  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • T
    TimO
    No, just look for the instructions to use the MQTT gateway with OpenHAB. It works the same way with OH1 and OH2.
    If I recall correctly you need a MQTT broker like mosquitto and connect the gateway and OpenHAB to the broker. I'm using the MQTT binding with OH2 myself to communicate to nodered.
    The communication works this way:
    MQTT gateway --> Mosquitto --> OpenHAB
    (and vice versa)
    With the OH2 binding the communication is this way:
    Ethernet gateway --> OH2 binding --> OH2
    • pentti12P
      pentti12P
      pentti12
      I have mosquitto broker installed into Pine64 and it is up and running. MySensors GatewayW5100MQTT Client has establish the connection with mosquitto broker. But the OH2 log show:
      2016-11-20 10:09:15.875 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.items'
      2016-11-20 10:09:25.235 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
      2016-11-20 10:09:32.486 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
      2016-11-20 10:09:34.022 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
      2016-11-20 10:09:34.634 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
      2016-11-20 10:09:35.139 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
      2016-11-20 10:09:36.492 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
      2016-11-20 10:09:37.044 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
      What to do next?
      • pentti12P
        pentti12P
        pentti12
        I changed my Arduino UNO Sketch to GatewayW5100. Now I get MySensors Ethernet Gateway at OH2 into ONLINE state.
        Next question: how I configure MQTT gateway - Mosquitto - OpenHAB communication branch?
        jogantJ 1 Reply Last reply
        • pentti12P pentti12
          jogantJ
          jogantJ
          jogant
          @pentti12
          I think we should clarify what should be setup. If you want to use mqtt gateway the have a look at https://forum.mysensors.org/topic/3605/can-t-get-openhab2-to-see-my-mqtt-messages
          Besides that I have the same setup like you. Openhab2 be, mysensors ethernet gateway. Works very reliable for four weeks now without any drops. I prefer this as we have a real oh2 binding with autodetection of things etc.
          Best regards
          jogant
          • pentti12P
            pentti12P
            pentti12
            Detection of Things worked from MySensors network (only one gateway and one node, which has temperature and humidity sensor). But I can't get real temperature nor humidity values to be shown on Paper UI control screen. I don't have glue what to do next.
            I don't understand why the Arduino MQTT Gateway is not supported by the OH2 Mysensors binding, so shall I go still to mqtt gateway direction?
              jogantJ
              jogantJ
              jogant
              @pentti12
              depends on what you want. At the moment there is no separate OH2 MQTT binding. You can use OH1 MQTT binding through compatibility layer but you will lose some features of OH2 like autodetection.
              To see values from a sensor in UI you have to define an item and link it to the thing whereas a thing can have lot of different sensors (two in your example) and you have to define an item for each sensor. You also can use autogeneration of items for new detected things. This is also a feature of OH2.
              If you use MQTT there is no autodetection. You have to define things through things configuration file(s) and also have to link items to thing-values. But you have to do it by hand.
              MQTT is the better choice if you plan to share your mysensors values with other controllers like node-red or similar. If you only use openhab then I would prefer using mysensors binding. That's what I did.
              • pentti12P
                pentti12P
                pentti12
                OK I stay with MySensors Binding and use MySensors Ethernet Gateway Things. And on Arduino side I use GatewayW5100 sketch.
                Still problem with getting real values of temperature or humidity. For example the Humidity Sensor is ONLINE and it has linked into Humidity channels, but when I switch to control screen of Paper UI, there is no humidity values reported (show -NaN). What is missing from OH2?
                  jogantJ
                  jogantJ
                  jogant
                  wrote on last edited by jogant
                  @pentti12
                  did you debug your sensor? Does it transmit correct values for both temperature and humidity?
                  I recognized that sometimes the initialization of the OH binding is not complete. So what I did was first restart mysensors binding via OH console (bundle:restart <mysensors binding number>), made a reset of the gateway and a reset of the sensor node. Then sensor node remains online with valid values.
                  Or try to increase OH debugging and see what happens in OH logs. log:set DEBUG org.openhab.binding.mysensors and log:tail
                  There you should see mysensor messages coming in. What do you see there?
                  • pentti12P
                    pentti12P
                    pentti12
                    OK, I will try to debug. It will take some time to done. I'll be back later on.
                      TimO
                      @pentti12 This is a bug in the binding. Please restart OH2 (or just the binding as @jogant suggested) after discovery of a new device till I was able to fix the issue . After the restart it should work.
                      • pentti12P
                        pentti12P
                        pentti12
                        Hi
                        I switched from win7 laptop to pine64 in order to continue searching problem.
                        What I did:
                        I started Karaf Console and restarted mysensors binding --> no help
                        I restarted Arduino UNO Ethernet Gateway --> no help
                        I restarted Arduino UNO Node 9 (which has temperature and humidity sensor) --> no help
                        Here is the listing of the DEBUG:
                        10:15:32.075 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:humidity:a9d5757b': java.lang.NullPointerException
                        java.util.concurrent.ExecutionException: java.lang.NullPointerException
                        at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
                        at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
                        at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)
                        at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)
                        at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)
                        at org.eclipse.smarthome.core.thing.internal.ThingManager.disposeHandler(ThingManager.java:857)
                        at org.eclipse.smarthome.core.thing.internal.ThingManager.handlerRemoved(ThingManager.java:311)
                        at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:138)
                        at org.eclipse.smarthome.core.thing.internal.ThingManager$ThingHandlerTracker.removedService(ThingManager.java:1)
                        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:967)[org.osgi.core-6.0.0.jar:]
                        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
                        at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)[org.osgi.core-6.0.0.jar:]
                        at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:909)[org.osgi.core-6.0.0.jar:]
                        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.unregisterHandler(BaseThingHandlerFactory.java:125)
                        at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.deactivate(BaseThingHandlerFactory.java:79)
                        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_101]
                        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_101]
                        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_101]
                        at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_101]
                        at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:342)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:157)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:783)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:757)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:550)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:725)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:530)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:414)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.Activator.access$300(Activator.java:53)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:273)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:290)[33:org.apache.felix.scr:2.0.2]
                        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
                        at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
                        at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:312)[33:org.apache.felix.scr:2.0.2]
                        at org.apache.felix.utils.extender.AbstractExtender.bundleChanged(AbstractExtender.java:186)[33:org.apache.felix.scr:2.0.2]
                        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.container.Module.doStop(Module.java:624)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.container.Module.stop(Module.java:488)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:420)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
                        at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:44)[39:org.apache.karaf.bundle.core:4.0.4]
                        at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:54)[39:org.apache.karaf.bundle.core:4.0.4]
                        at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:83)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:67)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:87)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:480)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:406)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.felix.gogo.runtime.Pipe.run(Pipe.java:108)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:182)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:119)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:94)[54:org.apache.karaf.shell.core:4.0.4]
                        at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:270)[54:org.apache.karaf.shell.core:4.0.4]
                        at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
                        Caused by: java.lang.NullPointerException
                        at org.openhab.binding.mysensors.handler.MySensorsHandler.getBridgeHandler(MySensorsHandler.java:207)[201:org.openhab.binding.mysensors:2.0.0.201601251249]
                        at org.openhab.binding.mysensors.handler.MySensorsHandler.dispose(MySensorsHandler.java:67)[201:org.openhab.binding.mysensors:2.0.0.201601251249]
                        at org.eclipse.smarthome.core.thing.internal.ThingManager$12.call(ThingManager.java:860)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                        at org.eclipse.smarthome.core.thing.internal.ThingManager$12.call(ThingManager.java:1)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                        at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
                        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
                        ... 1 more
                        10:15:32.165 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
                        10:15:32.167 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while disposing handler of thing 'mysensors:temperature:9d001ab8': java.lang.NullPointerException
                        ... 1 more
                        10:15:32.485 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                        10:15:32.488 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:9d001ab8' changed from INITIALIZING to ONLINE
                        10:15:32.494 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:a8641691' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                        10:15:32.513 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:a8641691' changed from INITIALIZING to ONLINE
                        10:15:32.542 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a9d5757b' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                        10:15:32.548 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a9d5757b' changed from INITIALIZING to ONLINE
                        So lot of stuff, which are unclear to me.
                          Hi
                          What I did:
                          ... 1 more
                          ... 1 more
                          jogantJ
                          jogantJ
                          jogant
                          @pentti12
                          At least the last 6 lines suggest that the initialization was successful. Seems that before mysensors has not been initialized completely and therefore dispose failed. Dispose is invoked through binding restart I think. So you can ignore theses failures.
                          Are you now able to link items? Do you see incoming mysensors messages in the cycle you defined in the node?
                          • pentti12P
                            pentti12P
                            pentti12
                            If I look at the configuration from HABmin side, I see for example this:
                            Channels [1 active, 2 total]
                            Temperature
                            Linked Items
                            Temperature
                            So there is some linked items!
                              Temperature
                              Linked Items
                              Temperature
                              jogantJ
                              jogantJ
                              jogant
                              @pentti12
                              ok, but you have to see mysensor messages in the log file on a regularly basis. At least the default sketch for temperature and humidity sends updates every minute. Maybe your temperature is very constant then you will see updates every hour I think. Try to heat the node and let it cool down again.
                              And connect your node or the gateway to the serial monitor. There you will see the mysensors activity. You should see OK for status updates and not to much NACK. Then you have a problem with your mysensors network.
                              good luck ...
                              • pentti12P
                                pentti12P
                                pentti12
                                Here is the serial monitor printout from MySensors W5100 Gateway. I think that this listing is OK, but still there is no actual temperature nor humidity values at control screen of OH2 .
                                0;255;3;0;9;TSM:INIT
                                0;255;3;0;9;TSM:RADIO:OK
                                0;255;3;0;9;TSM:GW MODE
                                0;255;3;0;9;TSM:READY
                                IP: 192.168.1.201
                                0;255;3;0;9;TSP:SANCHK:OK
                                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.6
                                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:37.9
                                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=11,c=1,t=0,pt=7,l=5,sg=0:22.7
                                0;255;3;0;9;TSP:MSG:READ 9-9-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                0;255;3;0;9;TSP:MSG:BC
                                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=9)
                                0;255;3;0;9;TSP:CHKUPL:OK
                                0;255;3;0;9;TSP:MSG:GWL OK
                                0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                0;255;3;0;9;TSP:MSG:PINGED (ID=9, hops=1)
                                0;255;3;0;9;TSP:MSG:SEND 0-0-9-9 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                0;255;3;0;9;TSP:MSG:READ 9-9-0 s=10,c=1,t=1,pt=7,l=5,sg=0:38.0
                                The problem must be on OpenHAB2 side. What to do next?
                                  IP: 192.168.1.201
                                  jogantJ
                                  jogantJ
                                  jogant
                                  @pentti12
                                  you are right, your serial log looks ok. So at least your mysensors network is up and running. In the moment the gateway receives an update from a sensor you should also see an incoming message in OH log. If this is not the case there might be something wrong with your binding config. You know https://github.com/tobof/openhab2-addons/wiki? There are valuable hints. Only difference to my setup is that I'm using mysensors 2.0.1 beta. No idea whether this makes any difference. Besides that I have no further idea. Sorry.
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    I see from OH2 event log:
                                    2016-11-22 06:17:43.911 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from UNINITIALIZED to INITIALIZING
                                    2016-11-22 06:17:43.937 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from INITIALIZING to ONLINE
                                    2016-11-22 06:19:49.491 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
                                    2016-11-22 06:20:05.658 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_temp' received command REFRESH
                                    2016-11-22 06:21:08.469 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
                                    And from OH2 log:
                                    2016-11-22 06:11:11.125 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
                                    2016-11-22 06:11:11.194 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
                                    2016-11-22 06:11:11.251 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Error while trying to connect InputStreamReader
                                    2016-11-22 06:11:11.255 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Something went wrong!
                                    2016-11-22 06:11:11.322 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                                    2016-11-22 06:12:08.388 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update configuration at 'things/mysensors:bridge-eth:gateway/config' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
                                    2016-11-22 06:12:32.535 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update at 'things/mysensors:bridge-eth:gateway' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
                                    2016-11-22 06:12:51.983 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                                    2016-11-22 06:12:51.990 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
                                    2016-11-22 06:12:52.016 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
                                    2016-11-22 06:12:52.072 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                                    2016-11-22 06:14:46.978 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
                                    2016-11-22 06:14:46.986 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
                                    2016-11-22 06:14:47.045 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
                                    So there are some problems at least on test.things file:
                                    Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.201", tcpPort=5003, sendDelay=200, imperial=false ] {
                                    humidity hum01 [ nodeId="9", childId="10" ]
                                    temperature temp01 [ nodeId="9", childId="11" ]
                                    Any advice?
                                      And from OH2 log:
                                      Any advice?
                                      jogantJ
                                      jogantJ
                                      jogant
                                      @pentti12
                                      ahh, try to leave out thing definition in config file and let OH discover things. After discovery remember to restart mysensors binding like @TimO explained. Then link discovered things to items and see if that works.
                                      Are you shure about your sonsor IDs? Usually they are numbered starting with 0.
                                      • pentti12P
                                        pentti12P
                                        pentti12
                                        No success!
                                        I ended up to the same situation, no real values of temperature nor humidity.
                                        OH2 cannot search things automatically. I added them manually after I configured the MySensors Gateway.
                                        jogantJ T 2 Replies Last reply
                                          No success!
                                          jogantJ
                                          jogantJ
                                          jogant
                                          @pentti12
                                          here you see a snippet from my log while in DEBUG mode for mysensors binding:
                                          10:57:19.269 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:57:29.271 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:57:39.273 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:57:39.820 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_EG_WZ_R_signal changed from -50 to -51
                                          10:57:42.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;21;0
                                          10:57:42.171 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.169+0100
                                          10:57:42.174 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.172+0100
                                          10:57:49.274 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:57:50.476 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_Ki_Li_signal changed from -61 to -60
                                          10:57:59.276 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:57:59.465 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_SZ_signal changed from -68 to -67
                                          10:58:09.278 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:58:19.280 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:58:29.282 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          10:58:30.810 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;23;80
                                          10:58:30.817 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.815+0100
                                          10:58:30.824 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.822+0100
                                          10:58:30.833 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.831+0100
                                          10:58:30.837 [INFO ] [marthome.event.ItemStateChangedEvent] - Lightlevel changed from 81 to 80
                                          10:58:39.284 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                          Here is the mysensors part my default.things
                                          Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.96.9", tcpPort=5003, sendDelay=200 ] {
                                          0_1479809074466_upload-a4b1d17f-3056-4c44-9f95-13fbeccae68b
                                          0_1479809140350_upload-320df1cc-3f4d-4893-8a5e-dc44d0045cba
                                          and the mysensors part of my items:
                                          /* mysensors Licht/Temp/Hum */
                                          Number Lightlevel "Helligkeit [%.0f %%]" <sun> (gLicht)                         { channel="mysensors:light-level:gateway:Light_level_1_0:light-level" }
                                          Number mySensors1Hum "Luftfeuchte [%.1f %%]" <water>                            { channel="mysensors:humidity:gateway:Humidity_1_1:hum" }
                                          Number mySensors1Temp "Temperatur [%.1f °C]" <temperature>                      { channel="mysensors:temperature:gateway:Temperature_1_2:temp" }
                                          Maybe this is of any help as I don't have an idea what's wrong with your config.
