [io.socket.engineio.client.Socket    ] - writing ping packet - expecting pong within 60000ms
        22:59:46.720 [DEBUG] [io.socket.engineio.client.Socket    ] - flushing 1 packets in socket
        22:59:46.765 [DEBUG] [io.socket.engineio.client.Socket    ] - socket received: type 'pong', data 'null'
        22:59:55.667 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@10fcc9b{/192.168.1.9:45209<->8080,Open,in,out,-,-,30000/30000,HttpConnection}{io=0,kio=0,kro=1} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
        22:59:55.669 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@10fcc9b{/192.168.1.9:45209<->8080,Open,in,out,-,-,30002/30000,HttpConnection}{io=0,kio=0,kro=1} idle timeout expired
        22:59:55.671 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SelectChannelEndPoint@10fcc9b{/192.168.1.9:45209<->8080,Open,in,out,-,-,30004/30000,HttpConnection}{io=0,kio=0,kro=1}
        22:59:57.110 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectorManager$ManagedSelector$Accept@13e699a
        22:59:57.112 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectorManager$ManagedSelector$Accept@13e699a
        22:59:57.113 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - onOpen SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,0/30000,null}{io=0,kio=0,kro=0}
        22:59:57.116 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,1/30000,null}{io=0,kio=0,kro=0} idle timeout check, elapsed: 1 ms, remaining: 29999 ms
        22:59:57.123 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - new HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=} -> SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,9/30000,null}{io=0,kio=0,kro=0},null,HttpChannelState@1d0ab0c{s=IDLE i=true a=null}
        22:59:57.126 [DEBUG] [.eclipse.jetty.server.HttpConnection] - New HTTP Connection HttpConnection@ec8647[IDLE,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,11/30000,null}{io=0,kio=0,kro=0}][p=HttpParser{s=START,0 of 0},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=}]
        22:59:57.128 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - onOpen HttpConnection@ec8647[IDLE,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,14/30000,HttpConnection}{io=0,kio=0,kro=0}][p=HttpParser{s=START,0 of 0},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=}]
        22:59:57.133 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested HttpConnection@ec8647[IDLE,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,15/30000,HttpConnection}{io=0,kio=0,kro=0}][p=HttpParser{s=START,0 of 0},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=}]
        22:59:57.136 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - IDLE-->FILL_INTERESTED HttpConnection@ec8647[FILL_INTERESTED,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,22/30000,HttpConnection}{io=0,kio=0,kro=0}][p=HttpParser{s=START,0 of 0},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=}]
        22:59:57.138 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 0 -> 1 for SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,0/30000,HttpConnection}{io=1,kio=0,kro=0}
        22:59:57.139 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        22:59:57.141 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Created SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,3/30000,HttpConnection}{io=1,kio=0,kro=0}
        22:59:57.143 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        22:59:57.145 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 0 -> 1 on SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,7/30000,HttpConnection}{io=1,kio=1,kro=0}
        22:59:57.146 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
        22:59:57.148 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 1/1 selected
        22:59:57.150 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 1 -> 0 on SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,12/30000,HttpConnection}{io=1,kio=0,kro=1}
        22:59:57.152 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 1 -> 0 for SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,14/30000,HttpConnection}{io=0,kio=0,kro=1}
        22:59:57.153 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        22:59:57.156 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILL_INTERESTED-->FILLING HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,17/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of 0},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=}]
        22:59:57.157 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        22:59:57.158 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
        22:59:57.158 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,20/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of 0},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=0,c=false,a=IDLE,uri=}] onFillable HttpChannelState@1d0ab0c{s=IDLE i=true a=null}
        22:59:57.159 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 381 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,22/30000,HttpConnection}{io=0,kio=0,kro=1}
        22:59:57.160 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@16d7302[p=0,l=381,c=8192,r=381]={<<<GET /rest/discove....6,en;q=0.4\r\n\r\n>>>2.168.1.96:8080/u...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
        22:59:57.161 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - START --> SPACE1
        22:59:57.162 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE1 --> URI
        22:59:57.162 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - URI --> SPACE2
        22:59:57.163 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE2 --> REQUEST_VERSION
        22:59:57.163 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - REQUEST_VERSION --> HEADER
        22:59:57.164 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        22:59:57.165 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        22:59:57.167 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.172 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        22:59:57.173 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.175 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        22:59:57.177 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        22:59:57.178 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.180 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        22:59:57.181 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        22:59:57.183 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.184 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        22:59:57.185 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        22:59:57.187 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.188 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        22:59:57.189 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.190 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        22:59:57.192 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        22:59:57.193 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        22:59:57.194 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> END
        22:59:57.195 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=/rest/discovery} messageComplete
        22:59:57.201 [DEBUG] [org.eclipse.jetty.server.HttpInput  ] - HttpInputOverHTTP@1a10417 EOF
        22:59:57.204 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=/rest/discovery} handle enter
        22:59:57.207 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@1d0ab0c{s=IDLE i=true a=null} handling IDLE
        22:59:57.214 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=DISPATCHED,uri=/rest/discovery} action REQUEST_DISPATCH
        22:59:57.218 [DEBUG] [org.eclipse.jetty.server.Server     ] - REQUEST GET /rest/discovery on HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=DISPATCHED,uri=/rest/discovery}
        22:59:57.220 [DEBUG] [ax.web.service.spi.model.ServerModel] - Matching [/rest/discovery]...
        22:59:57.223 [DEBUG] [ax.web.service.spi.model.ServerModel] - Path [/rest/discovery] matched to {pattern=/rest/.*,model=ServletModel{id=org.ops4j.pax.web.service.spi.model.ServletModel-2,name=org.ops4j.pax.web.service.spi.model.ServletModel-2,urlPatterns=[/rest/*],alias=/rest,servlet=com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge@bc5ed1,initParams={},context=ContextModel{id=org.ops4j.pax.web.service.spi.model.ContextModel-1,name=,httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default],contextParams={},virtualHosts={},connectors={}}}}
        22:59:57.225 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
        22:59:57.227 [DEBUG] [.jetty.server.handler.ContextHandler] - context=||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
        22:59:57.228 [DEBUG] [org.eclipse.jetty.server.session    ] - sessionManager=org.ops4j.pax.web.service.jetty.internal.LateInvalidatingHashSessionManager@32d70e
        22:59:57.229 [DEBUG] [org.eclipse.jetty.server.session    ] - session=null
        22:59:57.231 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - servlet |/rest|/discovery -> org.ops4j.pax.web.service.spi.model.ServletModel-2@378be0fa==com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge,-1,true
        22:59:57.232 [DEBUG] [ce.jetty.internal.HttpServiceContext] - Handling request for [/rest/discovery] using http context [DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]]
        22:59:57.233 [DEBUG] [y.internal.HttpServiceServletHandler] - handling request org.ops4j.pax.web.service.jetty.internal.HttpServiceRequestWrapper@166f693, org.ops4j.pax.web.service.jetty.internal.HttpServiceResponseWrapper@1596f67
        22:59:57.235 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - chain=null
        22:59:57.244 [DEBUG] [e.internal.WriterInterceptorExecutor] - Message body writer (class com.eclipsesource.jaxrs.provider.gson.GsonProvider) is trying to close the entity output stream. Not closing.
        22:59:57.246 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@5bfca8[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,13,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@1b5d408] generate: NEED_HEADER (null,[p=0,l=13,c=8192,r=13],true)@START
        22:59:57.249 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@5bfca8[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,13,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@1b5d408] generate: FLUSH ([p=0,l=141,c=8192,r=141],[p=0,l=13,c=8192,r=13],true)@COMPLETING
        22:59:57.253 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 154 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,W,93/30000,HttpConnection}{io=0,kio=0,kro=1}
        22:59:57.256 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@5bfca8[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,13,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@1b5d408] generate: DONE ([p=141,l=141,c=8192,r=0],[p=13,l=13,c=8192,r=0],true)@END
        22:59:57.259 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ o.e.j.s.h.ContextHandler@190a83a{/static,null,AVAILABLE}
        22:59:57.261 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.201611041332 [100], contextID=default]}
        22:59:57.262 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.201611041332 [137], contextID=default]}
        22:59:57.264 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.201611041332 [138], contextID=default]}
        22:59:57.269 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@1ea92c5}
        22:59:57.270 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.201611041332 [186], contextID=default]}
        22:59:57.272 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.classic_0.9.0.201611041332 [187], contextID=default]}
        22:59:57.273 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.201611041332 [188], contextID=default]}
        22:59:57.274 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.io.rest.docs_2.0.0.201611062131 [189], contextID=default]}
        22:59:57.276 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.0.0.201611062131 [192], contextID=default]}
        22:59:57.277 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.0.0.201611062131 [168], contextID=default]}
        22:59:57.278 [DEBUG] [org.eclipse.jetty.server.Server     ] - RESPONSE /rest/discovery  200 handled=true
        22:59:57.279 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@1d0ab0c{s=DISPATCHED i=true a=null} unhandle DISPATCHED
        22:59:57.281 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - reset HttpParser{s=END,0 of 0}
        22:59:57.281 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - END --> START
        22:59:57.283 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=} handle exit, result COMPLETE
        22:59:57.301 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,45/30000,HttpConnection}{io=0,kio=0,kro=1}
        22:59:57.303 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,46/30000,HttpConnection}{io=0,kio=0,kro=1}
        22:59:57.304 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@1860225[p=0,l=0,c=8192,r=0]={<<<>>>HTTP/1.1 200 OK\r\n...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
        22:59:57.307 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,50/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=}]
        22:59:57.310 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING-->FILLING_FILL_INTERESTED HttpConnection@ec8647[FILLING_FILL_INTERESTED,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,52/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=}]
        22:59:57.313 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING_FILL_INTERESTED-->FILL_INTERESTED HttpConnection@ec8647[FILL_INTERESTED,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,55/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=}]
        22:59:57.315 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 0 -> 1 for SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,0/30000,HttpConnection}{io=1,kio=0,kro=1}
        22:59:57.316 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        22:59:57.318 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 0/1 selected
        22:59:57.320 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        22:59:57.322 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 0 -> 1 on SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,7/30000,HttpConnection}{io=1,kio=1,kro=1}
        22:59:57.323 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
        23:00:01.810 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 1/1 selected
        23:00:01.812 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 1 -> 0 on SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,4497/30000,HttpConnection}{io=1,kio=0,kro=1}
        23:00:01.814 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 1 -> 0 for SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,4499/30000,HttpConnection}{io=0,kio=0,kro=1}
        23:00:01.814 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        23:00:01.816 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILL_INTERESTED-->FILLING HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,4502/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=}]
        23:00:01.817 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
        23:00:01.818 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
        23:00:01.819 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,4504/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=1,c=false,a=IDLE,uri=}] onFillable HttpChannelState@1d0ab0c{s=IDLE i=true a=null}
        23:00:01.821 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 525 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,4506/30000,HttpConnection}{io=0,kio=0,kro=1}
        23:00:01.822 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@16d7302[p=0,l=525,c=8192,r=525]={<<<POST /rest/discov...d":"mysensors"}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
        23:00:01.822 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - START --> SPACE1
        23:00:01.823 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE1 --> URI
        23:00:01.824 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - URI --> SPACE2
        23:00:01.824 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE2 --> REQUEST_VERSION
        23:00:01.825 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - REQUEST_VERSION --> HEADER
        23:00:01.826 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        23:00:01.827 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.828 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        23:00:01.828 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.829 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        23:00:01.830 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        23:00:01.831 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.832 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        23:00:01.832 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.833 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_NAME
        23:00:01.834 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_NAME --> HEADER_VALUE
        23:00:01.835 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        23:00:01.835 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.836 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        23:00:01.837 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.838 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        23:00:01.839 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.839 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_VALUE
        23:00:01.840 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
        23:00:01.841 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        23:00:01.842 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
        23:00:01.843 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
        • Puneit ThukralP
          Puneit ThukralP
          Puneit Thukral
          • ben999B
            ben999B
            ben999
            end of debug log (sorry, post too long)
            23:00:01.843 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
            23:00:01.844 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
            23:00:01.845 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> CONTENT
            23:00:01.846 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=IDLE,uri=/rest/discovery/bindings/mysensors/scan} handle enter
            23:00:01.847 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@1d0ab0c{s=IDLE i=true a=null} handling IDLE
            23:00:01.848 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=DISPATCHED,uri=/rest/discovery/bindings/mysensors/scan} action REQUEST_DISPATCH
            23:00:01.849 [DEBUG] [org.eclipse.jetty.server.Server     ] - REQUEST POST /rest/discovery/bindings/mysensors/scan on HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=DISPATCHED,uri=/rest/discovery/bindings/mysensors/scan}
            23:00:01.850 [DEBUG] [ax.web.service.spi.model.ServerModel] - Matching [/rest/discovery/bindings/mysensors/scan]...
            23:00:01.851 [DEBUG] [ax.web.service.spi.model.ServerModel] - Path [/rest/discovery/bindings/mysensors/scan] matched to {pattern=/rest/.*,model=ServletModel{id=org.ops4j.pax.web.service.spi.model.ServletModel-2,name=org.ops4j.pax.web.service.spi.model.ServletModel-2,urlPatterns=[/rest/*],alias=/rest,servlet=com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge@bc5ed1,initParams={},context=ContextModel{id=org.ops4j.pax.web.service.spi.model.ContextModel-1,name=,httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default],contextParams={},virtualHosts={},connectors={}}}}
            23:00:01.852 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
            23:00:01.853 [DEBUG] [.jetty.server.handler.ContextHandler] - context=||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
            23:00:01.853 [DEBUG] [org.eclipse.jetty.server.session    ] - sessionManager=org.ops4j.pax.web.service.jetty.internal.LateInvalidatingHashSessionManager@32d70e
            23:00:01.854 [DEBUG] [org.eclipse.jetty.server.session    ] - session=null
            23:00:01.855 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - servlet |/rest|/discovery/bindings/mysensors/scan -> org.ops4j.pax.web.service.spi.model.ServletModel-2@378be0fa==com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge,-1,true
            23:00:01.856 [DEBUG] [ce.jetty.internal.HttpServiceContext] - Handling request for [/rest/discovery/bindings/mysensors/scan] using http context [DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]]
            23:00:01.857 [DEBUG] [y.internal.HttpServiceServletHandler] - handling request org.ops4j.pax.web.service.jetty.internal.HttpServiceRequestWrapper@a929e4, org.ops4j.pax.web.service.jetty.internal.HttpServiceResponseWrapper@13d3535
            23:00:01.857 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - chain=null
            23:00:01.872 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@5bfca8[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,4,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@1866dfa] generate: NEED_HEADER (null,[p=0,l=4,c=8192,r=4],true)@START
            23:00:01.874 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@5bfca8[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,4,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@1866dfa] generate: FLUSH ([p=0,l=134,c=8192,r=134],[p=0,l=4,c=8192,r=4],true)@COMPLETING
            23:00:01.875 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 138 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,W,54/30000,HttpConnection}{io=0,kio=0,kro=1}
            23:00:01.877 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@5bfca8[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,4,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@1866dfa] generate: DONE ([p=134,l=134,c=8192,r=0],[p=4,l=4,c=8192,r=0],true)@END
            23:00:01.879 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ o.e.j.s.h.ContextHandler@190a83a{/static,null,AVAILABLE}
            23:00:01.880 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.201611041332 [100], contextID=default]}
            23:00:01.881 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.201611041332 [137], contextID=default]}
            23:00:01.882 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.201611041332 [138], contextID=default]}
            23:00:01.883 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@1ea92c5}
            23:00:01.884 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.201611041332 [186], contextID=default]}
            23:00:01.884 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.classic_0.9.0.201611041332 [187], contextID=default]}
            23:00:01.885 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.201611041332 [188], contextID=default]}
            23:00:01.886 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.io.rest.docs_2.0.0.201611062131 [189], contextID=default]}
            23:00:01.887 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.0.0.201611062131 [192], contextID=default]}
            23:00:01.888 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/discovery/bindings/mysensors/scan @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.0.0.201611062131 [168], contextID=default]}
            23:00:01.889 [DEBUG] [org.eclipse.jetty.server.Server     ] - RESPONSE /rest/discovery/bindings/mysensors/scan  200 handled=true
            23:00:01.891 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@1d0ab0c{s=DISPATCHED i=true a=null} unhandle DISPATCHED
            23:00:01.893 [DEBUG] [.eclipse.jetty.server.HttpConnection] - unconsumed input HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,16/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=CONTENT,0 of 25},g=HttpGenerator{s=END},c=HttpChannelOverHttp@1a5f1b6{r=2,c=true,a=COMPLETED,uri=/rest/discovery/bindings/mysensors/scan}]
            23:00:01.894 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=CONTENT HeapByteBuffer@16d7302[p=500,l=525,c=8192,r=25]={POST /rest/discov....6,en;q=0.4\r\n\r\n<<<{"bindingId":"mysensors"}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
            23:00:01.895 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=2,c=true,a=COMPLETED,uri=/rest/discovery/bindings/mysensors/scan} content java.nio.HeapByteBufferR[pos=500 lim=525 cap=8192]
            23:00:01.897 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=CONTENT HeapByteBuffer@16d7302[p=525,l=525,c=8192,r=0]={POST /rest/discov...d":"mysensors"}<<<>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
            23:00:01.897 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - CONTENT --> END
            23:00:01.898 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=2,c=true,a=COMPLETED,uri=/rest/discovery/bindings/mysensors/scan} messageComplete
            23:00:01.899 [DEBUG] [org.eclipse.jetty.server.HttpInput  ] - HttpInputOverHTTP@1a10417 EOF
            23:00:01.901 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,24/30000,HttpConnection}{io=0,kio=0,kro=1}
            23:00:01.903 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,26/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,25 of 25},g=HttpGenerator{s=END},c=HttpChannelOverHttp@1a5f1b6{r=2,c=true,a=COMPLETED,uri=/rest/discovery/bindings/mysensors/scan}] filled 0
            23:00:01.904 [DEBUG] [org.eclipse.jetty.server.HttpInput  ] - HttpInputOverHTTP@1a10417 eof EOF
            23:00:01.905 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - reset HttpParser{s=END,25 of 25}
            23:00:01.905 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - END --> START
            23:00:01.907 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=IDLE,uri=} handle exit, result COMPLETE
            23:00:01.908 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,31/30000,HttpConnection}{io=0,kio=0,kro=1}
            23:00:01.909 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,33/30000,HttpConnection}{io=0,kio=0,kro=1}
            23:00:01.910 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@1860225[p=0,l=0,c=8192,r=0]={<<<>>>HTTP/1.1 200 OK\r\n...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
            23:00:01.912 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested HttpConnection@ec8647[FILLING,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,36/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=IDLE,uri=}]
            23:00:01.914 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING-->FILLING_FILL_INTERESTED HttpConnection@ec8647[FILLING_FILL_INTERESTED,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,38/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=IDLE,uri=}]
            23:00:01.917 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING_FILL_INTERESTED-->FILL_INTERESTED HttpConnection@ec8647[FILL_INTERESTED,SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,-,-,40/30000,HttpConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@1a5f1b6{r=2,c=false,a=IDLE,uri=}]
            23:00:01.918 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 0 -> 1 for SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,1/30000,HttpConnection}{io=1,kio=0,kro=1}
            23:00:01.919 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
            23:00:01.920 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 0/1 selected
            23:00:01.923 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@b87e8a
            23:00:01.925 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 0 -> 1 on SelectChannelEndPoint@15c7d05{/192.168.1.9:45427<->8080,Open,in,out,R,-,7/30000,HttpConnection}{io=1,kio=1,kro=1}
            23:00:01.926 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
            23:00:09.067 [DEBUG] [rg.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
            23:00:11.859 [DEBUG] [io.socket.engineio.client.Socket    ] - writing ping packet - expecting pong within 60000ms
            23:00:11.859 [DEBUG] [io.socket.engineio.client.Socket    ] - flushing 1 packets in socket
            23:00:11.904 [DEBUG] [io.socket.engineio.client.Socket    ] - socket received: type 'pong', data 'null'
            :scream:
            192.168.1.9 is the computer (ubuntu) from which i do ssh...
            And this is the log during "idle"
            23:02:48.131 [DEBUG] [rg.quartz.core.QuartzSchedulerThread] - batch acquisition of 0 triggers
            23:02:55.692 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@10fcc9b{/192.168.1.9:45209<->8080,Open,in,out,-,-,30000/30000,HttpConnection}{io=0,kio=0,kro=1} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
            23:02:55.693 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@10fcc9b{/192.168.1.9:45209<->8080,Open,in,out,-,-,30002/30000,HttpConnection}{io=0,kio=0,kro=1} idle timeout expired
            23:02:55.695 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SelectChannelEndPoint@10fcc9b{/192.168.1.9:45209<->8080,Open,in,out,-,-,30003/30000,HttpConnection}{io=0,kio=0,kro=1}
            23:03:08.614 [DEBUG] [io.socket.engineio.client.Socket    ] - writing ping packet - expecting pong within 60000ms
            23:03:08.614 [DEBUG] [io.socket.engineio.client.Socket    ] - flushing 1 packets in socket
            23:03:08.655 [DEBUG] [io.socket.engineio.client.Socket    ] - socket received: type 'pong', data 'null'
            • ben999B ben999
              :scream:
              TimO
              @ben999 My bad sorry, your first log already contained the debug information.
              To which serial port is the gateway connected? I see that it connected, but I'm missing a few messages that should appear. Could you please specify the bridge / gateway (only the gateway) in the *.things file according to the description in the wiki and see if that works?
              We should see the messages the gateway receives in the debug output.
              • FutureCowF
                FutureCowF
                FutureCow
                I have almost the same problem. Items don't get added to the inbox when a new node is found.
                Also when i add them manualy, things don't work(it was working earlier) So i think something changed for the bindings. So at the moment the MySensors binding is not working with latest snapshot(#597)
                My Debug log:
                2016-11-20 01:43:15.119 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                2016-11-20 01:43:15.119 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
                2016-11-20 01:43:15.119 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                2016-11-20 01:43:15.126 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                2016-11-20 01:43:15.126 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [32, 52, 51, 40, 36, 35]
                2016-11-20 01:43:15.126 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                2016-11-20 01:43:15.127 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB21 [baudRate:9600]
                2016-11-20 01:43:15.127 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB21
                2016-11-20 01:43:15.133 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                2016-11-20 01:43:15.133 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                2016-11-20 01:43:18.235 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                2016-11-20 01:43:18.246 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.0.0
                2016-11-20 01:43:18.246 [DEBUG] [col.serial.MySensorsSerialConnection] - Good,Gateway is up and running! (Ver:2.0.0)
                2016-11-20 01:43:18.247 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                2016-11-20 01:43:18.247 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                2016-11-20 01:43:18.258 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 32, chiledId: 0, revertState: false
                2016-11-20 01:43:18.259 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 35, chiledId: 0, revertState: false
                2016-11-20 01:43:18.259 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 51, chiledId: 3, revertState: false
                2016-11-20 01:43:18.259 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 52, chiledId: 3, revertState: false
                2016-11-20 01:43:18.259 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 35, chiledId: 3, revertState: false
                2016-11-20 01:43:18.260 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 40, chiledId: 0, revertState: true
                2016-11-20 01:43:18.260 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 36, chiledId: 3, revertState: false
                2016-11-20 01:43:18.260 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 36, chiledId: 1, revertState: false
                2016-11-20 01:43:18.260 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 36, chiledId: 0, revertState: false
                2016-11-20 01:43:18.260 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 32, chiledId: 3, revertState: false
                2016-11-20 01:43:18.261 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 52, chiledId: 4, revertState: false
                2016-11-20 01:43:18.261 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 52, chiledId: 5, revertState: false
                2016-11-20 01:43:18.262 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 32, chiledId: 1, revertState: false
                2016-11-20 01:43:18.262 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 35, chiledId: 1, revertState: false
                2016-11-20 01:43:18.263 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 51, chiledId: 4, revertState: false
                2016-11-20 01:43:20.379 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:SANCHK:OK
                2016-11-20 01:43:28.247 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:43:38.248 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:43:48.248 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:43:58.249 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:44:01.834 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 32-32-0 s=255,c=3,t=22,pt=5,l=4,sg=0:19562725
                2016-11-20 01:44:01.845 [DEBUG] [rs.internal.protocol.MySensorsReader] - 32;255;3;0;22;19562725
                2016-11-20 01:44:02.591 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 32-32-0 s=1,c=1,t=0,pt=7,l=5,sg=0:18.2
                2016-11-20 01:44:02.591 [DEBUG] [rs.internal.protocol.MySensorsReader] - 32;1;1;0;0;18.2
                2016-11-20 01:44:02.683 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 32-32-0 s=2,c=1,t=4,pt=7,l=5,sg=0:1000.8
                2016-11-20 01:44:02.683 [DEBUG] [rs.internal.protocol.MySensorsReader] - 32;2;1;0;4;1000.8
                2016-11-20 01:44:02.764 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 32-32-0 s=0,c=1,t=1,pt=7,l=5,sg=0:52.1
                2016-11-20 01:44:02.774 [DEBUG] [rs.internal.protocol.MySensorsReader] - 32;0;1;0;1;52.1
                2016-11-20 01:44:02.855 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 32-32-0 s=2,c=1,t=5,pt=0,l=6,sg=0:cloudy
                2016-11-20 01:44:02.856 [DEBUG] [rs.internal.protocol.MySensorsReader] - 32;2;1;0;5;cloudy
                2016-11-20 01:44:08.249 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:44:18.249 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:44:20.380 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:SANCHK:OK
                2016-11-20 01:44:27.370 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 52-52-0 s=4,c=1,t=0,pt=7,l=5,sg=0:15.1
                2016-11-20 01:44:27.370 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:27.380 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-52-52 s=4,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:15.1
                2016-11-20 01:44:27.381 [DEBUG] [rs.internal.protocol.MySensorsReader] - 52;4;1;0;0;15.1
                2016-11-20 01:44:27.522 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 52-52-0 s=3,c=1,t=1,pt=7,l=5,sg=0:49.3
                2016-11-20 01:44:27.522 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:27.563 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-52-52 s=3,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:49.3
                2016-11-20 01:44:27.564 [DEBUG] [rs.internal.protocol.MySensorsReader] - 52;3;1;0;1;49.3
                2016-11-20 01:44:28.250 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:44:30.102 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 51-51-0 s=4,c=1,t=0,pt=7,l=5,sg=0:4.5
                2016-11-20 01:44:30.102 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:30.113 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-51-51 s=4,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:4.5
                2016-11-20 01:44:30.113 [DEBUG] [rs.internal.protocol.MySensorsReader] - 51;4;1;0;0;4.5
                2016-11-20 01:44:30.204 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 51-51-0 s=3,c=1,t=1,pt=7,l=5,sg=0:91.8
                2016-11-20 01:44:30.204 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:30.255 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-51-51 s=3,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:91.8
                2016-11-20 01:44:30.255 [DEBUG] [rs.internal.protocol.MySensorsReader] - 51;3;1;0;1;91.8
                2016-11-20 01:44:38.250 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                2016-11-20 01:44:42.816 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 35-35-0 s=255,c=3,t=0,pt=1,l=1,sg=0:57
                2016-11-20 01:44:42.826 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:42.826 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-35-35 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:57
                2016-11-20 01:44:42.837 [DEBUG] [rs.internal.protocol.MySensorsReader] - 35;255;3;0;0;57
                2016-11-20 01:44:42.908 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 35-35-0 s=3,c=1,t=38,pt=7,l=5,sg=0:2.6600
                2016-11-20 01:44:42.908 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:42.918 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:SEND 0-0-35-35 s=3,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:2.6600
                2016-11-20 01:44:42.919 [DEBUG] [rs.internal.protocol.MySensorsReader] - 35;3;1;0;38;2.6600
                2016-11-20 01:44:43.040 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 35-35-0 s=1,c=1,t=0,pt=7,l=5,sg=0:18.9
                2016-11-20 01:44:43.040 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:ACK msg
                2016-11-20 01:44:43.081 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;9;!TSP:MSG:SEND 0-0-35-35 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:18.9
                2016-11-20 01:44:43.081 [DEBUG] [rs.internal.protocol.MySensorsReader] - 35;1;1;0;0;18.9
                As you can see, i recieve messages from the gateway. No items are updated.
                • FutureCowF
                  FutureCowF
                  FutureCow
                  wrote on last edited by FutureCow
                  #301
                  • FutureCowF FutureCow
                    My Debug log:
                    TimO
                    @FutureCow Strange, I'll look into it. I suppose I've introduced this bug with the latest refactoring. :-/
                    • T TimO
                      ben999B
                      ben999B
                      ben999
                      #303
                      @TimO
                      Hi Tim
                      Thanks a lot for your message.
                      NRF is connected to GPIO pins as per https://www.mysensors.org/build/raspberry
                      I have run dmesg |grep -i tty as suggested by @Yveaux and i got
                      [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xcc3e67e3 smsc95xx.macaddr=B8:27:EB:3E:67:E3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                      [    0.001337] console [tty1] enabled
                      [    1.781491] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
                      I assumed that my serail port would be ttyAMA0
                      So i wrote my "home.things" file with it:
                      Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyAMA0", sendDelay=200 ] {
                          /** define things connected to that bridge here */  }
                      This pi@raspberrypi:~ $ screen /dev/ttyAMA0 115200 returns that
                      [screen is terminating]
                      Also, when watching the live output from sudo ./bin/mysgw -d i can see that
                      pi@raspberrypi:~ $ cd MySensors
                      mysgw: Starting gateway...
                      mysgw: Protocol version - 2.0.1-beta
                      mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSM:INIT:TSP OK
                      mysgw: TSM:INIT:GW MODE
                      mysgw: TSM:READY
                      but when i launch openhab with sudo ./start_debug.sh i see
                      5003 vs 5005... I tried that pi@raspberrypi:~/MySensors $ ./configure --my-port=5005 but no luck, I got that in return...
                      mysgw: accept: Bad file descriptor
                      going forever :(
                      • T TimO
                        Features
                        • Serial Gateway supported (with variable baud rate)
                        • Ethernet Gateway supported
                        • Supported sensors: S_TEMP, S_HUM, S_VOLTAGE, S_LIGHT, S_POWER, S_BARO, S_DOOR, S_MOTION, S_SMOKE, S_DIMMER, S_COVER (Stop not implemented in OH2 yet), S_WIND, S_RAIN, S_UV, S_WEIGHT, S_DISTANCE, S_LIGHT_LEVEL
                        • Request for an ID is answered (random free number is given)
                        • Discovery of devices, to use it: start the scan for devices in OpenHAB 2.0 and restart your nodes
                        Pictures
                        Discovery:
                        What is not working yet:
                        • no reconnect after lost connection
                        How to test:
                        Visit the wiki on the GitHub Repo.
                        bentrikB
                        bentrikB
                        bentrik
                        wrote on last edited by bentrik
                        #304
                        @TimO said:
                        GitHub Repo
                        So I´m very new to OpenHAB, but I´ve tried to bind MySensors for a few days now, and I´m stuck. I´d be really happy if someone could guide me a little further.
                        -I´ve flashed and installed OpenHABian on my Raspberry. (OpenHAB2)
                        -Managed to bind my Sonos through the paper ui, so the OpenHAB2 install looks good.
                        -Now I wish to bind Mysensors on a serial gateway.
                        Looking at the GitHub install guide it seems as simple as adding the MySensors.jar file to the addons directory, but from what I can see, bindings are not managed like that in OpenHab2? All guiding I read seems to refer to another file structure in OpenHab 1.8.
                        I managed to find an addons directory in /usr/share/openhab2/addons, but I can´t find a way to copy the .jar file there, as I get permission denied both through WinSCP in sudo mode and terminal ssh. The folder has permission 0775.
                        Can anyone guide me to thread that describes how to install MySensors on an OpenHABian Raspberry installation?
                        • T
                          TimO
                          That is the correct directory if you installed OH2 via .deb. Seems like you are using a user in WinSCP that is not allowed to write to the directory above. To circumvent this:
                          1. Copy the binding jar to /tmp.
                          2. Login via ssh and execute:
                          sudo cp /tmp/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar /usr/share/openhab2/addons/
                          and
                          sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                          OH2 is started/stopped/restarted with
                          service openhab2 start/stop/restart
                          To log into the karaf console do:
                          ssh openhab@localhost -p 8101
                          Password is: habopen
                          Follow the guide/wiki from:
                          In the console enter feature:install openhab-transport-serial
                          P 1 Reply Last reply
                          • ben999B ben999
                            @TimO
                            Hi Tim
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSM:READY
                            going forever :(
                            TimO
                            @ben999
                            If you are using the RPi gateway with the options you provided above:
                            sudo ./bin/mysgw -d
                            You need to configure the OH2 binding to connect to a ethernet gateway (via localhost, 127.0.0.1 and port 5003), don't use the serial gateway. You are able to confirm this if you execute a "telnet localhost 5003" on the RPi and should be see the messages incoming from the node.
                            • FutureCowF
                              FutureCowF
                              FutureCow
                              I did some testing with older and newer version:
                              OpenHAB #457, MySensor_Binding Aug2016, Text conf: No problems
                              OpenHAB #457, MySensor_Binding Nov2016, Text conf: No problems
                              OpenHAB #457, MySensor_Binding Aug2016, PaperUI conf: No autodiscovery, Manual Add: No problems
                              OpenHAB #457, MySensor_Binding Nov2016, PaperUI conf: No autodiscovery, Manual Add: No problems
                              OpenHAB #603, MySensor_Binding Aug2016, Text conf: Doesn't Work!
                              OpenHAB #603, MySensor_Binding Nov2016, Text conf: Doesn't work!
                              OpenHAB #603, MySensor_Binding Aug2016, PaperUI conf: No autodiscovery, Manual Add: Doesn't work!
                              OpenHAB #603, MySensor_Binding Nov2016, PaperUI conf: No autodiscovery, Manual Add: Doesn't work!
                              Doesn't work! means the gateway is working, I receive messages, but the items doesn't get updated.
                              Also restarting openhab/mysensor binding doesnt solve the problem.
                                TimO
                                @FutureCow Thanks for testing! There definiatly is a bug and slowly I'm getting a grip on it. The annoying thing is: in my development environment everything works smooth, so I updated my production environment and voila there is the problem: no thing updates.
                                It looks like a timing issue on initialization of the bridge/gateway. I'll dig deeper!
                                The topic autodiscovery will follow, I've not spent much time in testing this feature as it was of no use till lately. Now PaperUI/Habpanel are getting the functionality that makes it usable and will make the big difference to OpenHAB 1.
                                • bathoryrB
                                  bathoryrB
                                  bathoryr
                                  wrote on last edited by bathoryr
                                  #309
                                  I also have similar problems, after upgrade OH to latest snapshot yesterday. All things remain in offline status. Discovery is working when I hit "Search for things" from Paper UI and force presentation/reset on some sensor.
                                  21:23:12.982 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
                                  21:23:13.062 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.factory.MySensorsHandlerFactory, component.id=252, service.id=400, service.bundleid=198, service.scope=bundle} - org.openhab.binding.mysensors
                                  21:23:13.082 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=401, service.bundleid=198, service.scope=singleton} - org.openhab.binding.mysensors
                                  21:23:13.121 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
                                  21:23:13.548 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                  21:23:13.551 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: false
                                  21:23:13.552 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                                  21:23:13.555 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                  21:23:13.557 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [5, 12, 7, 10, 1, 9, 3, 8, 30, 6, 24]
                                  21:23:13.559 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                  21:23:13.549 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  21:23:13.571 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [127.0.0.1:5003]
                                  21:23:13.596 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                                  21:23:13.598 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.0.1-beta
                                  21:23:13.778 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                  21:23:13.797 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.0.1-beta
                                  21:23:13.800 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Good,Gateway is up and running! (Ver:2.0.1-beta)
                                  21:23:13.813 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from INITIALIZING to ONLINE
                                  21:23:13.828 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                  21:23:13.830 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 12, chiledId: 1, revertState: false
                                  21:23:13.830 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Network Sanity Checker thread disabled from bridge configuration
                                  21:23:13.855 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:power:gateway:house_power_12_1' changed from INITIALIZING to OFFLINE
                                  21:23:13.856 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:power:gateway:house_power_12_1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  21:23:13.882 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 24, chiledId: 1, revertState: false
                                  21:23:13.892 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:dimmer:gateway:Dimmer_24_1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  21:23:13.892 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 5, chiledId: 1, revertState: false
                                  21:23:13.899 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:dimmer:gateway:living_room_5_1' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                                  21:23:13.904 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:dimmer:gateway:Dimmer_24_1' changed from INITIALIZING to OFFLINE
                                  21:23:13.926 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:dimmer:gateway:living_room_5_1' changed from INITIALIZING to OFFLINE
                                  21:23:23.832 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  21:23:25.599 [DEBUG] [rs.internal.protocol.MySensorsReader] - 12;1;1;0;17;516
                                  21:23:25.624 [DEBUG] [rs.internal.protocol.MySensorsReader] - 12;1;1;0;24;550307
                                  21:23:25.639 [DEBUG] [rs.internal.protocol.MySensorsReader] - 12;1;1;0;18;55.0307
                                  21:23:29.103 [DEBUG] [rs.internal.protocol.MySensorsReader] - 7;1;1;0;0;19.8
                                  21:23:29.119 [DEBUG] [rs.internal.protocol.MySensorsReader] - 7;255;3;0;22;1208410
                                  Also, when I stop bundle from karaf console, this error appears in log:
                                  21:24:37.371 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=401, service.bundleid=198, service.scope=singleton} - org.openhab.binding.mysensors
                                  21:24:37.379 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:dimmer:gateway:Dimmer_24_1' changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
                                  21:24:37.397 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Disposing of the MySensors bridge
                                  21:24:37.399 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Destroying connection
                                  21:24:37.400 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                                  21:24:37.401 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                                  21:24:37.413 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                                  21:24:37.414 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                                  21:24:37.422 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                                  21:24:37.422 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                  21:24:37.426 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [5, 12, 7, 10, 1, 9, 3, 8, 30, 6, 24]
                                  21:24:37.433 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
                                  21:24:37.429 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:bridge-eth:gateway': java.lang.NullPointerException
                                  java.util.concurrent.ExecutionException: java.lang.NullPointerException
                                  	at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
                                  	at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
                                  	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)
                                  	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)
                                  	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)
                                  	at org.eclipse.smarthome.core.thing.internal.ThingManager.doDisposeHandler(ThingManager.java:858)
                                  	at org.eclipse.smarthome.core.thing.internal.ThingManager.disposeHandler(ThingManager.java:848)
                                  	at org.eclipse.smarthome.core.thing.internal.ThingManager.removeThingHandlerFactory(ThingManager.java:1045)
                                  	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
                                  	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
                                  	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
                                  	at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
                                  	at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.helper.BindMethod.invoke(BindMethod.java:41)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1774)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:393)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:364)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:295)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1241)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1136)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:996)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1175)[34:org.apache.felix.scr:2.0.2]
                                  	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[34:org.apache.felix.scr:2.0.2]
                                  	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                                  • T TimO
                                    @ben999
                                    sudo ./bin/mysgw -d
                                    ben999B
                                    ben999B
                                    ben999
                                    wrote on last edited by ben999
                                    #310
                                    @TimO
                                    Thank you one more time Tim
                                    So i went ahead and replaced
                                    with
                                    Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ]
                                    together with
                                    pi@raspberrypi:/usr/share/openhab2 $ ./configure --my-gateway=ethernet --my-port=5003 --my-serial-port=/dev/ttyAMA0
                                    pi@raspberrypi:/ $ telnet 127.0.0.1 5003 returns what is expected i guess :
                                    Trying 127.0.0.1...
                                    Connected to 127.0.0.1.
                                    Escape character is '^]'.
                                    1;255;0;0;17;2.0.0
                                    1;255;3;0;11;TemperatureAndHumidity
                                    1;255;3;0;12;1.1
                                    1;0;0;0;7;
                                    1;1;0;0;6;
                                    1;1;1;0;0;19.1
                                    1;0;1;0;1;62.5
                                    But still, there must be a missing link : neither in PaperUi nor openHab on iOS i get temp and humidity readings...
                                    This is my OH2 log:tail
                                    06:26:19.597 [DEBUG] [e.internal.WriterInterceptorExecutor] - Message body writer (class com.eclipsesource.jaxrs.provider.gson.GsonProvider) is trying to close the entity output stream. Not closing.
                                    06:26:19.598 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1785907[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,740,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@113ab9] generate: NEED_HEADER (null,[p=0,l=740,c=8192,r=740],true)@START
                                    06:26:19.600 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1785907[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,740,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@113ab9] generate: FLUSH ([p=0,l=105,c=8192,r=105],[p=0,l=740,c=8192,r=740],true)@COMPLETING
                                    06:26:19.601 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - write: WriteFlusher@af70aa{IDLE} [HeapByteBuffer@2a5ea9[p=0,l=105,c=8192,r=105]={<<<HTTP/1.1 200 OK\r\n....v20151106)\r\n\r\n>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},HeapByteBuffer@1ef785[p=0,l=740,c=8192,r=740]={<<<{"id":"_default",...idgets":[]}]}]}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}]
                                    06:26:19.602 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - update WriteFlusher@af70aa{WRITING}:IDLE-->WRITING
                                    06:26:19.604 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,W,128/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,58/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,0 of -1},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@170a7cc{r=25,c=true,a=DISPATCHED,uri=/rest/sitemaps/_default/_default}] flush enter [java.nio.HeapByteBuffer[pos=0 lim=105 cap=8192], java.nio.HeapByteBuffer[pos=0 lim=740 cap=8192]]
                                    06:26:19.607 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/874,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,W,131/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,61/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,0 of -1},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@170a7cc{r=25,c=true,a=DISPATCHED,uri=/rest/sitemaps/_default/_default}] wrap Status = OK HandshakeStatus = NOT_HANDSHAKING
                                    bytesConsumed = 845 bytesProduced = 874
                                    06:26:19.610 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,W,134/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,65/30000,SslConnection}{io=0,kio=0,kro=1} OK HeapByteBuffer@1543b4c[p=0,l=874,c=17408,r=874]={<<<\x17\x03\x03\x03e\x00\x00\x00\x00\x00\x00\x00\x19\xC1\xE8\x8c-...g\xEbkEP\x05\xD7D\x1d\xD51\xA4\x92\x86Y>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
                                    06:26:19.613 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 874 SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,68/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.615 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/0,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,W,140/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,0/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,0 of -1},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@170a7cc{r=25,c=true,a=DISPATCHED,uri=/rest/sitemaps/_default/_default}] flush exit, consumed 845
                                    06:26:19.617 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - update WriteFlusher@af70aa{IDLE}:WRITING-->IDLE
                                    06:26:19.619 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1785907[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,740,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@113ab9] generate: DONE ([p=105,l=105,c=8192,r=0],[p=740,l=740,c=8192,r=0],true)@END
                                    06:26:19.621 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ o.e.j.s.h.ContextHandler@2b17f5{/static,null,AVAILABLE}
                                    06:26:19.622 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.201611041332 [100], contextID=default]}
                                    06:26:19.623 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.201611041332 [137], contextID=default]}
                                    06:26:19.624 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.201611041332 [138], contextID=default]}
                                    06:26:19.625 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@715e88}
                                    06:26:19.626 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.201611041332 [186], contextID=default]}
                                    06:26:19.627 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.classic_0.9.0.201611041332 [187], contextID=default]}
                                    06:26:19.629 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.201611041332 [188], contextID=default]}
                                    06:26:19.630 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.io.rest.docs_2.0.0.201611062131 [189], contextID=default]}
                                    06:26:19.631 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.0.0.201611062131 [192], contextID=default]}
                                    06:26:19.632 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.0.0.201611062131 [168], contextID=default]}
                                    06:26:19.632 [DEBUG] [org.eclipse.jetty.server.Server     ] - RESPONSE /rest/sitemaps/_default/_default  200 handled=true
                                    06:26:19.633 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@8beceb{s=DISPATCHED i=true a=null} unhandle DISPATCHED
                                    06:26:19.635 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - reset HttpParser{s=END,0 of -1}
                                    06:26:19.636 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - END --> START
                                    06:26:19.637 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=} handle exit, result COMPLETE
                                    06:26:19.638 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,163/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,23/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] fill enter
                                    06:26:19.640 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,24/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.641 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,166/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,26/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] filled 0 encrypted bytes
                                    06:26:19.643 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,168/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,28/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] unwrap Status = BUFFER_UNDERFLOW HandshakeStatus = NOT_HANDSHAKING
                                    bytesConsumed = 0 bytesProduced = 0
                                    06:26:19.645 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,170/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,30/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] fill exit
                                    06:26:19.647 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,171/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,31/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] fill enter
                                    06:26:19.648 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,33/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.650 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,174/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,34/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] filled 0 encrypted bytes
                                    06:26:19.652 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,176/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,36/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] unwrap Status = BUFFER_UNDERFLOW HandshakeStatus = NOT_HANDSHAKING
                                    06:26:19.654 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,178/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,38/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] fill exit
                                    06:26:19.654 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@ad25df[p=0,l=0,c=17408,r=0]={<<<>>>GET /rest/sitemap...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
                                    06:26:19.656 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,181/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,41/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.658 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING-->FILLING_FILL_INTERESTED HttpConnection@5d1aa0[FILLING_FILL_INTERESTED,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,183/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,43/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.660 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING_FILL_INTERESTED-->FILL_INTERESTED HttpConnection@5d1aa0[FILL_INTERESTED,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,184/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,44/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.661 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILL_INTERESTED,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,R,-,1/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,46/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.663 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - IDLE-->FILL_INTERESTED SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILL_INTERESTED,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,R,-,3/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,48/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.664 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 0 -> 1 for SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,R,-,0/30000,SslConnection}{io=1,kio=0,kro=1}
                                    06:26:19.665 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@2ea554
                                    06:26:19.666 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 0/1 selected
                                    06:26:19.667 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@2ea554
                                    06:26:19.667 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 0 -> 1 on SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,R,-,3/30000,SslConnection}{io=1,kio=1,kro=1}
                                    06:26:19.667 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
                                    06:26:19.714 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 1/1 selected
                                    06:26:19.714 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 1 -> 0 on SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,R,-,50/30000,SslConnection}{io=1,kio=0,kro=1}
                                    06:26:19.715 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 1 -> 0 for SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,R,-,51/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.715 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@2ea554
                                    06:26:19.716 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILL_INTERESTED-->FILLING SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILL_INTERESTED,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,R,-,56/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,52/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.717 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - onFillable enter DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,R,-,57/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,53/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.718 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILL_INTERESTED-->FILLING HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,58/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,54/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.719 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - onFillable exit DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,59/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,55/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.720 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,59/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,55/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] onFillable HttpChannelState@8beceb{s=IDLE i=true a=null}
                                    06:26:19.721 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING-->IDLE SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,60/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,56/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}]
                                    06:26:19.721 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,60/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,56/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] fill enter
                                    06:26:19.721 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@2ea554
                                    06:26:19.722 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
                                    06:26:19.722 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 515 SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,57/30000,SslConnection}{io=0,kio=0,kro=1}
                                    06:26:19.726 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=515/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,62/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,2/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] filled 515 encrypted bytes
                                    06:26:19.730 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,70/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,8/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] unwrap Status = OK HandshakeStatus = NOT_HANDSHAKING
                                    bytesConsumed = 515 bytesProduced = 486
                                    06:26:19.733 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@d43845{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@5d1aa0[FILLING,DecryptedEndPoint@12d4ea{/192.168.1.24:54399<->8443,Open,in,out,-,-,73/30000,HttpConnection}->SelectChannelEndPoint@bd1cb6{/192.168.1.24:54399<->8443,Open,in,out,-,-,11/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@170a7cc{r=25,c=false,a=IDLE,uri=}] fill exit
                                    06:26:19.735 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@19b0494[p=0,l=486,c=17408,r=486]={<<<GET /rest/sitemap...rwin/16.1.0\r\n\r\n>>>\xBd\xE2\xFb\xC2E\x82\xF6\xD7\xEf\x82(\xE4\xBd`i\xDf\xBd...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
                                    06:26:19.737 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - START --> SPACE1
                                    06:26:19.738 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE1 --> URI
                                    06:26:19.740 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - URI --> SPACE2
                                    06:26:19.740 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE2 --> REQUEST_VERSION
                                    06:26:19.741 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - REQUEST_VERSION --> HEADER
                                    06:26:19.742 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.743 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.744 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_NAME
                                    06:26:19.745 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_NAME --> HEADER_VALUE
                                    06:26:19.746 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
                                    06:26:19.746 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.747 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.748 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.748 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.749 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.750 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.751 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.752 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.752 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.753 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_NAME
                                    06:26:19.754 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_NAME --> HEADER_VALUE
                                    06:26:19.755 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
                                    06:26:19.755 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.756 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_NAME
                                    06:26:19.756 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_NAME --> HEADER_VALUE
                                    06:26:19.757 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
                                    06:26:19.758 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.759 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.759 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.760 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.761 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.761 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                    06:26:19.762 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                    06:26:19.763 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> END
                                    06:26:19.764 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@170a7cc{r=26,c=false,a=IDLE,uri=/rest/sitemaps/_default/_default} messageComplete
                                    06:26:19.765 [DEBUG] [org.eclipse.jetty.server.HttpInput  ] - HttpInputOverHTTP@1f4ee36 EOF
                                    06:26:19.765 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@170a7cc{r=26,c=false,a=IDLE,uri=/rest/sitemaps/_default/_default} handle enter
                                    06:26:19.766 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@8beceb{s=IDLE i=true a=null} handling IDLE
                                    06:26:19.767 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@170a7cc{r=26,c=false,a=DISPATCHED,uri=/rest/sitemaps/_default/_default} action REQUEST_DISPATCH
                                    06:26:19.769 [DEBUG] [org.eclipse.jetty.server.Server     ] - REQUEST GET /rest/sitemaps/_default/_default on HttpChannelOverHttp@170a7cc{r=26,c=false,a=DISPATCHED,uri=/rest/sitemaps/_default/_default}
                                    06:26:19.769 [DEBUG] [ax.web.service.spi.model.ServerModel] - Matching [/rest/sitemaps/_default/_default]...
                                    06:26:19.770 [DEBUG] [ax.web.service.spi.model.ServerModel] - Path [/rest/sitemaps/_default/_default] matched to {pattern=/rest/.*,model=ServletModel{id=org.ops4j.pax.web.service.spi.model.ServletModel-2,name=org.ops4j.pax.web.service.spi.model.ServletModel-2,urlPatterns=[/rest/*],alias=/rest,servlet=com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge@f40c7,initParams={},context=ContextModel{id=org.ops4j.pax.web.service.spi.model.ContextModel-1,name=,httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default],contextParams={},virtualHosts={},connectors={}}}}
                                    06:26:19.771 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
                                    06:26:19.772 [DEBUG] [.jetty.server.handler.ContextHandler] - context=||/rest/sitemaps/_default/_default @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
                                    06:26:19.773 [DEBUG] [org.eclipse.jetty.server.session    ] - sessionManager=org.ops4j.pax.web.service.jetty.internal.LateInvalidatingHashSessionManager@18d27f3
                                    06:26:19.774 [DEBUG] [org.eclipse.jetty.server.session    ] - session=null
                                    06:26:19.775 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - servlet |/rest|/sitemaps/_default/_default -> org.ops4j.pax.web.service.spi.model.ServletModel-2@378be0fa==com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge,-1,true
                                    06:26:19.775 [DEBUG] [ce.jetty.internal.HttpServiceContext] - Handling request for [/rest/sitemaps/_default/_default] using http context [DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]]
                                    06:26:19.776 [DEBUG] [y.internal.HttpServiceServletHandler] - handling request org.ops4j.pax.web.service.jetty.internal.HttpServiceRequestWrapper@edd379, org.ops4j.pax.web.service.jetty.internal.HttpServiceResponseWrapper@662e02
                                    06:26:19.777 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - chain=null
                                    repeated every few seconds... anything can be understood from that?
                                    • T
                                      TimO
                                      Ok, here is the corrected jar file: LINK
                                      The things now should update.
                                      I've tested it with the current snapshot on two systems / mysensors environments. I've not tested it against the curren testing (beta4). It should work, but it may throw exceptions on startup.
                                      At the moment please only update if you expierence problems. I would like to ensure the binding is now working.
                                      ben999B 1 Reply Last reply
                                      • FutureCowF
                                        FutureCowF
                                        FutureCow
                                        Thanks, the new version is working nice. only your link didn't work for me, i used this one:
                                        https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar?raw=true
                                        • T TimO
                                          ben999B
                                          ben999B
                                          ben999
                                          @TimO
                                          Thank you for that new jar file.
                                          Gateway is "online" in PaperUI
                                          Sensors are "Uninitialised"
                                          PaperUI says Status: UNINITIALIZED - HANDLER_INITIALIZING_ERROR org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                          I have added these sensors manually to thing file:
                                          Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200, skipStartupCheck=true ] {
                                                  humidity        bathHum01               [ nodeId="1", childId="0" ]
                                                  temperature     bathTemp01              [ nodeId="1", childId="1" ]    }
                                          Here is log file from OH2
                                          22:06:55.465 [DEBUG] [io.socket.engineio.client.Socket    ] - writing ping packet - expecting pong within 60000ms
                                          22:06:55.466 [DEBUG] [io.socket.engineio.client.Socket    ] - flushing 1 packets in socket
                                          22:06:55.509 [DEBUG] [io.socket.engineio.client.Socket    ] - socket received: type 'pong', data 'null'
                                          22:07:04.487 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          22:07:07.682 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@310200{/192.168.1.9:60520<->8080,Open,in,out,-,-,30000/30000,HttpConnection}{io=0,kio=0,kro=1} idle timeout check, elapsed: 30000 ms, remaining: 0 ms
                                          22:07:07.683 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@310200{/192.168.1.9:60520<->8080,Open,in,out,-,-,30002/30000,HttpConnection}{io=0,kio=0,kro=1} idle timeout expired
                                          22:07:07.684 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - ignored: WriteFlusher@82249d{IDLE} java.util.concurrent.TimeoutException: Idle timeout expired: 30000/30000 ms
                                          22:07:07.685 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SelectChannelEndPoint@310200{/192.168.1.9:60520<->8080,Open,in,out,-,-,30003/30000,HttpConnection}{io=0,kio=0,kro=1}
                                          22:07:09.977 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,29439/30000,SslConnection}{io=0,kio=0,kro=1} idle timeout check, elapsed: 29439 ms, remaining: 561 ms
                                          22:07:10.540 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,30001/30000,SslConnection}{io=0,kio=0,kro=1} idle timeout check, elapsed: 30001 ms, remaining: -1 ms
                                          22:07:10.541 [DEBUG] [org.eclipse.jetty.io.IdleTimeout    ] - SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,30002/30000,SslConnection}{io=0,kio=0,kro=1} idle timeout expired
                                          22:07:10.541 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - ignored: WriteFlusher@f4107c{IDLE} java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
                                          22:07:10.542 [DEBUG] [rg.eclipse.jetty.io.AbstractEndPoint] - Ignored idle endpoint SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,30004/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:10.884 [DEBUG] [e.internal.WriterInterceptorExecutor] - Message body writer (class com.eclipsesource.jaxrs.provider.gson.GsonProvider) is trying to close the entity output stream. Not closing.
                                          22:07:10.886 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@ad3ff7[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,1051,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@b60904] generate: NEED_HEADER (null,[p=0,l=1051,c=8192,r=1051],true)@START
                                          22:07:10.887 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@ad3ff7[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,1051,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@b60904] generate: FLUSH ([p=0,l=106,c=8192,r=106],[p=0,l=1051,c=8192,r=1051],true)@COMPLETING
                                          22:07:10.889 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - write: WriteFlusher@18a5ae6{IDLE} [HeapByteBuffer@107873[p=0,l=106,c=8192,r=106]={<<<HTTP/1.1 200 OK\r\n....v20151106)\r\n\r\n>>> chunked\r\nServer:...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},HeapByteBuffer@6612b4[p=0,l=1051,c=8192,r=1051]={<<<{"id":"0000","tit..."widgets":[]}]}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}]
                                          22:07:10.892 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - update WriteFlusher@18a5ae6{WRITING}:IDLE-->WRITING
                                          22:07:10.895 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,W,30371/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,353/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,0 of -1},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@d19aaf{r=38,c=true,a=DISPATCHED,uri=/rest/sitemaps/_default/0000}] flush enter [java.nio.HeapByteBuffer[pos=0 lim=106 cap=8192], java.nio.HeapByteBuffer[pos=0 lim=1051 cap=8192]]
                                          22:07:10.901 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/1186,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,W,30377/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,358/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,0 of -1},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@d19aaf{r=38,c=true,a=DISPATCHED,uri=/rest/sitemaps/_default/0000}] wrap Status = OK HandshakeStatus = NOT_HANDSHAKING
                                          bytesConsumed = 1157 bytesProduced = 1186
                                          22:07:10.903 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,W,30379/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,361/30000,SslConnection}{io=0,kio=0,kro=1} OK HeapByteBuffer@eb6978[p=0,l=1186,c=17408,r=1186]={<<<\x17\x03\x03\x04\x9d\x00\x00\x00\x00\x00\x00\x00&\xFe3\xE3|...\xFe$\xE1\xF9J\xE06\xE9\xE96_=\x9a\xAa\x0c>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
                                          22:07:10.906 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 1186 SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,363/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:10.908 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/0,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,W,30384/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,1/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,0 of -1},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@d19aaf{r=38,c=true,a=DISPATCHED,uri=/rest/sitemaps/_default/0000}] flush exit, consumed 1157
                                          22:07:10.910 [DEBUG] [org.eclipse.jetty.io.WriteFlusher   ] - update WriteFlusher@18a5ae6{IDLE}:WRITING-->IDLE
                                          22:07:10.912 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@ad3ff7[PROCESSING][i=ResponseInfo{HTTP/1.1 200 OK,1051,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@b60904] generate: DONE ([p=106,l=106,c=8192,r=0],[p=1051,l=1051,c=8192,r=0],true)@END
                                          22:07:10.915 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ o.e.j.s.h.ContextHandler@1f3fece{/static,null,AVAILABLE}
                                          22:07:10.916 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.201611041332 [100], contextID=default]}
                                          22:07:10.917 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.201611041332 [137], contextID=default]}
                                          22:07:10.918 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.201611041332 [138], contextID=default]}
                                          22:07:10.919 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@14870c1}
                                          22:07:10.919 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.201611041332 [186], contextID=default]}
                                          22:07:10.920 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.classic_0.9.0.201611041332 [187], contextID=default]}
                                          22:07:10.921 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.201611041332 [188], contextID=default]}
                                          22:07:10.921 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.io.rest.docs_2.0.0.201611062131 [189], contextID=default]}
                                          22:07:10.922 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.0.0.201611062131 [192], contextID=default]}
                                          22:07:10.923 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.0.0.201611062131 [168], contextID=default]}
                                          22:07:10.924 [DEBUG] [org.eclipse.jetty.server.Server     ] - RESPONSE /rest/sitemaps/_default/0000  200 handled=true
                                          22:07:10.925 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@6e53d6{s=DISPATCHED i=true a=null} unhandle DISPATCHED
                                          22:07:10.926 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - reset HttpParser{s=END,0 of -1}
                                          22:07:10.926 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - END --> START
                                          22:07:10.927 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=} handle exit, result COMPLETE
                                          22:07:10.929 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30405/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,22/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] fill enter
                                          22:07:10.931 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,23/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:10.933 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30409/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,25/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] filled 0 encrypted bytes
                                          22:07:10.935 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30411/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,27/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] unwrap Status = BUFFER_UNDERFLOW HandshakeStatus = NOT_HANDSHAKING
                                          22:07:10.937 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30413/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,29/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] fill exit
                                          22:07:10.939 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30415/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,32/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] fill enter
                                          22:07:10.941 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 0 SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,33/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:10.942 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30419/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,35/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] filled 0 encrypted bytes
                                          22:07:10.945 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30421/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,37/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] unwrap Status = BUFFER_UNDERFLOW HandshakeStatus = NOT_HANDSHAKING
                                          22:07:10.947 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30423/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,39/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] fill exit
                                          22:07:10.948 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@1ac887b[p=0,l=0,c=17408,r=0]={<<<>>>GET /rest/sitemap...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
                                          22:07:10.949 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30426/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,42/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:10.951 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING-->FILLING_FILL_INTERESTED HttpConnection@12c6b19[FILLING_FILL_INTERESTED,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30427/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,44/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:10.953 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING_FILL_INTERESTED-->FILL_INTERESTED HttpConnection@12c6b19[FILL_INTERESTED,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,30429/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,46/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:10.955 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - fillInterested SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILL_INTERESTED,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,R,-,0/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,48/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:10.958 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - IDLE-->FILL_INTERESTED SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILL_INTERESTED,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,R,-,3/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,50/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:10.959 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 0 -> 1 for SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,R,-,0/30000,SslConnection}{io=1,kio=0,kro=1}
                                          22:07:10.960 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@1d2164a
                                          22:07:10.961 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 0/1 selected
                                          22:07:10.961 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@1d2164a
                                          22:07:10.962 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 0 -> 1 on SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,R,-,3/30000,SslConnection}{io=1,kio=1,kro=1}
                                          22:07:10.962 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
                                          22:07:11.035 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop woken up from select, 1/1 selected
                                          22:07:11.036 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Key interests updated 1 -> 0 on SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,R,-,78/30000,SslConnection}{io=1,kio=0,kro=1}
                                          22:07:11.036 [DEBUG] [lipse.jetty.io.SelectChannelEndPoint] - Local interests updating 1 -> 0 for SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,R,-,78/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:11.037 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Queued change org.eclipse.jetty.io.SelectChannelEndPoint$1@1d2164a
                                          22:07:11.038 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILL_INTERESTED-->FILLING SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILL_INTERESTED,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,R,-,83/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,79/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:11.038 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - onFillable enter DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,R,-,84/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,80/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:11.039 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILL_INTERESTED-->FILLING HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,85/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,81/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:11.040 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - onFillable exit DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,86/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,82/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:11.041 [DEBUG] [.eclipse.jetty.server.HttpConnection] - HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,86/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,82/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] onFillable HttpChannelState@6e53d6{s=IDLE i=true a=null}
                                          22:07:11.041 [DEBUG] [.eclipse.jetty.io.AbstractConnection] - FILLING-->IDLE SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,87/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,83/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}]
                                          22:07:11.042 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,87/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,83/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] fill enter
                                          22:07:11.042 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Running change org.eclipse.jetty.io.SelectChannelEndPoint$1@1d2164a
                                          22:07:11.042 [DEBUG] [org.eclipse.jetty.io.SelectorManager] - Selector loop waiting on select
                                          22:07:11.042 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - filled 473 SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,84/30000,SslConnection}{io=0,kio=0,kro=1}
                                          22:07:11.043 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=473/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,89/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,1/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] filled 473 encrypted bytes
                                          22:07:11.045 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=0/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,91/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,3/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] unwrap Status = OK HandshakeStatus = NOT_HANDSHAKING
                                          bytesConsumed = 473 bytesProduced = 444
                                          22:07:11.046 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@140f96f{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@12c6b19[FILLING,DecryptedEndPoint@47d536{/192.168.1.24:55097<->8443,Open,in,out,-,-,92/30000,HttpConnection}->SelectChannelEndPoint@c36456{/192.168.1.24:55097<->8443,Open,in,out,-,-,4/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=START,0 of -1},g=HttpGenerator{s=START},c=HttpChannelOverHttp@d19aaf{r=38,c=false,a=IDLE,uri=}] fill exit
                                          22:07:11.047 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - parseNext s=START HeapByteBuffer@c998ba[p=0,l=444,c=17408,r=444]={<<<GET /rest/sitemap...rwin/16.1.0\r\n\r\n>>>.0 CFNetwork/808....\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
                                          22:07:11.047 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - START --> SPACE1
                                          22:07:11.047 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE1 --> URI
                                          22:07:11.048 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - URI --> SPACE2
                                          22:07:11.048 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - SPACE2 --> REQUEST_VERSION
                                          22:07:11.048 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - REQUEST_VERSION --> HEADER
                                          22:07:11.048 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                          22:07:11.049 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                          22:07:11.049 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_NAME
                                          22:07:11.049 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_NAME --> HEADER_VALUE
                                          22:07:11.049 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
                                          22:07:11.050 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                          22:07:11.050 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                          22:07:11.051 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                          22:07:11.051 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                          22:07:11.052 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_NAME
                                          22:07:11.052 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_NAME --> HEADER_VALUE
                                          22:07:11.052 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_VALUE --> HEADER_IN_VALUE
                                          22:07:11.052 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                          22:07:11.052 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                          22:07:11.053 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER_IN_VALUE --> HEADER
                                          22:07:11.053 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> HEADER_IN_VALUE
                                          22:07:11.053 [DEBUG] [org.eclipse.jetty.http.HttpParser   ] - HEADER --> END
                                          22:07:11.054 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@d19aaf{r=39,c=false,a=IDLE,uri=/rest/sitemaps/_default/0000} messageComplete
                                          22:07:11.054 [DEBUG] [org.eclipse.jetty.server.HttpInput  ] - HttpInputOverHTTP@15ca2 EOF
                                          22:07:11.055 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@d19aaf{r=39,c=false,a=IDLE,uri=/rest/sitemaps/_default/0000} handle enter
                                          22:07:11.055 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@6e53d6{s=IDLE i=true a=null} handling IDLE
                                          22:07:11.056 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - HttpChannelOverHttp@d19aaf{r=39,c=false,a=DISPATCHED,uri=/rest/sitemaps/_default/0000} action REQUEST_DISPATCH
                                          22:07:11.056 [DEBUG] [org.eclipse.jetty.server.Server     ] - REQUEST GET /rest/sitemaps/_default/0000 on HttpChannelOverHttp@d19aaf{r=39,c=false,a=DISPATCHED,uri=/rest/sitemaps/_default/0000}
                                          22:07:11.057 [DEBUG] [ax.web.service.spi.model.ServerModel] - Matching [/rest/sitemaps/_default/0000]...
                                          22:07:11.057 [DEBUG] [ax.web.service.spi.model.ServerModel] - Path [/rest/sitemaps/_default/0000] matched to {pattern=/rest/.*,model=ServletModel{id=org.ops4j.pax.web.service.spi.model.ServletModel-2,name=org.ops4j.pax.web.service.spi.model.ServletModel-2,urlPatterns=[/rest/*],alias=/rest,servlet=com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge@1efe36d,initParams={},context=ContextModel{id=org.ops4j.pax.web.service.spi.model.ContextModel-1,name=,httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default],contextParams={},virtualHosts={},connectors={}}}}
                                          22:07:11.057 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
                                          22:07:11.058 [DEBUG] [.jetty.server.handler.ContextHandler] - context=||/rest/sitemaps/_default/0000 @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]}
                                          22:07:11.058 [DEBUG] [org.eclipse.jetty.server.session    ] - sessionManager=org.ops4j.pax.web.service.jetty.internal.LateInvalidatingHashSessionManager@1a5ce14
                                          22:07:11.059 [DEBUG] [org.eclipse.jetty.server.session    ] - session=null
                                          22:07:11.059 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - servlet |/rest|/sitemaps/_default/0000 -> org.ops4j.pax.web.service.spi.model.ServletModel-2@378be0fa==com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge,-1,true
                                          22:07:11.059 [DEBUG] [ce.jetty.internal.HttpServiceContext] - Handling request for [/rest/sitemaps/_default/0000] using http context [DefaultHttpContext [bundle=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [12], contextID=default]]
                                          22:07:11.060 [DEBUG] [y.internal.HttpServiceServletHandler] - handling request org.ops4j.pax.web.service.jetty.internal.HttpServiceRequestWrapper@5ce2b2, org.ops4j.pax.web.service.jetty.internal.HttpServiceResponseWrapper@97896c
                                          22:07:11.060 [DEBUG] [eclipse.jetty.servlet.ServletHandler] - chain=null
                                          22:07:11.073 [DEBUG] [e.internal.WriterInterceptorExecutor] - Message body writer (class com.eclipsesource.jaxrs.provider.gson.GsonProvider) is trying to close the entity output stream. Not closing.
