  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P
    pentti12P
    pentti12
    Detection of Things worked from MySensors network (only one gateway and one node, which has temperature and humidity sensor). But I can't get real temperature nor humidity values to be shown on Paper UI control screen. I don't have glue what to do next.
    I don't understand why the Arduino MQTT Gateway is not supported by the OH2 Mysensors binding, so shall I go still to mqtt gateway direction?
    jogantJ 1 Reply Last reply
    • pentti12P pentti12
      jogantJ
      jogantJ
      jogant
      @pentti12
      depends on what you want. At the moment there is no separate OH2 MQTT binding. You can use OH1 MQTT binding through compatibility layer but you will lose some features of OH2 like autodetection.
      To see values from a sensor in UI you have to define an item and link it to the thing whereas a thing can have lot of different sensors (two in your example) and you have to define an item for each sensor. You also can use autogeneration of items for new detected things. This is also a feature of OH2.
      If you use MQTT there is no autodetection. You have to define things through things configuration file(s) and also have to link items to thing-values. But you have to do it by hand.
      MQTT is the better choice if you plan to share your mysensors values with other controllers like node-red or similar. If you only use openhab then I would prefer using mysensors binding. That's what I did.
      • pentti12P
        pentti12P
        pentti12
        OK I stay with MySensors Binding and use MySensors Ethernet Gateway Things. And on Arduino side I use GatewayW5100 sketch.
        Still problem with getting real values of temperature or humidity. For example the Humidity Sensor is ONLINE and it has linked into Humidity channels, but when I switch to control screen of Paper UI, there is no humidity values reported (show -NaN). What is missing from OH2?
          jogantJ
          jogantJ
          jogant
          wrote on last edited by jogant
          @pentti12
          did you debug your sensor? Does it transmit correct values for both temperature and humidity?
          I recognized that sometimes the initialization of the OH binding is not complete. So what I did was first restart mysensors binding via OH console (bundle:restart <mysensors binding number>), made a reset of the gateway and a reset of the sensor node. Then sensor node remains online with valid values.
          Or try to increase OH debugging and see what happens in OH logs. log:set DEBUG org.openhab.binding.mysensors and log:tail
          There you should see mysensor messages coming in. What do you see there?
          • pentti12P
            pentti12P
            pentti12
            OK, I will try to debug. It will take some time to done. I'll be back later on.
              TimO
              @pentti12 This is a bug in the binding. Please restart OH2 (or just the binding as @jogant suggested) after discovery of a new device till I was able to fix the issue . After the restart it should work.
              • pentti12P
                pentti12P
                pentti12
                Hi
                I switched from win7 laptop to pine64 in order to continue searching problem.
                What I did:
                I started Karaf Console and restarted mysensors binding --> no help
                I restarted Arduino UNO Ethernet Gateway --> no help
                I restarted Arduino UNO Node 9 (which has temperature and humidity sensor) --> no help
                Here is the listing of the DEBUG:
                10:15:32.075 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:humidity:a9d5757b': java.lang.NullPointerException
                java.util.concurrent.ExecutionException: java.lang.NullPointerException
                at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
                at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
                at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)
                at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)
                at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)
                at org.eclipse.smarthome.core.thing.internal.ThingManager.disposeHandler(ThingManager.java:857)
                at org.eclipse.smarthome.core.thing.internal.ThingManager.handlerRemoved(ThingManager.java:311)
                at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:138)
                at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:1)
                at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:967)[org.osgi.core-6.0.0.jar:]
                at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
                at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)[org.osgi.core-6.0.0.jar:]
                at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:909)[org.osgi.core-6.0.0.jar:]
                at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.unregisterHandler(BaseThingHandlerFactory.java:125)
                at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.deactivate(BaseThingHandlerFactory.java:79)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_101]
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_101]
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_101]
                at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_101]
                at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:342)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:157)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:783)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:757)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:550)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:725)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:530)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:414)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.Activator.access$300(Activator.java:53)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:273)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:290)[33:org.apache.felix.scr:2.0.2]
                at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
                at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
                at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:312)[33:org.apache.felix.scr:2.0.2]
                at org.apache.felix.utils.extender.AbstractExtender.bundleChanged(AbstractExtender.java:186)[33:org.apache.felix.scr:2.0.2]
                at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.container.Module.doStop(Module.java:624)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.container.Module.stop(Module.java:488)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:420)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:44)[39:org.apache.karaf.bundle.core:4.0.4]
                at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:54)[39:org.apache.karaf.bundle.core:4.0.4]
                at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:83)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:67)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:87)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:480)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:406)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.felix.gogo.runtime.Pipe.run(Pipe.java:108)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:182)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:119)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:94)[54:org.apache.karaf.shell.core:4.0.4]
                at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:270)[54:org.apache.karaf.shell.core:4.0.4]
                at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
                Caused by: java.lang.NullPointerException
                at org.openhab.binding.mysensors.handler.MySensorsHandler.getBridgeHandler(MySensorsHandler.java:207)[201:org.openhab.binding.mysensors:2.0.0.201601251249]
                at org.openhab.binding.mysensors.handler.MySensorsHandler.dispose(MySensorsHandler.java:67)[201:org.openhab.binding.mysensors:2.0.0.201601251249]
                at org.eclipse.smarthome.core.thing.internal.ThingManager$12.call(ThingManager.java:860)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                at org.eclipse.smarthome.core.thing.internal.ThingManager$12.call(ThingManager.java:1)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
                ... 1 more
                10:15:32.165 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
                10:15:32.167 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:temperature:9d001ab8': java.lang.NullPointerException
                ... 1 more
                10:15:32.485 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                10:15:32.488 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from INITIALIZING to ONLINE
                10:15:32.494 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:a8641691' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                10:15:32.513 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:a8641691' changed from INITIALIZING to ONLINE
                10:15:32.542 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a9d5757b' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                10:15:32.548 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a9d5757b' changed from INITIALIZING to ONLINE
                So lot of stuff, which are unclear to me.
                  Hi
                  What I did:
                  ... 1 more
                  ... 1 more
                  jogantJ
                  jogantJ
                  jogant
                  @pentti12
                  At least the last 6 lines suggest that the initialization was successful. Seems that before mysensors has not been initialized completely and therefore dispose failed. Dispose is invoked through binding restart I think. So you can ignore theses failures.
                  Are you now able to link items? Do you see incoming mysensors messages in the cycle you defined in the node?
                  • pentti12P
                    pentti12P
                    pentti12
                    If I look at the configuration from HABmin side, I see for example this:
                    Channels [1 active, 2 total]
                    Temperature
                    Linked Items
                    Temperature
                    So there is some linked items!
                      Temperature
                      Linked Items
                      Temperature
                      jogantJ
                      jogantJ
                      jogant
                      @pentti12
                      ok, but you have to see mysensor messages in the log file on a regularly basis. At least the default sketch for temperature and humidity sends updates every minute. Maybe your temperature is very constant then you will see updates every hour I think. Try to heat the node and let it cool down again.
                      And connect your node or the gateway to the serial monitor. There you will see the mysensors activity. You should see OK for status updates and not to much NACK. Then you have a problem with your mysensors network.
                      good luck ...
                      • pentti12P
                        pentti12P
                        pentti12
                        Here is the serial monitor printout from MySensors W5100 Gateway. I think that this listing is OK, but still there is no actual temperature nor humidity values at control screen of OH2 .
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:RADIO:OK
                        0;255;3;0;9;TSM:GW MODE
                        0;255;3;0;9;TSM:READY
                        IP: 192.168.1.201
                        0;255;3;0;9;TSP:SANCHK:OK
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.6
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:37.9
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.7
                        0;255;3;0;9;TSP:MSG:READ 9-9-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:BC
                        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=9)
                        0;255;3;0;9;TSP:CHKUPL:OK
                        0;255;3;0;9;TSP:MSG:GWL OK
                        0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                        0;255;3;0;9;TSP:MSG:PINGED (ID=9, hops=1)
                        0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                        0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:38.0
                        The problem must be on OpenHAB2 side. What to do next?
                          IP: 192.168.1.201
                          jogantJ
                          jogantJ
                          jogant
                          @pentti12
                          you are right, your serial log looks ok. So at least your mysensors network is up and running. In the moment the gateway receives an update from a sensor you should also see an incoming message in OH log. If this is not the case there might be something wrong with your binding config. You know https://github.com/tobof/openhab2-addons/wiki? There are valuable hints. Only difference to my setup is that I'm using mysensors 2.0.1 beta. No idea whether this makes any difference. Besides that I have no further idea. Sorry.
                          • pentti12P
                            pentti12P
                            pentti12
                            I see from OH2 event log:
                            2016-11-22 06:17:43.911 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from UNINITIALIZED to INITIALIZING
                            2016-11-22 06:17:43.937 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from INITIALIZING to ONLINE
                            2016-11-22 06:19:49.491 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
                            2016-11-22 06:20:05.658 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_temp' received command REFRESH
                            2016-11-22 06:21:08.469 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
                            And from OH2 log:
                            2016-11-22 06:11:11.125 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
                            2016-11-22 06:11:11.194 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
                            2016-11-22 06:11:11.251 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Error while trying to connect InputStreamReader
                            2016-11-22 06:11:11.255 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Something went wrong!
                            2016-11-22 06:11:11.322 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                            2016-11-22 06:12:08.388 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update configuration at 'things/mysensors:bridge-eth:gateway/config' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
                            2016-11-22 06:12:32.535 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update at 'things/mysensors:bridge-eth:gateway' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
                            2016-11-22 06:12:51.983 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                            2016-11-22 06:12:51.990 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
                            2016-11-22 06:12:52.016 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
                            2016-11-22 06:12:52.072 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                            2016-11-22 06:14:46.978 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                            2016-11-22 06:14:46.986 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
                            2016-11-22 06:14:47.045 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
                            So there are some problems at least on test.things file:
                            Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.201", tcpPort=5003, sendDelay=200, imperial=false ] {
                            humidity hum01 [ nodeId="9", childId="10" ]
                            temperature temp01 [ nodeId="9", childId="11" ]
                            Any advice?
                              And from OH2 log:
                              Any advice?
                              jogantJ
                              jogantJ
                              jogant
                              @pentti12
                              ahh, try to leave out thing definition in config file and let OH discover things. After discovery remember to restart mysensors binding like @TimO explained. Then link discovered things to items and see if that works.
                              Are you shure about your sonsor IDs? Usually they are numbered starting with 0.
                              • pentti12P
                                pentti12P
                                pentti12
                                No success!
                                I ended up to the same situation, no real values of temperature nor humidity.
                                OH2 cannot search things automatically. I added them manually after I configured the MySensors Gateway.
                                jogantJ T 2 Replies Last reply
                                  No success!
                                  jogantJ
                                  jogantJ
                                  jogant
                                  @pentti12
                                  here you see a snippet from my log while in DEBUG mode for mysensors binding:
                                  10:57:19.269 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:57:29.271 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:57:39.273 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:57:39.820 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_EG_WZ_R_signal changed from -50 to -51
                                  10:57:42.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;21;0
                                  10:57:42.171 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.169+0100
                                  10:57:42.174 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.172+0100
                                  10:57:49.274 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:57:50.476 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_Ki_Li_signal changed from -61 to -60
                                  10:57:59.276 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:57:59.465 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_SZ_signal changed from -68 to -67
                                  10:58:09.278 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:58:19.280 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:58:29.282 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  10:58:30.810 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;23;80
                                  10:58:30.817 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.815+0100
                                  10:58:30.824 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.822+0100
                                  10:58:30.833 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.831+0100
                                  10:58:30.837 [INFO ] [marthome.event.ItemStateChangedEvent] - Lightlevel changed from 81 to 80
                                  10:58:39.284 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  Here is the mysensors part my default.things
                                  Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.96.9", tcpPort=5003, sendDelay=200 ] {
                                  0_1479809074466_upload-a4b1d17f-3056-4c44-9f95-13fbeccae68b
                                  0_1479809140350_upload-320df1cc-3f4d-4893-8a5e-dc44d0045cba
                                  and the mysensors part of my items:
                                  /* mysensors Licht/Temp/Hum */
                                  Number Lightlevel "Helligkeit [%.0f %%]" <sun> (gLicht)                         { channel="mysensors:light-level:gateway:Light_level_1_0:light-level" }
                                  Number mySensors1Hum "Luftfeuchte [%.1f %%]" <water>                            { channel="mysensors:humidity:gateway:Humidity_1_1:hum" }
                                  Number mySensors1Temp "Temperatur [%.1f °C]" <temperature>                      { channel="mysensors:temperature:gateway:Temperature_1_2:temp" }
                                  Maybe this is of any help as I don't have an idea what's wrong with your config.
                                    No success!
                                    TimO
                                    Hi @pentti12 !
                                    Stop searching, there is a bug in the binding. I'm working on it. ;-)
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      OK, TimO!
                                      I will wait for the new version until I continue!
                                      Pentti
                                      • T TimO
                                        Hi @pentti12 !
                                        jogantJ
                                        jogantJ
                                        jogant
                                        @TimO
                                        funny that it works for me :smiley:
                                        • jogantJ jogant
                                          @TimO
                                          TimO
                                          @jogant Sadly it works fine in my devolpment and test environment, too. ;-)
                                          If you are using a OH2 snapshot that is older than 11 days there is a chance that it still works but it's not predictable.
