  3. OpenHAB
  4. MySensors Ethernet Gateway goes to OFFLINE state
86 Posts 6 Posters 39.6k Views 6 Watching
  • pentti12P pentti12
    No success!
    I ended up to the same situation, no real values of temperature nor humidity.
    OH2 cannot search things automatically. I added them manually after I configured the MySensors Gateway.
    TimO
    Hi @pentti12 !
    Stop searching, there is a bug in the binding. I'm working on it. ;-)
    jogantJ 1 Reply Last reply
    • pentti12P
      pentti12P
      pentti12
      OK, TimO!
      I will wait for the new version until I continue!
      Pentti
      • T TimO
        Hi @pentti12 !
        jogantJ
        jogantJ
        jogant
        @TimO
        funny that it works for me :smiley:
        • jogantJ jogant
          @TimO
          TimO
          @jogant Sadly it works fine in my devolpment and test environment, too. ;-)
          If you are using a OH2 snapshot that is older than 11 days there is a chance that it still works but it's not predictable.
          • T TimO
            jogantJ
            jogantJ
            jogant
            @TimO
            ok, I'm using OH2 b4, that is definitely older than 11 days.
              OK, TimO!
              Pentti
              TimO
              @pentti12 I've pushed a new version of the binding to github, please try it out and let me know if it helps.
              • pentti12P
                pentti12P
                pentti12
                Now I got only MySensors Ethernet Gateway into ONLINE state. The Humidity and Temperature Sensors (Things) stay UNINITIALIZED state.
                  TimO
                  @pentti12 Have you deleted the things and newly discovered them? When the binding changes the mapdb (where discovered devices are stored) isn't updated as well. That's why I'm using the *.things files instead. If you try to remove the items errors could occure, this is another hint that this is the problem. After restart of OH2 the things should disappear.
                  Another way to do this is:
                  1. stop OH2
                  2. rm /var/lib/openhab2/mapdb/*
                  3. start OH2
                  But this will delete all discovered things (not only MySensors)!
                  • pentti12P
                    pentti12P
                    pentti12
                    I removed mapdb and things disappeared. I started OH2 again, but I got only MySensors Ethernet Gateway into ONLINE state after adding them manually The Humidity and Temperature Sensors (Things) stay UNINITIALIZED state.
                      TimO
                      @pentti12 What does the log say?
                      JicJ 1 Reply Last reply
                      • T TimO
                        JicJ
                        JicJ
                        Jic
                        @TimO I have exactly the same problem.
                        My event.log is:
                        2016-11-22 20:45:24.043 [temChannelLinkRemovedEvent] - Link 'mysensors_door_gateway_door01_armed => mysensors:door:gateway:door01:armed' has been removed.
                        2016-11-22 20:54:35.089 [ItemChannelLinkAddedEvent ] - Link 'door01_tripped-mysensors:door:gateway:door01:tripped' has been added.
                        2016-11-22 20:54:35.097 [ItemChannelLinkAddedEvent ] - Link 'door01_lastupdate-mysensors:door:gateway:door01:lastupdate' has been added.
                        2016-11-22 20:54:35.671 [ThingAddedEvent           ] - Thing 'mysensors:bridge-ser:gateway' has been added.
                        2016-11-22 20:54:35.682 [ThingAddedEvent           ] - Thing 'mysensors:door:gateway:door01' has been added.
                        2016-11-22 20:54:36.702 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                        2016-11-22 20:54:36.713 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
                        2016-11-22 20:54:40.191 [hingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to ONLINE
                        2016-11-22 20:54:40.262 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
                        2016-11-22 20:54:40.462 [hingStatusInfoChangedEvent] - 'mysensors:door:gateway:door01' changed from INITIALIZING to OFFLINE
                        And my openhab.log is:
                        2016-11-22 20:58:10.295 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-11-22 20:58:11.254 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;1
                        2016-11-22 20:58:16.264 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;0;23
                        2016-11-22 20:58:20.297 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-11-22 20:58:21.279 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;0
                        2016-11-22 20:58:26.295 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;0;23
                        2016-11-22 20:58:30.300 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                        2016-11-22 20:58:31.319 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;4;1;0;16;1
                        I have downloaded your last binding, and the last version of MySensors. Thanks
                        • pentti12P
                          pentti12P
                          pentti12
                          Event log:
                          2016-11-22 18:57:07.915 [hingStatusInfoChangedEvent] - 'mysensors:humidity:dd0f7b9e' changed from UNINITIALIZED to INITIALIZING
                          2016-11-22 18:57:07.928 [hingStatusInfoChangedEvent] - 'mysensors:humidity:dd0f7b9e' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                          And Openhba log:
                          2016-11-22 18:57:07.924 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:humidity:dd0f7b9e': java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                          java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                          at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_101]
                          at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_101]
                          at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                          at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                          at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[96:org.eclipse.smarthome.core:0.9.0.201611102032]
                          at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:761)[103:org.eclipse.smarthome.core.thing:0.9.0.201611102032]
                          at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
                          at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
                          at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_101]
                          at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_101]
                          at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
                          at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
                          at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
                          Caused by: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
                          at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.getBridgeHandler(MySensorsThingHandler.java:284)
                          at org.openhab.binding.mysensors.internal.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:74)
                          at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                          at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                          at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                          ... 3 more
                          • pentti12P
                            pentti12P
                            pentti12
                            Update:
                            I started from the scratch. I installed debian MATE and OH2-offline snapshot. I put the org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar into addons folder. I started openhab2 and after a while I got MySensors Ethernet Gateway and Temperature and Humidity Sensors ONLINE state.
                            But still I cannot see any temperature nor humidity values from my sensors!
                            Here is the Karaf Log after I pressed MySensorsGateway Reset button:
                            08:35:40.194 [ERROR] [otocol.MySensorsNetworkSanityChecker] - Retry period expired, gateway is down. Disconneting bridge...
                            08:35:40.196 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Request disconnection flag setted to: true
                            08:35:44.213 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Connection request disconnection...
                            08:35:44.215 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Request disconnection flag setted to: false
                            08:35:44.217 [INFO ] [otocol.MySensorsNetworkSanityChecker] - Network Sanity Checker thread stopped
                            08:35:44.223 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                            08:35:44.227 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                            08:35:44.241 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                            08:35:44.244 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                            08:35:44.246 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                            08:35:44.261 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to OFFLINE for device: mysensors:humidity:a825a6a7
                            08:35:44.263 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.201:5003]
                            08:35:44.267 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to OFFLINE for device: mysensors:temperature:43712fbc
                            08:35:44.295 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                            08:35:44.305 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:43712fbc' changed from ONLINE to OFFLINE
                            08:35:44.305 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:humidity:a825a6a7
                            08:35:44.313 [DEBUG] [ternal.handler.MySensorsThingHandler] - MySensors Bridge Status updated to ONLINE for device: mysensors:temperature:43712fbc
                            08:35:44.325 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                            08:35:44.349 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:d18f7f4c' changed from ONLINE to OFFLINE
                            08:35:44.354 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a825a6a7' changed from ONLINE to OFFLINE
                            08:35:44.361 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:d18f7f4c' changed from OFFLINE to ONLINE
                            08:35:44.373 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:a825a6a7' changed from OFFLINE to ONLINE
                            08:35:44.392 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:43712fbc' changed from OFFLINE to ONLINE
                            08:35:54.341 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
                            So what to do next?
                            • JicJ
                              JicJ
                              Jic
                              I think that your sensor will be online also when your node are switched off. I am working with SerialGateway not with ethernet, so I am not sure.
                              Can you send us your .things and your .items? Have you write or automatically discover them?
                              And output from your node?
                              Keep the sensor connected to your computer and enable the Serial Monitor in the Arduino IDE. Tools>Serial Monitor.
                              • pentti12P
                                pentti12P
                                pentti12
                                Openhab2 detected things automatically, I don't use my own. Here is the sensor node monitor listing:
                                B´AÚXStarting sensor (RNNNA-, 2.0.0)
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=9)
                                TSM:FPAR
                                TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSM:FPAR
                                TSM:FPAR
                                TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                TSP:MSG:PAR OK (ID=0, dist=1)
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:CHKID:OK (ID=9)
                                TSM:UPL
                                TSP:PING:SEND (dest=0)
                                TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                TSP:MSG:PONG RECV (hops=1)
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                !TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:My Bedroom
                                TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                TSP:MSG:SEND 9-9-0-0 s=10,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                TSP:MSG:SEND 9-9-0-0 s=11,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                Request registration...
                                TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                Node registration=1
                                Init complete, id=9, parent=0, distance=1, registration=1
                                !TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:21.8
                                T: 21.80
                                TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=ok:24.2
                                H: 24.20
                                TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:24.6
                                H: 24.60
                                TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.9
                                T: 21.90
                                TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:25.4
                                H: 25.40
                                TSP:MSG:SEND 9-9-0-0 s=11,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
                                T: 22.00
                                !TSP:MSG:SEND 9-9-0-0 s=10,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:25.3
                                H: 25.30
                                It is operating normally and it send both temperature and humidity values.
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:CHKID:OK (ID=9)
                                  TSM:UPL
                                  TSP:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  Node registration=1
                                  T: 21.80
                                  H: 24.20
                                  H: 24.60
                                  T: 21.90
                                  H: 25.40
                                  T: 22.00
                                  H: 25.30
                                  jogantJ
                                  jogantJ
                                  jogant
                                  @pentti12
                                  everytime you see a SEND message in the node debug log, you should also see a READ message in your gateway. And than you should also see a SEND message to the controller and a message coming in in your openhab binding.
                                  So would you mind start logging all three stages of the message at the same time as I showed several posts before? If you don't see incoming messages in the binding log there is something wrong with your ethernet connection. Otherwise it's only guessing whats wrong.
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    Before I set up full logging environment, I wonder why I cannot get connection when I enter following command on the terminal window of OH2 server (Pine64):
                                    telnet localhost 5003
                                    unable to connect to remote host
                                    • JicJ
                                      JicJ
                                      Jic
                                      I didn't see in your node log an ip assignament. Are your sketch configured to Ethernet Gateway?
                                      I think you should use some parameters:
                                      #define MY_IP_ADDRESS 192,168,178,87
                                      #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
                                      #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
                                      I am not sure how to use Ethernet Gateway, perhaps this example help you
                                      https://github.com/mysensors/MySensors/blob/development/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
                                      • pentti12P
                                        pentti12P
                                        pentti12
                                        I am not using the MQTT gateway, I am using standard GatewayW5100.ino, which has correct IP-settings:
                                        #define MY_IP_ADDRESS 192,168,1,201 // If this is disabled, DHCP is used to retrieve address
                                        #define MY_PORT 5003
                                        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 185
                                        // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                                        And MySensors Ethernet Gateway is detected by Advanced IP Scanner and I can ping it and so on..
                                          jogantJ
                                          jogantJ
                                          jogant
                                          @pentti12
                                          the gateway is the server. You should succeed with telnet <ip_of_mysensors_gw> 5003
