  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P pentti12
    I see from OH2 event log:
    2016-11-22 06:17:43.911 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from UNINITIALIZED to INITIALIZING
    2016-11-22 06:17:43.937 [hingStatusInfoChangedEvent] - 'mysensors:bridge-eth:19d1e911' changed from INITIALIZING to ONLINE
    2016-11-22 06:19:49.491 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
    2016-11-22 06:20:05.658 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_temp' received command REFRESH
    2016-11-22 06:21:08.469 [ItemCommandEvent ] - Item 'mysensors_temperature_9d001ab8_battery' received command REFRESH
    And from OH2 log:
    2016-11-22 06:11:11.125 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
    2016-11-22 06:11:11.194 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
    2016-11-22 06:11:11.251 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Error while trying to connect InputStreamReader
    2016-11-22 06:11:11.255 [ERROR] [rs.protocol.ip.MySensorsIpConnection] - Something went wrong!
    2016-11-22 06:11:11.322 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
    2016-11-22 06:12:08.388 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update configuration at 'things/mysensors:bridge-eth:gateway/config' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
    2016-11-22 06:12:32.535 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update at 'things/mysensors:bridge-eth:gateway' for an unmanaged thing 'mysensors:bridge-eth:gateway'.
    2016-11-22 06:12:51.983 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
    2016-11-22 06:12:51.990 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
    2016-11-22 06:12:52.016 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
    2016-11-22 06:12:52.072 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
    2016-11-22 06:14:46.978 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.things'
    2016-11-22 06:14:46.986 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.things' is either empty or cannot be parsed correctly!
    2016-11-22 06:14:47.045 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.things'
    So there are some problems at least on test.things file:
    Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.1.201", tcpPort=5003, sendDelay=200, imperial=false ] {
    humidity hum01 [ nodeId="9", childId="10" ]
    temperature temp01 [ nodeId="9", childId="11" ]
    Any advice?
    jogantJ
    jogantJ
    jogant
    @pentti12
    ahh, try to leave out thing definition in config file and let OH discover things. After discovery remember to restart mysensors binding like @TimO explained. Then link discovered things to items and see if that works.
    Are you shure about your sonsor IDs? Usually they are numbered starting with 0.
    • pentti12P
      pentti12P
      pentti12
      No success!
      I ended up to the same situation, no real values of temperature nor humidity.
      OH2 cannot search things automatically. I added them manually after I configured the MySensors Gateway.
      jogantJ T 2 Replies Last reply
        No success!
        jogantJ
        jogantJ
        jogant
        @pentti12
        here you see a snippet from my log while in DEBUG mode for mysensors binding:
        10:57:19.269 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:57:29.271 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:57:39.273 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:57:39.820 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_EG_WZ_R_signal changed from -50 to -51
        10:57:42.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;21;0
        10:57:42.171 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.169+0100
        10:57:42.174 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2016-11-22T10:57:42.172+0100
        10:57:49.274 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:57:50.476 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_Ki_Li_signal changed from -61 to -60
        10:57:59.276 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:57:59.465 [INFO ] [marthome.event.ItemStateChangedEvent] - RTemp_UG_SZ_signal changed from -68 to -67
        10:58:09.278 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:58:19.280 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:58:29.282 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        10:58:30.810 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;23;80
        10:58:30.817 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.815+0100
        10:58:30.824 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.822+0100
        10:58:30.833 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 1 to 2016-11-22T10:58:30.831+0100
        10:58:30.837 [INFO ] [marthome.event.ItemStateChangedEvent] - Lightlevel changed from 81 to 80
        10:58:39.284 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        Here is the mysensors part my default.things
        Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.96.9", tcpPort=5003, sendDelay=200 ] {
        0_1479809074466_upload-a4b1d17f-3056-4c44-9f95-13fbeccae68b
        0_1479809140350_upload-320df1cc-3f4d-4893-8a5e-dc44d0045cba
        and the mysensors part of my items:
        /* mysensors Licht/Temp/Hum */
        Number Lightlevel "Helligkeit [%.0f %%]" <sun> (gLicht)                         { channel="mysensors:light-level:gateway:Light_level_1_0:light-level" }
        Number mySensors1Hum "Luftfeuchte [%.1f %%]" <water>                            { channel="mysensors:humidity:gateway:Humidity_1_1:hum" }
        Number mySensors1Temp "Temperatur [%.1f °C]" <temperature>                      { channel="mysensors:temperature:gateway:Temperature_1_2:temp" }
        Maybe this is of any help as I don't have an idea what's wrong with your config.
          No success!
          TimO
          Hi @pentti12 !
          Stop searching, there is a bug in the binding. I'm working on it. ;-)
          jogantJ 1 Reply Last reply
          • pentti12P
            pentti12P
            pentti12
            OK, TimO!
            I will wait for the new version until I continue!
            Pentti
            • T TimO
              Hi @pentti12 !
              jogantJ
              jogantJ
              jogant
              @TimO
              funny that it works for me :smiley:
              • jogantJ jogant
                @TimO
                TimO
                @jogant Sadly it works fine in my devolpment and test environment, too. ;-)
                If you are using a OH2 snapshot that is older than 11 days there is a chance that it still works but it's not predictable.
                • T TimO
                  jogantJ
                  jogantJ
                  jogant
                  @TimO
                  ok, I'm using OH2 b4, that is definitely older than 11 days.
                    OK, TimO!
                    Pentti
                    TimO
                    @pentti12 I've pushed a new version of the binding to github, please try it out and let me know if it helps.
                    • pentti12P
                      pentti12P
                      pentti12
                      Now I got only MySensors Ethernet Gateway into ONLINE state. The Humidity and Temperature Sensors (Things) stay UNINITIALIZED state.
                        TimO
                        @pentti12 Have you deleted the things and newly discovered them? When the binding changes the mapdb (where discovered devices are stored) isn't updated as well. That's why I'm using the *.things files instead. If you try to remove the items errors could occure, this is another hint that this is the problem. After restart of OH2 the things should disappear.
                        Another way to do this is:
                        1. stop OH2
                        2. rm /var/lib/openhab2/mapdb/*
                        3. start OH2
                        But this will delete all discovered things (not only MySensors)!
                        • pentti12P
                          pentti12P
                          pentti12
                          I removed mapdb and things disappeared. I started OH2 again, but I got only MySensors Ethernet Gateway into ONLINE state after adding them manually The Humidity and Temperature Sensors (Things) stay UNINITIALIZED state.
                            TimO
                            @pentti12 What does the log say?
                            JicJ 1 Reply Last reply
                            • T TimO
                              JicJ
                              JicJ
                              Jic
                              @TimO I have exactly the same problem.
                              My event.log is:
                              2016-11-22 20:45:24.043 [temChannelLinkRemovedEvent] - Link 'mysensors_door_gateway_door01_armed => mysensors:door:gateway:door01:armed' has been removed.
                              2016-11-22 20:54:35.089 [ItemChannelLinkAddedEvent ] - Link 'door01_tripped-mysensors:door:gateway:door01:tripped' has been added.
                              2016-11-22 20:54:35.097 [ItemChannelLinkAddedEvent ] - Link 'door01_lastupdate-mysensors:door:gateway:door01:lastupdate' has been added.
                              2016-11-22 20:54:35.671 [ThingAddedEvent           ] - Thing 'mysensors:bridge-ser:gateway' has been added.
                              2016-11-22 20:54:35.682 [ThingAddedEvent           ] - Thing 'mysensors:door:gateway:door01' has been added.
                              2016-11-22 20:54:36.702 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                              2016-11-22 20:54:36.713 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
                              2016-11-22 20:54:40.191 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to ONLINE
                              2016-11-22 20:54:40.262 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                              2016-11-22 20:54:40.462 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from INITIALIZING to OFFLINE
                              And my openhab.log is:
                              2016-11-22 20:58:10.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                              2016-11-22 20:58:11.254 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;1
                              2016-11-22 20:58:16.264 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;0;23
                              2016-11-22 20:58:20.297 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                              2016-11-22 20:58:21.279 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;0
                              2016-11-22 20:58:26.295 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;0;23
                              2016-11-22 20:58:30.300 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                              2016-11-22 20:58:31.319 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;1
                              I have downloaded your last binding, and the last version of MySensors. Thanks
                              • pentti12P
                                pentti12P
                                pentti12
                                Event log:
                                2016-11-22 18:57:07.915 [hingStatusInfoChangedEvent] - 'mysensors:humidity:dd0f7b9e' changed from UNINITIALIZED to INITIALIZING
                                2016-11-22 18:57:07.928 [hingStatusInfoChangedEvent] - 'mysensors:humidity:dd0f7b9e' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                And Openhba log:
                                2016-11-22 18:57:07.924 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:humidity:dd0f7b9e': java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
                                at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
                                at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                                at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:761)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                                at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
                                at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
                                at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_101]
                                at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_101]
                                at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
                                at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
                                at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
                                Caused by: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                                at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.getBridgeHandler(MySensorsThingHandler.java:284)
                                at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:74)
                                at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                                at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                                at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                                ... 3 more
                                • pentti12P
                                  pentti12P
                                  pentti12
                                  Update:
                                  I started from the scratch. I installed debian MATE and OH2-offline snapshot. I put the org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar into addons folder. I started openhab2 and after a while I got MySensors Ethernet Gateway and Temperature and Humidity Sensors ONLINE state.
                                  But still I cannot see any temperature nor humidity values from my sensors!
                                  Here is the Karaf Log after I pressed MySensorsGateway Reset button:
                                  08:35:40.194 [ERROR] [otocol.MySensorsNetworkSanityChecker] - Retry period expired, gateway is down. Disconneting bridge...
                                  08:35:40.196 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Request disconnection flag setted to: true
                                  08:35:44.213 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Connection request disconnection...
                                  08:35:44.215 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Request disconnection flag setted to: false
                                  08:35:44.217 [INFO ] [otocol.MySensorsNetworkSanityChecker] - Network Sanity Checker thread stopped
                                  08:35:44.223 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                                  08:35:44.227 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                                  08:35:44.241 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                                  08:35:44.244 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                                  08:35:44.246 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                                  08:35:44.261 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to OFFLINE for device: mysensors:humidity:a825a6a7
                                  08:35:44.263 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.201:5003]
                                  08:35:44.267 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to OFFLINE for device: mysensors:temperature:43712fbc
                                  08:35:44.295 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                                  08:35:44.305 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:43712fbc' changed from ONLINE to OFFLINE
                                  08:35:44.305 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:a825a6a7
                                  08:35:44.313 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:43712fbc
                                  08:35:44.325 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                  08:35:44.349 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:d18f7f4c' changed from ONLINE to OFFLINE
                                  08:35:44.354 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a825a6a7' changed from ONLINE to OFFLINE
                                  08:35:44.361 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:d18f7f4c' changed from OFFLINE to ONLINE
                                  08:35:44.373 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a825a6a7' changed from OFFLINE to ONLINE
                                  08:35:44.392 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:43712fbc' changed from OFFLINE to ONLINE
                                  08:35:54.341 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                                  So what to do next?
                                  • JicJ
                                    JicJ
                                    Jic
                                    I think that your sensor will be online also when your node are switched off. I am working with SerialGateway not with ethernet, so I am not sure.
                                    Can you send us your .things and your .items? Have you write or automatically discover them?
                                    And output from your node?
                                    Keep the sensor connected to your computer and enable the Serial Monitor in the Arduino IDE. Tools>Serial Monitor.
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      Openhab2 detected things automatically, I don't use my own. Here is the sensor node monitor listing:
                                      B´AÚXStarting sensor (RNNNA-, 2.0.0)
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=9)
                                      TSM:FPAR
                                      TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=9)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      !TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:My Bedroom
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                      TSP:MSG:SEND 9-9-0-0 s=10,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 9-9-0-0 s=11,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                      Request registration...
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=9, parent=0, distance=1, registration=1
                                      !TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:21.8
                                      T: 21.80
                                      TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=ok:24.2
                                      H: 24.20
                                      TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:24.6
                                      H: 24.60
                                      TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.9
                                      T: 21.90
                                      TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:25.4
                                      H: 25.40
                                      TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
                                      T: 22.00
                                      !TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:25.3
                                      H: 25.30
                                      It is operating normally and it send both temperature and humidity values.
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=9)
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        Node registration=1
                                        T: 21.80
                                        H: 24.20
                                        H: 24.60
                                        T: 21.90
                                        H: 25.40
                                        T: 22.00
                                        H: 25.30
                                        jogantJ
                                        jogantJ
                                        jogant
                                        @pentti12
                                        everytime you see a SEND message in the node debug log, you should also see a READ message in your gateway. And than you should also see a SEND message to the controller and a message coming in in your openhab binding.
                                        So would you mind start logging all three stages of the message at the same time as I showed several posts before? If you don't see incoming messages in the binding log there is something wrong with your ethernet connection. Otherwise it's only guessing whats wrong.
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          Before I set up full logging environment, I wonder why I cannot get connection when I enter following command on the terminal window of OH2 server (Pine64):
                                          telnet localhost 5003
                                          unable to connect to remote host
