  3. MH-Z14A CO2 sensor
MH-Z14A CO2 sensor
25 Posts 5 Posters 20.3k Views 6 Watching
  • FotoFieberF FotoFieber
    @korttoma said:
    @FotoFieber My new sensor is giving me the exact same behaivour. Could it be that the problem is that I'm using a 5V Pro Mini?
    Yes. You have to use a 3.3V arduino and power the sensor with 5V (seperate voltage). The sensor may break with a 5V arduino. I use a 3.3V 8 MHz pro mini.
    korttomaK
    korttomaK
    korttoma
    @FotoFieber
    So the symptom I see as the sensor constantly reporting the value 562 could be because it is already broken?
    Or would a broken sensor just stop communicating via serial?
    • Tomas
    • korttomaK korttoma
      @FotoFieber
      FotoFieberF
      FotoFieberF
      FotoFieber
      @korttoma
      As I do not have a broken sensor, I can not tell you.
      If I were you, I would try to fix the voltage issues and check, if it is working then.
      The sensor requires a preheat. Have you used my sketch from above?
      korttomaK 1 Reply Last reply
        @korttoma
        korttomaK
        korttomaK
        korttoma
        @FotoFieber I swapped out the 5V Pro Mini with a 3.3V Pro Mini yesterday and I'm afraid it did not help at all. If the Sensor would have had a problem with the 5V on the serial pins I bet it would no longer communicate.
        I used some parts of your sketch but since I use an Si7021 and a different radio I had to do some modifications:
         *  MH-Z14 CO2 sensor
         *  Wiring:
         *   Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
         *   Pad 2, Pad 3, Pad 12: GND
         *   Pad 6: PWM output ==> pin 6
         *  From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
         *    MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accurancy of ±200ppm.
         *    The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
         *    CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
         *  From: http://airqualityegg.wikispaces.com/Sensor+Tests
         *    - response time is less than 30 s
         *   - 3 minute warm up time
         *  datasheet:
        * Contributor: epierre
        #define MY_NODE_ID  6
        #define SN "AIQ CO2 MH-Z14 TxRx"
        #define SV "2.1"
        #define MY_BAUD_RATE  9600
        #include <MyConfig.h>
        #include <SI7021.h>
        #include <RunningAverage.h>
        #include <SoftwareSerial.h>
        // Define a static node address, remove if you want auto address assignment
        SoftwareSerial mySerial(6, 7); // RX, TX
        byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
        char response[9];
        // Child sensor ID's
        #define CHILD_ID_AIQ 1
        #define CHILD_ID_HUM   2
        #define CHILD_ID_TEMP  3
        //#define AIQ_SENSOR_ANALOG_PIN 5
        #define AVERAGES 2
        float valAIQ =0.0;
        float lastAIQ =0.0;
        unsigned int loop_round = 0;
        int lastppm = 0;
        boolean preheat = true;  // wait TEMP_HUM_ROUNDS for preheat
        SI7021 humiditySensor;
        MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
        MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
        // Global settings
        boolean isMetric = true;
        float lastTemperature = -100;
        int lastHumidity = -100;
          mySerial.begin(9600);
          humiditySensor.begin();
          sleep(SLEEP_TIME);
          //pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
          isMetric = getConfig().isMetric;
          Serial.print(F("isMetric: ")); Serial.println(isMetric);
          raHum.clear();
             wait(200);
          send(msg2.set("ppm"));
          sendSketchInfo(SN, SV);
          present(CHILD_ID_AIQ, S_AIR_QUALITY);
          present(CHILD_ID_TEMP,S_TEMP);
          present(CHILD_ID_HUM,S_HUM);
          wait(200);
            mySerial.write(cmd, 9);
          mySerial.readBytes(response, 9);
          int responseHigh = (int) response[2];
          int responseLow = (int) response[3];
          int co2ppm = (256 * responseHigh) + responseLow;
          Serial.print(F("c02ppm :"));Serial.println(co2ppm);
          if ( (abs(co2ppm - lastppm) >= 10)) {
              send(msg.set(co2ppm));
              lastppm = co2ppm;
          raHum.addValue(data.humidityPercent);
          float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
          Serial.print(F("TempDiff :"));Serial.println(diffTemp);
          Serial.print(F("HumDiff  :"));Serial.println(diffHum);
          if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
            float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
            Serial.print("T: ");Serial.println(temperature);
            send(msgTemp.set(temperature,1));
          if (diffHum > HUMI_TRANSMIT_THRESHOLD) {
            Serial.print("H: ");Serial.println(humidity);
            send(msgHum.set(humidity));
            lastHumidity = humidity;
          //Serial.println();
          // Power down the radio.  Note that the radio will get powered back up
          // on the next write() call.
          sleep(SLEEP_TIME); //sleep for: sleepTime
        I hope I made a mistake in the sketch since I'm running out of ideas and I don't want the sensors to be broken.
        From where did you buy your sensor? I got them from aliexpress...
        • Tomas
        • FotoFieberF
          FotoFieberF
          FotoFieber
          @korttoma
          Where is the preheat logic in your sketch?
          Values in the preheat time could be wrong....
            @korttoma
            korttomaK
            korttomaK
            korttoma
            @FotoFieber Yeah, I don't have preheat logic but that would only account for values when I first plug it in. I get the strange values even if it has been running for weeks. I will try to get a graph of what I see this evening so you can see what I mean. I'm seriously considering to just exclude the value 562 from being sent to the controller.
            • Tomas
            alexsh1A 1 Reply Last reply
              alexsh1A
              alexsh1A
              alexsh1
              @korttoma Sounds like you have a faulty sensor. Did you try analogue output? This is just to make sure the sensor is working.
              There are PWM or UART.
              Did you try both of them? I am using 5V Arduino Nano with no problem.
              The digital pins communicate via PWM or UART. Output (and input for UART) of these ports work on 3.3 Volts - this means you should change the ARef of your Arduino - or rescale your values
              • korttomaK
                korttomaK
                korttoma
                • Tomas
                • alexsh1A
                  alexsh1A
                  alexsh1
                  @korttoma try to put it outside for some time to recalibrate. If it does not help, you may need to calibrate it.
                  Or you just got a bad one.
                  • alexsh1A alexsh1
                    korttomaK
                    korttomaK
                    korttoma
                    @alexsh1 Will the sensor really recalibrate by itself if I put it outside?
                    I could send a "zero calibration" command via serial but then I would need to "input Nitrogen gas for 5 minutes when make zero calibration. "
                    Instead of exposing it to nitrogen gas could I just like you said put it outside and then send the "zero calibration" command?
                    To do the " span calibration" I would need to know what kind of values to send to it and I have no idea.
                    btw, here are some values I read now via serial at the office (I do not get the 562 value so far) but does these values seem reasonable for a well ventilated office?
                    HiResp :3
                    LoResp :-21
                    Tem.channel :63
                    c02ppm :747
                    HiResp :3
                    LoResp :124
                    Tem.channel :63
                    c02ppm :892
                    HiResp :3
                    LoResp :21
                    Tem.channel :63
                    c02ppm :789
                    HiResp :2
                    LoResp :-57
                    Tem.channel :63
                    c02ppm :455
                    HiResp :2
                    LoResp :-110
                    Tem.channel :63
                    c02ppm :402
                    HiResp :2
                    LoResp :99
                    Tem.channel :63
                    c02ppm :611
                    HiResp :2
                    LoResp :51
                    Tem.channel :63
                    c02ppm :563
                    HiResp :2
                    LoResp :20
                    Tem.channel :63
                    c02ppm :532
                    HiResp :1
                    LoResp :-2
                    Tem.channel :63
                    c02ppm :254
                    HiResp :1
                    LoResp :-32
                    Tem.channel :63
                    c02ppm :224
                    HiResp :1
                    LoResp :-55
                    Tem.channel :63
                    c02ppm :201
                    HiResp :1
                    LoResp :-68
                    Tem.channel :63
                    c02ppm :188
                    HiResp :1
                    LoResp :-75
                    Tem.channel :63
                    c02ppm :181
                    HiResp :1
                    LoResp :-79
                    Tem.channel :63
                    c02ppm :177
                    HiResp :1
                    LoResp :-98
                    Tem.channel :63
                    c02ppm :158
                    HiResp :1
                    LoResp :-102
                    Tem.channel :63
                    c02ppm :154
                    HiResp :1
                    LoResp :-109
                    Tem.channel :63
                    c02ppm :147
                    HiResp :1
                    LoResp :-116
                    Tem.channel :63
                    c02ppm :140
                    HiResp :1
                    LoResp :-125
                    Tem.channel :63
                    c02ppm :131
                    HiResp :1
                    LoResp :-124
                    Tem.channel :63
                    c02ppm :132
                    HiResp :1
                    LoResp :111
                    Tem.channel :63
                    c02ppm :367
                    HiResp :1
                    LoResp :115
                    Tem.channel :63
                    c02ppm :371
                    HiResp :1
                    LoResp :121
                    Tem.channel :63
                    c02ppm :377
                    HiResp :1
                    LoResp :114
                    Tem.channel :63
                    c02ppm :370
                    HiResp :1
                    LoResp :-62
                    Tem.channel :63
                    c02ppm :194
                    HiResp :1
                    LoResp :-7
                    Tem.channel :63
                    c02ppm :249
                    HiResp :1
                    LoResp :-53
                    Tem.channel :63
                    c02ppm :203
                    HiResp :1
                    LoResp :-68
                    Tem.channel :63
                    c02ppm :188
                    HiResp :1
                    LoResp :-96
                    Tem.channel :63
                    c02ppm :160
                    HiResp :1
                    LoResp :-111
                    Tem.channel :63
                    c02ppm :145
                    HiResp :1
                    LoResp :-121
                    Tem.channel :63
                    c02ppm :135
                    HiResp :1
                    LoResp :-127
                    Tem.channel :63
                    c02ppm :129
                    HiResp :1
                    LoResp :-124
                    Tem.channel :63
                    c02ppm :132
                    HiResp :1
                    LoResp :-126
                    Tem.channel :63
                    c02ppm :130
                    HiResp :1
                    LoResp :-126
                    Tem.channel :63
                    c02ppm :130
                    HiResp :1
                    LoResp :-110
                    Tem.channel :63
                    c02ppm :146
                    HiResp :1
                    LoResp :-110
                    Tem.channel :63
                    c02ppm :146
                    HiResp :1
                    LoResp :-60
                    Tem.channel :63
                    c02ppm :196
                    HiResp :1
                    LoResp :-69
                    Tem.channel :63
                    c02ppm :187
                    HiResp :1
                    LoResp :-101
                    Tem.channel :63
                    c02ppm :155
                    HiResp :1
                    LoResp :-104
                    Tem.channel :63
                    c02ppm :152
                    HiResp :1
                    LoResp :-114
                    Tem.channel :63
                    c02ppm :142
                    HiResp :1
                    LoResp :-128
                    Tem.channel :63
                    c02ppm :128
                    HiResp :1
                    LoResp :-122
                    Tem.channel :63
                    c02ppm :134
                    HiResp :1
                    LoResp :122
                    Tem.channel :63
                    c02ppm :378
                    HiResp :1
                    LoResp :119
                    Tem.channel :63
                    c02ppm :375
                    HiResp :1
                    LoResp :-128
                    Tem.channel :63
                    c02ppm :128
                    HiResp :1
                    LoResp :-86
                    Tem.channel :63
                    c02ppm :170
                    HiResp :1
                    LoResp :-110
                    Tem.channel :63
                    c02ppm :146
                    HiResp :1
                    LoResp :-123
                    Tem.channel :63
                    c02ppm :133
                    HiResp :1
                    LoResp :-101
                    Tem.channel :63
                    c02ppm :155
                    HiResp :1
                    LoResp :-75
                    Tem.channel :63
                    c02ppm :181
                    HiResp :1
                    LoResp :-92
                    Tem.channel :63
                    c02ppm :164
                    HiResp :1
                    LoResp :-101
                    Tem.channel :63
                    c02ppm :155
                    HiResp :1
                    LoResp :-123
                    Tem.channel :63
                    c02ppm :133
                    HiResp :1
                    LoResp :-114
                    Tem.channel :63
                    c02ppm :142
                    HiResp :1
                    LoResp :-127
                    Tem.channel :63
                    c02ppm :129
                    HiResp :1
                    LoResp :-120
                    Tem.channel :63
                    c02ppm :136
                    HiResp :1
                    LoResp :126
                    Tem.channel :63
                    c02ppm :382
                    HiResp :1
                    LoResp :118
                    Tem.channel :63
                    c02ppm :374
                    HiResp :1
                    LoResp :-127
                    Tem.channel :63
                    c02ppm :129
                    HiResp :1
                    LoResp :118
                    Tem.channel :63
                    c02ppm :374
                    HiResp :1
                    LoResp :120
                    Tem.channel :63
                    c02ppm :376
                    HiResp :1
                    LoResp :118
                    Tem.channel :63
                    c02ppm :374
                    HiResp :1
                    LoResp :115
                    Tem.channel :63
                    c02ppm :371
                    HiResp :1
                    LoResp :124
                    Tem.channel :63
                    c02ppm :380
                    HiResp :1
                    LoResp :120
                    Tem.channel :63
                    c02ppm :376
                    HiResp :1
                    LoResp :-119
                    Tem.channel :63
                    c02ppm :137
                    HiResp :1
                    LoResp :-126
                    Tem.channel :63
                    c02ppm :130
                    HiResp :1
                    LoResp :-127
                    Tem.channel :63
                    c02ppm :129
                    HiResp :1
                    LoResp :-124
                    Tem.channel :63
                    c02ppm :132
                    HiResp :1
                    LoResp :121
                    Tem.channel :63
                    c02ppm :377
                    HiResp :1
                    LoResp :114
                    Tem.channel :63
                    c02ppm :370
                    HiResp :1
                    LoResp :108
                    Tem.channel :63
                    c02ppm :364
                    HiResp :1
                    LoResp :108
                    Tem.channel :63
                    c02ppm :364
                    HiResp :1
                    LoResp :119
                    Tem.channel :63
                    c02ppm :375
                    HiResp :1
                    LoResp :-110
                    Tem.channel :63
                    c02ppm :146
                    HiResp :1
                    LoResp :124
                    Tem.channel :63
                    c02ppm :380
                    HiResp :1
                    LoResp :127
                    Tem.channel :63
                    c02ppm :383
                    HiResp :1
                    LoResp :-43
                    Tem.channel :63
                    c02ppm :213
                    HiResp :1
                    LoResp :-72
                    Tem.channel :63
                    c02ppm :184
                    HiResp :1
                    LoResp :-77
                    Tem.channel :63
                    c02ppm :179
                    HiResp :1
                    LoResp :-63
                    Tem.channel :63
                    c02ppm :193
                    HiResp :1
                    LoResp :-92
                    Tem.channel :63
                    c02ppm :164
                    HiResp :1
                    LoResp :-105
                    Tem.channel :63
                    c02ppm :151
                    HiResp :1
                    LoResp :-116
                    Tem.channel :63
                    c02ppm :140
                    HiResp :2
                    LoResp :41
                    Tem.channel :63
                    c02ppm :553
                    HiResp :2
                    LoResp :47
                    Tem.channel :63
                    c02ppm :559
                    HiResp :2
                    LoResp :26
                    Tem.channel :63
                    c02ppm :538
                    HiResp :2
                    LoResp :-107
                    Tem.channel :63
                    c02ppm :405
                    HiResp :2
                    LoResp :-76
                    Tem.channel :63
                    c02ppm :436
                    HiResp :2
                    LoResp :-97
                    Tem.channel :63
                    c02ppm :415
                    HiResp :2
                    LoResp :-109
                    Tem.channel :63
                    c02ppm :403
                    HiResp :2
                    LoResp :106
                    Tem.channel :63
                    c02ppm :618
                    HiResp :2
                    LoResp :-96
                    Tem.channel :63
                    c02ppm :416
                    HiResp :2
                    LoResp :80
                    Tem.channel :63
                    c02ppm :592
                    HiResp :2
                    LoResp :69
                    Tem.channel :63
                    c02ppm :581
                    HiResp :2
                    LoResp :40
                    Tem.channel :63
                    c02ppm :552
                    HiResp :2
                    LoResp :84
                    Tem.channel :63
                    c02ppm :596
                    HiResp :2
                    LoResp :45
                    Tem.channel :63
                    c02ppm :557
                    HiResp :2
                    LoResp :3
                    Tem.channel :63
                    c02ppm :515
                    HiResp :1
                    LoResp :-30
                    Tem.channel :63
                    c02ppm :226
                    HiResp :1
                    LoResp :-62
                    Tem.channel :63
                    c02ppm :194
                    HiResp :1
                    LoResp :-73
                    Tem.channel :63
                    c02ppm :183
                    HiResp :1
                    LoResp :-75
                    Tem.channel :63
                    c02ppm :181
                    HiResp :1
                    LoResp :-96
                    Tem.channel :63
                    c02ppm :160
                    HiResp :1
                    LoResp :-89
                    Tem.channel :63
                    c02ppm :167
                    HiResp :1
                    LoResp :-101
                    Tem.channel :63
                    c02ppm :155
                    HiResp :1
                    LoResp :-112
                    Tem.channel :63
                    c02ppm :144
                    HiResp :1
                    LoResp :-107
                    Tem.channel :63
                    c02ppm :149
                    HiResp :1
                    LoResp :-112
                    Tem.channel :63
                    c02ppm :144
                    HiResp :1
                    LoResp :-110
                    Tem.channel :63
                    c02ppm :146
                    HiResp :1
                    LoResp :-124
                    Tem.channel :63
                    c02ppm :132
                    HiResp :1
                    LoResp :-120
                    Tem.channel :63
                    c02ppm :136
                    HiResp :1
                    LoResp :-75
                    Tem.channel :63
                    c02ppm :181
                    Some of the values seem a bit low to me. Especially while the HiResp is 1 or the LoResp is negative.
                    I will do this test again at home when I get the chance.
                    • Tomas
                    • FotoFieberF
                      FotoFieberF
                      FotoFieber
                      @korttoma
                      In the technical specification I only find the calibration with nitrogen. I don't think, that putting it outside, will help, as it is usually at around 400 ppm at the moment. (AFAIK netatmo sets the lowest measured value in the last one or two weeks to 400 for calibration).
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        #21
                        @korttoma values are completely off. Co2 cannot go down below 300 level. This is a value of co2 outside (300-400).
                        You have to calibrate it regularly. Zero calibration (this is what you are talking about) is different.
                        8.1 The sensor should be calibrated regularly. The cycle time is better to be no more than 6 months. 8.2 Do not use the sensor in the high dusty environment for long time.
                        8.3 Please use the sensor with correct power supply.
                        8.4 Forbidden to cut the sensor pin.
                        Try to put it outside for 10mins and then short pins 8 and 12 (see the photo below). This worked for me when I had some weird readings
                          @korttoma
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @FotoFieber Netatmo is using index also cannot be compared with mh-z14a.
                          I think the idea putting the sensor outside is to stabilise it - the reading is in the range of 300-400
                          • alexsh1A alexsh1
                            korttomaK
                            korttomaK
                            korttoma
                            Where did you get this kind of information from? The MH-Z14.pdg I found online does not mention anything about this.
                            • Tomas
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @korttoma It was recommended by an Aliexpress seller who sold me the sensor.
                              Let's agree that Chinese documentation is not always comprehensive :)
                              • korttomaK
                                korttomaK
                                korttoma
                                I finally found some time to really look in to this 562 issue. I looked at the raw data in DataMine2 and I noticed that the 562 value appeared every 10 minutes on the minute.
                                Then I knew that this value cannot possibly come from the sensor. I search around in my Vera device for a bit and I found some lua code that copied the "Variable1" value from the sensor to the "CurrentLevel" every 10 minutes. Then I remembered that in the previous version of this sensor the value was reported via V_VAR1 and I had to copy it to another variable in Vera to be able to draw any graph. The current version of the sensor reports the value directly to the "CurrentLevel" variable and the value 562 that was still in the old variable was copied over the "real" value every 10 minutes.
                                I also previously had some really low values from time to time from the sensor mostly when responseHigh = 1 and responseLow = negative value
                                so I forced the responseLow to always be a positive value like this:
                                int responseLow = abs((int) response[3]);
                                I will keep an eye on the behavior of the sensor now that I have finally removed the confusing 562 value.
                                • Tomas
